| 01-Chassis Views and Technical Specifications | 1.23 MB |
1 Chassis views
The figures in this section are for illustration only.
MSR1008
Figure1-1 Front view
(1) AC power receptacle |
(2) Console port |
(3) USB port |
(4) Reset button (RESET) |
(5) GE copper ports GE0 and GE1 (combo ports) |
(6) GE fiber ports SFP0 and SFP1 (combo ports) |
(7) 10GE fiber ports SFP+10 and SFP+11 |
(8) GE copper ports GE2 to GE9 |
Figure1-2 Rear view
(1) Grounding screw |
MSR1004S-5G/MSR1004S-5G-GL
Figure1-3 Front view
(1) Power adapter receptacle |
(2) Reset button (RESET) |
(3) Console port |
(4) USB port |
(5) GE copper ports GE1 to GE4 |
(6) GE copper port GE0 |
(7) GE fiber ports SFP5 and SFP6 |
Figure1-4 Left view
(2) Micro SIM card slots SIM0 and SIM1 |
(3) 5G antenna port (ANT3/GNSS) |
(4) 5G antenna ports (ANT0 to ANT2) |
MSR1004S-5G-CN
Figure1-5 Front view
(3) Console port |
(4) USB port |
Figure1-6 Left view
(3) 5G antenna ports (M0 to M3) |
MSR1104S-W
Figure1-7 Front view
(1) GE copper ports GE2 to GE5 |
(2) GE copper port GE0 |
(3) GE fiber port GE1 |
(4) Console port |
(5) Reset button (RESET) |
(6) USB port |
(7) Power adapter receptacle |
Figure1-8 Rear view
(2) 2.4 GHz and 5 GHz WLAN antennas |
MSR1104S-W-CAT6
Figure1-9 Front view
(4) Micro SIM card slots SIM0 and SIM1 |
(5) Console port |
(6) Reset button (RESET) |
(7) USB port |
(8) Power adapter receptacle |
Figure1-10 Rear view
(2) 4G LTE antenna ports 1 and 2 |
(3) GNSS antenna port (reserved) |
(4) 2.4 GHz and 5 GHz WLAN antennas |
MSR1104S-5G-CN
Figure1-11 Front view
(5) Console port |
(7) USB port |
Figure1-12 Rear view
(2) 5G antenna ports (M0 to M3) |
MSR1104S-W-5G-CN
Figure1-13 Front view
(5) Console port |
(7) USB port |
Figure1-14 Rear view
(3) 2.4 GHz and 5 GHz WLAN antennas |
2 Technical specifications
Router specifications
Table2-1 Technical specifications for the MSR1008, MSR1004S-5G, and MSR1004S-5G-GL routers
Item |
MSR1008 |
MSR1004S-5G/MSR1004S-5G-GL |
Console port |
1 |
1 |
USB port |
1 |
1 |
GE copper port |
10, including two combo ports |
5 |
GE fiber port |
2, combo ports |
2 |
10 GE fiber port |
2 |
N/A |
Built-in 5G module |
N/A |
5G NSA/SA, LTE, UMTS WCDMA |
5G ANT port |
N/A |
4 |
GNSS antenna port |
N/A |
1 |
Memory |
2 GB DDR4 |
1 GB DDR3 |
Flash |
4 GB |
512 MB |
Dimensions (H × W × D) (excluding rubber feet and mounting brackets) |
43.6 × 266 × 161 mm (1.72 × 10.47 × 6.34 in) |
52.4 × 150 × 127 mm (2.06 × 5.91 × 5.00 in) |
Rated input voltage |
100 to 240 VAC @ 50 to 60 Hz |
Max input current |
1 A |
3 A |
Max power consumption |
36 W |
48 W |
Operating temperature |
0°C to 45°C (32°F to 113°F) |
-40°C to +70°C (–40°F to +158°F) |
Operating humidity |
5% RH to 95% RH, noncondensing |
Table2-2 Technical specifications for the MSR1004S-5G-CN router
Item |
MSR1004S-5G-CN |
Console port |
1 |
USB port |
1 |
GE copper port |
5 |
GE fiber port |
2 |
5G ANT port |
4 |
Memory |
1 GB DDR3 |
Flash |
512 MB |
Max input current |
3 A |
48 W |
–40°C to +70°C (–40°F to +158°F) |
Table2-3 Technical specifications for the MSR1104S-W and MSR1104S-W-CAT6 routers
Item |
MSR1104S-W |
MSR1104S-W-CAT6 |
Console port |
1 |
1 |
USB port |
1 |
1 |
GE copper port |
5 |
5 |
GE fiber port |
1 |
1 |
Built-in 4G module |
N/A |
TDD-LTE, FDD-LTE, WCDMA |
4G LTE antenna port |
N/A |
2 |
GNSS antenna port |
N/A |
1 (reserved) |
WLAN antenna port |
2 (fixed antennas) |
Memory |
1 GB DDR4 |
1 GB DDR4 |
Flash |
256 MB |
256 MB |
