11-ACL and QoS Command Reference
HomeSupportRoutersCR16000-M SeriesReference GuidesCommand ReferencesH3C CR16000-M Routers Command Reference-R838x-6W10011-ACL and QoS Command Reference
06-Flowspec commands
06-Flowspec commands 403.08 KB
Flowspec commands· 1
address-family ipv4· 1
address-family ipv4 flowspec (BGP instance view) 1
address-family ipv4 flowspec (BGP-VPN instance view) 2
address-family ipv4 flowspec (VPN instance view) 2
address-family ipv6· 3
address-family ipv6 flowspec (BGP instance view) 4
address-family ipv6 flowspec (BGP-VPN instance view) 4
address-family ipv6 flowspec (VPN instance view) 5
address-family vpnv4 flowspec· 5
address-family vpnv6 flowspec· 6
apply· 7
check flow-route-configuration· 11
commit 14
description (Flowspec interface group view) 15
display bgp group flowspec· 16
display bgp routing-table ipv4 flowspec· 18
display bgp routing-table ipv6 flowspec· 23
display bgp routing-table vpnv4 flowspec· 28
display bgp routing-table vpnv6 flowspec· 35
display flow-route· 42
display flowspec flow-interface-group· 46
display flowspec statistics· 47
flow-route ipv6· 49
flow-route (system view) 50
flow-route (Flowspec IPv4 address family view, Flowspec IPv6 address family view) 50
flow-route flow-interface-group· 51
flowspec· 52
flowspec flow-interface-group· 52
if-match· 53
interface (Flowspec interface group view) 60
peer next-hop-invariable· 60
peer redirect ip rfc-compatible· 61
peer redirect rt rfc-compatible· 62
peer redirect-nexthop· 63
peer reflect-client 64
peer validation-disable· 66
peer validation-redirect-disable· 67
policy vpn-target 68
redirect ip recursive-lookup tunnel 69
reflect between-clients· 69
reflector cluster-id· 70
reset flowspec statistics· 71
route-distinguisher 72
route match-destination· 73
route validation-mode include-as· 74
vpn-target 75
Flowspec commands
address-family ipv4
Use address-family ipv4 to create a Flowspec IPv4 address family, or enter the view of an existing Flowspec IPv4 address family.
Use undo address-family ipv4 to delete a Flowspec IPv4 address family and all its settings.
address-family ipv4 [ vpn-instance vpn-instance-name ]
undo address-family ipv4 [ vpn-instance vpn-instance-name ]
No Flowspec IPv4 address family exists.
Flowspec view
vpn-instance vpn-instance-name: Creates the Flowspec IPv4 address family for an MPLS L3VPN instance. The vpn-instance-name argument represents the VPN instance name, a case-sensitive string of 1 to 31 characters. To create a Flowspec IPv4 address family for the public network, do not specify this option.
# Create a Flowspec IPv4 address family for the public network and enter its view.
[Sysname] flowspec
[Sysname-flowspec] address-family ipv4
[Sysname-flowspec-ipv4]
Use address-family ipv4 flowspec to create a BGP IPv4 Flowspec address family, or enter the view of an existing BGP IPv4 Flowspec address family.
Use undo address-family ipv4 flowspec to delete a BGP IPv4 Flowspec address family and all its settings.
No BGP IPv4 Flowspec address family exists.
BGP instance view
The settings in the view of a BGP IPv4 Flowspec address family take effect only on routes and peers of the BGP IPv4 Flowspec address family.
# Create a BGP IPv4 Flowspec address family and enter its view.
[Sysname] bgp 100
[Sysname-bgp-default] address-family ipv4 flowspec
[Sysname-bgp-default-ipv4-flowspec]
Use address-family ipv4 flowspec to create a BGP-VPN IPv4 Flowspec address family, or enter the view of an existing BGP-VPN IPv4 Flowspec address family.
Use undo address-family ipv4 flowspec to delete a BGP-VPN IPv4 Flowspec address family and all its settings.
No BGP-VPN IPv4 Flowspec address family exists.
The settings in the view of a BGP-VPN IPv4 Flowspec address family take effect only on routes and peers of the BGP-VPN IPv4 Flowspec address family.
# Create a BGP-VPN IPv4 Flowspec address family and enter its view.
[Sysname] bgp 100
[Sysname-bgp-default-vpn1] address-family ipv4 flowspec
[Sysname-bgp-default-flowspec-ipv4-vpn1]
Use address-family ipv4 flowspec to enter the IPv4 Flowspec address family view of a VPN instance.
Use undo address-family ipv4 flowspec to delete all settings in the IPv4 Flowspec address family view of a VPN instance.
VPN instance view
You can configure IPv4 Flowspec parameters in the IPv4 Flowspec address family view of a VPN instance. For example, you can configure route targets for a VPN instance.
# Enter the IPv4 Flowspec address family view of a VPN instance.
[Sysname-vpn-instance-vpn1] address-family ipv4 flowspec
[Sysname-vpn-flowspec-ipv4-vpn1]
address-family ipv6
Use address-family ipv6 to create a Flowspec IPv6 address family, or enter the view of an existing Flowspec IPv6 address family.
Use undo address-family ipv6 to delete a Flowspec IPv6 address family and all its settings.
address-family ipv6 [ vpn-instance vpn-instance-name ]
undo address-family ipv6 [ vpn-instance vpn-instance-name ]
No Flowspec IPv6 address family exists.
Flowspec view
vpn-instance vpn-instance-name: Creates the Flowspec IPv6 address family for an MPLS L3VPN instance. The vpn-instance-name argument represents the VPN instance name, a case-sensitive string of 1 to 31 characters. To create a Flowspec IPv6 address family for the public network, do not specify this option.
# Create a Flowspec IPv6 address family for the public network and enter its view.
[Sysname] flowspec
[Sysname-flowspec] address-family ipv6
[Sysname-flowspec-ipv6]
Use address-family ipv6 flowspec to create a BGP IPv6 Flowspec address family, or enter the view of an existing BGP IPv6 Flowspec address family.
Use undo address-family ipv6 flowspec to delete a BGP IPv6 Flowspec address family and all its settings.
No BGP IPv6 Flowspec address family exists.
BGP instance view
The settings in the view of a BGP IPv6 Flowspec address family take effect only on routes and peers of the BGP IPv6 Flowspec address family.
# Create a BGP IPv6 Flowspec address family and enter its view.
[Sysname] bgp 100
[Sysname-bgp-default] address-family ipv6 flowspec
[Sysname-bgp-default-ipv6-flowspec]
Use address-family ipv6 flowspec to create a BGP-VPN IPv6 Flowspec address family, or enter the view of an existing BGP-VPN IPv6 Flowspec address family.
Use undo address-family ipv6 flowspec to delete a BGP-VPN IPv6 Flowspec address family and all its settings.
No BGP-VPN IPv6 Flowspec address family exists.
The settings in the view of a BGP-VPN IPv6 Flowspec address family take effect only on routes and peers of the BGP-VPN IPv6 Flowspec address family.
# Create a BGP-VPN IPv6 Flowspec address family and enter its view.
[Sysname] bgp 100
[Sysname-bgp-default-vpn1] address-family ipv6 flowspec
[Sysname-bgp-default-flowspec-ipv6-vpn1]
bgp (Layer 3—IP Routing Command Reference)
ip vpn-instance (MPLS Command Reference)
Use address-family ipv6 flowspec to enter the IPv6 Flowspec address family view of a VPN instance.
Use undo address-family ipv6 flowspec to delete all settings in the IPv6 Flowspec address family view of a VPN instance.
VPN instance view
You can configure IPv6 Flowspec parameters in the IPv6 Flowspec VPN address family view of a VPN instance. For example, you can configure route targets for a VPN instance.
# Enter the IPv6 Flowspec VPN address family view of a VPN instance.
[Sysname-vpn-instance-vpn1] address-family ipv6 flowspec
[Sysname-vpn-flowspec-ipv6-vpn1]
Use address-family vpnv4 flowspec to create a BGP VPNv4 Flowspec address family, or enter the view of an existing BGP VPNv4 Flowspec address family.
Use undo address-family vpnv4 flowspec to delete a BGP VPNv4 Flowspec address family and all its settings.
No BGP VPNv4 Flowspec address family exists.
BGP instance view
# Create a BGP VPNv4 Flowspec address family and enter its view.
[Sysname] bgp 100
[Sysname-bgp-default] address-family vpnv4 flowspec
[Sysname-bgp-default-vpnv4-flowspec]
Use address-family vpnv6 flowspec to create a BGP VPNv6 Flowspec address family, or enter the view of an existing BGP VPNv6 Flowspec address family.
Use undo address-family vpnv6 flowspec to delete a BGP VPNv6 Flowspec address family and all its settings.
No BGP VPNv6 Flowspec address family exists.
BGP instance view
# Create a BGP VPNv6 Flowspec address family and enter its view.
[Sysname] bgp 100
[Sysname-bgp-default] address-family vpnv6 flowspec
[Sysname-bgp-default-vpnv6-flowspec]
apply
Use apply to apply an action to matching traffic in a Flowspec rule.
Use undo apply to remove an action from a Flowspec rule.
apply action
undo apply action
No action is applied in a Flowspec rule.
IPv4 Flowspec rule view
IPv6 Flowspec rule view
action: Specifies an action. Table 1 shows available actions.
Table 1 Available actions
Action
deny
Drops packets.
redirect next-hop { ipv4-address | ipv6-address } [ copy-mode ]
Redirects packets to a next hop:
·     ipv4-address: Specifies the IPv4 address of the next hop.
·     ipv6-address: Specifies the IPv6 address of the next hop.
·     copy-mode: Redirects copies of the packets.
redirect next-hop { ipv4-address color color | ipv6-address color color [ sid sid-value ] }
Redirects packets to an SR-MPLS TE policy or SRv6 TE policy:
·     ipv4-address: Specifies the destination node address of the SR-MPLS TE policy.
·     ipv6-address: Specifies the destination node address of the SRv6 TE policy.
·     color color: Specifies the color attribute of the SR-MPLS TE policy, in the format of CO (color-only) flag:color attribute value. The range value for the CO flag is 00 to 11.
·     sid sid-value: Specifies the SRv6 SID of the egress node. The device adds the SRv6 SID to the SRH header and places it after the SID list. After the packets are forwarded to the egress node, the egress node takes the forwarding action based on the SRv6 SID.
For more information about SR-MPLS TE policies or SRv6 TE policies, see Segment Routing Configuration Guide.
redirect next-hop ipv6-address sid sid-value [ prefix-length prefix-length ]
Redirects packets to an SRv6 BE tunnel:
·     ipv6-address: Specifies the destination node address of the SRv6 BE tunnel.
·     sid sid-value: Specifies the SRv6 SID of the SRv6 BE tunnel. The device performs an AND operation on the SRv6 SID and the prefix length to obtain the subnet address of the locator. Then,  the device uses the subnet address of the locator to recurse to the SRv6 BE tunnel for packet forwarding. The device uses the subnet address of the locator as the destination address in the new IPv6 basic header and encapsulate the SRH header.
·     prefix-length prefix-length: Specifies the locator prefix length of the SID, in the range of to 32 to 120.
