| 00-Preface | 100.49 KB |
Preface
H3C S5590-HI[EI]&S5500V3-HI Switch Series Installation Guide describes the installation, power-on, maintenance, and troubleshooting of the S5590-HI[EI]&S5500V3-HI switches .
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the switches.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
