H3C WX2860X Access Controllers Installation Guide-6W100
HomeSupportWirelessWX2800X Series Access ControllersInstall & UpgradeInstallation GuidesH3C WX2860X Access Controllers Installation Guide-6W100
06-Appendix B LEDs
06-Appendix B LEDs 72.03 KB
6 Appendix B  LEDs
LEDs
Figure6-1 LEDs
(1) 100/1000MBASE-T autosensing port LEDs
(2) 10GBASE-R-SFP+ autosensing port LEDs
(3) 2.5G/1000BASE-T autosensing port LED
(4) System status LED (SYS)
LED description
Table6-1 LED description
LED
Mark
Status
System status LED
SYS
Flashing green (4 Hz)
The system is starting up.
Flashing green (0.5 Hz)
The system is operating correctly.
Steady red
A critical alarm has occurred, such as a power supply alarm, fan tray alarm, high temperature alarm, or software missing alarm.
Off
The device has not started up.
100/1000BASE-T autosensing port LEDs
100/1000BASE-T
Steady green
A 1000 Mbps link is present on the port.
Flashing green
The port is receiving or transmitting data at 1000 Mbps.
Steady yellow
A 100 Mbps link is present on the port.
Flashing yellow
The port is receiving or transmitting data at 100 Mbps.
Off
No link is present on the port.
10GBASE-R-SFP+
Steady green
A 10 Gbps link is present on the port.
Flashing green
The port is receiving or transmitting data at 10 Gbps.
Steady yellow
A 1 Gbps link is present on the port.
Flashing yellow
The port is receiving or transmitting data at 1 Gbps.
Off
2.5G/1000 BASE-T
Steady green
A 2.5 Gbps link is present on the port.
Flashing green
The port is receiving or transmitting data at 2.5 Gbps.
Steady yellow
Flashing yellow
The port is receiving or transmitting data at 2.5 Mbps.
Off
