05-Layer 3—IP Routing Configuration Guide
HomeSupportResource CenterSwitchesS12500X-AF SeriesS12500X-AF SeriesTechnical DocumentsConfigure & DeployConfiguration GuidesH3C S12500X-AF Switch Series Configuration Guides(R28xx)-6W10005-Layer 3—IP Routing Configuration Guide
05-IS-IS configuration
05-IS-IS configuration 926.90 KB
Configuring IS-IS·· 1
About IS-IS· 1
Terminology· 1
IS-IS address· 1
NET· 2
IS-IS area· 3
IS-IS topology· 3
Route leaking· 4
IS-IS network types· 4
DIS and pseudonodes· 4
IS-IS PDUs· 5
IPv6 IS-IS· 7
Protocols and standards· 7
IPv4 IS-IS tasks at a glance· 8
IPv6 IS-IS tasks at a glance· 10
Configuring basic IS-IS· 11
Enabling IPv4 IS-IS· 11
Enabling IPv6 IS-IS· 12
Setting the IS level and circuit level 12
Configuring P2P network type for an interface· 13
Configuring IPv6 IS-IS MTR· 14
Configuring IS-IS route control 15
Configuring IS-IS link cost 15
Enabling IS-IS to advertise the maximum link cost to neighbors· 17
Specifying a preference for IS-IS· 18
Configuring the maximum number of ECMP routes· 18
Configuring IS-IS route summarization· 19
Advertising a default route· 20
Configuring IS-IS route redistribution· 20
Filtering routes calculated from received LSPs· 22
Filtering redistributed routes· 22
Configuring IS-IS route leaking· 23
Advertising IS-IS link state information to BGP· 24
Configuring the IPv6 IS-IS link tag feature· 24
Configuring IS-IS timers· 25
Specifying the interval for sending IS-IS hello packets· 25
Specifying the interval for sending IS-IS CSNP packets· 26
Setting the maximum age of LSPs· 26
Setting the LSP refresh interval and generation interval 26
Setting LSP sending intervals· 27
Setting the SPF calculation interval 28
Configuring IS-IS packet-related features· 29
Configuring a DIS priority for an interface· 29
Configuring the tag value for an interface· 29
Specifying the IS-IS hello multiplier 30
Disabling an interface from sending/receiving IS-IS packets· 30
Enabling an interface to send small hello packets· 30
Setting LSP lengths· 31
Enabling LSP flash flooding· 31
Enabling LSP fragment extension· 32
Limiting LSP flooding· 32
Configuring advanced IS-IS features· 33
Enabling source address check for hello packets on a P2P interface· 33
Configuring convergence priorities for specific routes· 33
Setting the LSDB overload bit 34
Configuring IS-IS isolation· 35
Configuring the ATT bit 35
Configuring system ID to host name mappings· 36
Configuring IS-IS logging and SNMP notifications· 38
Enabling the logging of neighbor state changes· 38
Configuring IS-IS network management 38
Configuring IS-IS fast convergence· 39
Enabling ISPF· 39
Enabling prefix suppression· 39
Configuring IS-IS PIC· 40
Enhancing IS-IS network security· 41
Configuring neighbor relationship authentication· 41
Configuring area authentication· 42
Configuring routing domain authentication· 42
Enhancing IS-IS network reliability· 43
Configuring IS-IS GR· 43
Configuring IS-IS NSR· 44
Configuring BFD for IS-IS· 45
Configuring IS-IS FRR· 45
Display and maintenance commands for IS-IS· 49
Displaying and maintaining IPv4 IS-IS· 49
Displaying and maintaining IPv6 IS-IS· 51
IS-IS configuration examples· 52
Example: Configuring basic IS-IS· 52
Example: Configuring DIS election· 57
Example: Configuring IS-IS route redistribution· 61
Example: Configuring IS-IS authentication· 64
Example: Configuring IS-IS GR· 67
Example: Configuring IS-IS NSR· 68
Example: Configuring BFD for IS-IS· 71
Example: Configuring IS-IS FRR· 74
IPv6 IS-IS configuration examples· 77
Example: Configuring IPv6 IS-IS basics· 77
Example: Configuring BFD for IPv6 IS-IS· 81
Example: Configuring IPv6 IS-IS FRR· 84
Configuring IS-IS
About IS-IS
IS-IS is an IGP used within an AS. It uses the SPF algorithm for route calculation.
Terminology
·     Intermediate system—Similar to a router in TCP/IP, IS is the basic unit used in an IS-IS routing domain to generate and propagate routing information. Throughout this chapter, an IS refers to a router.
·     End system—Similar to a host in TCP/IP, an ES does not run IS-IS. ISO defines the ES-IS protocol for communication between an ES and an IS.
·     Routing domain—An RD comprises a group of ISs that exchange routing information with each other by using the same routing protocol.
·     Area—An IS-IS routing domain can be split into multiple areas.
·     Link State Database—All link states in the network form the LSDB. Each IS has a minimum of one LSDB. An IS uses the SPF algorithm and LSDB to generate IS-IS routes.
·     Link State Protocol Data Unit or Link State Packet—An IS advertises link state information in an LSP.
·     Network Protocol Data Unit—An NPDU is a network layer protocol packet in OSI, similar to an IP packet in TCP/IP.
·     Designated IS—A DIS is elected on a broadcast network.
·     Network service access point—An NSAP is an OSI network layer address. The NSAP identifies an abstract network service access point and describes the network address format in the OSI reference model.
IS-IS address
As shown in Figure 1, an NSAP address comprises the Initial Domain Part (IDP) and the Domain Specific Part (DSP). The IDP is analogous to the network ID of an IP address, and the DSP is analogous to the subnet and host ID.
The IDP includes the Authority and Format Identifier (AFI) and the Initial Domain Identifier (IDI).
