| 05-Appendix A Chassis views and technical specifications | 141.96 KB |
5 Appendix A Chassis views and technical specifications
Chassis views
(1) 100/1000BASE-T autosensing Ethernet ports 1 through 8 |
(2) 10GBASE-R-SFP+ ports 9 and 10 |
(3) 2.5G/1000BASE-T autosensing Ethernet ports 11 and 12 |
(4) USB port |
(5) Console port |
(6) Reset button (RESET) |
Figure5-2 Rear view
(1) AC-input power receptacle |
(2) Grounding screw |
Interface arrangement
The access controller provides fixed interfaces GigabitEthernet 1/0/1 through GigabitEthernet 1/0/8., Ten-GigabitEthernet1/0/9~Ten-GigabitEthernet1/0/10,Smartrate-Ethernet1/0/11~Smartrate-Ethernet1/0/12 You can identify an interface by its mark.
· GigabitEthernet 1/0/1 through GigabitEthernet 1/0/8—100/1000BASE-T autosensing Ethernet ports.
· GigabitEthernet 1/0/9 through GigabitEthernet 1/0/10—10GBASE-R-SFP+ ports.
· GigabitEthernet 1/0/11 through GigabitEthernet 1/0/12—2.5G/1000BASE-T autosensing Ethernet ports.
Technical specifications
Table5-1 Technical specifications
Item |
Specification |
Console port |
1, 9600 bps ( default ) to 115200bps |
USB port |
USB 2.0, used for data transfer |
GE port |
· 8 × 100/1000BASE-T autosensing Ethernet copper ports · 2× 2.5G/1000BASE-T autosensing Ethernet copper port |
SFP+ port |
2 × 10GBASE-R-SFP+ port |
· To restore the device to factory default settings, press and hold the button for more than 5 seconds after the device starts up normally. · To reset the device, press and hold the button for more than 15 ms. NOTE: During startup of the device, you can only use the reset button to reset the device. |
Memory |
2048MB DDR4 |
Storage media |
8GB eMMC memory |
Dimensions (H × W × D) (excluding the rubber feet and mounting brackets) |
43.6 × 250 × 440 mm (1.72× 9.84 × 17.32 in) |
AC power supply |
Rated voltage range: 100 to 240 VAC @ 50/60 Hz |
System power consumption |
12.1 W to 29.5 W |
Weight |
3.1 kg (6.83 lb) |
Operating temperature |
0°C to 45°C (32°F to 113°F) |
Operating humidity |
5% RH to 95% RH |
