H3C MSR600 Router Series Hardware Information and Specifications-6W101
HomeSupportRoutersMSR600 SeriesInstall & UpgradeInstallation GuidesH3C MSR600 Router Series Hardware Information and Specifications-6W101
01-Chassis Views and Technical Specifications
01-Chassis Views and Technical Specifications 100.43 KB
1 Chassis views
IMPORTANT
IMPORTANT:
The router provides a reset (RESET) button for rebooting the system and restoring the factory default settings. To reboot the router, press and hold the reset button for a short time. To reboot the router and restore the factory settings, press and hold the reset button for a minimum of 4 seconds.
H3C MSR600 router series has one model: MSR610.
The figures in this section are for illustration only.
Figure1-1 Front view
(1) Power adapter receptacle
(2) Gigabit Ethernet LAN ports (GE1 to GE4)
(3) Console port
(4) Gigabit fiber port (SFP5)
(5) Reset button (RESET)
(6) USB port
(7) Gigabit Ethernet WAN port (GE0)
Figure1-2 Rear view
(1) Grounding terminal
2 Technical specifications
Table2-1 Technical specifications
Item
MSR610
Console port
1
USB port
1
GE WAN port
1
GE SFP port
1
GE LAN port
4
Memory
1 GB DDR3
Flash
256 MB
Dimensions (H × W × D) (excluding rubber feet and mounting brackets)
44 × 210 × 140 mm (1.73 × 8.27 × 5.51 in)
Input voltage
100 VAC to 240 VAC @ 50 to 60 Hz
Rated power
8 W
Operating temperature
0°C to 45°C (32°F to 113°F)
Operating humidity
5% RH to 95% RH, noncondensing
3 Link mode of interfaces
Table3-1 Interfaces that support link mode change
Device model
Interfaces
MSR610
GE0 to GE4, SFP5