The DSP includes:
·     High Order Part of DSP (HO-DSP)—Identifies the area.
·     System ID—Identifies the host.
·     SEL—Also known as the N-SEL or the NSAP selector (SEL). It is similar to the protocol identifier in IP and is used to identify the type of service. Different transport layer protocols correspond to different SELs.
The IDP and DSP are variable in length. The length of an NSAP address is in the range of 8 to 20 bytes.
Figure 1 NSAP address format
An IS-IS address contains the following components:
·     Area address
The area address comprises the IDP and the HO-DSP of the DSP, which identify the area and the routing domain. Different routing domains cannot have the same area address.
Typically, a router only needs one area address, and all nodes in the same area must have the same area address. To support smooth area merging, partitioning, and switching, a router can have a maximum of three area addresses.
·     System ID
A system ID uniquely identifies a host or router. It has a fixed length of 48 bits (6 bytes).
The system ID of a device can be generated from the router ID. For example, suppose a router uses the IP address 168.10.1.1 of Loopback 0 as the router ID. The system ID can be obtained in the following steps:
a.     Extend each decimal number of the IP address to three digits by adding 0s from the left, such as 168.010.001.001.
b.     Divide the extended IP address into three sections that each has four digits to get the system ID 1680.1000.1001.
If you use other methods to define a system ID, make sure that it can uniquely identify the host or router.
·     SEL
An SEL is used to identify the type of service. Different transport layer protocols correspond to different SELs. It has a fixed length of 8 bits. All SELs in IP are 00.
NET
A network entity title (NET) identifies the network layer information of an IS. It does not include transport layer information. A NET is a special NSAP address with the SEL being 0. The length of a NET is in the range of 8 to 20 bytes, same as a NSAP address.
A NET includes the following parts:
·     Area ID—Has a length of 1 to 13 bytes.
·     System ID—A system ID uniquely identifies a host or router in the area and has a fixed length of 6 bytes.
·     SEL—Has a value of 0 and a fixed length of 1 byte.
For example, for a NET ab.cdef.1234.5678.9abc.00, the area ID is ab.cdef, the system ID is 1234.5678.9abc, and the SEL is 00.
Typically, a router only needs one NET, but it can have a maximum of three NETs for smooth area merging and partitioning. When you configure multiple NETs, make sure the system IDs are the same.
IS-IS area
IS-IS has a 2-level hierarchy to support large-scale networks. A large-scale routing domain is divided into multiple areas. Typically, a Level-1 router is deployed within an area. A Level-2 router is deployed between areas. A Level-1-2 router is deployed between Level-1 and Level-2 routers.
Level-1 router
A Level-1 router establishes neighbor relationships with Level-1 and Level-1-2 routers in the same area. It maintains an LSDB comprising intra-area routing information. A Level-1 router forwards packets destined for external areas to the nearest Level-1-2 router. Level-1 routers in different areas cannot establish neighbor relationships.
Level-2 router
A Level-2 router establishes neighbor relationships with Level-2 and Level-1-2 routers in the same area or in different areas. It maintains a Level-2 LSDB containing inter-area routing information. All the Level-2 and Level-1-2 routers must be contiguous to form the backbone of the IS-IS routing domain. Level-2 routers can establish neighbor relationships even if they are in different areas.
Level-1-2 router
A router with both Level-1 and Level-2 router functions is a Level-1-2 router. It can establish Level-1 neighbor relationships with Level-1 and Level-1-2 routers in the same area. It can establish Level-2 neighbor relationships with Level-2 and Level-1-2 routers in different areas. A Level-1 router can reach other areas only through a Level-1-2 router. The Level-1-2 router maintains two LSDBs, a Level-1 LSDB for intra-area routing and a Level-2 LSDB for inter-area routing.
IS-IS topology
Figure 2 shows one IS-IS network topology. Area 1 is the backbone that comprises a set of Level-2 routers. The other four areas are non-backbone areas connected to the backbone through Level-1-2 routers.
Figure 2 IS-IS topology 1
Figure 3 shows another IS-IS topology. No area is defined as the backbone in this topology. The backbone comprises all contiguous Level-2 and Level-1-2 routers in different areas. The IS-IS backbone does not need to be a specific area.
Figure 3 IS-IS topology 2
Both the Level-1 and Level-2 routers use the SPF algorithm to generate the shortest path tree.
Route leaking
Level-2 and Level-1-2 routers form a Level-2 area. An IS-IS routing domain comprises only one Level-2 area and multiple Level-1 areas. A Level-1 area must connect to the Level-1-2 area rather than another Level-1 area.
Level-1-2 routers send the routing information of Level-1 areas to the Level-2 area. Level-2 routers know the routing information of the entire IS-IS routing domain. By default, a Level-2 router does not advertise the routing information of other areas to a Level-1 area. A Level-1 router simply sends packets destined for other areas to the nearest Level-1-2 router. The path passing through the Level-1-2 router might not be the best. To solve this problem, IS-IS provides the route leaking feature.
Route leaking enables a Level-1-2 router to advertise the routes of other areas to the connected Level-1 area so that the Level-1 routers can select the optimal routes.
IS-IS network types
IS-IS supports broadcast networks (for example, Ethernet and Token Ring) and point-to-point networks (for example, PPP and HDLC).
IS-IS cannot run on P2MP links.
DIS and pseudonodes
IS-IS routers on a broadcast network must elect a DIS.
The Level-1 and Level-2 DISs are elected separately. You can assign different priorities to a router for different level DIS elections. The higher the router priority, the more likely the router becomes the DIS. If multiple routers with the same highest DIS priority exist, the one with the highest Subnetwork Point of Attachment (SNPA) address will be elected. On a broadcast network, the SNPA address is the MAC address. A router can be the DIS for different levels.
IS-IS DIS election differs from OSPF DIS election in the following ways:
·     A router with priority 0 can also participate in the DIS election.