For more information about SRv6, see Segment Routing Configuration Guide.
redirect tunnel-id tunnel-id
Redirects packets to a tunnel interface:
tunnel-id: Specifies a tunnel interface by its number. The value range for the tunnel-id argument is 0 to 4294967295. Only the MPLS TE tunnel is supported. For more information about tunnel interfaces, see tunneling configuration in Layer 3—IP Services Configuration Guide..
redirect vpn-target import-vpn-target
Redirects packets to a route target.
The import-vpn-target argument specifies a route target, a string of 3 to 21 characters. A route target can be indicated in one of the following formats:
·     16-bit AS number:32-bit user-defined number, for example, 100:3.
·     32-bit IP address:16-bit user-defined number, for example, 192.168.122.15:1.
·     32-bit AS number:16-bit user-defined number, for example, 65536:1. The smallest AS number is 65536.
remark-dscp dscp-value
Marks the DSCP value for packets.
The dscp-value argument specifies a DSCP value, which can be a number from 0 to 63 or a keyword in Table 2.
traffic-rate rate
Limits the rate of packets.
The rate argument specifies the traffic rate in the range of 1 to 100000000 kbps.
traffic-sampling
Sample packets. The sampling rate is 0.1%
Table 2 DSCP keywords and values
Keyword
DSCP value (binary)
DSCP value (decimal)
default
000000
0
af11
001010
10
af12
001100
12
af13
001110
14
af21
010010
18
af22
010100
20
af23
010110
22
af31
011010
26
af32
011100
28
af33
011110
30
af41
100010
34
af42
100100
36
af43
100110
38
cs1
001000
8
cs2
010000
16
cs3
011000
24
cs4
100000
32
cs5
101000
40
cs6
110000
48
cs7
111000
56
ef
101110
46
If you execute this command multiple times with the same type of action in a Flowspec rule, the most recent configuration takes effect.
The relationship among different action types in a Flowspec rule is logic AND.
If both actions of redirecting to a VPN instance and redirecting to a tunnel interface are configured, only the action of redirecting to the VPN instance takes effect.
If both actions of redirecting to a tunnel interface and redirecting to a next hop are configured, only the action of redirecting to the VPN instance takes effect.
The action of redirecting to a next hop is mutually exclusive with the action of redirecting to a tunnel interface. If both actions are configured, neither action takes effect.
For successful traffic redirection, make sure the next hop IP address is reachable. The redirection feature periodically looks up the routing table to verify the reachability of the next hop IP address. If the next hop IP address is detected unreachable, traffic redirection to a next hop is no longer in effect.
You can only redirect traffic to the public network by redirecting the traffic to an SR-MPLS TE policy.
You can redirect traffic to the public network or a VPN instance by redirecting the traffic to an SRv6 TE policy. If you do not specify  the { sid | vpnsid } sid option, traffic is redirected to the public network.
·     To redirect traffic to a VPN instance by using an SRv6 TE policy, you must specify the sid sid-value option and make sure the SID Function type is End.DT4/End.DT6/End.DT46/End.DX4/End.DX6. For more information about Function types, see SRv6 configuration in Segment Routing Configuration Guide.
·     To redirect traffic to the public network by using an SRv6 TE policy, you can optionally specify the sid sid-value option and make sure the SID Function type is a public network SID. For more information about Function types, see SRv6 configuration in Segment Routing Configuration Guide.
A traffic sampling action must work with NetStream. You must enable NetStream and specify a destination host for NetStream data export. Matching packets in an Flowspec rule are sampled and sent to the NetStream module. The NetStream module sends them to a remote collector for analysis. For more information about NetStream and IPv6 NetStream, see Network Management and Monitoring Configuration Guide.
# Apply a deny action in an IPv4 Flowspec rule.
[Sysname] flow-route route1
[Sysname-flow-route-route1] if-match port 23
[Sysname-flow-route-route1] apply deny
# Apply a redirection action in an IPv4 Flowspec rule.
[Sysname-flow-route-route1] apply redirect vpn-target 4:4
# Apply an action of marking DSCP value af11 for packets in an IPv4 Flowspec rule.
[Sysname-flow-route-route1] apply remark-dscp af11
# Apply an action of limiting the traffic rate to 419200 kbps in an IPv4 Flowspec rule.
[Sysname-flow-route-route1] apply traffic-rate 419200
# Apply a deny action in an IPv6 Flowspec rule.
[Sysname] flow-route route1 ipv6
[Sysname-flow-route-ipv6-route1] if-match port 23
[Sysname-flow-route-ipv6-route1] apply deny
# Apply a redirection action in an IPv6 Flowspec rule.
[Sysname-flow-route-ipv6-route1] apply redirect vpn-target 4:4
# Apply an action of redirecting traffic to an SR-MPLS TE policy in an IPv4 Flowspec rule: The destination node address is 192.168.45.45, and the color attribute is 01:1.
[Sysname-flow-route-route1] apply redirect next-hop 192.168.45.45 color 01:1
# Apply an action of redirecting traffic to an SRv6 TE policy in an IPv6 Flowspec rule: The destination node address is 2::2, the color attribute is 11:2, and the SRv6 SID of the egress node is 2::3.
[Sysname-flow-route-ipv6-route2] apply redirect next-hop 2::2 color 11:2 sid 2::3
# Apply an action of sampling packets in an IPv4 Flowspec rule.
[Sysname-flow-route-route1] apply traffic-sampling
# Apply an action of redirecting packets to a tunnel interface in an IPv4 Flowspec rule.
[Sysname-flow-route-route1] apply redirect tunnel-id 10
flow-route ipv6 (system view)
Use check flow-route-configuration to display uncommitted match criteria and actions in a Flowspec rule.
If you configure match criteria and actions for the first time in a Flowspec rule and do not commit them, this command displays all uncommitted match criteria and actions.
If some match criteria and actions are committed and others are not committed in a Flowspec rule, this command displays all match criteria and actions, including those that are committed. To display the committed match criteria and actions of a Flowspec rule, use the display this command in Flowspec rule view.
# Display uncommitted match criteria and actions in an IPv4 Flowspec rule.
[Sysname-flow-route-route1] check flow-route-configuration
Traffic filtering rules:
Destination IP   : 1.1.0.0 255.255.0.0
Destination port : 23
DSCP             : 24
Fragment type    : match fragment
ICMP code        : 8
ICMP type        : 10
Packet length    : 150
Protocol         : 2
Source IP        : 1.1.0.0 255.255.0.0
Source port      : 238 to 240 550
TCP flags        : match 23
Traffic filtering actions:
Traffic rate                : 1000(kbps)
Traffic sampling
DSCP marking                : 56
Redirecting to VPN target   : 100:1
Redirect SR-TE policy:
  Nexthop: 2.2.2.3
  Color  : 00:56874
Redirect SRv6-BE:
  Nexthop: 4d::56
  SID    : 5a::13
  Prefix-length  : 32
Redirect to tunnel id     : 10
# Display uncommitted match criteria and actions in an IPv6 Flowspec rule.
[Sysname-flow-route-ipv6-route1] check flow-route-configuration
Destination IPv6 : 88:11:11::/123
DSCP             : 24
ICMP code        : 8
ICMP type        : 10
Packet length    : 150
Next header      : 2
Source IPv6      : 11:33::/76
Flow label       : 100
Traffic sampling
DSCP marking                : 56
Redirect SRv6-TE policy:
  Nexthop: 4d::56
  Color  : 00:156879
  SID    : 5a::13
Redirect SRv6-BE:
  Nexthop: 4d::56
  SID    : 5a::13
  Prefix-length  : 32
Match criteria that are not committed.
For more information about match criteria, see Table 4.
If no match criteria are configured or the match criteria are committed, this field displays N/A.
Actions that are not committed.
For more information about actions, see Table 5.
If no actions are configured or the actions are committed, this field displays N/A.
Table 4 Match criteria
Destination IP
Matches the destination IPv4 address.
Destination IPv6
Matches the destination IPv6 address.
Destination port
Matches the destination port.
DSCP
Matches the DSCP value.
Fragment type
Matches the fragment type:
·     match—Indicates that the specified fragment type is a successful match criterion.
·     not—Indicates that all fragment types except the specified fragment type are successful match criteria.
·     fragment—Matches fragmented packets.
·     non-fragment—Matches non-fragmented packets.
·     fragment-spe-first—Matches the first fragment of fragmented packets.
ICMP code
Matches the ICMP code.
ICMP type
Matches the ICMP type.
Packet length
Matches the packet length (including the Layer 3 header).
Port
Matches the source and destination ports.
Protocol
Matches the protocol number.
Source IP
Matches the source IPv4 address.
Source IPv6
Matches the source IPv6 address.
Source port
Matches the source port.
TCP flags
Matches TCP flags.
·     match—Indicates that the specified TCP flags are successful match criteria.
·     not—Indicates that all TCP flags except the specified TCP flags are successful match criteria.
Next header
Matches the protocol in an IPv6 next header.
Flow label
Matches the IPv6 flow label.
Table 5 Actions
Deny
Drops packets.
Traffic rate
Limits the traffic rate.
Traffic sampling
Samples packets.
Redirecting to next-hop
Redirects packets to a next hop.
DSCP marking
Redirect to SR-TE policy
Redirect traffic to an SR-MPLS TE policy.
·     Nexthop—Destination node address of the SR-MPLS TE policy.
·     Color—Color attribute of the SR-MPLS TE policy.
Redirect to SRv6-TE policy
Redirect traffic to an SRv6 TE policy:
·     Nexthop—Destination node address of the SRv6 TE policy.
·     Color—Color attribute of the SRv6 TE policy.
·     SID—SRv6 SID of the egress node.
Redirect SRv6-BE
Redirect traffic to an SRv6 BE tunnel:
·     Nexthop—Destination node address of the SRv6 BE tunnel.
·     SID—SRv6 SID of the SRv6 BE tunnel.
·     Prefix-length—Prefix length.
Redirect traffic to a tunnel interface.
commit
commit
Use commit to commit match criteria and actions in a Flowspec rule.
commit
Match criteria and actions in a Flowspec rule are not committed.
Match criteria and actions in a Flowspec rule can be modified dynamically. To reduce network instability caused by dynamic modification, you must execute the commit command to make the modification in a Flowspec rule take effect.
As a best practice before executing the commit command, use the check flow-route-configuration command to display the match criteria and actions that are not committed.
Multiple Flowspec rules can be applied to a Flowspec IPv4 or IPv6 address family. However, different Flowspec rules cannot have the same committed match criteria.
# Commit match criteria and actions in IPv4 Flowspec rule route1.
[Sysname-flow-route-route1] commit
# Commit match criteria and actions in IPv6 Flowspec rule route1.
[Sysname-flow-route-ipv6-route1] apply traffic-rate 419200
[Sysname-flow-route-ipv6-route1] commit
Use description to configure a description for a Flowspec interface group.
Use undo description to delete the description of a Flowspec interface group.
No description is configured for a Flowspec interface group.
text: Specifies a description, a case-sensitive string of 1 to 127 characters.
# Configure the description as abc for Flowspec interface group 1.
[Sysname] flowspec flow-interface-group 1
[Sysname-flowspec-interface-group-1] description abc
Use display bgp group flowspec to display BGP peer group information.
display bgp [ instance instance-name ] group { ipv4 | ipv6 | vpnv4 | vpnv6 } flowspec [ vpn-instance vpn-instance-name ] [ group-name group-name ]
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a BGP instance, this command displays the information for the default BGP instance.
ipv4: Displays IPv4 BGP peer group information.
ipv6: Displays IPv6 BGP peer group information.
vpnv4: Displays VPNv4 BGP peer group information.
vpnv6: Displays VPNv6 BGP peer group information.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays the information for the public network.
group-name group-name: Specifies a BGP peer group by its name, a case-sensitive string of 1 to 47 characters. If you do not specify a group, this command displays brief information about all BGP peer groups for the specified address family.
