| 02-LEDs | 789.30 KB |
2 LEDs
LEDs
MSR1008
Figure2-1 LEDs on the front panel
(1) GE copper port LEDs (GE2 to GE9) |
(2) 10GE fiber port LEDs (SFP+10 and SFP+11) |
(3) Fiber combo port LEDs (SFP0 and SFP1) |
(4) Copper combo port LEDs (GE0 and GE1) |
(5) System status LED (SYS) |
(6) CTRL LED |
MSR1004S-5G/MSR1004S-5G-GL
Figure2-2 LEDs on the front panel
(1) WWAN LED |
(2) 5G network signal LED |
(3) 3G/4G LTE LED |
(4) GNSS LED |
(5) GE copper port LEDs (GE0 to GE4) |
(6) GE fiber port LEDs (SFP5 and SFP6) |
(7) Micro SIM card status LED |
(8) System status LED (SYS) |
(9) Power status LED (PWR) |
MSR1004S-5G-CN
Figure2-3 LEDs on the front panel
(1) WWAN LED |
(3) 3G/4G LTE LED |
(4) GE copper port LEDs (GE0 to GE4) |
(5) GE fiber port LEDs (SFP5 and SFP6) |
(6) Micro SIM card status LED |
(7) System status LED (SYS) |
(8) Power status LED (PWR) |
MSR1104S-W
Figure2-4 LEDs on the front panel
(1) GE copper port LEDs (GE0, GE2 to GE5) |
(2) GE fiber port LED (GE1) |
(3) 2.4G Wi-Fi status LED |
(4) 5G Wi-Fi status LED |
(5) CTRL LED |
(6) System status LED (SYS) |
MSR1104S-W-CAT6
Figure2-5 LEDs on the front panel
(3) Micro SIM0 card status LED |
(4) Micro SIM1 card status LED |
(5) 2.4G Wi-Fi status LED |
(6) 5G Wi-Fi status LED |
(7) 3G/4G LTE LED |
(8) CTRL LED |
(9) System status LED (SYS) |
MSR1104S-5G-CN
Figure2-6 LEDs on the front panel
(5) 5G network signal LED |
(6) 3G/4G LTE LED |
(7) CTRL LED |
MSR1104S-W-5G-CN
Figure2-7 LEDs on the front panel
(5) 2.4G and 5G Wi-Fi status LED |
(6) 5G network signal LED |
(7) 3G/4G LTE LED |
(8) CTRL LED |
LED descriptions
Table2-1 LED descriptions
LED |
Status |
Fast flashing green |
The BootWare is running. |
Steady green |
The Kernel (including Eshell) is running. |
Slowly flashing green |
Comware is starting or running correctly. |
Slowly flashing yellow |
The memory test has failed (BootWare stage). |
Fast flashing yellow |
The extended BootWare segment does not exist (BootWare stage). |
Steady yellow |
The boot.bin file does not exist (BootWare stage). |
Off |
No power is present, the power system has failed, or a hardware failure has occurred. |
Steady green |
The power system is operating correctly. |
Off |
No power input. |
GE copper port LED Copper combo port LED |
Steady green |
A link is present on the port, and the port is operating at 1000 Mbps. |
Flashing green |
The port is sending or receiving data at 1000 Mbps. |
Steady yellow |
A link is present on the port, and the port is operating at 10/100 Mbps. |
Flashing yellow |
The port is sending or receiving data at 10/100 Mbps. |
Off |
No link is present on the port. |
GE fiber port LED Fiber combo port LED |
Steady green |
Flashing green |
Steady yellow |
A link is present on the port, and the port is operating at 100 Mbps. |
Flashing yellow |
The port is sending or receiving data at 100 Mbps. |
Off |
10GE fiber port LED |
Steady green |
A link is present on the port, and the port is operating at 10 Gbps. |
Flashing green |
The port is sending or receiving data at 10 Gbps. |
Steady yellow |
Flashing yellow |
Off |
CTRL LED (applicable to MSR1008) |
Steady green |
The device has established a WebSocket connection with the AD-WAN controller. |
Flashing yellow |
The device is trying to establishing a connection with the AD-WAN controller. |
Off |
No connection is established between the device and the AD-WAN controller. |
CTRL LED (applicable to MSR1104S-W/MSR1104S-W-CAT6/MSR1104S-5G-CN/MSR1104S-W-5G-CN) |
Steady green |
Off |
WWAN LED |
Steady green |
A link is present. |
Flashing green (8 Hz) |
Data is being sent or received. |
Flashing green (1 Hz) |
Searching for networks. |
Off |
No link is present. |
5G network signal LED (applicable to MSR1004S-5G/MSR1004S-5G-GL/MSR1004S-5G-CN) |
Steady green |
Strong 5G network signals in SA mode. |
Fair 5G network signals in SA mode. |
Weak 5G network signals in SA mode. |
Steady yellow |
Strong 5G network signals in NSA mode. |
Flashing yellow (8 Hz) |
Fair 5G network signals in NSA mode. |
Flashing yellow (1 Hz) |
Weak 5G network signals in NSA mode. |
Off |
Poor 5G network signals. 5G services are not available. |
5G network signal LED (applicable to MSR1104S-5G-CN/MSR1104S-W-5G-CN) |
Steady green |
Strong 5G network signals in SA or NSA mode. |
Fair 5G network signals in SA or NSA mode. |
Weak 5G network signals in SA or NSA mode. |
Off |
3G/4G LTE LED (applicable to MSR1004S-5G/MSR1004S-5G-GL/MSR1004S-5G-CN) |
Steady green |
Strong 4G network signals. |
Fair 4G network signals. |
Weak 4G network signals. |
Steady yellow |
Strong 3G network signals |
Fair 3G network signals. |
Weak 3G network signals. |
Off |
Poor network signals. 3G and 4G services are not available. |
3G/4G LTE LED (applicable to MSR1104S-W-CAT6/MSR1104S-5G-CN/MSR1104S-W-5G-CN) |
Steady green |
Steady yellow |
Off |
Steady green |
The 2.4G radio is in standby state and does not have associated clients. |
Flashing green |
The 2.4G radio has associated clients and is sending or receiving data. |
Off |
The 2.4G radio is disabled. |
Steady green |
The 5G radio is in standby state and does not have associated clients. |
Flashing green |
The 5G radio has associated clients and is sending or receiving data. |
Off |
The 5G radio is disabled. |
Steady green |
The radios are in standby state and do not have associated clients. |
Flashing green |
A radio has associated clients and is sending or receiving data. |
Off |
The radios are disabled. |
GNSS LED |
Steady green |
Normal GNSS service. |
Off |
GNSS service is not enabled or is abnormal. |
Steady green |
A card is present in SIM card slot 1. |
Steady yellow |
A card is present in SIM card slot 2. |
Off |
No card is present in both the SIM card slots. |
Micro SIM0/SIM1 card status LED (applicable to MSR1104S-W-CAT6) |
Steady green |
The SIM card is present. |
The SIM card is being used for dial-up. |
The 4G port for the SIM card is sending or receiving data at 2 Gbps, 3 Gbps, or 4 Gbps. |
Steady yellow |
The SIM card is faulty. |
Off |
No SIM card is present, or the 4G module is not present or is being initialized. |
Micro SIM0/SIM1 card status LED (applicable to MSR1104S-5G-CN/MSR1104S-W-5G-CN) |
Steady green |
The 5G port for the SIM card is sending or receiving data at 2 Gbps, 3 Gbps, 4 Gbps, or 5 Gbps. |
Steady yellow |
Off |
No SIM card is present, or the module is not present or is being initialized. |
