- 01-Fundamentals Command Reference
- 01-CLI commands
- 02-RBAC commands
- 03-Login management commands
- 04-License management commands
- 05-Device management commands
- 06-FTP and TFTP commands
- 07-File system management commands
- 08-Configuration file management commands
- 09-Software upgrade commands
- 10-ISSU commands
- 11-Automatic configuration commands
- 12-Tcl commands
- 13-Python commands
03-Login management commands | 298.55 KB |
ip https certificate access-control-policy
restful https ssl-server-policy
telnet server acl-deny-log enable
web https-authorization username
Some login management commands are available in both user line view and user line class view. For these commands, the device uses the following rules to determine the settings to be activated:
· A setting in user line view applies only to the user line. A setting in user line class view applies to all user lines of the class.
· A non-default setting in either view takes precedence over a default setting in the other view. A non-default setting in user line view takes precedence over a non-default setting in user line class view.
· A setting in user line class view takes effect on login sessions that are established after the setting is configured.
activation-key
Use activation-key to set the terminal session activation key. Pressing this shortcut key starts a terminal session.
Use undo activation-key to restore the default.
activation-key key-string
undo activation-key
The terminal session activation key is Enter.
User line view
User line class view
context-admin
key-string: Specifies a shortcut key. It can be a character (case sensitive), or an ASCII code value in the range of 0 to 127. For example, if you use activation-key 1, the shortcut key is Ctrl+A. If you use activation-key a, the shortcut key is a. For information about ASCII code values of individual characters, see the standard ASCII code chart. For information about ASCII code values of combined keys that use the Ctrl key, see Table 1.
This command is not supported in VTY line view or VTY line class view.
This command takes effect immediately.
This command is available in both user line view and user line class view. A non-default setting in either view takes precedence over a default setting in the other view. A non-default setting in user line view takes precedence over a non-default setting in user line class view.
You can use only the specified terminal session activation key to start a terminal session. To display the current terminal session activation key, use the display current-configuration | include activation-key command.
Table 1 ASCII code values for combined keys that use the Ctrl key
Combined key |
ASCII code value |
Ctrl+A |
1 |
Ctrl+B |
2 |
Ctrl+C |
3 |
Ctrl+D |
4 |
Ctrl+E |
5 |
Ctrl+F |
6 |
Ctrl+G |
7 |
Ctrl+H |
8 |
Ctrl+I |
9 |
Ctrl+J |
10 |
Ctrl+K |
11 |
Ctrl+L |
12 |
Ctrl+M |
13 |
Ctrl+N |
14 |
Ctrl+O |
15 |
Ctrl+P |
16 |
Ctrl+Q |
17 |
Ctrl+R |
18 |
Ctrl+S |
19 |
Ctrl+T |
20 |
Ctrl+U |
21 |
Ctrl+V |
22 |
Ctrl+W |
23 |
Ctrl+X |
24 |
Ctrl+Y |
25 |
Ctrl+Z |
26 |
# Configure character s as the terminal session activation key for console line 0.
[Sysname] line console 0
[Sysname-line-console0] activation-key s
To verify the configuration:
1. Exit the console session.
[Sysname-line-console0] return
<Sysname> quit
2. Log in again through the console line.
The following message appears:
Press ENTER to get started.
3. Press Enter.
Pressing Enter does not start a session.
4. Press s.
A terminal session is started.
<Sysname>
authentication-mode
Use authentication-mode to set the authentication mode for a user line.
Use undo authentication-mode to restore the default.
authentication-mode { none | password | scheme }
The authentication mode is scheme for the VTY and console lines.
User line view
context-admin
none: Disables authentication.
password: Performs local password authentication.
scheme: Performs AAA authentication. For more information about AAA, see Security Configuration Guide.
CAUTION: · When authentication is disabled, users can login without authentication. For security purpose, disable authentication with caution. · When you enable password authentication, you must also configure an authentication password for the line or line class. If no authentication password is configured, you cannot log in to the device through the line or line class at the next time. · When you enable scheme authentication, make sure an authentication user account is available. If no authentication user account is available, you cannot log in to the device through the line or line class at the next time. |
Only users assigned the network-admin, context-admin, or level-15 user role can execute this command. Other users cannot execute this command, even if they are granted the right to execute this command.
In VTY line view, this command is associated with the protocol inbound command.
· If the settings of the two commands in VTY line view are both the default settings, the settings for the commands in VTY line class view take effect.
· If the settings of the two commands in VTY line view are both non-default settings, the non-default settings in VTY line view take effect.
· If only one command has a non-default setting in VTY line view, the other command uses the default setting, regardless of the setting in VTY line class view.
An authentication mode change does not take effect on the current session. It takes effect on subsequent login sessions.
# Enable the none authentication mode for VTY line 0.
[Sysname] line vty 0
[Sysname-line-vty0] authentication-mode none
# Enable password authentication for VTY line 0 and set the password to hello12345.
[Sysname-line-vty0] authentication-mode password
[Sysname-line-vty0] set authentication password simple hello12345
# Enable scheme authentication for VTY line 0. Configure local user test and set the password to hello12345. Assign the Telnet service and the user role network-admin to the user.
[Sysname-line-vty0] authentication-mode scheme
[Sysname-line-vty0] quit
[Sysname] local-user test
[Sysname-luser-manage-test] password simple hello12345
[Sysname-luser-manage-test] authorization-attribute user-role network-admin
auto-execute command
Use auto-execute command to specify the command to be automatically executed for a login user.
Use undo auto-execute command to restore the default.
auto-execute command command
No command is specified to be automatically executed for a login user.
User line view
context-admin
command: Specifies the command to be automatically executed.
CAUTION: After using this command for a user line, you might be unable to access the CLI through the user line. Make sure you can access the CLI through a different user line before you use this command and save the configuration. |
The device will automatically execute the specified command when a user logs in through the user line, and close the user connection after the command is executed.
This command is not supported in console line view or console line class view.
A configuration change made by this command does not take effect on the current session. It takes effect on subsequent login sessions.
# Configure the device to automatically execute the telnet 192.168.1.41 command when a user logs in through VTY line 0.
[Sysname-line-vty0] auto-execute command telnet 192.168.1.41
This action will lead to configuration failure through line-vty0. Are you sure?
[Y/N]:y
[Sysname-line-vty0]
# To verify the configuration, Telnet to the device (192.168.1.40).
The device automatically Telnets to 192.168.1.41. The following output is displayed on the configuration terminal:
C:\> telnet 192.168.1.40
* Without the owner's prior written consent, *
* no decompiling or reverse-engineering shall be allowed. *
<Sysname>
Trying 192.168.1.41 ...
Press CTRL+K to abort
Connected to 192.168.1.41 ...
<Sysname.41>
This operation is the same as directly logging in to the device at 192.168.1.41 through Telnet. When you close the Telnet connection to 192.168.1.41, the Telnet connection to 192.168.1.40 is closed at the same time.
command accounting
Use command accounting to enable command accounting.
Use undo command accounting to disable command accounting.
command accounting
Command accounting is disabled. The accounting server does not record executed commands.
User line view
context-admin
When command accounting is enabled but command authorization is not, every executed command is recorded on the HWTACACS server. When both command accounting and command authorization are enabled, only authorized commands that are executed are recorded on the HWTACACS server.
Invalid commands are not recorded.
After you use the command accounting command in user line class view, you cannot use the undo command accounting command in any user line views in the class.
# Enable command accounting for VTY line 0.
[Sysname-line-vty0] command accounting
accounting command (Security Command Reference)
Use command authorization to enable command authorization.
Use undo command authorization to disable command authorization.
Command authorization is disabled. Logged-in users can execute commands without authorization.