·     When a router with a higher priority is added to the network, an LSP flooding process is performed to elect the router as the new DIS.
As shown in Figure 4, the same level routers on a network, including non-DIS routers, establish adjacency with each other.
Figure 4 DIS in the IS-IS broadcast network
The DIS creates and updates pseudonodes, and generates LSPs for the pseudonodes, to describe all routers on the network.
A pseudonode represents a virtual node on the broadcast network. It is not a real router. In IS-IS, it is identified by the system ID of the DIS and a 1-byte Circuit ID (a non-zero value).
Using pseudonodes simplifies network topology and can reduce the amount of resources consumed by SPF.
On an IS-IS broadcast network, all routers establish adjacency relationships, but they synchronize their LSDBs through the DIS.
IS-IS PDUs
PDU
IS-IS PDUs are encapsulated into link layer frames. An IS-IS PDU has two parts, the headers and the variable length fields. The headers comprise the PDU common header and the PDU specific header. All PDUs have the same PDU common header. The specific headers vary by PDU type.
Figure 5 PDU format
Table 1 PDU types
PDU Type
Acronym
15
Level-1 LAN IS-IS hello PDU
L1 LAN IIH
16
Level-2 LAN IS-IS hello PDU
L2 LAN IIH
17
Point-to-Point IS-IS hello PDU
P2P IIH
18
Level-1 Link State PDU
L1 LSP
20
Level-2 Link State PDU
L2 LSP
24
Level-1 Complete Sequence Numbers PDU
L1 CSNP
25
Level-2 Complete Sequence Numbers PDU
L2 CSNP
26
Level-1 Partial Sequence Numbers PDU
L1 PSNP
27
Level-2 Partial Sequence Numbers PDU
L2 PSNP
Hello PDU
IS-to-IS hello (IIH) PDUs are used by routers to establish and maintain neighbor relationships. On broadcast networks, Level-1 routers use Level-1 LAN IIHs, and Level-2 routers use Level-2 LAN IIHs. The P2P IIHs are used on point-to-point networks.
LSP
The LSPs carry link state information. LSPs include Level-1 LSPs and Level-2 LSPs. The Level-2 LSPs are sent by the Level-2 routers, and the Level-1 LSPs are sent by the Level-1 routers. The Level-1-2 router can send both types of LSPs.
SNP
A sequence number PDU (SNP) describes the complete or partial LSPs for LSDB synchronization.
SNPs include CSNP and PSNP, which are further divided into Level-1 CSNP, Level-2 CSNP, Level-1 PSNP, and Level-2 PSNP.
A CSNP describes the summary of all LSPs for LSDB synchronization between neighboring routers. On broadcast networks, CSNPs are sent by the DIS periodically (every 10 seconds by default). On point-to-point networks, CSNPs are sent only during the first adjacency establishment.
A PSNP only contains the sequence numbers of one or multiple latest received LSPs. It can acknowledge multiple LSPs at one time. When LSDBs are not synchronized, a PSNP is used to request missing LSPs from a neighbor.
CLV
The variable fields of PDU comprise multiple Code-Length-Value (CLV) triplets.
Figure 6 CLV format
Table 2 shows that different PDUs contain different CLVs. Codes 1 through 10 are defined in ISO 10589 (code 3 and 5 are not shown in the table). Codes 128 through 132 are defined in RFC 1195. Codes 222 through 237 are defined in RFC 5120.
Table 2 CLV codes and PDU types
CLV Code
Name
PDU Type
1
Area Addresses
IIH, LSP
2
IS Neighbors (LSP)
LSP
4
Partition Designated Level 2 IS
L2 LSP
6
IS Neighbors (MAC Address)
LAN IIH
7
IS Neighbors (SNPA Address)
LAN IIH
8
Padding
IIH
9
LSP Entries
SNP
10
Authentication Information
IIH, LSP, SNP
128
IP Internal Reachability Information
LSP
129
Protocols Supported
IIH, LSP
130
IP External Reachability Information
L2 LSP
131
Inter-Domain Routing Protocol Information
L2 LSP
132
IP Interface Address
IIH, LSP
222
MT-ISN
LSP
229
M-Topologies
IIH, LSP
235
MT IP. Reach
LSP
237
MT IPv6 IP. Reach
LSP
IPv6 IS-IS
IS-IS supports multiple network protocols, including IPv6. To support IPv6, the IETF added two type-length-values (TLVs) and a new network layer protocol identifier (NLPID).
The TLVs are as follows:
·     IPv6 Reachability—Contains routing prefix and metric information to describe network reachability and has a type value of 236 (0xEC).
·     IPv6 Interface Address—Same as the "IP Interface Address" TLV in IPv4 ISIS, except that the 32-bit IPv4 address is translated to the 128-bit IPv6 address.
The new NLPID is an 8-bit field that identifies which network layer protocol is supported. For IPv6, the NLPID is 142 (0x8E).