# Display brief information about all BGP IPv4 peer groups.
<Sysname> display bgp group ipv4 flowspec
 BGP peer group: group1
 Remote AS: 600
 Authentication type configured: None
 Type: external
 Members:
  1.1.1.10
 BGP peer group: group2
 Remote AS number: not specified
 Type: external
 Members:
  2.2.2.2
Table 6 Command output
BGP peer group
Name of the BGP peer group.
Remote AS
AS number of the peer group.
Authentication mode of the peer group:
·     None.
·     MD5.
·     Keychain (keychain-name).
Type of the peer group:
·     external—EBGP peer group.
·     internal—IBGP peer group.
Maximum number of prefixes allowed
Maximum number of routes allowed to learn from the peer.
This field does not apply to BGP L2VPN.
Threshold
Percentage of received routes from the peer to maximum routes allowed to learn from the peer. If the percentage is reached, the system generates a log message.
Configured hold time
Configured hold interval in seconds.
Keepalive time
Keepalive interval in seconds.
Minimum time between advertisements
Minimum route advertisement interval in seconds.
Peer preferred value
Preferred value specified for routes from the peer.
Site-of-Origin
SoO for the peer group.
Routing policy configured
Routing policy configured for the peer group.
If you do not specify a routing policy, this field displays No routing policy is configured.
Members
Information about peers included in the peer group.
* - Dynamically created peer
An asterisk (*) before a peer address indicates that the peer is a dynamic peer.
Peer
IPv4 or IPv6 address of the peer.
AS
AS number of the peer.
MsgRcvd
Number of messages received.
MsgSent
Number of messages sent.
OutQ
Number of messages to be sent.
PrefRcv
For the IPv4, IPv6, VPNv4, and VPNv6 address families, this field displays the number of prefixes received from the peer.
For MPLS L2VPN, this field displays the number of label blocks received from the peer.
For VPLS, this field displays the total number of label blocks and VPLS PEs discovered by BGP.
For the IPv4 flowspec address family, this field displays the number of IPv4 flowspec messages received from the peer.
For the IPv4 MDT address family, this field displays the number of MDT messages received from the peer.
Up/Down
Lasting time of the current BGP session state.
Current state of the BGP session between the local router and the peer.
IPsec profile name
IPsec profile applied to the IPv6 BGP peer group.
Use display bgp routing-table ipv4 flowspec to display BGP IPv4 Flowspec routing information.
display bgp [ instance instance-name ] routing-table ipv4 flowspec [ vpn-instance vpn-instance-name ] [as-path-acl { as-path-acl-number | as-path-acl-name } | as-path-regular-expression regular-expression | flowspec-prefix [ advertise-info ] | statistics ]
display bgp [ instance instance-name ] routing-table ipv4 flowspec [ vpn-instance vpn-instance-name ] peer { ipv4-address | ipv6-address } { advertised-routes | received-routes } [ flowspec-prefix [ verbose ] | statistics ]
display bgp [ instance instance-name ] routing-table ipv4 flowspec [ vpn-instance vpn-instance-name ] peer { ipv4-address | ipv6-address } { accepted-routes | not-accepted-routes }
as-path-acl as-path-acl-number: Displays BGP IPv4 Flowspec routes that match the AS path list specified by its number in the range of 1 to 256.
as-path-acl as-path-acl-name: Displays BGP IPv4 Flowspec routes that match the AS path list specified by its name, a case-sensitive string of 1 to 51 characters. The AS path list name cannot contain only digits.
as-path-regular-expression regular-expression: Displays BGP IPv4 Flowspec routes that match the specified regular expression, a case-sensitive string of 1 to 256 characters.
flowspec-prefix: Displays detailed BGP IPv4 Flowspec routing information. The values for this argument are the values under the Network field displayed when you do not specify this argument.
verbose: Displays detailed information about BGP IPv4 Flowspec routes. If you do not specify this keyword, the command displays brief information about BGP IPv4 Flowspec routes.
advertise-info: Displays advertisement information for BGP IPv4 Flowspec routes.
peer { ipv4-address | ipv6-address }: Displays BGP IPv4 or IPv6 Flowspec routing information advertised to or received from the specified peer.
advertised-routes: Displays BGP IPv4 Flowspec routing information advertised to the specified peer.
received-routes: Displays BGP IPv4 Flowspec routing information received from the specified peer.
statistics: Displays routing statistics.
accepted-routes: Displays BGP IPv4 Flowspec routing information received from the specified peer and permitted by a receiving policy.
not-accepted-routes: Displays BGP IPv4 Flowspec routing information received from the specified peer and not permitted by a receiving policy.
If you do not specify any parameters, this command displays brief information about all BGP IPv4 Flowspec routes.
# Display brief information about all BGP IPv4 Flowspec routes in the default BGP instance.
<Sysname> display bgp routing-table ipv4 flowspec
 Total number of routes: 1
 BGP local router ID is 10.1.1.1
     Network            NextHop         MED        LocPrf     PrefVal Path/Ogn
* >e DEST:1.2.3.4/32,Proto:=0|=1|=60,DPort:=200,SPort:=100,ICMPType:=200/176
                        0.0.0.0                               0       200?
# Displays BGP IPv4 Flowspec routes in the default BGP instance of the public network that match AS path list 1.
<Sysname> display bgp routing-table ipv4 flowspec as-path-acl 1
                        0.0.0.0                               0       200?
# Displays BGP IPv4 Flowspec routes in the default BGP instance of the public network that match any AS path attributes.
<Sysname> display bgp routing-table ipv4 flowspec as-path-regular-expression ^.*
                        0.0.0.0                               0       200?
Table 7 Command output
Status codes
Status codes:
·     * – valid—Valid route.
·     > – best—Optimal route.
·     d – dampened—Dampened route.
·     h – history—History route.
·     s – suppressed—Suppressed route.
·     S – stale—Stale route.
·     i – internal—Internal route.
·     e – external—External route.
Origin
Origin of the route:
·     i – IGP—Originated in the AS. The origin of routes advertised with the network command is IGP.
·     e – EGP—Learned through EGP.
·     ?– incomplete—Unknown origin. The origin of routes redistributed from IGP protocols is incomplete.
Network
Destination network address.
NextHop
Next hop IP address.
MED
Multi-Exit Discriminator attribute.
LocPrf
Local preference value.
PrefVal
Preferred value of the route.
Path/Ogn
AS_PATH and ORIGIN attributes of the route:
·     AS_PATH—Records the ASs the route has passed. This attribute can avoid routing loops.
·     ORIGIN—Identifies the origin of the route.
# Display detailed information about a BGP IPv4 Flowspec route (DEST:1.1.1.0/24,DPort:=10/64) for the default BGP instance in the public network.
<Sysname> display bgp routing-table ipv4 flowspec DEST:1.1.1.0/24,DPort:=10/64
 BGP local router ID: 10.1.1.1
 Local AS number: 10
 Paths:   1 available, 1 best
 BGP routing table information of DEST:1.1.1.0/24,DPort:=10/64:
 Imported route.
 Original nexthop: 0.0.0.0
 Out interface   : NULL0
 Route age       : 01h55m46s
 OutLabel        : NULL
 Ext-Community   : <FLOWSPEC RATE: 2500 Bps>, <FLOWSPEC REDIRECT: Tunnel-ID(22)
                    Flags(0x0)>
 Wide-Community  : <DownloadToFIB: SourceAS(65515) RelyFlag(0xa5)>
 RxPathID        : 0x0
 TxPathID        : 0x0
 Org-validation  : Valid
 AS-path         : (null)
 Origin          : igp
 Attribute value : pref-val 32768
 State           : valid, local, best
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
Table 8 Command output
Paths
Number of routes:
·     available—Number of valid routes.
·     best—Number of optimal routes.
Information about the BGP route to network 1.1.1.0/24.
Imported route
This route is an imported route.
Original nexthop
Original next hop of the route. If the route was obtained from a BGP UPDATE message, the original next hop is the next hop IP address in the message.
Out interface
Next hop output interface information.
Route age
Time elapsed since the most recent route update.
OutLabel
Outgoing label of the route.
Ext-community
Extended community attribute.
Wide-Community
Wide community attribute.
RxPathID
Add-path ID of received routes.
TxPathID
Add-path ID of advertised routes.
Org-validation
BGP RPKI validation state:
·     Valid.
·     Not found.
·     Invalid.
AS-path
AS_PATH attribute of the route, which records the ASs the route has passed and avoids routing loops.
Origin
·     igp—Originated in the AS.
·     egp—Learned through EGP.
·     incomplete—Unknown origin.
Attribute value
BGP path attributes:
·     MED—MED value.
·     localpref—Local preference value.
·     pref-val—Preferred value.
·     pre—Route preference.
Originator
Peer that generated the route.
Cluster list
CLUSTER_LIST attribute of the route. If the route does not carry this attribute, this field is not displayed.
Advertised to VPN peers (1 in total)
Peers to which the route has been advertised.
Current state of the route:
·     valid.
·     internal.
·     external.
·     local.
·     synchronize.
·     best.
·     delay—The route will be delayed for optimal route selection. This field is displayed only in the detailed command output.
·     bgp-rib-only—The route will not be flushed to the routing table. This field is displayed only in the detailed command output.
IP precedence
IP precedence in the range of 0 to 7. N/A indicates that the route does not support this field.
QoS local ID
QoS local ID in the range of 1 to 4095. N/A indicates that the route does not support this field.
Traffic index
Traffic index in the range of 1 to 64. N/A indicates that the route does not support this field.
# Display statistics for BGP IPv4 Flowspec routes advertised to peer 10.2.1.2 for the default BGP instance.
<Sysname> display bgp routing-table ipv4 flowspec peer 10.2.1.2 advertised-routes statistics
 Advertised routes total: 2
# Display statistics for BGP IPv4 Flowspec routes received from peer 10.2.1.2 for the default BGP instance.
<Sysname> display bgp routing-table ipv4 flowspec peer 10.2.1.2 received-routes statistics
 Received routes total: 2
Table 9 Command output
Total number of advertised routes.
Total number of received routes.
