- 01-Fundamentals Command Reference
- 01-CLI commands
- 02-RBAC commands
- 03-Login management commands
- 04-License management commands
- 05-Device management commands
- 06-FTP and TFTP commands
- 07-File system management commands
- 08-Configuration file management commands
- 09-Software upgrade commands
- 10-ISSU commands
- 11-Automatic configuration commands
- 12-Tcl commands
- 13-Python commands
11-Automatic configuration commands | 39.72 KB |
autodeploy udisk enable
Use autodeploy udisk enable to enable USB-based automatic configuration.
Use undo autodeploy udisk enable to disable USB-based automatic configuration.
The following compatibility matrixes show the support of hardware platforms for this command:
F1000 series |
Models |
Command compatibility |
F1000-X-G5 series |
F1000-A-G5, F1000-C-G5, F1000-C-G5-LI, F1000-E-G5, F1000-H-G5, F1000-S-G5 |
Yes |
F1000-X-G3 series |
F1000-A-G3, F1000-C-G3, F1000-E-G3, F1000-S-G3 |
Yes |
F1000-X-G2 series |
F1000-A-G2, F1000-C-G2, F1000-E-G2, F1000-S-G2 |
Yes |
F1000-9X0-AI series |
F1000-9390-AI, F1000-9385-AI, F1000-9380-AI, F1000-9370-AI, F1000-9360-AI, F1000-9350-AI, F1000-9330-AI, F1000-9320-AI, F1000-990-AI, F1000-980-AI, F1000-970-AI, F1000-960-AI, F1000-950-AI, F1000-930-AI, F1000-920-AI, F1000-910-AI, F1000-905-AI |
Yes |
F1000-C83X0 series |
F1000-C8395, F1000-C8390, F1000-C8385, F1000-C8380, F1000-C8370, F1000-C8360, F1000-C8350, F1000-C8330 |
Yes |
F1000-C81X0 series |
F1000-C8180, F1000-C8170, F1000-C8160, F1000-C8150, F1000-C8130, F1000-C8120, F1000-C8110 |
Yes |
F1000-7X0-HI series |
F1000-770-HI, F1000-750-HI, F1000-740-HI, F1000-730-HI, F1000-720-HI, F1000-710-HI |
Yes |
F1000-C-X series |
F1000-C-EI, F1000-C-HI, F1000-C-XI, F1000-E-XI |
Yes |
F1000-V series |
F1000-E-VG, F1000-S-VG |
Yes |
SecBlade IV |
LSPM6FWD8, LSQM2FWDSC8 |
No |
F100 series |
Models |
F100-X-G5 series |
F100-A-G5, F100-C-G5, F100-E-G5, F100-M-G5, F100-S-G5 |
Yes |
F100-X-G3 series |
F100-A-G3, F100-C-G3, F100-E-G3, F100-M-G3, F100-S-G3 |
Yes |
F100-X-G2 series |
F100-A-G2, F100-C-G2, F100-E-G2, F100-M-G2, F100-S-G2 |
Yes |
F100-WiNet series |
F100-A80-WiNet, F100-C80-WiNet, F100-C60-WiNet, F100-C50-WiNet, F100-S80-WiNet, F100-A91-WiNet, F100-A81-WiNet |
Yes |
F100-C-A series |
F100-C-A6, F100-C-A5, F100-C-A3, F100-C-A1, F100-C-A2, F100-C-A6-WL, F100-C-A5-W, F100-C-A3-W |
Yes |
F100-X-XI series |
F100-A-EI, F100-A-HI, F100-A-SI, F100-C-EI, F100-C-HI, F100-C-XI, F100-E-EI, F100-S-HI, F100-S-XI |
Yes |
USB-based automatic configuration is enabled.
context-admin
# Disable USB-based automatic configuration.
[Sysname] undo autodeploy udisk enable