·     ISO 8348, Ad2 Network Services Access Points
·     ISO 9542, ES-IS Routing Protocol
·     ISO 10589, ISO IS-IS Routing Protocol
·     RFC 1195, Use of OSI IS-IS for Routing in TCP/IP and Dual Environments
·     RFC 2973, IS-IS Mesh Groups
·     RFC 3277, IS-IS Transient Blackhole Avoidance
·     RFC 3358, Optional Checksums in ISIS
·     RFC 3359, Reserved Type, Length and Value (TLV) Codepoints in Intermediate System to Intermediate System
·     RFC 3563, Cooperative Agreement Between the ISOC/IETF and ISO/IEC Joint Technical Committee 1/Sub Committee 6 (JTC1/SC6) on IS-IS Routing Protocol Development
·     RFC 3719, Recommendations for Interoperable Networks using Intermediate System to Intermediate System (IS-IS)
·     RFC 3787, Recommendations for Interoperable IP Networks using Intermediate System to Intermediate System (IS-IS)
·     RFC 4444, Management Information Base for Intermediate System to Intermediate System (IS-IS)
·     RFC 4972, Routing Extensions for Discovery of Multiprotocol (MPLS) Label Switch Router (LSR) Traffic Engineering (TE) Mesh Membership
·     RFC 5029, Definition of an IS-IS Link Attribute Sub-TLV
·     RFC 5089, IS-IS Protocol Extensions for Path Computation Element (PCE) Discovery
·     RFC 5120, Multi Topology (MT) Routing in Intermediate System to Intermediate Systems (IS-ISs)
·     RFC 5130, A Policy Control Mechanism in IS-IS Using Administrative Tags
·     RFC 5301, Dynamic Hostname Exchange Mechanism for IS-IS
·     RFC 5302, Domain-Wide Prefix Distribution with Two-Level IS-IS
·     RFC 5303, Three-Way Handshake for IS-IS Point-to-Point Adjacencies
·     RFC 5304, IS-IS Cryptographic Authentication
·     RFC 5305, IS-IS Extensions for Traffic Engineering
·     RFC 5306, Restart Signaling for IS-IS
·     RFC 5308, Routing IPv6 with IS-IS
·     RFC 5310, IS-IS Generic Cryptographic Authentication
·     RFC 5311, Simplified Extension of Link State PDU (LSP) Space for IS-IS
·     RFC 6165, Extensions to IS-IS for Layer-2 Systems
·     RFC 6213, IS-IS BFD-Enabled TLV
·     RFC 6232, Purge Originator Identification TLV for IS-IS
·     RFC 6233, IS-IS Registry Extension for Purges
·     RFC 6329, IS-IS Extensions Supporting IEEE 802.1aq Shortest Path Bridging
·     RFC 6571, Loop-Free Alternate (LFA) Applicability in Service Provider (SP) Networks
·     RFC 6823, Advertising Generic Information in IS-IS
·     RFC 7142, OSI IS-IS Intra-domain Routing Protocol
·     RFC 7356, IS-IS Flooding Scope Link State PDUs (LSPs)
·     RFC 7370, Updates to the IS-IS TLV Codepoints Registry
·     RFC 7602, IS-IS Extended Sequence Number TLV
·     RFC 7645, The Keying and Authentication for Routing Protocol (KARP) IS-IS Security Analysis
·     RFC 7775, IS-IS Route Preference for Extended IP and IPv6 Reachability
·     RFC 7794, IS-IS Prefix Attributes for Extended IPv4 and IPv6 Reachability
·     RFC 7810, IS-IS Traffic Engineering (TE) Metric Extensions
·     RFC 7813, IS-IS Path Control and Reservation
·     RFC 7917, Advertising Node Administrative Tags in IS-IS
·     RFC 7981, IS-IS Extensions for Advertising Router Information
·     RFC 7987, IS-IS Minimum Remaining Lifetime
To configure IPv4 IS-IS, perform the following tasks:
1.     Configuring basic IS-IS
a.     Enabling IPv4 IS-IS
b.     (Optional.) Setting the IS level and circuit level
c.     (Optional.) Configuring P2P network type for an interface
2.     (Optional.) Configuring IS-IS route control
¡     Configuring IS-IS link cost
¡     Enabling IS-IS to advertise the maximum link cost to neighbors
¡     Specifying a preference for IS-IS
¡     Configuring the maximum number of ECMP routes
¡     Configuring IS-IS route summarization
¡     Advertising a default route
¡     Configuring IS-IS route redistribution
¡     Filtering routes calculated from received LSPs
¡     Filtering redistributed routes
¡     Configuring IS-IS route leaking
¡     Advertising IS-IS link state information to BGP
3.     (Optional.) Configuring IS-IS timers
¡     Specifying the interval for sending IS-IS hello packets
¡     Specifying the interval for sending IS-IS CSNP packets
¡     Setting the maximum age of LSPs
¡     Setting the LSP refresh interval and generation interval
¡     Setting LSP sending intervals
¡     Setting the SPF calculation interval
4.     (Optional.) Configuring IS-IS packet-related features
¡     Configuring a DIS priority for an interface
¡     Configuring the tag value for an interface
¡     Specifying the IS-IS hello multiplier
¡     Disabling an interface from sending/receiving IS-IS packets
¡     Enabling an interface to send small hello packets
¡     Setting LSP lengths
¡     Enabling LSP flash flooding
¡     Enabling LSP fragment extension
5.     (Optional.) Limiting LSP flooding
6.     (Optional.) Configuring advanced IS-IS features
¡     Enabling source address check for hello packets on a P2P interface
¡     Configuring convergence priorities for specific routes
¡     Setting the LSDB overload bit
¡     Configuring IS-IS isolation
¡     Configuring the ATT bit
¡     Configuring system ID to host name mappings
7.     (Optional.) Configuring IS-IS logging and SNMP notifications
¡     Enabling the logging of neighbor state changes
¡     Configuring IS-IS network management
8.     (Optional.) Configuring IS-IS fast convergence
¡     Enabling ISPF
¡     Enabling prefix suppression
¡     Configuring IS-IS PIC
9.     (Optional.) Enhancing IS-IS network security
¡     Configuring neighbor relationship authentication
¡     Configuring area authentication
¡     Configuring routing domain authentication
10.     (Optional.) Enhancing IS-IS network reliability
¡     Configuring IS-IS GR
¡     Configuring IS-IS NSR
¡     Configuring BFD for IS-IS
¡     Configuring IS-IS FRR
To configure IPv6 IS-IS, perform the following tasks:
a.     Enabling IPv6 IS-IS
2.     (Optional.) Configuring IPv6 IS-IS MTR
3.     (Optional.) Configuring IS-IS route control
¡     Configuring the IPv6 IS-IS link tag feature
4.     (Optional.) Configuring IS-IS timers
5.     (Optional.) Configuring IS-IS packet-related features
6.     (Optional.) Limiting LSP flooding
7.     (Optional.) Configuring advanced IS-IS features
8.     (Optional.) Configuring IS-IS logging and SNMP notifications
9.     (Optional.) Configuring IS-IS fast convergence
¡     Enabling ISPF
10.     (Optional.) Enhancing IS-IS network security
11.     (Optional.) Enhancing IS-IS network reliability
Enabling IPv4 IS-IS
2.     Enable IS-IS and enter IS-IS view.
By default, IS-IS is disabled.