Use display bgp routing-table ipv6 flowspec to display BGP IPv6 Flowspec routing information.
display bgp [ instance instance-name ] routing-table ipv6 flowspec [ vpn-instance vpn-instance-name ] [ as-path-acl { as-path-acl-number | as-path-acl-name } | as-path-regular-expression regular-expression |flowspec-prefix [ advertise-info ] | statistics ]
display bgp [ instance instance-name ] routing-table ipv6 flowspec [ vpn-instance vpn-instance-name ] peer { ipv4-address | ipv6-address } { advertised-routes | received-routes } [ flowspec-prefix [ verbose ] | statistics ] ]
display bgp [ instance instance-name ] routing-table ipv6 flowspec [ vpn-instance vpn-instance-name ] peer { ipv4-address | ipv6-address } { accepted-routes | not-accepted-routes }
as-path-acl as-path-acl-number: Displays BGP IPv6 Flowspec routes that match the AS path list specified by its number in the range of 1 to 256.
as-path-acl as-path-acl-name: Displays BGP IPv6 Flowspec routes that match the AS path list specified by its name, a case-sensitive string of 1 to 51 characters. The AS path list name cannot contain only digits.
as-path-regular-expression regular-expression: Displays BGP IPv6 Flowspec routes that match the specified regular expression, a case-sensitive string of 1 to 256 characters.
flowspec-prefix: Displays detailed BGP IPv6 Flowspec routing information. The values for this argument are the values under the Network field displayed when you do not specify this argument.
verbose: Displays detailed information about BGP IPv6 Flowspec routes. If you do not specify this keyword, the command displays brief information about BGP IPv6 Flowspec routes.
advertise-info: Displays advertisement information for BGP IPv6 Flowspec routes.
advertised-routes: Displays BGP IPv6 Flowspec routing information advertised to the specified peer.
received-routes: Displays BGP IPv6 Flowspec routing information received from the specified peer.
accepted-routes: Displays BGP IPv6 Flowspec routing information received from the specified peer and permitted by a receiving policy.
not-accepted-routes: Displays BGP IPv6 Flowspec routing information received from the specified peer and not permitted by a receiving policy.
If you do not specify any parameters, this command displays brief information about all BGP IPv6 Flowspec routes.
# Display brief information about all public-network BGP IPv6 Flowspec routes in the default BGP instance.
<Sysname> display bgp routing-table ipv6 flowspec
BGP local router ID is 10::1
* >e DEST:11::1/64,Proto:=0|=1|=60,DPort:=200,SPort:=100,ICMPType:=200/176
                        0.0.0.0                               0       200?
<Sysname> display bgp routing-table ipv6 flowspec as-path-acl 1
                        0.0.0.0                               0       200?
<Sysname> display bgp routing-table ipv6 flowspec as-path-regular-expression ^.*
                        0.0.0.0                               0       200?
# Display information about public-network BGP IPv6 Flowspec routes advertised to peer 10::1 in the default BGP instance.
<Sysname> display bgp routing-table ipv6 flowspec peer 10:: 1 advertised-routes
 BGP local router ID is 10::2
     Network            NextHop         MED        LocPrf             Path/Ogn
* >  DEST:11::1/64,Proto:=0|=1|=60,DPort:=200,SPort:=100,ICMPType:=200/176
                        0.0.0.0                                       200?
# Display information about public-network BGP IPv6 Flowspec routes received from peer 10::2 in the default BGP instance.
<Sysname> display bgp routing-table ipv6 flowspec peer 10::2 received-routes
                        0.0.0.0                               0       200?
Table 10 Command output
Status codes
Status codes:
Origin
Network
NextHop
Next-hop IP address.
MED
LocPrf
PrefVal
Path/Ogn
# Display statistics for BGP IPv6 Flowspec routes advertised to peer 10::2 in the default BGP instance.
<Sysname> display bgp routing-table ipv6 flowspec peer 10::2 advertised-routes statistics
# Display statistics for BGP IPv6 Flowspec routes received from peer 10::2 in the default BGP instance.
<Sysname> display bgp routing-table ipv6 flowspec peer 10::2 received-routes statistics
Table 11 Command output
# Display information about public-network BGP IPv6 Flowspec routes to destination network with DPort as 1000/32 in the default BGP instance.
<Sysname> display bgp routing-table ipv6 flowspec DPort:=1000/32
 BGP local router ID: 1.1.1.2
 Local AS number: 100
 BGP routing table information of DPort:=1000/32:
 Imported route.
 Route age       : 00h00m10s
 OutLabel        : NULL
 Ext-Community   : <CO-Flag:Color(00:1)>
 Ext-Community6  : <FLOWSPEC REDIRECT-IP: 11::1:0>
 RxPathID        : 0x0
 TxPathID        : 0x0
 PrefixSID       : N/A SID <123::1>
 AS-path         : (null)
 Origin          : igp
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
Table 12 Command output
Paths
Number of routes:
Original nexthop
Out interface
Route age
OutLabel
Ext-Community
Ext-Community6
IPv6 extended community attribute.
RxPathID
TxPathID
Org-validation
·     Valid.
·     Not found.
·     Invalid.
PrefixSID
Prefix SID:
·     Label index—Label index.
·     SRGB—SRGB range.
AS-path
Origin
Attribute value
·     MED—MED value.
Originator
Cluster list
·     valid.
·     internal.
·     external.
·     local.
·     synchronize.
·     best.
·     not preferred for reason—Reason why the route is not selected as the optimal route.
·     not ECMP for reason—Reason why the route does not form ECMP routes with other routes.
IP precedence
QoS local ID
Traffic index
Use display bgp routing-table vpnv4 flowspec to display BGP VPNv4 Flowspec routing information.
display bgp [ instance instance-name ] routing-table vpnv4 flowspec [ as-path-acl { as-path-acl-number | as-path-acl-name } | as-path-regular-expression regular-expression | peer { ipv4-address | ipv6-address } { advertised-routes | received-routes } [ flowspec-prefix [ verbose ] | statistics ] | [ route-distinguisher route-distinguisher ] [ flowspec-prefix [ advertise-info ] ] | statistics ]
display bgp [ instance instance-name ] routing-table vpnv4 flowspec peer { ipv4-address | ipv6-address } { accepted-routes | not-accepted-routes }
as-path-acl as-path-acl-number: Displays BGP VPNv4 Flowspec routes that match the AS path list specified by its number in the range of 1 to 256.
as-path-acl as-path-acl-name: Displays BGP VPNv4 Flowspec routes that match the AS path list specified by its name, a case-sensitive string of 1 to 51 characters. The AS path list name cannot contain only digits.
as-path-regular-expression regular-expression: Displays BGP VPNv4 Flowspec routes that match the specified regular expression, a case-sensitive string of 1 to 256 characters.
peer { ipv4-address | ipv6-address }: Displays BGP VPNv4 or VPNv6 Flowspec routing information advertised to or received from the specified peer.
advertised-routes: Displays BGP VPNv4 Flowspec routing information advertised to the specified peer.
received-routes: Displays BGP VPNv4 Flowspec routing information received from the specified peer.
route-distinguisher route-distinguisher: Displays BGP VPNv4 Flowspec routing information for the specified route distinguisher. The route-distinguisher argument is a string of 3 to 21 characters and can be specified in one of the following formats:
·     16-bit AS number:32-bit user-defined number, for example, 101:3.
·     32-bit AS number:16-bit user-defined number, for example, 65536:1. The smallest AS number is 65535.
flowspec-prefix: Displays detailed BGP VPNv4 Flowspec routing information. The values for this argument are the values under the Network field displayed when you do not specify this argument.
verbose: Displays detailed information about BGP VPNv4 Flowspec routes. If you do not specify this keyword, the command displays brief information about BGP VPNv4 Flowspec routes.
advertise-info: Displays advertisement information for BGP VPNv4 Flowspec routes.
accepted-routes: Displays BGP VPNv4 Flowspec routing information received from the specified peer and permitted by a receiving policy.
not-accepted-routes: Displays BGP VPNv4 Flowspec routing information received from the specified peer and not permitted by a receiving policy.
If you do not specify any parameters, this command displays brief information about all BGP VPNv4 Flowspec routes.
# Display brief information about all BGP VPNv4 Flowspec routes for the default BGP instance.
<Sysname> display bgp routing-table vpnv4 flowspec
 BGP local router ID is 192.168.56.55
 Total number of routes from all PEs: 4
 Route distinguisher: 1:3
 Total number of routes: 2
* >i DEST:1.2.3.4/32,Source:2.3.4.5/32,Proto:=0|=1|=60,Port:=200,DPort:=200|=300
,SPort:=100|=120|=140,ICMPType:=200|=100|=120|=140,ICMPCode:=200|=220|=230,TCPFl
ags:=255,Length:=1024,DSCP:=6|=2,Frag:=4/528
                        0.0.0.0                    100        0       ?
* >i DEST:4.5.6.7/32,Proto:=0|=1|=60,DPort:=200,SPort:=100,ICMPType:=200/176
                        0.0.0.0                    100        0       ?
 Route distinguisher: 1:5(vpn1)
 Total number of routes: 5
                        0.0.0.0                    100        0       ?
* >e DEST:1.2.3.4/32,Source:2.3.4.5/32,Proto:=0|=1|=60,Port:=200,DPort:=200|=300
ags:=255,Length:=1024,DSCP:=6|=2,Frag:=4,DEST:1.2.3.4/32,Source:2.3.4.5/32,Proto
:=0|=1|=60,Port:=200,DPort:=200|=300,SPort:=100|=120|=140,ICMPType:=200|=100|=12
0|=140,ICMPCode:=200|=220|=230,TCPFlags:=255,Length:=1024,DSCP:=6|=2,Frag:=4/105
6
                        0.0.0.0                               0       100?
* >  DEST:4.5.6.7/32,Proto:=0|=1|=60,DPort:=200,SPort:=100,ICMPType:=200/176
                        0.0.0.0                               32768   ?
*  i                    0.0.0.0                    100        0       ?
*  e                    0.0.0.0                               0       100?
 Route distinguisher: 1:6
6
                        0.0.0.0                               0       100?
* >e DEST:4.5.6.7/32,Proto:=0|=1|=60,DPort:=200,SPort:=100,ICMPType:=200/176
                        0.0.0.0                               0       100?
# Displays BGP VPNv4 Flowspec routes that match AS path list 1.
<Sysname> display bgp routing-table vpnv4 flowspec as-path-acl 1
                        0.0.0.0                    100        0       ?
                        0.0.0.0                    100        0       ?
                        0.0.0.0                    100        0       ?
6
                        0.0.0.0                               0       100?
                        0.0.0.0                               32768   ?
*  i                    0.0.0.0                    100        0       ?
*  e                    0.0.0.0                               0       100?
6
                        0.0.0.0                               0       100?
                        0.0.0.0                               0       100?
# Displays BGP VPNv4 Flowspec routes that match any AS path attributes.
<Sysname> display bgp routing-table vpnv4 flowspec as-path-regular-expression ^.*
                        0.0.0.0                    100        0       ?
                        0.0.0.0                    100        0       ?
                        0.0.0.0                    100        0       ?
6
                        0.0.0.0                               0       100?
                        0.0.0.0                               32768   ?
*  i                    0.0.0.0                    100        0       ?
*  e                    0.0.0.0                               0       100?
6
                        0.0.0.0                               0       100?
                        0.0.0.0                               0       100?