User line view
context-admin
When command authorization is enabled, commands available for a user vary by the user's login authentication mode.
· If authentication is disabled or password authentication is enabled, command authorization does not take effect, and the user cannot use any commands.
· If scheme authentication is enabled, commands available for a user vary by the user's access authentication method.
¡ If local authentication is used, the device uses the user roles assigned to the user to perform command authorization.
¡ If remote authentication is used, the remote authorization server performs command authorization to determine whether a command entered by a login user is permitted. If remote authorization fails, the device uses the user roles of a local user with the same name as the login user to determine whether the command can be used. If the authorization also fails, the login user cannot use the command.
Command authorization configuration changes in user line class view do not take effect on the current session. The changes take effect only on subsequent login sessions. Command authorization configuration changes in user line view take effect immediately on all users that access the user line.
If you use the command authorization command in user line class view, command authorization is enabled for all user lines in the class. You cannot use the undo command authorization command in the view of a user line in the class.
# Enable command authorization for VTY line 0.
[Sysname-line-vty0] command authorization
authorization command (Security Command Reference)
command accounting
databits
Use databits to specify the number of data bits for a character.
Use undo databits to restore the default.
databits { | 7 | 8 }
undo databits
Eight data bits are used for a character.
User line view
context-admin
7: Uses seven data bits for a character.
8: Uses eight data bits for a character.
This command is not supported in VTY line class view.
This setting must be the same as the setting on the configuration terminal.
# Set the number of data bits for a character to 7.
[Sysname-line-console0] databits 7
display ip http
Use display ip http to display HTTP service configuration and status information.
display ip http
context-admin
context-operator
# Display HTTP service configuration and status information. In this example, a Layer 2 ACL is applied to the HTTP service.
<Sysname> display ip http
HTTP port: 80
ACL: 4444 (Layer 2)
Operation status: Enabled
# Display HTTP service configuration and status information. In this example, an IPv4 basic ACL and an IPv6 basic ACL are applied to the HTTP service.
HTTP port: 80
IPv4 ACL: 2222 (basic)
IPv6 ACL: 2333 (basic)
HTTP port |
HTTP service port number. |
ACL/IPv4 ACL/IPv6 ACL |
Number or name of the Layer 2, IPv4, or IPv6 ACL used to control HTTP access. If no ACL is used, this field displays 0. The ACL type is enclosed into a pair of parentheses. Available ACL types: · basic—Basic ACL. · advanced—Advanced ACL. · Layer 2—Layer 2 ACL. |
Operation status |
Whether the HTTP service is enabled. |
ip http acl
ip http enable
ip http port
display ip https
Use display ip https to display HTTPS service configuration and status information.
display ip https
context-admin
context-operator
# Display HTTPS service configuration and status information. In this example, a Layer 2 ACL is applied to the HTTPS service.
<Sysname> display ip https
HTTPS port: 443
SSL server policy: test
Certificate access-control-policy: Not configured
ACL: 4444 (layer 2)
# Display HTTPS service configuration and status information. In this example, an IPv4 basic ACL and an IPv6 basic ACL are applied to the HTTPS service.
HTTPS port: 443
HTTPS port |
HTTPS service port number. |
SSL server policy |
SSL server policy applied to the HTTPS service. If no SSL server policy is applied, this field displays Not configured. |
Certificate access-control-policy |
Certificate-based access control policy used to control client access rights. If no certificate-based access control policy is used, this field displays Not configured. |
Number or name of the Layer 2, IPv4, or IPv6 ACL used to control HTTPS access. If no ACL is used, this field displays 0. The ACL type is enclosed into a pair of parentheses. Available ACL types: · basic—Basic ACL. · advanced—Advanced ACL. · Layer 2—Layer 2 ACL. |
Operation status |
Whether the HTTPS service is enabled. |
ip https acl
ip https enable
ip https port
ip https ssl-server-policy
display line
Use display line to display user line information.
display line [ number1 | { console | vty } number2 ] [ summary ]
context-admin
context-operator
number1: Specifies the absolute number of a user line. To view the value range for this argument, enter a question mark (?) in the place of this argument.
console: Specifies the console line.
vty: Specifies the VTY line.
number2: Specifies the relative number of a user line. To view the value range for this argument, enter a question mark (?) in the place of this argument.
summary: Displays summary information about user lines. If you do not specify this keyword, the command displays detailed information.
# Display information about user line 0.
<Sysname> display line 0
Idx Type Tx/Rx Modem Auth Int Location
+ 0 CON 0 9600 - N - 1/0
+ : Line is active.
F : Line is active and in async mode.
Idx : Absolute index of line.
Type : Type and relative index of line.
Auth : Login authentication mode.
Int : Physical port of the line.
A : Authentication use AAA.
N : No authentication is required.
P : Password authentication.
Modem |
Whether the modem allows calling in or out. By default, this attribute is not configured and this field displays a hyphen (-). This field is not supported in the current software version. |
Int |
Physical port for the line. If there is no physical port for the line or the port is a console port, this field displays a hyphen (-). |
Location |
Physical position of the line, in the form of slot number/CPU number. |
# Display summary information about all user lines.
<Sysname> display line summary
Line type : [CON]
0:XX
Line type : [VTY]
2:UUUX XXXX XXXX XXXX
18:XXXX XXXX XXXX XXXX
34:XXXX XXXX XXXX XXXX
50:XXXX XXXX XXXX XXXX
3 lines used. (U)
63 lines not used. (X)
Table 5 Command output
Fields |
Type of the user line: · CON—Console line. · VTY—VTY line. |
number:status |
number: Absolute number of the first user line in the user line class. status: User line status. X is for unused and U is for used. |
display telnet client
Use display telnet client to display the packet source setting for the Telnet client.
context-admin
context-operator
This command displays the source IPv4 address or source interface specified for the Telnet client to use in outgoing Telnet packets, depending on the telnet client source command.
# Display the packet source setting for the Telnet client.
<Sysname> display telnet client
The source IP address is 1.1.1.1.
display user-interface
Use display user-interface to display user line information.
display user-interface [ number1 | { console | vty } number2 ] [ summary ]
context-admin
context-operator
summary: Displays summary information about user lines. If you do not specify this keyword, the detailed information is displayed.
This command is an older version reserved for backward compatibility purposes. It has the same functionality and output as the display line command. As a best practice, use the display line command.
<Sysname> display user-interface 0
+ : Line is active.
Table 6 Command output
Modem |
Int |
Location |
<Sysname> display user-interface summary
Line type : [CON]
0:XX
Line type : [VTY]
Table 7 Command output
Fields |
Line type |
number:status |
display users
Use display users to display online CLI users.
display users [ all ]
context-admin
context-operator
all: Displays all user lines supported by the device.
# Display online user information.
<Sysname> display users
Idx Line Idle Time Pid Type
+ 10 VTY 0 00:00:00 Jan 01 00:33:10 484 TEL
12 VTY 2 00:06:22 Jan 01 00:33:22 495 TEL
Following are more details.
VTY 0 :
VTY 2 :
+ : Current operation user.
F : Current operation user works in async mode.
Table 8 Command output
Idx |
Absolute number of the user line. |
Line |
Type and relative number of the user line. |
Idle |
Time elapsed after the user's most recent input, in the hh:mm:ss format. |
Time |
Login time of the user. |
Pid |
Process ID of the user session. |
Type |
User type: · TEL—Telnet user. · SSH—SSH user. · Switchto User—User who logged in by using the switchto context command. · For a user who logged in through the console port, this field does not display anything. |
User line you are using. |
User name |
Username used by the user. This field is displayed only if the user provided a username and password for authentication at login. |
Location |
IP address of the user. |
display web menu
Use display web menu to display Web interface navigation tree information.
display web menu [ chinese ]
context-admin
context-operator
chinese: Displays information about the Chinese Web interface navigation tree. If you do not specify this keyword, the command displays information about the English Web interface navigation tree.