3.     Assign a NET.
network-entity net
By default, NET is not assigned.
CAUTION
CAUTION:
When you execute the network-entity command together with the cost-style and is-level commands for the same IS-IS process, execute the network-entity command at last. Incorrect configuration order might cause data loss because the IS-IS process will restart.
4.     Return to system view.
5.     Enter interface view.
6.     Enable IS-IS on the interface.
isis enable [ process-id ]
Enabling IPv6 IS-IS
2.     Enable an IS-IS process and enter IS-IS view.
By default, no IS-IS process is enabled.
3.     Configure the NET for the IS-IS process.
network-entity net
By default, the NET is not configured.
CAUTION
CAUTION:
4.     Create the IPv6 address family and enter its view.
5.     Return to IS-IS view.
6.     Return to system view.
7.     Enter interface view.
8.     Enable IPv6 for IS-IS on the interface.
isis ipv6 enable [ process-id ]
By default, IPv6 is disabled for IS-IS on an interface.
Follow these guidelines when you configure the IS level for routers in only one area:
·     Set the IS level of all routers to Level-1 or Level-2 rather than different levels because the routers do not need to maintain two identical LSDBs.
·     Set the IS level to Level-2 on all routers in an IP network for good scalability.
For an interface of a Level-1 or Level-2 router, the circuit level can only be Level-1 or Level-2. For an interface of a Level-1-2 router, the default circuit level is Level-1-2. If the router only needs to form Level-1 or Level-2 neighbor relationships, set the circuit level for its interfaces to Level-1 or Level-2. This will limit neighbor relationship establishment.
2.     Enter IS-IS view.
3.     Specify the IS level.
is-level { level-1 | level-1-2 | level-2 }
By default, the IS level is Level-1-2.
6.     Specify the circuit level.
isis circuit-level [ level-1 | level-1-2 | level-2 ]
By default, an interface can establish either the Level-1 or Level-2 adjacency.
Interfaces with different network types operate differently. For example, broadcast interfaces on a network must elect the DIS and flood CSNP packets to synchronize the LSDBs. However, P2P interfaces on a network do not need to elect the DIS, and have a different LSDB synchronization mechanism.
If only two routers exist on a broadcast network, set the network type of attached interfaces to P2P. This avoids DIS election and CSNP flooding, saving network bandwidth and speeding up network convergence.
2.     Enter interface view.
3.     Configure P2P network type for an interface.
isis circuit-type p2p
By default, the network type of a VLAN interface is broadcast.
Perform this task only for a broadcast network that has up to two attached routers.
On a network, IPv4 and IPv6 topologies must be consistent so that both IPv6 IS-IS and IPv4 IS-IS can use the SPF algorithm to perform route calculation. If they are different, routers supporting both IPv4 and IPv6 might send IPv6 packets to routers that do not support IPv6, resulting in packet loss.
To resolve this issue, configure IPv6 IS-IS MTR to perform route calculation separately in IPv4 and IPv6 topologies.
Figure 7 Network diagram
As shown in Figure 7, the numbers refer to the link costs. Router A, Router B, and Router D support both IPv4 and IPv6. Router C supports only IPv4 and cannot forward IPv6 packets.
Enable IPv6 IS-IS MTR on Router A, Router B, Router C, and Router D to make them perform route calculation separately in IPv4 and IPv6 topologies. With this configuration, Router A does not forward IPv6 packets destined to Router D through Router B, avoiding packet loss.
As a best practice to avoid route calculation failures, configure this feature when both IPv4 and IPv6 topologies exist in the network.
3.     Specify an IS-IS cost style.
cost-style { compatible | wide | wide-compatible }
By default, IS-IS only transmits and receives packets using the narrow cost style.
4.     Enter IPv6 address family view.
5.     Enable IPv6 IS-IS MTR.
multi-topology [ compatible ]
By default, IPv6 IS-IS MTR is disabled.
The IS-IS cost of an interface is determined in the following order:
1.     IS-IS cost specified in interface view.
2.     IS-IS cost specified in system view.
The cost is applied to the interfaces associated with the IS-IS process.
3.     Automatically calculated cost.
If the cost style is wide or wide-compatible, IS-IS automatically calculates the cost using the formula: Interface cost = (Bandwidth reference value / Expected interface bandwidth) × 10, in the range of 1 to 16777214. For other cost styles, Table 3 applies.
Configure the expected bandwidth of an interface with the bandwidth command.
Table 3 Automatic cost calculation scheme for cost styles other than wide and wide-compatible
Interface bandwidth
Interface cost
≤ 10 Mbps
60
≤ 100 Mbps
50
≤ 155 Mbps
40
≤ 622 Mbps
30
≤ 2500 Mbps
20
> 2500 Mbps
10
4.     If none of the above costs is used, a default cost of 10 applies.
Configuring an IPv4 IS-IS cost for an interface
3.     (Optional.) Specify an IS-IS cost style.
By default, the IS-IS cost type is narrow.
6.     Specify a cost for the IS-IS interface.
isis cost cost-value [ level-1 | level-2 ]
By default, no cost for the interface is specified.
