H3C MSR600 Router Series Hardware Information and Specifications-6W101
HomeSupportRoutersMSR600 SeriesInstall & UpgradeInstallation GuidesH3C MSR600 Router Series Hardware Information and Specifications-6W101
02-LEDs
02-LEDs 79.24 KB
2 LEDs
LEDs
Figure2-1 LEDs on the front panel
(1) System status LED (SYS)
(2) GE copper port LEDs (GE1 to GE4)
(3) GE copper port LED (GE0)
(4) SFP fiber port LED
(5) CTRL LED
LED descriptions
Table2-1 LED descriptions
LED
Status
Steady green
The SDRAM is performing self-test.
Flashing green (8 Hz)
The system software image is being copied and decompressed.
Flashing green (1 Hz)
Comware has started with the configuration file and the router has booted up.
Flashing yellow (1 Hz)
The SDRAM has failed the self-test.
Flashing yellow (8 Hz)
The extended segment does not exist.
Steady yellow
The system software image does not exist.
Off
No power input, or exceptions have occurred.
GE copper port LED
Steady green
A 1000 Mbps link is present.
Flashing green
Data is being received or transmitted at 1000 Mbps.
Steady yellow
A 10/100 Mbps link is present.
Flashing yellow
Data is being received or transmitted at 10/100 Mbps.
Off
No link is present.
SFP fiber port LED
Steady green
Flashing green
Steady yellow
A 100 Mbps link is present.
Flashing yellow
Data is being received or transmitted at 100 Mbps.
Off
No link is present.
CTRL LED
Steady green
The router has established a WebSocket connection with the controller.
Off
No connection is established between the router and controller.