This command displays all options on the Web interface navigation tree.
# Display Web interface navigation tree information.
<Sysname> display web menu
|--Dashboard: ID = dashboard
| |--Operation Monitor: ID = m_dashboard
| |--Traffic Monitor: ID = m_flowdetection
| |--Threat Monitor: ID = m_threatdetection
| |--Filtering Monitor: ID = m_urldetection
| |--LoadBalance Monitor: ID = m_loadbalancedash
| |--User-Defined Monitor: ID = m_definedboard
| `--Interface Information: ID = m_ifinfopanel
|--Monitor: ID = m_monitor
| |--Application Analysis Center: ID = m_cdas
| |--Security Logs: ID = m_atklog
| | |--Blacklist Logs: ID = m_blacklistlog
| | |--Single-Packet Attack Logs: ID = m_singleatk
| | |--Scanning Attack Logs: ID = m_scanatk
| | |--Flood Attack Logs: ID = m_floodatk
| | |--Threat Logs: ID = m_threatlog
| | |--URL Filtering Logs: ID = m_urllog
| | |--File Filtering Logs: ID = m_filefilterlog
| | |--Security Policy Logs: ID = m_zonepairlog
| | |--Sandbox Logs: ID = m_aptlog
| | |--NAT Logs: ID = m_natflowlog
| | |--SSL VPN User Access Logs: ID = m_sslvpnuserlog
---- More ----
display web users
Use display web users to display online Web users.
display web users
context-admin
context-operator
# Display online Web users.
<Sysname> display web users
UserID Name Type Language JobCount LoginTime LastOperation
AB2039483271293 Administrator HTTP Chinese 3 12:00:23 14:10:05
F09382BA2014AC8 user HTTPS English 1 13:05:00 14:11:00
Table 9 Command output
UserID |
ID used to uniquely identify the online Web user. |
JobCount |
Number of connections established by the user. |
escape-key
Use escape-key to set the escape key.
Use undo escape-key to disable the escape key.
escape-key { key-string | default }
undo escape-key
The escape key is Ctrl+C.
User line view
context-admin
key-string: Specifies a shortcut key. It can be a character (case sensitive, except for d and D), or an ASCII code value in the range of 0 to 127. For example, if you use escape-key 1, the shortcut key is Ctrl+A. If you use escape-key a, the shortcut key is a. If you specify the character d or D for this argument, the actual shortcut key is Ctrl+C. To use d or D as the shortcut key, you must specify the ASCII code value of the character for this argument. For information about ASCII code values of individual characters, see the standard ASCII code chart. For information about ASCII code values of combined keys that use the Ctrl key, see Table 1.
default: Restores the default escape key Ctrl+C.
You can press the escape key to abort a command that is being executed, for example, a ping or tracert command. Whether a command can be aborted by Ctrl+C by default depends on the software implementation of the command. For more information, see the usage guidelines for the command.
As a best practice, use a key sequence as the escape key. If you define a single character as the escape key, pressing the key while a command is being executed stops the command. If no command is being executed, pressing the key enters the character as a common character. If you Telnet from the device to a remote device, pressing the key enters the character as a common character on the remote device. The key acts as the escape key on the remote device only when the following conditions are met:
· You define the same character as the escape key on the remote device.
· You press the key while a command is being executed on the remote device.
The undo escape-key command disables the current escape key. After you execute this undo command, no escape key is available.
The setting in user line view takes effect immediately on the current session. The setting in user line class view takes effect on login sessions that are established after the setting is configured.
To display the current escape key, use the display current-configuration | include escape-key command.
# Configure character a as the escape key for VTY line 0.
[Sysname-line-vty0] escape-key a
1. Ping IP address 192.168.1.49, specifying the -c keyword to set the number of ICMP echo request packets to 20.
Ping 192.168.1.49 (192.168.1.49): 56 data bytes, press 'a' to break
56 bytes from 192.168.1.49: icmp_seq=0 ttl=255 time=1.000 ms
56 bytes from 192.168.1.49: icmp_seq=1 ttl=255 time=0.000 ms
2. Press a.
The system aborts the command and returns to user view.
--- Ping statistics for 192.168.1.49 ---
20 packet(s) transmitted, 20 packet(s) received, 0.0% packet loss
round-trip min/avg/max/std-dev = 0.000/0.200/1.000/0.400 ms
<Sysname>
flow-control
Use flow-control to configure the flow control mode.
Use undo flow-control to restore the default.
undo flow-control
Flow control is disabled.
User line view
context-admin
hardware: Performs hardware flow control.
none: Disables flow control.
software: Performs software flow control.
This command is not supported in VTY line view.
The device supports flow control in both the inbound and outbound directions.
· For flow control in the inbound direction, the local device listens to flow control information from the remote device.
· For flow control in the outbound direction, the local device sends flow control information to the remote device.
The flow control setting takes effect in both directions.
To communicate, two devices must operate in the same flow control mode.
# Configure software flow control in the inbound and outbound directions for console line 0.
[Sysname-line-console0] flow-control software
free line
Use free line to release a user line.
free line { number1 | { console | vty } number2 }
context-admin
This command does not release the line you are using.
# Release VTY line 1.
<Sysname> free line vty 1
Are you sure to free line vty1? [Y/N]:y
[OK]
free user-interface
Use free user-interface to release a user line.
free user-interface { number1 | { console | vty } number2 }
context-admin
This command is an older version reserved for backward compatibility purposes. It has the same functionality and output as the free line command. As a best practice, use the free line command.
<Sysname> free user-interface vty 1
[OK]
free web users
Use free web users to log off online Web users.
context-admin
all: Specifies all Web users.
user-id user-id: Specifies a Web user by the ID, a hexadecimal number of 15 digits. The system assigns each Web user a unique ID at login to identify the user.
user-name: Specifies a Web user by the username, a case-sensitive string of 1 to 255 characters.
# Log off all online Web users.
<Sysname> free web users all
display web users
history-command max-size
Use history-command max-size to set the size of the command history buffer for a user line.
Use undo history-command max-size to restore the default.
history-command max-size size-value
The command history buffer for a user line stores up to 10 history commands.
User line view
context-admin
size-value: Specifies the maximum number of history commands the buffer can store, in the range of 0 to 256.
Each user line uses a separate command history buffer to store commands successfully executed by its user. The buffer size determines how many history commands the buffer can store.
To display history commands in the buffer for your session, press the up or down arrow key, or execute the display history-command command. For more information about the command history buffer, see Fundamentals Configuration Guide.
Terminating a CLI session clears the commands in the command history buffer.
# Set the command history buffer size to 20 for VTY line 0.
[Sysname-line-vty0] history-command max-size 20
http method
Use http method to specify the HTTP methods to be added to the reply to an OPTIONS request.
Use undo http method to remove the HTTP methods to be added to the reply to an OPTIONS request.
undo http method { delete | get | head | options | post | put } *
No HTTP methods are specified.
context-admin
delete: Specifies the DELETE method.
get: Specifies the GET method.
head: Specifies the HEAD method.
options: Specifies the OPTIONS method.
post: Specifies the POST method.
put: Specifies the PUT method.
An HTTP client sends an OPTIONS request to the device to obtain the HTTP methods supported by the device. The device identifies whether the requested URL resources have a service that has registered for the OPTIONS method.
· If yes, the service responds to the OPTIONS request.
· If not, the device identifies whether the options keyword is specified for this command.