Table 13 Command output
Status codes
Status codes:
Origin
Network
NextHop
MED
LocPrf
PrefVal
Path/Ogn
# Display detailed information about BGP VPNv4 Flowspec route DEST:1.1.1.0/24,DPort:=10/64 advertised to peer 1.1.1.9.
<Sysname> display bgp routing-table vpnv4 flowspec peer 1.1.1.9 advertised-routes DEST:1.1.1.0/24,DPort:=10/64 verbose
 BGP local router ID: 192.168.56.3
 Route distinguisher: 100:1
 Paths:   1 best
 Ext-Community   : <RT: 12:1>, <FLOWSPEC RATE: 1250 Bps>
 AS-path         : (null)
 Origin          : igp
 Attribute value : localpref 100
1.1.1.9
# Display statistics for BGP VPNv4 Flowspec routes advertised to peer 15.5.6.2 for the default BGP instance.
<Sysname> display bgp routing-table vpnv4 flowspec peer 15.5.6.2 advertised-routes statistics
 Advertised routes total: 3
# Display statistics for BGP VPNv4 Flowspec routes received from peer 15.5.6.2 for the default BGP instance.
<Sysname> display bgp routing-table vpnv4 flowspec peer 15.5.6.2 received-routes statistics
Table 14 Command output
# Display statistics for BGP VPNv4 Flowspec routes.
<Sysname> display bgp routing-table vpnv4 flowspec statistics
Use display bgp routing-table vpnv6 flowspec to display BGP VPNv6 Flowspec routing information.
display bgp [ instance instance-name ] routing-table vpnv6 flowspec [ as-path-acl { as-path-acl-number | as-path-acl-name } | as-path-regular-expression regular-expression | peer { ipv4-address | ipv6-address } { advertised-routes | received-routes } [ flowspec-prefix [ verbose ] | statistics ] | [ route-distinguisher route-distinguisher ] [ flowspec-prefix [ advertise-info ] ] | statistics ]
display bgp [ instance instance-name ] routing-table vpnv6 flowspec peer { ipv4-address | ipv6-address } { accepted-routes | not-accepted-routes }
as-path-acl as-path-acl-number: Displays BGP VPNv6 Flowspec routes that match the AS path list specified by its number in the range of 1 to 256.
as-path-acl as-path-acl-name: Displays BGP VPNv6 Flowspec routes that match the AS path list specified by its name, a case-sensitive string of 1 to 51 characters. The AS path list name cannot contain only digits.
as-path-regular-expression regular-expression: Displays BGP VPNv6 Flowspec routes that match the specified regular expression, a case-sensitive string of 1 to 256 characters.
advertised-routes: Displays BGP VPNv6 Flowspec routing information advertised to the specified peer.
received-routes: Displays BGP VPNv6 Flowspec routing information received from the specified peer.
route-distinguisher route-distinguisher: Displays BGP VPNv6 Flowspec routing information for the specified route distinguisher. The route-distinguisher argument is a string of 3 to 21 characters and can be specified in one of the following formats:
flowspec-prefix: Displays detailed BGP VPNv6 Flowspec routing information. The values for this argument are the values under the Network field displayed when you do not specify this argument.
verbose: Displays detailed information about BGP VPNv6 Flowspec routes. If you do not specify this keyword, the command displays brief information about BGP VPNv6 Flowspec routes.
advertise-info: Displays advertisement information for BGP VPNv6 Flowspec routes.
accepted-routes: Displays BGP VPNv6 Flowspec routing information received from the specified peer and permitted by a receiving policy.
not-accepted-routes: Displays BGP VPNv6 Flowspec routing information received from the specified peer and not permitted by a receiving policy.
If you do not specify any parameters, this command displays brief information about all BGP VPNv6 Flowspec routes.
# Display brief information about all BGP VPNv6 Flowspec routes in the default BGP instance.
<Sysname> display bgp routing-table vpnv6 flowspec
 BGP local router ID is 1::1
* >i DEST:2::1/32,Source:3::1/32,Proto:=0|=1|=60,Port:=200,DPort:=200|=300
                        0.0.0.0                    100        0       ?
* >i DEST:4::1/32,Proto:=0|=1|=60,DPort:=200,SPort:=100,ICMPType:=200/176
                        0.0.0.0                    100        0       ?
                        0.0.0.0                    100        0       ?
* >e DEST:4::1/32,Source:3::1/32,Proto:=0|=1|=60,Port:=200,DPort:=200|=300
ags:=255,Length:=1024,DSCP:=6|=2,Frag:=4,DEST:2::1/32,Source:3::1/32,Proto
6
                        0.0.0.0                               0       100?
* >  DEST:4::1/32,Proto:=0|=1|=60,DPort:=200,SPort:=100,ICMPType:=200/176
                        0.0.0.0                               32768   ?
*  i                    0.0.0.0                    100        0       ?
*  e                    0.0.0.0                               0       100?
* >e DEST:2::1/32,Source:3::1/32,Proto:=0|=1|=60,Port:=200,DPort:=200|=300
6
                        0.0.0.0                               0       100?
* >e DEST:4::1 /32,Proto:=0|=1|=60,DPort:=200,SPort:=100,ICMPType:=200/176
                        0.0.0.0                               0       100?
# Displays BGP VPNv6 Flowspec routes that match AS path list 1.
<Sysname> display bgp routing-table vpnv6 flowspec as-path-acl 1
                        0.0.0.0                    100        0       ?
6
                        0.0.0.0                               0       100?
                        0.0.0.0                               32768   ?
*  i                    0.0.0.0                    100        0       ?
*  e                    0.0.0.0                               0       100?
# Displays BGP VPNv6 Flowspec routes that match any AS path attributes.
<Sysname> display bgp routing-table vpnv6 flowspec as-path-regular-expression ^.*
                        0.0.0.0                    100        0       ?
6
                        0.0.0.0                               0       100?
                        0.0.0.0                               32768   ?
*  i                    0.0.0.0                    100        0       ?
*  e                    0.0.0.0                               0       100?
# Display brief information about all BGP VPNv6 Flowspec routes with route distinguisher 1:5 in the default BGP instance.
<Sysname> display bgp routing-table vpnv6 flowspec route-distinguisher 1:5
                        0.0.0.0                    100        0       ?
6
                        0.0.0.0                               0       100?
                        0.0.0.0                               32768   ?
*  i                    0.0.0.0                    100        0       ?
*  e                    0.0.0.0                               0       100?
Table 15 Command output
Status codes
Status codes:
Origin
Network
NextHop
MED
LocPrf
PrefVal
Path/Ogn
# Display statistics for BGP VPNv6 Flowspec routes advertised to peer 15.5.6.2 in the default BGP instance.
<Sysname> display bgp routing-table vpnv6 flowspec peer 15.5.6.2 advertised-routes statistics
# Display statistics for BGP VPNv6 Flowspec routes received from peer 15.5.6.2 in the default BGP instance.
<Sysname> display bgp routing-table vpnv6 flowspec peer 15.5.6.2 received-routes statistics
Table 16 Command output
# Display statistics for BGP VPNv6 Flowspec routes.
<Sysname> display bgp routing-table vpnv6 flowspec statistics
# Display information about public-network BGP VPNv6 Flowspec routes to destination network with DPort as 1000/32 in the default BGP instance.
<Sysname> display bgp routing-table vpnv6 flowspec DPort:=1000/32
 BGP local router ID: 192.168.56.11
 Local AS number: 1
 Route distinguisher: 1:1(1)
 Imported route.
 Route age       : 00h00m26s
 OutLabel        : NULL
 Ext-Community   : <RT: 1:1>, <CO-Flag:Color(00:1)>
 Ext-Community6  : <FLOWSPEC REDIRECT-IP: 1::1:0>
 RxPathID        : 0x0
 TxPathID        : 0x0
 PrefixSID       : N/A SID <111::1>
 AS-path         : (null)
 Origin          : igp
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
Table 17 Command output
Paths
Number of routes:
Original nexthop
Out interface
Route age
OutLabel
Ext-Community
Ext-Community6
RxPathID
TxPathID
Org-validation
·     Valid.
·     Not found.
·     Invalid.
PrefixSID
Prefix SID:
·     SRGB—SRGB range.
AS-path
Origin
Attribute value
·     MED—MED value.
Inlabel
Inbound label of the value.
Originator
Cluster list
·     valid.
·     internal.
·     external.
·     local.
·     synchronize.
·     best.
IP precedence
QoS local ID
Traffic index
display flow-route
Use display flow-route to display Flowspec rule information on a Flowspec edge router.
display flow-route { { ipv4 | ipv6 } all | flow-route-id } [ slot slot-number ]
display flow-route { { ipv4 | ipv6 } [ instance instance-name ] [ vpn-instance vpn-instance-name | public-instance ] | flow-route-id } [ slot slot-number ]
ipv4: Specifies IPv4 Flowspec rules.
ipv6: Specifies IPv6 Flowspec rules.
all: Specifies all Flowspec rules.
flow-route-id: Specifies a Flowspec rule by its ID in the range of 0 to fffffffffffffffe (hexadecimal).
public-instance: Displays information about Flowspec rules in the public network.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays the Flowspec rule information for the active MPU.
If multiple effective Flowspec rules exist, the device compares a packet with Flowspec rules in their display order in the command output.
# Display information about all IPv4 Flowspec rules.
<Sysname> display flow-route ipv4 all
Total number of flow-routes: 3
Flow route (ID 0x0)(Failed)
  BGP instance : default
   Destination IP   : 1.2.3.4 255.255.255.255
   Port             : 22 33 44 55
   Source IP        : 2.3.4.5 255.255.255.255
   DSCP marking           : 10
   Redirecting to VPN instance : vpn3
   Sampling : Enabled
Flow route (ID 0x1)
   Deny
Flow route (ID 0x2)
  VPN instance : vpn1
   ICMP type        : 23
   Redirecting to next-hop: 1.1.1.1
   NID                    : 268435456
Flow route (ID 0x3)
  VPN instance : vpn1
   Source port        : 80
   Redirecting to VPN target : 3:3 (Inactive)
Flow route (ID 0x4)
  VPN instance : vpn1
   Source port        : 90
   Redirecting to SR-TE policy
     NID: 16824674
Flow route (ID 0x5)
   Destination IPv6 : 6::6/128
   Redirecting to SRv6 BE
     VNID         : 0x726000001
     SID          : 1000::102
Flow route (ID 0x6)
  VPN instance : vpn1
   Source port        : 70
  Traffic filtering actions: (bgp.bgp4)
   Redirecting to tunnel id    : 1
  Statistics:
   Matched     : 0 packets, 0 bytes
   Transmitted : 0 packets, 0 bytes
   Dropped     : 0 packets, 0 bytes
# Display information about all IPv6 Flowspec rules.
<Sysname> display flow-route ipv6 all
Total number of flow-routes: 2
   Destination Ipv6   : 88:11:11::/123
   Port               : 22 33 44 55
   Source Ipv6        : 66:11::/43
   DSCP marking           : 10
   Sampling : Enabled
Flow route (ID 0x1)
   Deny
Flow route (ID 0x2)
   Redirecting to SRv6-TE policy
     Forwarding ID: 16824365
     SID          : 5e::35
Flow route (ID 0x3)
     VNID         : 0x726000001
     SID          : 1000::102
Flow route (ID 0x6)
  VPN instance : vpn1
   Source port        : 70
  Statistics:
Table 18 Command output
Flow route (ID 0x0)
Flowspec rule ID.
The (Failed) attribute indicates that the Flowspec rule failed to be applied.
VPN instance
VPN instance where the Flowspec rule takes effect.
If this field does not appear, the Flowspec rule takes effect in the public network.
Redirects packets to a VPN instance.
If the route target for redirection cannot be mapped to a VPN instance, the redirection action does not take effect (indicated by Inactive enclosed in parenthesis). In addition, this field is displayed as Redirecting to VPN target.
Sampling
Sampling action: Enabled or Disabled.
If the next hop is unreachable or invalid, the redirection action does not take effect (indicated by Inactive enclosed in parenthesis).
Redirect traffic to an SRv6 TE policy.