Max input current |
2 A |
2 A |
24 W |
24 W |
Table2-4 Technical specifications for the MSR1104S-5G-CN and MSR1104S-W-5G-CN routers
Item |
MSR1104S-5G-CN |
MSR1104S-W-5G-CN |
Console port |
1 |
1 |
USB port |
1 |
1 |
GE copper port |
5 |
5 |
GE fiber port |
1 |
1 |
5G ANT port |
4 |
4 |
WLAN antenna port |
N/A |
Memory |
1 GB DDR4 |
1 GB DDR4 |
Flash |
256 MB |
256 MB |
Max input current |
2 A |
2 A |
24 W |
24 W |
Antenna specifications
Table2-5 5G stick antenna specifications for MSR1004S-5G/MSR1004S-5G-GL
Item |
Specification |
Frequency range |
· 617 to 960 MHz/1710 to 2170 MHz · 2300 to 2700 MHz/3300 to 3800 MHz · 4400 to 5000 MHz/5150 to 5850 MHz |
Voltage standing wave ratio (VSWR) |
≤ 4 |
Input impedance |
50 ohms |
Gain |
· 617 to 960 MHz @ 0.59 dBi · 1710 to 2170 MHz @ 3.74 dBi · 2300 to 2700 MHz @ 3.51 dBi · 3300 to 3800 MHz @ 3.7 dBi · 4400 to 5000 MHz @ 4.0 dBi · 5150 to 5850 MHz @ 4.87 dBi |
Max power |
1 W |
Color |
Black |
Weight |
19.63 g (0.69 oz) |
–20°C to +65°C (–4°F to +149°F) |
Table2-6 5G stick antenna specifications for MSR1004S-5G-CN/MSR1104S-5G-CN/MSR1104S-W-5G-CN
Item |
Specification |
Frequency range |
0.6 to 6 GHz |
≤ 6 |
Input impedance |
50 ohms |
Gain |
· 2.74 dBi Max. @ 0.617 to 0.96 GHz · 1.01 dBi Max. @ 1.4 to 1.612 GHz · 4.48 dBi Max. @ 1.71 to 2.17 GHz · 3.98 dBi Max. @ 2.3 to 2.7 GHz · 4.74 dBi Max. @ 3.3 to 4.0 GHz · 5.50 dBi Max. @ 4.0 to 5.0 GHz · 5.82 dBi Max. @ 5.15 to 5.85 GHz |
Polarization |
Vertical |
Max input power |
1 W |
Connector type |
SMA male connector |
Height |
17.6 cm (6.93 in) |
Weight |
20 g (0.71 oz) |
Color |
Black |
Table2-7 4G stick antenna specifications for MSR1104S-W-CAT6
Item |
Specification |
Frequency range |
· 617 to 960 MHz/1420 to 1520 MHz · 1710 to 2690 MHz/3300 to 3800 MHz · 4400 to 5000 MHz/5150 to 5850 MHz |
≤ 3 |
Input impedance |
50 ohms |
Gain |
· 617 to 960 MHz @ 0.5 dBi · 1420 to 1520 MHz @ 1.4 dBi · 1710 to 2690 MHz @ 3.4 dBi · 3300 to 3800 MHz @ 4.0 dBi · 4400 to 5000 MHz @ 4.0 dBi · 5150 to 5850 MHz @ 3 dBi |
Max power |
1 W |
Color |
Black |
Weight |
21.2 g (0.75 oz) |
–20°C to +60°C (–4°F to +140°F) |
4G/5G antenna extension cable specifications
Table2-8 4G/5G antenna extension cable specifications
Cable length |
Applicable router model |
3 m (9.84 ft)/10 m (32.81 ft)/15 m (49.21 ft)/20 m (65.62 ft) |
· MSR1004S-5G · MSR1004S-5G-GL |
5 m (16.40 ft)/10 m (32.81 ft) |
MSR1104S-W-CAT6 |
1 m (3.28 ft)/5 m (16.40 ft)/10 m (32.81 ft)/15 m (49.21 ft) |
· MSR1004S-5G-CN · MSR1104S-5G-CN · MSR1104S-W-5G-CN |
Link mode of interfaces
Table2-9 Interfaces that can operate only as Layer 3 Ethernet interfaces
Device model |
Interfaces |
MSR1008 |
Combo 0 (GE0, SFP0), Combo 1 (GE1, SFP1), SFP+10, SFP+11 |
GE0, SFP5, SFP6 |
MSR1004S-5G-CN |
GE0, SFP5, SFP6 |
MSR1104S-W |
GE0, GE1 |
MSR1104S-W-CAT6 |
GE0, GE1 |
MSR1104S-5G-CN |
GE0, GE1 |
MSR1104S-W-5G-CN |
GE0, GE1 |
Table2-10 Interfaces that can operate only as Layer 2 Ethernet interfaces
Device model |
Interfaces |
MSR1008 |
GE6 to GE9 |
N/A |
MSR1004S-5G-CN |
N/A |
MSR1104S-W |
N/A |
MSR1104S-W-CAT6 |
N/A |
MSR1104S-5G-CN |
N/A |
MSR1104S-W-5G-CN |
N/A |
Table2-11 Interfaces that operate as Layer 2 interfaces by default and can be changed to Layer 3 interfaces
Device model |
Interfaces |
MSR1008 |
GE2 to GE5 |
GE1 to GE4 |
MSR1004S-5G-CN |
GE1 to GE4 |
MSR1104S-W |
GE2 to GE5 |
MSR1104S-W-CAT6 |
GE2 to GE5 |
MSR1104S-5G-CN |
GE2 to GE5 |
MSR1104S-W-5G-CN |
GE2 to GE5 |