¡ If yes, the device uses the settings for this command to generate and return a reply to the OPTIONS request.
¡ If not, the device returns the 405 Method Not Allowed message.
This command does not affect HTTP requests except for OPTIONS requests.
# Specify GET, HEAD, POST, and OPTIONS methods as the HTTP methods to be added to the reply to an OPTIONS request.
[Sysname] http method get head post options
idle-timeout
Use idle-timeout to set the CLI connection idle-timeout timer.
Use undo idle-timeout to restore the default.
undo idle-timeout
The CLI connection idle-timeout timer is 10 minutes.
User line view
context-admin
minutes: Specifies the number of minutes, in the range of 0 to 35791.
seconds: Specifies the number of seconds, in the range of 0 to 59. The default is 0 seconds.
The system automatically terminates a user connection if no information interaction occurs on the connection within the idle-timeout interval.
To disable the idle-timeout feature, execute the idle-timeout 0 command.
# Set the CLI connection idle-timeout timer to 1 minute and 30 seconds for VTY line 0.
[Sysname-line-vty0] idle-timeout 1 30
ip http acl
Use ip http acl to apply an ACL to the HTTP service.
Use undo ip http acl to restore the default.
ip http acl [ ipv6 ] [ advanced ] { acl-number | name acl-name }
ip http acl mac { acl-number | name acl-name }
undo ip http acl [ ipv6 ]
undo ip http acl mac
No ACL is applied to the HTTP service.
context-admin
ipv6: Specifies an IPv6 ACL. If you do not specify this keyword, the command applies an IPv4 ACL to the HTTP service.
advanced: Specifies an advanced ACL. If you do not specify this keyword, the command applies a basic ACL to the HTTP service.
mac: Specifies a Layer 2 ACL.
acl-number: Specifies an ACL number in the range of 2000 to 4999.
· 2000 to 2999 for a basic ACL.
· 3000 to 3999 for an advanced ACL.
· 4000 to 4999 for a Layer 2 ACL.
name acl-name: Specifies an ACL by its name. The acl-name argument is a case-insensitive string of 1 to 63 characters. It must start with an English letter and to avoid confusion, it cannot be all. The specified ACL takes effect only when the ACL exists.
To specify an IPv4 basic ACL, do not specify the advanced or ipv6 keyword. To specify an IPv6 basic ACL, specify the ipv6 keyword without the advanced keyword.
In an advanced ACL applied to the HTTP service, only the following match criteria take effect:
· Source and destination IP addresses.
· Source and destination ports.
· Transport layer protocol.
In a Layer 2 ACL applied to the HTTP service, only the source MAC address match criterion takes effect.
When no ACL is applied to the HTTP service or the applied ACL does not exist or does not have rules, all clients can access the device through HTTP. To control HTTP access, specify an ACL that exists and has rules so only clients permitted by the ACL can access the device through HTTP.
You can apply one IPv4 basic ACL and one IPv6 basic ACL to the HTTP service, or apply one IPv4 advanced ACL and one IPv6 advanced ACL to the HTTP service. If you execute this command multiple times for the same type of ACLs, the most recent configuration takes effect.
If a VPN instance is specified in an ACL rule, the rule applies only to the packets of the VPN instance. If no VPN instance is specified in an ACL rule, the rule applies only to the packets on the public network.
For more information about ACLs, see ACL and QoS Configuration Guide.
# Use IPv4 basic ACL 2001 to allow only users from 10.10.0.0/16 to access the device through HTTP.
[Sysname] acl basic 2001
[Sysname-acl-ipv4-basic-2001] rule permit source 10.10.0.0 0.0.255.255
[Sysname] ip http acl 2001
acl (ACL and QoS Command Reference)
ip http enable
Use ip http enable to enable the HTTP service.
Use undo ip http enable to disable the HTTP service.
ip http enable
undo ip http enable
The HTTP service is disabled.
context-admin
To allow users to access the device through HTTP, you must enable the HTTP service.
To improve device security, the system automatically enables the HTTPS service when you enable the HTTP service. When the HTTP service is enabled, you cannot disable the HTTPS service.
# Enable the HTTP service.
[Sysname] ip http enable
ip https enable
ip http port
Use ip http port to specify the HTTP service port number.
Use undo ip http port to restore the default.
ip http port port-number
undo ip http port
The HTTP service port number is 80.
context-admin
port-number: Specifies a port number in the range of 1 to 65535.
When the HTTP service is enabled, changing the HTTP service port number re-enables the HTTP service and closes all HTTP connections. To log in again, users must enter the new URL in the Web browser's address bar.
# Set the HTTP service port number to 80.
[Sysname] ip http port 80
ip https acl
Use ip https acl to apply an ACL to the HTTPS service.
Use undo ip https acl to restore the default.
ip https acl [ ipv6 ] [ advanced ] {acl-number | name acl-name }
ip https acl mac { acl-number | name acl-name }
undo ip https acl [ ipv6 ]
undo ip https acl mac
No ACL is applied to the HTTPS service.
context-admin
ipv6: Specifies an IPv6 ACL. If you do not specify this keyword, the command applies an IPv4 ACL to the HTTPS service.
advanced: Specifies an advanced ACL. If you do not specify this keyword, the command applies a basic ACL to the HTTPS service.
In an advanced ACL applied to the HTTPS service, only the following match criteria take effect:
In a Layer 2 ACL applied to the HTTPS service, only the source MAC address match criterion takes effect.
When no ACL is applied to the HTTPS service or the applied ACL does not exist or does not have rules, all clients can access the device through HTTPS. To control HTTPS access, specify an ACL that exists and has rules so only clients permitted by the ACL can access the device through HTTPS.
Because the device always uses HTTPS to transfer Web login requests, the ACL applied to the HTTPS service controls both HTTPS and HTTP logins. To access the device, HTTP clients must be permitted by the following ACLs:
· ACL applied to the HTTP service.
· ACL applied to the HTTPS service.
You can apply one IPv4 basic ACL and one IPv6 basic ACL to the HTTPS service, or apply one IPv4 advanced ACL and one IPv6 advanced ACL to the HTTPS service. If you execute this command multiple times for the same type of ACLs, the most recent configuration takes effect.
# Use IPv4 basic ACL 2001 to allow only users from 10.10.0.0/16 to access the device through HTTPS or HTTP.
[Sysname] ip https acl 2001
Use ip https certificate access-control-policy to apply a certificate-based access control policy to control HTTPS access.
Use undo ip https certificate access-control-policy to restore the default.
No certificate-based access control policy is applied for HTTPS access control.
context-admin
policy-name: Specifies a certificate-based access control policy by its name, a case-sensitive string of 1 to 31 characters.
For more information about the certificate-based access control policy, see PKI configuration in Security Configuration Guide.
# Use certificate-based access control policy myacl to control HTTPS access.
[Sysname] ip https certificate access-control-policy myacl
pki certificate access-control-policy (Security Command Reference)
ip https enable
Use ip https enable to enable the HTTPS service.
Use undo ip https enable to disable the HTTPS service.
ip https enable
The HTTPS service is enabled.
context-admin
To allow users to access the device through HTTPS, you must enable the HTTPS service.
Enabling the HTTPS service triggers the SSL handshake negotiation process.
· If the device has a local certificate, the SSL handshake negotiation succeeds and the HTTPS service starts up.
· If the device does not have a local certificate, the certificate application process starts. Because the certificate application process takes a long time, the SSL handshake negotiation might fail and the HTTPS service might not be started. To solve the problem, execute this command again until the HTTPS service is enabled.
# Enable the HTTPS service.
[Sysname] ip https enable
ip https port
Use ip https port to specify the HTTPS service port number.