Configuring a global IPv4 IS-IS cost
3.     Specify a global IS-IS cost.
circuit-cost cost-value [ level-1 | level-2 ]
By default, no global cost is specified.
Enabling automatic IPv4 IS-IS cost calculation
3.     Enable automatic IS-IS cost calculation.
auto-cost enable
By default, automatic IS-IS cost calculation is disabled.
4.     (Optional.) Configure a bandwidth reference value for automatic IS-IS cost calculation.
bandwidth-reference value
The default setting is 100 Mbps.
Configuring an IPv6 IS-IS cost for an interface
9.     Specify an IPv6 cost for the IS-IS interface.
isis ipv6 cost cost-value [ level-1 | level-2 ]
By default, no IPv6 cost is specified for the interface.
Configuring a global IPv6 IS-IS cost
3.     Enter IPv6 address family view.
4.     Specify a global IPv6 IS-IS cost.
By default, no global IPv6 cost is specified.
Enabling automatic IPv6 IS-IS cost calculation
cost-style { wide | wide-compatible }
By default, the IS-IS cost style is narrow.
5.     Enable automatic IPv6 IS-IS cost calculation.
auto-cost enable
By default, automatic IPv6 IS-IS cost calculation is disabled.
6.     (Optional.) Configure a bandwidth reference value for automatic IPv6 IS-IS cost calculation.
By default, the bandwidth reference value is 100 Mbps.
On an IS-IS network, when a link recovers from failures or the state of an interface changes, IS-IS will re-establish neighbor relationships and perform route convergence. During the route convergence process, routing loops and traffic loss might occur because the convergence speeds of the nodes are different. To address this issue, enable IS-IS to advertise the maximum link cost to neighbors within the specified period, so the traffic forwarding path remains unchanged. After the specified period, IS-IS advertises the original link cost to neighbors and performs optimal route selection again.
3.     Enable IS-IS to advertise the maximum link cost to neighbors within the specified period.
isis peer hold-max-cost duration time
By default, IS-IS does not advertise the maximum link cost to neighbors during a route convergence.
If multiple routing protocols find routes to the same destination, the route found by the routing protocol that has the highest preference is selected as the optimal route.
Perform this task to assign a preference to IS-IS directly or by using a routing policy. For more information about the routing policy, see "Configuring routing policies."
Configuring a preference for IPv4 IS-IS
2.     Enter IS-IS IPv4 unicast address family view.
3.     Configure a preference for IPv4 IS-IS.
The default setting is 15.
Configuring a preference for IPv6 IS-IS
3.     Enter IS-IS IPv6 address family view.
4.     Configure a preference for IPv6 IS-IS.
preference { route-policy route-policy-name | preference } *
Perform this task to implement load sharing over ECMP routes.
Configuring the maximum number of ECMP routes for IPv4 IS-IS
3.     Specify the maximum number of ECMP routes.
maximum load-balancing number
By default, the maximum number of ECMP routes supported by IPv4 IS-IS equals the maximum number of ECMP routes supported by the system.
Configuring the maximum number of ECMP routes for IPv6 IS-IS
4.     Specify the maximum number of ECMP routes.
By default, the maximum number of ECMP routes supported by IPv6 IS-IS equals the maximum number of ECMP routes supported by the system.
Perform this task to summarize specific routes, including IS-IS routes and redistributed routes, into a single route. Route summarization can reduce the routing table size and the LSDB scale.
Route summarization applies only to locally generated LSPs.
Configuring IPv4 IS-IS route summarization
3.     Configure IPv4 IS-IS route summarization.
summary ip-address { mask-length | mask } [ avoid-feedback | generate_null0_route | [ level-1 | level-1-2 | level-2 ] | tag tag ] *
By default, IPv4 IS-IS route summarization is not configured.
The cost of the summary route is the lowest one among the costs of the more-specific routes.
Configuring IPv6 IS-IS route summarization
4.     Configure IPv6 IS-IS route summarization.
summary ipv6-prefix prefix-length [ avoid-feedback | generate_null0_route | [ level-1 | level-1-2 | level-2 ] | tag tag ] *
By default, IPv6 IS-IS route summarization is not configured.
IS-IS cannot redistribute a default route to its neighbors. This task enables IS-IS to advertise a default route of 0.0.0.0/0 in an LSP to the same-level neighbors. Upon receiving the default route, the neighbors add it into their routing table.
Advertising an IPv4 IS-IS default route
3.     Advertise a Level-1 or Level-2 default route.
default-route-advertise [ [ level-1 | level-1-2 | level-2 ] | route-policy route-policy-name ] *
By default, IPv4 IS-IS does not advertise a Level-1 or Level-2 default route.
Advertising an IPv6 IS-IS default route
4.     Advertise a Level-1 or Level-2 default route.
default-route-advertise [ avoid-learning | [ level-1 | level-1-2 | level-2 ] | route-policy route-policy-name | tag tag ] *
By default, IPv6 IS-IS does not advertise a Level-1 or Level-2 default route.
Perform this task to redistribute routes from other routing protocols into IS-IS. You can specify a cost for redistributed routes and specify the maximum number of redistributed routes.
This command redistributes only active routes. To display active routes, use the display ip routing-table protocol command.
Configuring IPv4 IS-IS route redistribution
3.     Redistribute routes from other routing protocols or other IS-IS processes.
import-route bgp [ as-number ] [ allow-ibgp ] [ cost cost-value | cost-type { external | internal } | [ level-1 | level-1-2 | level-2 ] | route-policy route-policy-name | tag tag ] *
import-route bgp [ as-number ] [ allow-ibgp ] inherit-cost [ [ level-1 | level-1-2 | level-2 ] | route-policy route-policy-name | tag tag ] *
import-route { direct | static } [ cost cost-value | cost-type { external | internal } | [ level-1 | level-1-2 | level-2 ] | route-policy route-policy-name | tag tag ] *
import-route { direct | static } inherit-cost [ [ level-1 | level-1-2 | level-2 ] | route-policy route-policy-name | tag tag ] *
import-route { isis | ospf | rip } [ process-id | all-processes ] [ allow-direct | cost cost-value | cost-type { external | internal } | [ level-1 | level-1-2 | level-2 ] | route-policy route-policy-name | tag tag ] *
import-route { isis | ospf | rip } [ process-id | all-processes ] inherit-cost [ allow-direct | [ level-1 | level-1-2 | level-2 ] | route-policy route-policy-name | tag tag ] *
By default, no route is redistributed.
