- 03-Layer 2—LAN Switching Command Reference
- 01-Ethernet interface commands
- 02-Loopback, null, and inloopback interface commands
- 03-Bulk interface commands
- 04-MAC address table commands
- 05-Ethernet link aggregation commands
- 06-DRNI commands
- 07-Port isolation commands
- 08-VLAN commands
- 09-MVRP commands
- 10-QinQ commands
- 11-VLAN mapping commands
- 12-Loop detection commands
- 13-Spanning tree commands
- 14-LLDP commands
- 15-L2PT commands
- 16-PPP commands
- 17-Service loopback group commands
| 00-Preface | 99.99 KB |
Preface
This command reference describes configuration commands for Layer 2—LAN switching features.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