Use undo ip https port to restore the default.
ip https port port-number
undo ip https port
The HTTPS service port number is 443.
context-admin
When the HTTPS service is enabled, changing the HTTPS service port number re-enables the HTTPS service and closes all HTTPS and HTTP connections. To log in again, users must enter the new URL in the Web browser's address bar.
# Set the HTTPS service port number to 8080.
[Sysname] ip https port 8080
Use ip https ssl-server-policy to apply an SSL server policy to control HTTPS access.
Use undo ip https ssl-server-policy to restore the default.
No SSL server policy is applied. The HTTPS service uses a self-signed certificate.
context-admin
policy-name: Specifies an SSL server policy name, a string of 1 to 31 characters.
If the HTTP service and HTTPS service are enabled, changes to the applied SSL server policy do not take effect. For the changes to take effect, you must disable HTTP and HTTPS, and then apply the policy and enable HTTP and HTTPS again.
To restore the default, you must disable HTTP and HTTPS, execute the undo ip https ssl-server-policy command, and then enable HTTP and HTTPS again.
# Apply SSL server policy myssl to the HTTPS service.
[Sysname] ip https ssl-server-policy myssl
ssl server-policy (Security Command Reference)
line
Use line to enter one or multiple user line views.
line { first-number1 [ last-number1 ] | { console | vty } first-number2 [ last-number2 ] }
context-admin
first-number1: Specifies the absolute number of the first user line. To view the value range for this argument, enter a question mark (?) in the place of this argument.
last-number1: Specifies the absolute number of the last user line. To view the value range for this argument, enter a question mark (?) in the place of this argument. This number must be greater than first-number1.
first-number2: Specifies the relative number of the first user line. To view the value range for this argument, enter a question mark (?) in the place of this argument.
last-number2: Specifies the relative number of the last user line. To view the value range for this argument, enter a question mark (?) in the place of this argument. This number must be greater than first-number2.
# Enter the view of VTY line 0.
[Sysname-line-vty0]
# Enter the views of VTY lines 0 to 63.
[Sysname] line vty 0 63
[Sysname-line-vty0-63]
line class
line class
Use line class to enter user line class view.
line class { console | vty }
context-admin
console: Specifies the console line class view.
vty: Specifies the VTY line class view.
To configure the same settings for all user lines of a line class, use this command to enter the user line class view.
In user line class view, you can execute the following commands:
· activation-key
· auto-execute command
· authentication-mode
· command accounting
· command authorization
· escape-key
· history-command max-size
· idle-timeout
· protocol inbound
· screen-length
· set authentication password
· shell
· terminal type
· user-role
For commands that are available in both user line view and user line class view, the device uses the following rules to determine the settings to use:
· A setting in user line class view does not take effect on current online users. It takes effect only on new login users.
# Set the CLI connection idle-timeout timer to 15 minutes in VTY line class view.
[Sysname] line class vty
[Sysname-line-class-vty] idle-timeout 15
# In console line class view, configure the character s as the terminal session activation key.
[Sysname] line class console
[Sysname-line-class-console] activation-key s
[Sysname-line-class-console] quit
# In the view of console line 0, restore the default terminal session activation key.
[Sysname-line-console0] undo activation-key
Alternatively, you can use the following command:
[Sysname-line-console0] activation-key 13
1. Exit the session on console line 0.
<Sysname> quit
2. Log in again through the user line.
3. Press Enter.
4. Enter s.
<Sysname>
line
lock
Use lock to lock the current user line and set the password for unlocking the line.
lock
The system does not lock any user lines.
context-admin
This command locks the current user line to prevent unauthorized users from using the line. You must set the password for unlocking the line as prompted. The user line is locked after you enter the password and confirm the password.
To unlock the user line, press Enter and enter the password you set.
# Lock the current user line and set the password for unlocking the line.
<Sysname> lock
Please input password<1 to 16> to lock current line:
Password:
Again:
locked !
// The user line is locked. To unlock it, press Enter and enter the password:
Password:
<Sysname>
lock reauthentication
Use lock reauthentication to lock the current user line and enable unlocking authentication.
The system does not lock any user lines or initiate reauthentication.
context-admin
This command locks the current user line. To unlock the user line, you must press Enter and provide the login password to pass reauthentication. If you have changed the login password after login, you must provide the new password. If no login password is set, the system unlocks the user line after you press Enter.
# Lock the current user line and enable unlocking authentication.
<Sysname> lock reauthentication
Please press Enter to unlock the screen.
// The user line is locked. To unlock it, press Enter and enter the login password:
Password:
<Sysname>
lock-key
lock-key
Use lock-key to set the user line locking key. Pressing this shortcut key locks the current user line and enables unlocking authentication.
Use undo lock-key to restore the default.
lock-key key-string
undo lock-key
No user line locking key is set.
User line view
context-admin
key-string: Specifies a shortcut key. It can be a character (case sensitive), or an ASCII code value in the range of 0 to 127. For example, if you use lock-key 1, the shortcut key is Ctrl+A. If you use lock-key a, the shortcut key is a. For information about ASCII code values of individual characters, see the standard ASCII code chart. For information about ASCII code values of combined keys that use the Ctrl key, see Table 1.
As a best practice, specify a combined key as the user line locking key. If you specify a single character as the key, the character acts only as the user line locking key. You cannot type the character for any commands, keywords, or arguments.
Pressing the user line locking key is equivalent to executing the lock reauthentication command.
To display the current user line locking key, use the display current-configuration | include lock-key command.
# Set the user line locking key to Ctrl+A for VTY line 0.
[Sysname-line-vty0] lock-key 1
1. Press Ctrl+A.
[Sysname]
2. Press Enter and enter the login password.
Password:
[Sysname]
parity
Use parity to specify the parity.
Use undo parity to restore the default.
undo parity
The setting is none. No parity is used.
User line view
context-admin
even: Uses even parity.
mark: Uses mark parity.
none: Uses no parity.
odd: Uses odd parity.
space: Uses space parity.
The configuration terminal and the device must use the same parity.
# Configure console line 0 to use odd parity.
[Sysname-line-console0] parity odd
protocol inbound
Use protocol inbound to specify the supported protocols.
Use undo protocol inbound to restore the default.
protocol inbound { all| ssh | telnet }
All of the protocols are supported.
VTY line view
VTY line class view
context-admin
all: Supports both Telnet and SSH.
ssh: Supports SSH only.
telnet: Supports Telnet only.
A configuration change in user line view does not take effect on the current session. It takes effect on subsequent login sessions.
Before configuring a user line to support SSH, set the authentication mode to scheme for the user line.
In VTY line view, this command is associated with the authentication-mode command. If you specify a non-default value for one of the two commands, the other command uses the default setting, regardless of the setting in VTY line class view.
# Enable user lines VTY 0 through VTY 4 to support only SSH.
[Sysname] line vty 0 4
[Sysname-line-vty0-4] authentication-mode scheme
[Sysname-line-vty0-4] protocol inbound ssh
# Enable SSH support and set the authentication mode to scheme in VTY line class view. Enable user lines VTY 0 through VTY 4 to support all protocols and disable authentication for the user lines.
[Sysname-line-class-vty] authentication-mode scheme
[Sysname-line-class-vty] protocol inbound ssh
[Sysname-line-class-vty] line vty 0 4
[Sysname-line-vty0-4] authentication-mode none
1. Telnet to the device.
<Client> telnet 192.168.1.241
Trying 192.168.1.241 ...
Connected to 192.168.1.241 ...
<Server>
You are logged in without authentication.