4.     (Optional.) Configure the maximum number of redistributed Level 1/Level 2 IPv4 routes.
import-route limit number
By default, the maximum number of redistributed Level 1/Level 2 IPv4 routes is 4194304.
Configuring IPv6 IS-IS route redistribution
4.     Redistribute routes from other routing protocols or other IS-IS processes.
import-route bgp4+ [ as-number ] [ allow-ibgp ] [ [ cost cost-value | inherit-cost ] | cost-type { external | internal } | [ level-1 | level-1-2 | level-2 ] | route-policy route-policy-name | tag tag ] *
import-route { direct | static } [ [ cost cost-value | inherit-cost ] | cost-type { external | internal } | [ level-1 | level-1-2 | level-2 ] | route-policy route-policy-name | tag tag ] *
import-route { isisv6 | ospfv3 | ripng } [ process-id ] [ allow-direct | [ cost cost-value | inherit-cost ] | cost-type { external | internal } | [ level-1 | level-1-2 | level-2 ] | route-policy route-policy-name | tag tag ] *
5.     (Optional.) Configure the maximum number of redistributed Level 1/Level 2 IPv6 routes.
By default, the maximum number of redistributed Level 1/Level 2 IPv6 routes is 4194304.
IS-IS saves LSPs received from neighbors in the LSDB, and uses the SPF algorithm to calculate the shortest path tree with itself as the root. IS-IS installs the calculated routes to the IS-IS routing table and the optimal routes to the IP routing table.
Perform this task to filter calculated routes. Only routes that are not filtered can be added to the IP routing table. The filtered routes retain in the IS-IS routing table and can be advertised to neighbors.
Filtering IPv4 IS-IS routes calculated from received LSPs
3.     Filter routes calculated using received LSPs.
filter-policy { ipv4-acl-number | prefix-list prefix-list-name | route-policy route-policy-name } import
By default, IPv4 IS-IS route filtering is not configured.
Filtering IPv6 IS-IS routes calculated from received LSPs
4.     Filter routes calculated using received LSPs.
filter-policy { ipv6-acl-number | prefix-list prefix-list-name | route-policy route-policy-name } import
By default, IPv6 IS-IS route filtering is not configured.
IS-IS can redistribute routes from other routing protocols or other IS-IS processes, add them to the IS-IS routing table, and advertise them in LSPs.
Perform this task to filter redistributed routes. Only routes that are not filtered can be added to the IS-IS routing table and advertised to neighbors.
Use this command together with the import-route command.
Filtering redistributed IPv4 IS-IS routes
3.     Filter routes redistributed from other routing protocols or IS-IS processes.
filter-policy { ipv4-acl-number | prefix-list prefix-list-name | route-policy route-policy-name } export [ protocol [ process-id ] ]
Filtering redistributed IPv6 IS-IS routes
4.     Filter routes redistributed from other routing protocols or IS-IS processes.
filter-policy { ipv6-acl-number | prefix-list prefix-list-name | route-policy route-policy-name } export [ protocol [ process-id ] ]
Perform this task to control route advertisement (route leaking) between Level-1 and Level-2.
You can configure IS-IS to advertise routes from Level-2 to Level-1, and to not advertise routes from Level-1 to Level-2.
Configuring IPv4 IS-IS route leaking
3.     Configure route leaking from Level-1 to Level-2.
import-route isis level-1 into level-2 [ filter-policy { ipv4-acl-number | prefix-list prefix-list-name | route-policy route-policy-name } | tag tag ] *
By default, IS-IS advertises routes from Level-1 to Level-2.
4.     Configure route leaking from Level-2 to Level-1.
import-route isis level-2 into level-1 [ filter-policy { ipv4-acl-number | prefix-list prefix-list-name | route-policy route-policy-name } | tag tag ] *
By default, IS-IS does not advertise routes from Level-2 to Level-1.
Configuring IPv6 IS-IS route leaking
import-route isisv6 level-2 into level-1 [ filter-policy { ipv6-acl-number | prefix-list prefix-list-name | route-policy route-policy-name } | tag tag ] *
5.     Configure route leaking from Level-1 to Level-2.
import-route isisv6 level-1 into level-2 [ filter-policy { ipv6-acl-number | prefix-list prefix-list-name | route-policy route-policy-name } | tag tag ] *
After the device advertises IS-IS link state information to BGP, BGP can advertise the information for intended applications. For more information about BGP LS, see "Configuring BGP."
3.     Advertise IS-IS link state information to BGP.
distribute bgp-ls [ instance-id id ] [ level-1 | level-2 ]
By default, the device does not advertise IS-IS link state information to BGP.
Set an IPv6 IS-IS link tag for a device (for example, Device A) and enable IPv6 IS-IS link tag inheritance on another device (for example, Device B) to filter routes as follows:
1.     Device A advertises the IPv6 IS-IS link tag in LSPs.
2.     After receiving the LSPs advertised by Device A, Device B inherits the IPv6 IS-IS link tag advertised by Device A.
If Device B receives multiple link tags from Device A, Device B selects and inherits only one tag.
3.     Device B configures the link tag as the route tag for all routes that pass the link.
Then, the route tag can be used for route filtering.