NID
Next Hop Label Forwarding Entry (NHLFE) index.
Forwarding ID
Forwarding entry index of the SRv6 TE policy.
SID
Redirect traffic to an SRv6 BE tunnel.
VNID
Next hop index.
For information about other fields, see Table 3, Table 4, and Table 5.
Use display flowspec flow-interface-group to display the configuration of Flowspec interface groups.
display flowspec flow-interface-group [ group-id ]
group-id: Specifies a Flowspec interface group by its ID in the range of 0 to 16383. If you do not specify a Flowspec interface group, this command displays the configuration of all Flowspec interface groups.
# Display the configuration of all Flowspec interface groups.
<Sysname> display flowspec flow-interface-group
Flowspec interface group: 1
  Description: aaaaadsfadfdf
  Interfaces:
    Ten-GigabitEthernet3/0/1
    Ten-GigabitEthernet3/0/2
    Ten-GigabitEthernet3/0/3
Flowspec interface group: 2
  Interfaces:
Flowspec interface group: 3
  Interfaces:
Use display flowspec statistics to display traffic statistics for a Flowspec rule.
display flowspec statistics flow-route-id [ flow-interface-group group-id ]
flow-route-id: Specifies a Flowspec rule by its ID in the range of 0 to fffffffffffffffe (hexadecimal). To obtain Flowspec rule IDs, execute the display flow-route command. A Flowspec rule is uniquely identified by its ID.
flow-interface-group group-id: Specifies a Flowspec interface group by its ID in the range of 0 to 16383. If you do not specify a Flowspec interface group, this command displays traffic statistics for all Flowspec interface groups associated with a Flowspec rule.
# Display traffic statistics for Flowspec rule 1, which is not associated with any Flowspec interface groups.
<Sysname> display flowspec statistics 1
Flow route ID: 0x1
Statistics:
   Matched     : 7981 packets, 1140192 bytes, 15 pps, 21516 bps
   Transmitted : 2979 Packets, 485628 bytes, 7 pps, 10431 bps
   Dropped     : 4002 packets, 654564 bytes, 8 pps, 11085 bps
# Display traffic statistics for Flowspec rule 1, which is associated with Flowspec interface group 1.
<Sysname>display flowspec statistics 1 flow-interface-group 1
Flow route ID: 0x1
Statistics:
# Display traffic statistics for Flowspec interface groups all associated with Flowspec rule 1.
Flow route ID: 0x1
Statistics:
Statistics:
Statistics:
Table 19 Command output
Matched
Total number of matching packets and average rate during the last statistics polling interval configured by using the flow-interval command (see Ethernet interface commands in Interface Command Reference).
Transmitted
Number of forwarded matching packets and average forwarding rate during the last statistics polling interval configured by using the flow-interval command (see Ethernet interface commands in Interface Command Reference).
Dropped
Number of dropped matching packets and average dropping rate during the last statistics polling interval configured by using the flow-interval command (see Ethernet interface commands in Interface Command Reference).
flow-route ipv6
Use flow-route ipv6 to create an IPv6 Flowspec rule, or enter the view of an existing IPv6 Flowspec rule.
Use undo flow-route ipv6 to delete an IPv6 Flowspec rule.
flow-route flowroute-name ipv6
undo flow-route flowroute-name ipv6
Non IPv6 Flowspec rules exist.
flowroute-name: Specifies an IPv6 Flowspec rule name, a case-sensitive string of 1 to 31 characters.
To delete an IPv6 Flowspec rule applied to a Flowspec IPv6 address family, perform the following tasks:
1.     Execute the undo flow-route ipv6 command in Flowspec IPv6 address family view.
2.     Execute the undo flow-route ipv6 command in system view.
# Create an IPv6 Flowspec rule named route1.
Use flow-route to create an IPv4 Flowspec rule, or enter the view of an existing IPv4 Flowspec rule.
Use undo flow-route to delete an IPv4 Flowspec rule.
No IPv4 Flowspec rules exist.
flowroute-name: Specifies an IPv4 Flowspec rule name, a case-sensitive string of 1 to 31 characters.
To delete an IPv4 Flowspec rule applied to a Flowspec IPv4 address family, perform the following tasks:
1.     Execute the undo flow-route command in Flowspec IPv4 address family view.
2.     Execute the undo flow-route command in system view.
# Create an IPv4 Flowspec rule named route1.
Use flow-route to apply a Flowspec rule to a Flowspec IPv4 or IPv6 address family.
Use undo flow-route to remove a Flowspec rule from a Flowspec IPv4 or IPv6 address family.
No Flowspec rule is applied to a Flowspec IPv4 or IPv6 address family.
flowroute-name: Specifies an existing Flowspec rule by its name, a case-sensitive string of 1 to 31 characters.
If multiple Flowspec rules are applied to a Flowspec IPv4 or IPv6 address family, you can use the display flow-route command on a Flowspec edge router to display the match order of match criteria that are committed. If match criteria in multiple Flowspec rules can match a packet, the packet is matched by the match criterion that appears at the top.
# Apply Flowspec rule route1 to the Flowspec IPv4 address family in the public network.
[Sysname] flowspec
[Sysname-flowspec-ipv4] flow-route route1
# Apply Flowspec rule route1 to the Flowspec IPv6 address family in the public network.
[Sysname] flowspec
[Sysname-flowspec-ipv6] flow-route route1
Use flow-route flow-interface-group to associate a Flowspec rule with a Flowspec interface group.
Use undo flow-route flow-interface-group to restore the default.
A Flowspec rule is not associated with any Flowspec interface groups.
Flowspec IPv4 VPN instance address family view
Flowspec IPv6 VPN instance address family view
A Flowspec rule can be associated with more than one Flowspec interface group, and vice versa.
To associate a Flowspec rule already applied in Flowspec IPv4/IPv6 address family view or Flowspec IPv4/IPv6 VPN instance address family view with a Flowspec interface group, first execute the undo flow-route command to remove the Flowspec rule from the Flowspec IPv4 address family.
# Associate Flowspec rule route1 with Flowspec interface group 1.
[Sysname] flowspec
[Sysname-flowspec-ipv4] flow-route route1 flow-interface-group 1
flowspec
Use flowspec to enter Flowspec view.
flowspec
# Enter Flowspec view.
[Sysname] flowspec
[Sysname-flowspec]
Use flowspec flow-interface-group to create a Flowspec interface group, or enter the view of an existing Flowspec interface group.
Use undo flowspec flow-interface-group to delete a Flowspec interface group.
flowspec flow-interface-group group-id
undo flowspec flow-interface-group group-id
No Flowspec interface groups exist.
group-id: Specifies a Flowspec interface group ID in the range of 0 to 16383.
By default, a Flowspec router applies a received Flowspec rule to all interfaces on the device. To apply a received Flowspec rule to only some interfaces, perform the following tasks:
1.     Create a Flowspec interface group.
2.     Add those interfaces to it by using the interface command to the Flowspec interface group.
3.     Associate the Flowspec interface group with the Flowspec rule by using the flow-route flow-interface-group command in Flowspec IPv4 or IPv6 address family view.
# Create Flowspec interface group 1 and enter its view.
interface (Flowspec interface group view)
if-match
Use if-match to configure a match criterion in a Flowspec rule.
Use undo if-match to delete a match criterion from a Flowspec rule.
if-match match-criteria
undo if-match match-criteria
No match criterion is configured in a Flowspec rule.
match-criteria: Specifies a match criterion. Table 20 shows the available match criteria.
Table 20 Available match criteria
Match criterion type ID
Option
1
destination-ip ipv4-address { mask-length | mask }
Matches the destination IPv4 address of packets.
The ipv4-address argument specifies an IPv4 address in dotted decimal notation.
The mask-length argument specifies the mask length in the range of 0 to 32.
The mask argument specifies the mask in dotted decimal notation.
1
destination-ipv6 { ipv6-address prefix-length | ipv6-address/prefix-length }
Matches the destination IPv6 address of packets.
The ipv6-address argument specifies an IPv6 address in sets of 16-bit hexadecimal values separated by colons (:).
The prefix-length argument specifies the prefix length in the range of 0 to 128. For the ipv6-address/prefix-length argument, the prefix-length argument cannot be 0.
2
source-ip ipv4-address { mask-length | mask }
Matches the source IPv4 address of packets.
2
source-ipv6 { ipv6-address prefix-length | ipv6-address/prefix-length }
Matches the source IPv6 address of packets.
3
protocol { proto-list | proto-name&<1-8> }
Matches a protocol.
The proto-list argument specifies a space-separated list of up to eight protocol items. Each item specifies a protocol or a range of protocols by numerical values in the form of proto-start to proto-end. The value for proto-end must be greater than or equal to the value for proto-start. The value range for the proto argument is 0 to 255.
The proto-name argument specifies up to eight protocols by keyword. The available keywords are: icmp (1), igmp (2), ipinip (4), tcp (6), egp (8), udp (17), ipv6 (41), rsvp (46), gre (47), esp (50), ospf (89), and pim (103).
3
next-header { next-header-list | next-header-name&<1-8> }
The next-header-list argument specifies a space-separated list of up to eight protocol items. Each item specifies a protocol or a range of protocols by numerical values in the form of next-header-start to next-header-end. The value for next-header-end must be greater than or equal to the value for next-header-start. The value range for the next-header argument is 0 to 255.
The next-header-name argument specifies up to eight protocols by keyword. The available keywords are: icmp (1), igmp (2), ipinip (4), tcp (6), egp (8), udp (17), ipv6 (41), rsvp (46), gre (47), esp (50), icmpv6 (58), ospf (89), and pim (103).
4
port port-list
Matches the source and destination port numbers of packets.
The port-list argument specifies a space-separated list of up to eight port number items. Each item specifies a port number or a range of port numbers in the form of port-start to port-end. The value for port-end must be greater than or equal to the value for port-start. The value range for the port argument is 0 to 65535.
5
destination-port port-list
Matches the destination port number of packets.
6
source-port port-list
Matches the source port number of packets.
7
icmp-type type-list
Matches the ICMP type of packets.
The type-list argument specifies a space-separated list of up to eight type items. Each item specifies a type or a range of types in the form of type-start to type-end. The value for type-end must be greater than or equal to the value for type-start. The value range for the type argument is 0 to 255.
8
icmp-code code-list
Matches the ICMP code of packets.
The code-list argument specifies a space-separated list of up to eight code items. Each item specifies a code or a range of codes in the form of code-start to code-end. The value for code-end must be greater than or equal to the value for code-start. The value range for the code argument is 0 to 255.
9
tcp-flags { match | not } tcp-flags [ any ]
Matches the TCP flag of packets.
The match keyword indicates that the specified TCP flags are successful match criteria.
The not keyword indicates that all TCP flags except the specified TCP flags are successful match criteria.
The tcp-flags argument specifies a TCP flag value in the range of 0 to 63. This field in the packet is a 6-bit binary value.
The any keyword matches all packets with the specified bits as 1 in the binary TCP flag values. For example, to match all packets with the first and third bits as 1 in the TCP flag values, configure the if-match tcp-flags match 5 any command. The decimal TCP flag value 5 corresponds to the binary value 000101.
10
packet-length length-list
Matches the Layer 3 packet length (including Layer 3 header) of packets.
The length-list argument specifies a space-separated list of up to 10 length items. Each item specifies a length value or a range of length values in the form of length-start to length-end. The value for length-end must be greater than or equal to the value for length-start. The value range for the length argument is 0 to 65535.