2. Display online CLI user information.
<Server> display users
+ 50 VTY 0 00:00:00 Jan 17 15:29:27 189 TEL
VTY 0 :
The output shows that you are using VTY 0. The configuration in user line view is effective.
authentication-mode
restful http enable
Use restful http enable to enable RESTful access over HTTP.
Use undo restful http enable to disable RESTful access over HTTP.
restful http enable
RESTful access over HTTP is disabled.
context-admin
For users to access the device through the HTTP-based RESTful API, you must enable RESTful access over HTTP.
# Enable RESTful access over HTTP.
[Sysname] restful http enable
restful http port
Use restful http port to specify the service port number for RESTful access over HTTP.
Use undo restful http port to restore the default.
restful http port port-number
The service port number for RESTful access over HTTP is 80.
context-admin
When RESTful access over HTTP is enabled, changing the service port number re-enables the service and closes all RESTful access over HTTP connections. To log in again, users must use the new port number.
# Set the service port number to 1000 for RESTful access over HTTP.
[Sysname] restful http port 1000
restful https enable
Use restful https enable to enable RESTful access over HTTPS.
Use undo restful https enable to disable RESTful access over HTTPS.
RESTful access over HTTPS is disabled.
context-admin
For users to access the device through the HTTPS-based RESTful API, you must enable RESTful access over HTTPS.
# Enable RESTful access over HTTPS.
[Sysname] restful https enable
restful https port
Use restful https port to specify the service port number for RESTful access over HTTPS.
Use undo restful https port to restore the default.
restful https port port-number
The service port number for RESTful access over HTTPS is 443.
context-admin
When RESTful access over HTTPS is enabled, changing the service port number re-enables the service and closes all RESTful access over HTTPS connections. To log in again, users must use the new port number.
# Set the service port number to 1000 for RESTful access over HTTPS.
[Sysname] restful https port 1000
Use restful https ssl-server-policy to apply an SSL server policy to the RESTful access over HTTPS service.
Use undo restful https ssl-server-policy to restore the default.
restful https ssl-server-policy policy-name
No SSL server policy is applied to the RESTful access over HTTPS service.
context-admin
The RESTful access over HTTPS service will use the SSL server policy to enhance service security. For more information about SSL server policies, see SSL configuration in Security Configuration Guide.
You can use this command only when RESTful access over HTTPS is disabled.
This command takes effect after you enable RESTful access over HTTPS.
After the RESTful access over HTTPS service is enabled, changes to the applied SSL server policy take effect only on HTTPS connections established after the changes. These changes do not take effect on existing HTTPS connections.
# Apply SSL server policy myssl to the RESTful access over HTTPS service.
[Sysname] restful https ssl-server-policy myssl
screen-length
Use screen-length to set the maximum number of lines of command output to send to the terminal at a time when the screen pausing feature is enabled.
Use undo screen-length to restore the default.
screen-length screen-length
undo screen-length
A maximum of 24 lines are sent.
User line view
context-admin
screen-length: Specifies the maximum number of lines to send, in the range of 0 to 512. To send command output without pausing, set the number to 0 or execute the screen-length disable command.
The number of lines that can be displayed on the terminal screen is restricted by both this setting and the display specification of the terminal. For example, if this setting is 40, the device sends 40 lines to the terminal at a time. If the terminal display specification is 24 lines, only the last 24 lines are displayed on the terminal screen. To view the previous 16 lines, you must press PgUp.
To continue to display command output after a pause, press the space bar.
By default, pausing between screens of output is enabled.
# Set the maximum number of lines to send at a time to 30 for VTY line 0.
[Sysname-line-vty0] screen-length 30
send
Use send to send messages to online login users.
send { all | number1 | { console | vty } number2 }
context-admin
all: Specifies all user lines.
You can use this command to send notifications to online users before performing an operation that might affect other online users, for example, before rebooting the device.
To end a message, press Enter. To abort the send operation, press Ctrl+C.
# Send a notification to the user on VTY 1.
<Sysname> send vty 1
Input message, end with Enter; abort with CTRL+C:
Your attention, please. I will reboot the system in 3 minutes.
Send message? [Y/N]:y
The message should appear on the user's terminal screen as follows:
[Sysname]
***Message from vty0 to vty1
Use set authentication password to set the password for local password authentication.
Use undo set authentication password to restore the default.
set authentication password { hash | simple } string
No password is set for local password authentication.
User line view
context-admin
hash: Specifies a password in hashed form.
simple: Sets a password in plaintext form. For security purposes, the password specified in plaintext form will be stored in hashed form.
string: Specifies the password. Its plaintext form is a case-sensitive string of 4 to 16 characters and must contain a minimum of two character types. Its hashed form is a case-sensitive string of 1 to 110 characters.
A password change does not take effect on the current session. It takes effect on subsequent login sessions.
# Set the password to hello12345 for local password authentication on VTY line 0.
authentication-mode
shell
Use shell to enable the terminal service for user lines.
Use undo shell to disable the terminal service for user lines.
shell
undo shell
The terminal service is enabled on all user lines.
User line view
context-admin
The undo shell command is not supported in console line view or console line class view.
You cannot disable the terminal service on the user line you are using.
When the device acts as a Telnet or SSH server, you cannot use the undo shell command.
If the undo shell command is used in user line class view, you cannot use the shell command in the view of a user line in the class.
# Disable the terminal service for VTY lines VTY 0 through 4 so no user can log in to the device through the user lines.
[Sysname-line-vty0-4] undo shell
Disable ui-vty0-4 , are you sure? [Y/N]:y
speed
Use speed to set the transmission rate (also called the baud rate) on a user line.
Use undo speed to restore the default.
speed speed-value
undo speed
The transmission rate is 9600 bps on a user line.
User line view
context-admin
speed-value: Specifies the transmission rate in bps. Supported transmission rates depend on the network environment. The transmission rates for asynchronous serial interfaces might include:
· 300 bps.
· 600 bps.
· 1200 bps.
· 2400 bps.
· 4800 bps.
· 9600 bps.
· 19200 bps.
· 38400 bps.
· 57600 bps.
· 115200 bps.
The configuration terminal and the device must be configured with the same transmission rate to communicate.
# Set the transmission rate to 19200 bps for console line 0.
[Sysname-line-console0] speed 19200
stopbits
Use stopbits to specify the number of stop bits for a character.
Use undo stopbits to restore the default.
stopbits { 1 | 1.5 | 2 }
undo stopbits
One stop bit is used.
User line view
context-admin
1: Uses one stop bit.
1.5: Uses one and a half stop bits. The device does not support using one and a half stop bits. If you specify this keyword, two stop bits are used.
2: Uses two stop bits.
The configuration terminal and the device must use the same number of stop bits to communicate.
# Set the number of stop bits to 1 for console line 0.
[Sysname-line-console0] stopbits 1
telnet
Use telnet to Telnet to a host in an IPv4 network.
telnet remote-host [ service-port ] [ vpn-instance vpn-instance-name ] [ source { interface interface-type interface-number | ip ip-address } ] [ dscp dscp-value ] [ escape character ]
context-admin
remote-host: Specifies the IPv4 address or host name of a remote host. A host name can be a case-insensitive string of 1 to 253 characters. Valid characters include letters, digits, hyphens (-), underscores (_), and dots (.).
service-port: Specifies the TCP port number for the Telnet service on the remote host. The value range is 0 to 65535 and the default is 23.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the remote host belongs. The vpn-instance-name argument represents the VPN instance name, a case-sensitive string of 1 to 31 characters. If the remote host belongs to the public network, do not specify this option.
source: Specifies a source IPv4 address or source interface for outgoing Telnet packets. If you do not specify this option, the device uses the primary IPv4 address of the output interface for the route to the server as the source address.
interface interface-type interface-number: Specifies the source interface. The primary IPv4 address of the interface will be used as the source IPv4 address for outgoing Telnet packets.
ip ip-address: Specifies the source IPv4 address for outgoing Telnet packets.
dscp dscp-value: Specifies a DSCP value for outgoing Telnet packets. The value range is 0 to 63. The default is 48.
escape character: Specifies an escape character. You can use the escape character together with a dot (.) as the escape key to terminate the current Telnet connection and return to the upper level connection. The value for the character argument is case sensitive and must be different from the login username. As a best practice, specify a tilde (~) for the character argument.
