- 06-Layer 3—IP Services Command Reference
- 01-ARP commands
- 02-IP addressing commands
- 03-DNS commands
- 04-mDNS relay commands
- 05-IP forwarding basics commands
- 06-Fast forwarding commands
- 07-Adjacency table commands
- 08-IRDP commands
- 09-IP performance optimization commands
- 10-UDP helper commands
- 11-IPv6 basics commands
- 12-IPv6 fast forwarding commands
- 13-AFT commands
- 14-Tunneling commands
- 15-GRE commands
- 16-ADVPN commands
- 17-HTTP redirect commands
| 17-HTTP redirect commands | 53.26 KB |
display http-redirect statistics
http-redirect https-rate-limit
http-redirect ssl-server-policy
reset http-redirect statistics
Use display http-redirect statistics to display packet statistics for HTTP redirect.
In standalone mode:
display http-redirect statistics [ slot slot-number ]
In IRF mode:
display http-redirect statistics [ chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays HTTP redirect packet statistics on all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays HTTP redirect packet statistics on all cards. (In IRF mode.)
# (In standalone mode.) Display HTTP redirect packet statistics for slot 1.
<Sysname> display http-redirect statistics slot 1
Slot 1:
HTTP:
Received SYN packets :1000
Sent SYN ACK packets :1000
Sent RST packets :500
Redirect node not found events :50
Assembled redirect URL failed times/total times :100/700
HTTPS:
Redirect node not found events :300
SSL handshake failed times/total times :0/700
SSL data interaction failed times/total times :0/700
HTTP |
Packet statistics for HTTP redirect. |
Received SYN packets |
Number of SYN packets that have been received. |
Sent SYN ACK packets |
Number of SYN ACK packets that have been sent. |
Sent RST packets |
Number of RST packets that have been sent. |
Redirect node not found events |
Number of times that the system failed to find redirect nodes. |
Redirect URL assembly failures and total number of redirect URL assemblies. |
HTTPS |
Packet statistics for HTTPS redirect. |
SSL handshake failed/total times |
Number of SSL handshake failures, and the total number of SSL handshakes. |
SSL data interaction failed times/total times |
Number of SSL data exchange failures, and the total number of SSL data exchanges. |
http-redirect https-port
Use http-redirect https-port to specify the HTTPS redirect listening port number.
Use undo http-redirect https-port to restore the default.
http-redirect https-port port-number
The HTTPS redirect listening port number is 6654.
port-number: Specifies the TCP port number on which the HTTPS redirect service listens for HTTPS requests. The value range for the port number is 1 to 65535.
To avoid service unavailability caused by port conflict, do not specify a TCP port number used by a well-known protocol or used by any other service. To display TCP port numbers that have been used by services, use the display tcp command.
# Specify 8888 as the HTTPS redirect listening port number.
[Sysname] http-redirect https-port 8888
Use http-redirect https-rate-limit to set the HTTPS redirect rate limit.
Use undo http-redirect https-rate-limit to restore the default.
http-redirect https-rate-limit pps
The default HTTPS redirect rate limit is not set.
pps: Specifies the HTTPS redirect rate limit, in the range of 1 to 65535, in packets per second (pps).
Redirecting a large number of HTTPS requests will overwhelm the CPU and affect other services on the device. To resolve this issue, you can limit the rate of HTTPS redirect packets sent to the CPU. When the rate of the HTTP redirect packets exceeds the limit, the device drops the exceeding HTTPS redirect packets.
Setting this limit affects the performances of services that need to redirect HTTPS requests, for example, the user online rate of the authentication service. Set a proper HTTPS redirect rate limit according to the network condition.
# Set the HTTPS redirect rate limit to 200 bps.
[Sysname] http-redirect https-rate-limit 200
Use http-redirect ssl-server-policy to associate an SSL server policy with the HTTPS redirect service.
Use undo http-redirect ssl-server-policy to restore the default.
http-redirect ssl-server-policy policy-name
No SSL server policy is associated with the HTTPS redirect service. The HTTPS redirect service uses a self-assigned certificate and the default SSL parameters.
policy-name: Specifies an SSL server policy by its name, a case-insensitive string of 1 to 31 characters.
HTTPS redirect is unavailable if the associated SSL server policy does not exist. You can first associate a nonexistent SSL server policy with the HTTPS redirect service and then configure the SSL server policy.
If you change the SSL server policy associated with the HTTPS redirect service, the new policy takes effect immediately.
If you perform this task multiple times, the most recent configuration takes effect.
# Associate SSL server policy policy1 with the HTTPS redirect service.
[Sysname] http-redirect ssl-server-policy policy1
ssl server-policy
Use reset http-redirect statistics to reset packet statistics for HTTP redirect.
In standalone mode:
reset http-redirect statistics [ slot slot-number ]
In IRF mode:
reset http-redirect statistics [ chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command clears HTTP redirect packet statistics on all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command clears HTTP redirect packet statistics on all cards. (In IRF mode.)
# (In standalone mode.) Clear HTTP redirect packet statistics for slot 1.
<Sysname> reset http-redirect statistics slot 1