11
dscp { dscp-name&<1-8> | dscp-list }
Matches the DSCP value of packets.
The dscp-name argument specifies up to eight DSCP values by keyword. Table 2 shows the available keywords.
The dscp-list argument specifies a space-separated list of up to eight DSCP values. Each item specifies a DSCP value or a range of DSCP values in the form of dscp-start to dscp-end. The value for dscp-end must be greater than or equal to the value for dscp-start. The value range for the dscp argument is 0 to 63.
12
fragment-type { match | not } { fragment | non-fragment | fragment-spe-first }
Matches the fragment type.
The match keyword indicates that the specified fragment type is a successful match criterion.
The not keyword indicates that all fragment types except the specified fragment type are successful match criteria.
The fragment keyword matches fragmented packets.
The non-fragment keyword matches non-fragmented packets.
The fragment-spe-first keyword matches the first fragment of fragmented packets.
13
flow-label flow-label-list
The flow-label-list argument specifies a space-separated list of up to eight flow label items. Each item specifies a protocol or a range of protocols by numerical values in the form of flow-label-start to flow-label-end. The value for flow-label-end must be greater than or equal to the value for flow-label-start. The value range for the flow-label argument is 0 to 1048575.
In a single Flowspec rule, the following rules apply:
·     The port port-list option is mutually exclusive with the source-port port-list or destination-port port-list option.
·     The relationship among match criteria of different types is logic AND.
·     The relationship among match criteria of the same type is logic OR.
If multiple Flowspec rules exist, the device matches the Flowspec rules in ascending order of match criterion type IDs. If a match is found, the matching process stops and the action in the matching Flowspec rule is applied. For the match order of the same-type match criteria, see section 5.1 in RFC 5575.
# Configure Flowspec rule route1 to match packets with destination IPv4 address 192.168.100.1/24.
[Sysname-flow-route-route1] if-match destination-ip 192.168.100.1 24
# Configure Flowspec rule route1 to match packets with destination port number 80.
[Sysname-flow-route-route1] if-match destination-port 80
# Configure Flowspec rule route1 to match packets with DSCP value af11.
[Sysname-flow-route-route1] if-match dscp af11
# Configure Flowspec rule route1 to match all fragmented packets.
[Sysname-flow-route-route1] if-match fragment-type match fragment
# Configure Flowspec rule route1 to match packets with ICMP code 0.
[Sysname-flow-route-route1] if-match icmp-code 0
# Configure Flowspec rule route1 to match packets with ICMP type 1.
[Sysname-flow-route-route1] if-match icmp-type 1
# Configure Flowspec rule route1 to match packets with the packet length in the range of 1200 to 1500 bytes.
[Sysname-flow-route-route1] if-match packet-length 1200 to 1500
# Configure Flowspec rule route1 to match packets with both the source and destination port numbers as 80.
[Sysname-flow-route-route1] if-match port 80
# Configure Flowspec rule route1 to match ICMP packets.
[Sysname-flow-route-route1] if-match protocol icmp
# Configure Flowspec rule route1 to match packets with source IPv4 address 192.168.100.1/24.
# Configure Flowspec rule route1 to match packets with source port number 23.
[Sysname-flow-route-route1] if-match source-port 23
# Configure Flowspec rule route1 to match packets with TCP flag 6.
[Sysname-flow-route-route1] if-match tcp-flags match 6
# Configure Flowspec rule route1 to match the IPv6 packets with destination IPv6 address 55:44:77::/24.
[Sysname-flow-route-ipv6-route1] if-match destination-ipv6 55:44:77:: 24
# Configure Flowspec rule route1 to match the IPv6 packets with flow label value 6.
[Sysname-flow-route-ipv6-route1] if-match flow-label 6
Use interface to add an interface to the Flowspec interface group.
Use undo interface to remove an interface from the Flowspec interface group.
undo interface interface-type interface-number
A Flowspec interface group does not contain any interfaces.
An interface can belong to only one Flowspec interface group.
A Flowspec interface group can contain a maximum of 128 interfaces.
# Add Ten-GigabitEthernet 3/0/1 to Flowspec interface group 1.
[Sysname-flowspec-interface-group-1] interface ten-gigabitethernet 3/0/1
peer next-hop-invariable
Use peer next-hop-invariable to configure the device to not change the next hop of routes advertised to EBGP peers.
Use undo peer next-hop-invariable to restore the default.
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } next-hop-invariable
The device uses its IP address as the next hop of routes advertised to EBGP peers.
BGP IPv4 Flowspec address family view
BGP-VPN IPv4 Flowspec address family view
BGP VPNv4 Flowspec address family view
BGP IPv6 Flowspec address family view
BGP-VPN IPv6 Flowspec address family view
BGP VPNv6 Flowspec address family view
group-name: Specifies a peer group by its name, a case-sensitive string of 1 to 47 characters.
ipv4-address: Specifies a peer by its IPv4 address.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet in this command, the device does not change the next hop of routes advertised to all dynamic peers in the subnet.
ipv6-address: Specifies a peer by its IPv6 address.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet in this command, the device does not change the next hop of routes advertised to all dynamic peers in the subnet.
If you configure a redirection action in a Flowspec rule and also want to apply the redirection action on EBGP peers, configure this command. This command enables the device to use the next hop specified in the apply redirect command in routes advertised to EBGP peers.
# Configure the device to not change the next hop of routes advertised to peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-default-af-vpnv4] peer 1.1.1.1 next-hop-invariable
# Configure the device to not change the next hop of routes advertised to peer 1:1::1.
[Sysname] bgp 100
[Sysname-bgp-default] address-family ipv6 flowspec
[Sysname-bgp-default-af-ipv6-flowspec] peer 1:1::1 next-hop-invariable
peer redirect ip rfc-compatible
Use peer redirect ip rfc-compatible to configure the attribute ID for the redirection next hop in IPv4 Flowspec rules as the RFC-specified ID.
Use undo peer redirect ip rfc-compatible to restore the default.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } redirect ip rfc-compatible
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } redirect ip rfc-compatible
The attribute ID for the redirection next hop in static IPv4 Flowspec rules is 0x0800.
BGP-VPNv4 Flowspec address family view
BGP-VPNv6 Flowspec address family view
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a mask length, all dynamic peers in the subnet are specified.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a prefix length in this command, all dynamic peers in the subnet are specified.
Two attribute IDs for the redirection next hop exist: RFC 8956-specified 0x010C (for IPv4) and 0x000C (for IPv6) and IETF-specified 0x0800 (for both IPv4 and IPv6). To interoperate with a third-party device that does not support IETF-specified 0x0800, you can execute this command.
# Configure the attribute ID for the redirection next hop in IPv4 Flowspec rules as the RFC-specified 0x010C.
[Sysname] bgp 100
[Sysname-bgp-default] address-family ipv4 flowspec
[Sysname-bgp-default-flowspec-ipv4] peer 1.1.1.1 redirect ip rfc-compatible
peer redirect rt rfc-compatible
Use peer redirect rt rfc-compatible to configure the attribute ID for the redirection VPN target in IPv4 Flowspec rules as the RFC-specified 0x000D.
Use undo peer redirect rt rfc-compatible to restore the default.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } redirect rt rfc-compatible
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } redirect rt rfc-compatible
The attribute ID for the redirection VPN target in static IPv4 Flowspec rules is 0x800B.
Two attribute IDs for the redirection VPN target exist: RFC 8956-specified 0x000D and IETF-specified 0x800B. To interoperate with a third-party device that does not support IETF-specified 0x800B, you can execute this command.
# Configure the attribute ID for the redirection VPN target in IPv4 Flowspec rules as the RFC-specified 0x000D.
[Sysname] bgp 100
[Sysname-bgp-default-flowspec-ipv6] peer 10::1 redirect rt rfc-compatible
peer redirect-nexthop
Use peer redirect-nexthop to apply the action of redirecting to a next hop in Flowspec rules.
Use undo peer redirect-nexthop to disable the action of redirecting to a next hop in Flowspec rules.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } redirect-nexthop
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } redirect-nexthop
The action of redirecting to a next hop in Flowspec rules is applied.
# In BGP IPv4 Flowspec address family view, disable the action redirecting to a next hop in Flowspec rules received from peer group test.
[Sysname] bgp 100
[Sysname-bgp-default-flowspec-ipv4] undo peer test redirect-nexthop
peer reflect-client
Use peer reflect-client to configure the device as a route reflector and specify a peer or peer group as a client.
Use undo peer reflect-client to remove the configuration.
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } reflect-client
Neither the route reflector nor the client is configured.
group-name: Specifies a peer group by its name, a case-sensitive string of 1 to 47 characters. The peer group must have been created.
ipv4-address: Specifies a peer by its IPv4 address. The peer must have been created.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command configures the device as a route reflector and specifies all dynamic peers in the subnet as clients.
ipv6-address: Specifies a peer by its IPv6 address. The peer must have been created.
prefix-length: Specifies a prefix length in the range of 0 to 128. You can use the ipv6-address and prefix-length arguments together to specify a subnet. If you specify a subnet, this command configures the device as a route reflector and specifies all dynamic peers in the subnet as clients.
Using route reflectors can solve the issue brought by too many IBGP connections. In an AS, a router acts as a route reflector, and other routers act as clients connecting to the route reflector. The route reflector forwards the routing information received from a client to other clients. In this way, all clients can receive routing information from one another without establishing BGP sessions.
# In BGP IPv4 Flowspec address family view, configure the local device as a route reflector and specify IBGP peer group test as a client.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] peer test reflect-client
# In BGP IPv6 Flowspec address family view, configure the local device as a route reflector and specify IBGP peer group test as a client.
[Sysname] bgp 100
[Sysname-bgp-default-ipv6-flowspec] peer test reflect-client
reflect between-clients
reflector cluster-id
peer validation-disable
Use peer validation-disable to disable validation of Flowspec rules from BGP Flowspec peers.
Use undo peer validation-disable to enable this function.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } validation-disable
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } validation-disable
Flowspec rules from BGP Flowspec peers are validated.
group-name: Specifies an existing peer group by its name, a case-sensitive string of 1 to 47 characters.
ipv4-address: Specifies an existing peer by its IPv4 address.
mask-length: Specifies a mask length in the range of 0 to 32. If you specify a mask length, all dynamic peers in the subnet are specified.
ipv6-address: Specifies an existing peer by its IPv6 address.
prefix-length: Specifies a prefix length in the range of 0 to 128. If you specify a prefix length, all dynamic peers in the subnet are specified.
When the device receives a Flowspec rule with a destination IP address match criterion, it looks up the destination IP address in the routing table for the best unicast route. The validation succeeds if the following conditions exist:
·     The unicast route is a BGP route.
·     The sender of the BGP route is the same as the sender of the Flowspec rule.
If you want to use a destination IP address that cannot pass the validation as a match criterion, disable this function.
# In BGP IPv4 Flowspec address family view of the default BGP instance, disable validation of Flowspec rules from BGP Flowspec peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4-flowspec] peer 1.1.1.1 validation-disable
# In BGP IPv6 Flowspec address family view of the default BGP instance, disable validation of Flowspec rules from BGP Flowspec peer 1:1::1.