Methods for terminating Telnet connections include:
· Pressing Ctrl+K—Terminates all Telnet connections. You can use this method in any scenarios unless you configure an escape character. After you configure an escape character, pressing Ctrl+K does not terminate Telnet connections.
· Executing the quit command—Terminates the current Telnet connection and returns to the upper level connection. This method is not available when the Telnet server reboots or fails.
· Using the escape key—Terminates the current Telnet connection and returns to the upper level connection. You can use this method in any scenarios.
To use the escape key to terminate the current Telnet connection, enter the escape character and a dot in a new line. If you enter any other characters or perform any other operations (for example, pressing the backspace key) before entering the escape character, the escape character does not take effect.
The source address or interface specified by this command is applied only to the Telnet connection that is being established.
# Telnet to host 1.1.1.2, using 1.1.1.1 as the source IP address for outgoing Telnet packets.
<Sysname> telnet 1.1.1.2 source ip 1.1.1.1
Use telnet client source to specify a source IPv4 address or source interface for the Telnet client to use for outgoing Telnet packets.
Use undo telnet client source to restore the default.
No source IPv4 address or source interface is specified. The Telnet client uses the primary IPv4 address of the output interface for the route to the server as the source IPv4 address.
context-admin
interface interface-type interface-number: Specifies a source interface. The primary IPv4 address of the interface will be used as the source IPv4 address for outgoing Telnet packets.
ip ip-address: Specifies a source IPv4 address.
The setting configured by this command applies to all Telnet connections but has a lower precedence than the source setting specified for the telnet command.
# Set the source IPv4 address to 1.1.1.1 for outgoing Telnet packets.
[Sysname] telnet client source ip 1.1.1.1
telnet ipv6
Use telnet ipv6 to Telnet to a host in an IPv6 network.
telnet ipv6 remote-host [ -i interface-type interface-number ] [ port-number ] [ vpn-instance vpn-instance-name ] [ source { interface interface-type interface-number | ipv6 ipv6-address } ] [ dscp dscp-value ] [ escape character ]
context-admin
remote-host: Specifies the IPv6 address or host name of a remote host. A host name can be a case-insensitive string of 1 to 253 characters. Valid characters include letters, digits, hyphens (-), underscores (_), and dots (.).
-i interface-type interface-number: Specifies the interface for sending Telnet packets. This option is required when the remote host address is a link-local address. When the server address is a global unicast address, you cannot specify this option.
port-number: Specifies the TCP port number for the Telnet service on the remote host. The value range is 0 to 65535 and the default is 23.
source: Specifies a source IPv6 address or source interface for outgoing Telnet packets. If you do not specify this option, the device uses the primary IPv6 address of the output interface for the route to the server as the source address.
interface interface-type interface-number: Specifies the source interface. The primary IPv6 address of the interface will be used as the source IPv6 address for outgoing Telnet packets.
ipv6 ipv6-address: Specifies the source IPv6 address for outgoing Telnet packets.
# Telnet to the host at 5000::1.
<Sysname> telnet ipv6 5000::1
# Telnet to the host at 2000::1. Use 1000::1 as the source address for outgoing Telnet packets.
<Sysname> telnet ipv6 2000::1 source ipv6 1000::1
telnet server acl
Use telnet server acl to apply an ACL to filter Telnet logins.
Use undo telnet server acl to restore the default.
telnet server acl [ mac ] acl-number
No ACL is used to filter Telnet logins.
context-admin
mac: Specifies a Layer 2 ACL. To specify an ACL of a different type, do not specify this keyword.
acl-number: Specifies an ACL by its number. If you specify the mac keyword, the value range of this argument is 4000 to 4999. If you do not specify the mac keyword, the value range of this argument is 2000 to 3999.
When no ACL is applied to the Telnet service, all users can Telnet to the device. To control Telnet logins, specify an ACL that exists and has rules so only users permitted by the ACL can Telnet to the device. If you specify an ACL that does not exist or does not have rules, no users can Telnet to the device.
This command does not take effect on existing Telnet connections.
# Permit only the user at 1.1.1.1 to Telnet to the device.
[Sysname] telnet server acl 2001
telnet server acl-deny-log enable
Use telnet server acl-deny-log enable to enable logging for Telnet login attempts that are denied by the Telnet login control ACL.
Use undo telnet server acl-deny-log enable to disable logging for Telnet login attempts that are denied by the Telnet login control ACL.
Logging is disabled for Telnet login attempts that are denied by the Telnet login control ACL.
context-admin
Only clients permitted by the Telnet login control ACL can Telnet to the device. This logging feature generates log messages for Telnet login attempts that are denied by the Telnet login control ACL.
For information about log message output, see the information center in Network Management and Monitoring Configuration Guide. For information about configuring a Telnet login control ACL, see the telnet server acl or telnet server ipv6 acl command.
# Enable logging for Telnet login attempts that are denied by the Telnet login control ACL.
[Sysname] telnet server acl-deny-log enable
telnet server acl
telnet server dscp
Use telnet server dscp to specify the DSCP value for IPv4 to use for Telnet packets sent to a Telnet client.
Use undo telnet server dscp to restore the default.
telnet server dscp dscp-value
IPv4 uses the DSCP value 48 for Telnet packets sent to a Telnet client.
context-admin
dscp-value: Specifies a DSCP value in the range of 0 to 63.
The DSCP value is carried in the ToS field of an IPv4 packet to indicate the packet transmission priority.
# Set the DSCP value for IPv4 to use for outgoing Telnet packets to 30 on a Telnet server.
[Sysname] telnet server dscp 30
telnet server enable
Use telnet server enable to enable the Telnet server.
Use undo telnet server enable to disable the Telnet server.
The Telnet server is disabled.
context-admin
Users can Telnet to the device only when the Telnet server is enabled.
# Enable the Telnet server.
Use telnet server ipv6 acl to apply an IPv6 ACL to filter IPv6 Telnet logins.
Use undo telnet server ipv6 acl to restore the default.
telnet server ipv6 acl { ipv6 | mac } acl-number
No IPv6 ACL is used to filter IPv6 Telnet logins.
context-admin
acl-number: Specifies an ACL by its number. If you specify the ipv6 keyword, the value range of this argument is 2000 to 3999. If you specify the mac keyword, the value range of this argument is 4000 to 4999.
# Permit only the user at 2000::1 to Telnet to the device.
[Sysname] acl ipv6 basic 2001
[Sysname-acl6-ipv6-basic-2001] rule permit source 2000::1 128
[Sysname-acl6-ipv6-basic-2001] quit
[Sysname] telnet server ipv6 acl ipv6 2001
telnet server ipv6 dscp
Use telnet server ipv6 dscp to specify the DSCP value for IPv6 to use for Telnet packets sent to a Telnet client.
Use undo telnet server ipv6 dscp to restore the default.
IPv6 uses the DSCP value 48 for Telnet packets sent to a Telnet client.
context-admin
The DSCP value is carried in the Traffic class field of an IPv6 packet to indicate the packet transmission priority.