[Sysname] bgp 100
[Sysname-bgp-default-ipv6-flowspec] peer 1:1::1 validation disable
peer validation-redirect-disable
Use peer validation-redirect-disable to disable validation of the redirection next hops in Flowspec rules from BGP Flowspec peers.
Use undo peer validation-redirect-disable to enable this function.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } validation-redirect-disable
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } validation-redirect-disable
The redirection next hops in Flowspec rules from BGP Flowspec peers are validated.
When the device receives a Flowspec rule with a redirect-to-nexthop action, it looks up the next hop IP address in the routing table for the best unicast route. The validation succeeds if the following conditions exist:
·     The first AS number of the route is the same as the AS number of the BGP peer that sends the Flowspec rule.
To redirect packets to a next hop that cannot pass the validation, disable this function.
Only EBGP peers support this command.
# In BGP IPv4 Flowspec address family view, disable validation of the redirection next hops in Flowspec rules from BGP Flowspec peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4-flowspec] peer 1.1.1.1 validation-redirect-disable
# In BGP IPv6 Flowspec address family view, disable validation of the redirection next hops in Flowspec rules from BGP Flowspec peer 1:1::1.
[Sysname] bgp 100
[Sysname-bgp-default-ipv6-flowspec] peer 1:1::1 validation-redirect-disable
policy vpn-target
Use policy vpn-target to enable route target filtering of received VPN routes. The VPN routes whose export route target attribute matches the local import route target attribute are added to the routing table.
Use undo policy vpn-target to disable route target filtering, permitting all incoming VPN routes.
policy vpn-target
The route target filtering feature is enabled for received VPN routes.
To reflect all received VPN routes to clients without adding them to the routing table, execute the undo policy vpn-target command.
# Disable route target filtering of received VPNv4 routes.
[Sysname] bgp 100
[Sysname-bgp-default-vpnv4] undo policy vpn-target
redirect ip recursive-lookup tunnel
Use redirect ip recursive-lookup tunnel to enable recursion to tunnels for Flowspec rules with an action of redirecting to a next hop.
Use undo redirect ip recursive-lookup tunnel to restore the default.
redirect ip recursive-lookup tunnel [ tunnel-selector tunnel-selector-name ]
Recursion to tunnels is disabled for Flowspec rules with an action of redirecting to a next hop.
tunnel-selector tunnel-selector-name: Specifies a tunnel selector by its name, a case-sensitive string of 1 to 40 characters. If you do not specify a tunnel selector, the device uses the default tunnel selection order to select tunnels. For information about route recursion, see BGP configuration in Layer 3—IP Routing Configuration Guide. For information about tunnel selectors, see tunnel policy configuration in MPLS Configuration Guide.
# Enable recursion to tunnels for IPv4 Flowspec rules with an action of redirecting to a next hop.
[Sysname] bgp 200
[Sysname-bgp-default-flowspec-ipv4] redirect ip recursive-lookup tunnel tunnel-selector bgp
Use reflect between-clients to enable route reflection between clients.
Use undo reflect between-clients to disable route reflection between clients.
Route reflection between clients is enabled.
When a route reflector is configured, and the clients of a route reflector are fully meshed, route reflection is unnecessary because it consumes more bandwidth resources. You can use the undo reflect between-clients command to disable route reflection instead of modifying network configuration or changing network topology.
After route reflection is disabled between clients, routes can still be reflected between a client and a non-client.
# In BGP IPv4 Flowspec address family view, disable route reflection between clients.
[Sysname] bgp 100
[Sysname-bgp-default] address-family ipv4 unicast
[Sysname-bgp-default-ipv4] undo reflect between-clients
# In BGP IPv6 Flowspec address family view, disable route reflection between clients.
[Sysname] bgp 100
[Sysname-bgp-default-ipv6-flowspec] undo reflect between-clients
Use reflector cluster-id to configure the cluster ID for a route reflector.
Use undo reflector cluster-id to restore the default.
A route reflector uses its router ID as the cluster ID.
cluster-id: Specifies the cluster ID in the form of an integer, in the range of 1 to 4294967295.
ipv4-address: Specifies the cluster ID in the form of an IPv4 address in dotted decimal notation.
The route reflector and clients form a cluster. Typically a cluster has one route reflector. The ID of the route reflector is the cluster ID.
You can configure more than one route reflector in a cluster to improve network reliability and prevent a single point of failure. Use this command to configure the same cluster ID for all route reflectors in the cluster to avoid routing loops.
Do not configure the router ID of a client as the cluster ID.
# In BGP IPv4 Flowspec address family view, set the cluster ID on the local router (a reflector in the cluster) to 80.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] reflector cluster-id 80
# In BGP VPNv6 Flowspec address family view, set the cluster ID on the local router (a reflector in the cluster) to 80.
[Sysname] bgp 100
[Sysname-bgp-default] address-family vpnv6 flowspec
[Sysname-bgp-default-flowspec-vpnv6] reflector cluster-id 80
reset flowspec statistics
Use reset flowspec statistics to clear traffic statistics for a Flowspec rule.
reset flowspec statistics flow-route-id [ flow-interface-group group-id ]
flow-interface-group group-id: Specifies a Flowspec interface group by its ID in the range of 0 to 16383. If you do not specify a Flowspec interface group, this command clears traffic statistics for all Flowspec interface groups associated with a Flowspec rule.
# Clear traffic statistics for Flowspec rule 1.
<Sysname> reset flowspec statistics 1
route-distinguisher
Use route-distinguisher to configure a route distinguisher (RD).
Use undo route-distinguisher to restore the default.
No RD is configured.
VPN instance view
VPN instance IPv4 Flowspec family address view
VPN instance IPv6 Flowspec family address view
route-distinguisher: Specifies an RD, a string of 3 to 21 characters in one of the following formats:
·     16-bit AS number:32-bit user-defined number. For example, 101:3.
·     32-bit IP address:16-bit user-defined number. For example, 192.168.122.15:1.
·     32-bit AS number:16-bit user-defined number, where the minimum value of the AS number is 65536. For example, 65536:1.
RDs enable VPNs to use the same address space. An RD and an IPv4 prefix form a unique VPN-IPv4 prefix.
If you configure an RD for a VPN instance, all address families in the VPN instance must use the same RD as the VPN instance.
If you do not configure an RD for a VPN instance, address families in the VPN instance can use different RDs.
To configure an RD for a VPN instance, make sure either of the following conditions exists:
·     No RDs have been configured for address families in the VPN instance.
In this case, the RD of the VPN instance will be synchronized to all address families in the VPN instance.
·     All address families in the VPN instance use the same RD.
In this case, you must configure the same RD as the address families for the VPN instance.
When you remove the RD from an address family, the RD will also be removed from the VPN instance of the address family.
To guarantee global uniqueness for a VPN-IPv4 address, do not set the AS number or IP address in an RD to any private AS number or private IP address.
To modify an RD, execute the undo route-distinguisher command to remove the RD and then execute the route-distinguisher command to configure a new RD.
# Configure RD 22:1 for the IPv4 Flowspec family address of VPN instance vpn1.
[Sysname-vpn-instance-vpn1] address-family ipv4 flowspec
[Sysname-vpn-flowspec-ipv4-vpn1] route-distinguisher 22:1
route match-destination
Use route match-destination to use the destination address in Flowspec rules to match routing policies.
Use undo route match-destination to restore the default.
Route prefix 0.0.0.0/0 is used to match routing policies.
A Flowspec rule does not carry route prefix information. By default, the device uses the routing policy that matches the destination in a Flowspec rule to filter or modify the Flowspec rule. The device uses route prefix 0.0.0.0/0 to match the destination address in a routing policy for all Flowspec rules. Therefore, the device cannot perform accurate filtering and route attribute control on Flowspec rules.
Execute this command to use the destination address in a Flowspec rule as the route prefix to match routing policies. Therefore, you can flexibly filter or modify Flowspec rules.
This command must be used with the peer route-policy command, and a destination address match criterion must be configured in the routing policy.
# In BGP IPv4 Flowspec address family view, use the destination address in Flowspec rules to match routing policies.
[Sysname] bgp 100
[Sysname-bgp-default-flowspec-ipv4] undo route match-destination
if-match
peer route-policy (Layer 3—IP Routing Command Reference)
routing-table bgp-rib-only (Layer 3—IP Routing Command Reference)
route validation-mode include-as
Use route validation-mode include-as to validate destination address match criteria for only Flowspec rules that contain the AS_SET or AS_SEQ AS_Path attribute.
Use undo route validation-mode include-as to restore the default.
Destination address match criteria are validated for all Flowspec rules.
By default, a BGP peer validates destination address match criteria in all received Flowspec rules. When a BGP peer receives a Flowspec rule with a destination address match criterion, it looks up the routing table for an optimum unicast route. If the unicast route is a BGP route and the distributor is the same as the distributor of the Flowspec rule, the Flowspec rule passes validation. Then, the match criteria and actions in the Flowspec rule are applied. If the Flowspec rule fails validation, the BGP peer does not apply the match criteria and actions in the Flowspec rule.
This command allows a BGP peer to not validate the destination address match criteria in Flowspec rules with an AS_Path attribute other than the AS_SET and AS_SEQ types.
# In BGP IPv4 Flowspec address family view, validate destination address match criteria for only Flowspec rules that contain the AS_SET or AS_SEQ AS_Path attribute.
[Sysname] bgp 100
[Sysname-bgp-default-flowspec-ipv4] route validation-mode include-as
vpn-target
Use vpn-target to configure route targets for a VPN instance.
Use undo vpn-target to remove the specified or all route targets of a VPN instance.
No route targets are configured for a VPN instance.
VPN instance view
vpn-target&<1-8>: Specifies a space-separated list of up to eight route targets.
A route target is a string of 3 to 21 characters in one of the following formats:
·     32-bit AS number:16-bit user-defined number, where the AS number must not be less than 65536. For example, 65536:1.
both: Uses the specified route targets as both import targets and export targets. The both keyword is also used when you do not specify any of the following keywords: both, export-extcommunity, and import-extcommunity.
export-extcommunity: Uses the specified route targets as export targets.
import-extcommunity: Uses the specified route targets as import targets.
all: Removes all route targets.
MPLS L3VPN uses route targets to control the advertisement of VPN routing information. A PE adds the configured export targets into the route target attribute of routes advertised to a peer. The peer uses the local import targets to match the route targets of received routes. If a match is found, the peer adds the routes to the routing table of the VPN instance.
You can repeat the vpn-target command to configure multiple route targets.
Route targets configured in VPN instance view applies to both the IPv4 Flowspec family address and the IPv6 Flowspec family address of the VPN instance. Route targets configured in VPN instance IPv4 Flowspec family address view apply only to the IPv4 Flowspec family address of the VPN instance. Route targets configured in VPN instance IPv6 Flowspec family address view apply only to the IPv6 Flowspec family address of the VPN instance.
Route targets configured in VPN instance IPv4 Flowspec family address view have higher priority than route targets configured in VPN instance view. Route targets configured in VPN instance IPv6 Flowspec family address view have higher priority than route targets configured in VPN instance view.
# Configure route targets for VPN instance vpn1.
[Sysname-vpn-instance-vpn1] vpn-target 3:3 export-extcommunity
[Sysname-vpn-instance-vpn1] vpn-target 4:4 import-extcommunity
[Sysname-vpn-instance-vpn1] vpn-target 5:5 both
  • Become a Partner
  • Partner Resources