# Set the DSCP value for IPv6 to use for outgoing Telnet packets to 30 on a Telnet server.
[Sysname] telnet server ipv6 dscp 30
telnet server ipv6 port
Use telnet server ipv6 port to specify the IPv6 Telnet service port number.
Use undo telnet server ipv6 port to restore the default.
The IPv6 Telnet service port number is 23.
context-admin
port-number: Specifies a port number. The value can be 23 or in the range of 1025 to 65535.
This command terminates all existing Telnet connections to the IPv6 Telnet server. To use the Telnet service, users must reestablish Telnet connections.
# Set the IPv6 Telnet service port number to 1026.
[Sysname] telnet server ipv6 port 1026
telnet server port
Use telnet server port to specify the IPv4 Telnet service port number.
Use undo telnet server port to restore the default.
The IPv4 Telnet service port number is 23.
context-admin
This command terminates all existing Telnet connections to the IPv4 Telnet server. To use the Telnet service, users must reestablish Telnet connections.
# Set the IPv4 Telnet service port number to 1025.
[Sysname] telnet server port 1025
terminal type
Use terminal type to specify the terminal display type.
Use undo terminal type to restore the default.
undo terminal type
The terminal display type is ANSI.
User line view
User line class view
context-admin
ansi: Specifies the ANSI type.
vt100: Specifies the VT100 type.
The device supports two terminal display types: ANSI and VT100. As a best practice, specify the VT100 type on both the device and the configuration terminal. If either side uses the ANSI type, a display problem might occur when a command line has more than 80 characters. For example, a cursor positioning error might occur.
This command is available in both user line view and user line class view. A non-default setting in either view takes precedence over a default setting in the other view. A non-default setting in user line view takes precedence over a non-default setting in user line class view.
A terminal display type change does not take effect on the current session. It takes effect on subsequent login sessions.
# Set the terminal display type to VT100.
[Sysname-line-vty0] terminal type vt100
user-interface
Use user-interface to enter one or multiple user line views.
user-interface { first-number1 [ last-number1 ] | { console | vty } first-number2 [ last-number2 ] }
context-admin
This command is an older version reserved for backward compatibility purposes. It has the same functionality and output as the line command. As a best practice, use the line command.
To configure settings for a single user line, use this command to enter the user line view.
To configure the same settings for multiple user lines, use this command to enter multiple user line views.
# Enter the view of console line 0.
[Sysname] user-interface console 0
# Enter the views of VTY lines 0 to 4.
[Sysname] user-interface vty 0 4
user-interface class
Use user-interface class to enter user line class view.
user-interface class { console | vty }
context-admin
This command is an older version reserved for backward compatibility purposes. It has the same functionality and output as the line class command. As a best practice, use the line class command.
To configure the same settings for all user lines of a line class, you can use this command to enter the user line class view.
The following commands are available in user line class view:
· activation-key
· escape-key
· idle-timeout
· protocol inbound
· screen-length
· shell
· terminal type
· user-role
· A setting in user line view applies only to the user line. A setting in user line class view applies to all user lines of the class.
· A non-default setting in either view takes precedence over a default setting in the other view. A non-default setting in user line view takes precedence over a non-default setting in user line class view.
[Sysname] user-interface class vty
# In console line class view, configure character s as the terminal session activation key.
[Sysname] user-interface class console
To verify the configuration:
[Sysname-line-console0] return
<Sysname> quit
2. Log in again through the console line.
The following message appears:
Press ENTER to get started.
3. Press Enter.
Pressing Enter does not start a session.
4. Enter s.
A terminal session is started.
<Sysname>
user-interface
user-role
Use user-role to assign a user role to a user line. The device assigns the user role to a user of the line when the user logs in.
Use undo user-role to remove a user role or restore the default.
user-role role-name
undo user-role [ role-name ]
A console user of the default context is assigned the network-admin user role. Other users on the default context are assigned the network-operator user role. A user on a non-default context is assigned the context-operator user role.
User line view
context-admin
role-name: Specifies a user role name, a case-sensitive string of 1 to 63 characters. The user role can be user-defined or predefined. Available predefined user roles include network-admin, network-operator, context-admin, context-operator,and level-0 to level-15. The predefined security-audit and guest-manager user roles are not supported in user line view or user line class view. If you do not specify this argument, the undo user-role command restores the default user roles.
Only users assigned the network-admin, context-admin, or level-15 user role can execute this command. Other users cannot execute this command, even if they are granted the right to execute this command.
A user role change does not take effect on the current session. It takes effect on subsequent login sessions.
You can assign up to 64 user roles to a user line.
For more information about user roles, see RBAC configuration in Fundamentals Configuration Guide.
# Assign user role network-admin to VTY line 0 to 63.
[Sysname-line-vty0-63] user-role network-admin
web captcha
Use web captcha to specify a fixed verification code for Web login.
Use undo web captcha to restore the default.
web captcha verification-code
undo web captcha
No fixed verification code is specified for Web login. A Web user must enter the verification code displayed on the login page.
context-admin
verification-code: Specifies the fixed verification code, a case-sensitive 4-character string.
In test environments where a script is used for Web function tests, you can configure a fixed verification code to improve test efficiency.
For Web access security purposes, do not use this feature in production environments.
If you execute the web captcha command multiple times, the most recent configuration takes effect.
This command is not saved to the configuration file and will not take effect after a reboot.
# Set the fixed verification code to test for Web login.
<Sysname> web captcha test
web https-authorization mode
Use web https-authorization mode to set the authentication and authorization mode for HTTPS login.
Use undo web https-authorization mode to restore the default.
web https-authorization mode { auto | certificate | certificate-manual | manual }
Manual mode is used for HTTPS login authentication and authorization.
context-admin
auto: Requires the user to provide a username and password or a certificate for authentication and authorization
certificate: Requires the user to provide a certificate for authentication and authorization.
certificate-manual: Requires the user to provide a username and password as well as a certificate for authentication and authorization.
manual: Requires the user to provide a username and password for authentication and authorization.
For a user to use a certificate for HTTPS login authentication and authorization, perform the following tasks:
· Apply an SSL server policy to the HTTPS service and enable client authentication in the policy so the SSL server performs certificate-based authentication.
· Specify the certificate field to be used as the username for certificate-based authentication, and create a local user that uses the same username.
During HTTPS connection establishment, a user must select the correct certificate.
# Set the HTTPS login authentication and authorization mode to certificate.
[Sysname] web https-authorization mode certificate
web https-authorization username
Use web https-authorization username to specify the certificate field to be used as the username for certificate-based authentication.
Use undo web https-authorization username to restore the default.
web https-authorization username { cn | email-prefix | oid oid-value }
The CN field in the certificate is used as the username for certificate-based authentication.
context-admin
cn: Uses the CN field in the certificate as the username.
email-prefix: Uses the string before the @ sign in the emailAddress field of the certificate as the username.
oid oid-value: Uses the field corresponding to an OID as the username. The oid-value argument is a dotted decimal string of 1 to 255 characters.
This command is required when the authentication and authorization mode for HTTPS login is certificate or auto.
# Specify the field corresponding to an OID as the username for certificate-based authentication.
[Sysname] web https-authorization username oid 1.2.840.113549.1.9.1
web idle-timeout
Use web idle-timeout to set the Web connection idle-timeout timer.
Use undo web idle-timeout to restore the default.
web idle-timeout idle-time
The Web connection idle-timeout timer is 10 minutes.
context-admin
idle-time: Specifies the Web connection idle-timeout timer in minutes. The value range is 1 to 999.
The system automatically terminates a Web user connection if no mouse or keyboard operation occurs within the idle-timeout interval.
This command takes effect immediately on current Web connections.
# Set the Web connection idle-timeout timer to 100 minutes.
[Sysname] web idle-timeout 100