This feature is usually used in Source Address Validation Architecture (SAVA) scenarios to ensure the consistency of IPv6 SAVA entries on multiple gateway devices:
1.     Set an IPv6 IS-IS link tag for the customer-side interface on the gateway device that advertises IPv6 SAVA entries.
2.     Enable IPv6 IS-IS link tag inheritance on the gateway device that receives IPv6 SAVA entries. The device generates an IPv6 SAVA entry based on a route prefix if the following two tags are the same:
¡     The route tag configured by executing the ipv6 sava import remote-route-tag command.
¡     The IPv6 IS-IS link tag that the route inherits.
For more information about SAVA and IPv6 SAVA entries, see SAVA configuration in Security Configuration Guide.
Setting an IPv6 IS-IS link tag for an interface
3.     Set an IPv6 IS-IS link tag for the interface.
isis ipv6 link-tag tag
By default, no IPv6 IS-IS link tag is configured for the interface.
Enabling IPv6 IS-IS link tag inheritance
4.     Enable IPv6 IS-IS link tag inheritance.
link-tag inherit enable
By default, IPv6 IS-IS link tag inheritance is disabled.
If a neighbor does not receive any hello packets from the router within the advertised hold time, it considers the router down and recalculates the routes. The hold time is the hello multiplier multiplied by the hello interval.
The interval between hello packets sent by the DIS is 1/3 the hello interval set with the isis timer hello command.
3.     Specify the interval for sending hello packets.
isis timer hello seconds [ level-1 | level-2 ]
The default setting is 10 seconds.
On a broadcast network, perform this task on the DIS that uses CSNP packets to synchronize LSDBs.
3.     Specify the interval for sending CSNP packets on the DIS of a broadcast network.
isis timer csnp seconds [ level-1 | level-2 ]
Each LSP has an age that decreases in the LSDB. Any LSP with an age of 0 is deleted from the LSDB. You can adjust the age value based on the scale of a network.
3.     Set the maximum LSP age.
timer lsp-max-age seconds
The default setting is 1200 seconds.
Each router needs to refresh its LSPs at a configurable interval and send them to other routers to prevent valid routes from aging out. A smaller refresh interval speeds up network convergence but consumes more bandwidth.
When network topology changes such as neighbor state, interface metric, system ID, or area ID changes occur, the router generates an LSP after a configurable interval. If such a change occurs frequently, excessive LSPs are generated, consuming a large amount of router resources and bandwidth. To solve the problem, you can adjust the LSP generation interval.
Follow these restrictions and guidelines when you configure the timer lsp-generation command:
·     If you specify only the maximum-interval argument, the LSP generation interval is maximum-interval.
·     If you do not specify the incremental-interval argument, the LSP generation interval is in the range of minimum-interval to maximum-interval.
·     If you specify the incremental-interval argument, the LSP generation interval is as follows:
¡     When network changes are not frequent, the minimum-interval is adopted.
¡     If network changes are frequent, the LSP generation interval increases by incremental-interval × 2n-2 (n is the number of calculation times) each time a generation occurs until the maximum-interval is reached.
3.     Set the LSP refresh interval.
timer lsp-refresh seconds
By default, the LSP refresh interval is 900 seconds.
4.     Set the LSP generation interval.
timer lsp-generation maximum-interval [ minimum-interval [ incremental-interval ] ] [ level-1 | level-2 ]
By default:
¡     The maximum interval is 5 seconds.
¡     The minimum interval is 50 milliseconds.
¡     The incremental interval is 200 milliseconds.
If a change occurs in the LSDB, IS-IS advertises the changed LSP to neighbors. You can specify the minimum interval for sending these LSPs to control the amount of LSPs on the network.
On a P2P link, IS-IS requires an advertised LSP be acknowledged. If no acknowledgment is received within a configurable interval, IS-IS will retransmit the LSP.
3.     Specify the minimum interval for sending LSPs and the maximum LSP number that can be sent at a time.
isis timer lsp time [ count count ]
By default, the minimum interval is 33 milliseconds, and the maximum LSP number that can be sent at a time is 5.
4.     Specify the LSP retransmission interval on a P2P link.
isis timer retransmit seconds
By default, the LSP retransmission interval on a P2P link is 5 seconds.
Based on the LSDB, an IS-IS router uses the SPF algorithm to calculate the shortest path tree with itself being the root, and uses the shortest path tree to determine the next hop to a destination network. By adjusting the SPF calculation interval, you can prevent bandwidth and router resources from being over consumed due to frequent topology changes.
When network changes are not frequent, the minimum-interval is adopted. If network changes become frequent, the SPF calculation interval increases by incremental-interval × 2n-2 (n is the number of calculation times) each time a calculation occurs until the maximum-interval is reached.
Setting the IPv4 SPF calculation interval
3.     Set the SPF calculation interval.
timer spf maximum-interval [ minimum-interval [ incremental-interval ] ]
By default:
Setting the IPv6 SPF calculation interval
4.     Set the SPF calculation interval.
By default:
On a broadcast network, IS-IS must elect a router as the DIS at a routing level. You can specify a DIS priority at a level for an interface. The greater the interface's priority, the more likely it becomes the DIS. If multiple routers in the broadcast network have the same highest DIS priority, the router with the highest MAC address becomes the DIS.
3.     Configure a DIS priority for the interface.
isis dis-priority priority [ level-1 | level-2 ]
The default setting is 64.
Perform this task when the link cost style is wide, wide-compatible, or compatible.
When IS-IS advertises a prefix with a tag value, IS-IS adds the tag to the IP reachability information TLV of the prefix.
Configuring the IPv4 IS-IS tag value for an interface
3.     Configure the IPv4 IS-IS tag value for the interface.
isis tag tag
By default, the IPv4 IS-IS tag value of the interface is not configured.
Configuring the IPv6 IS-IS tag value for an interface
3.     Configure the IPv6 IS-IS tag value for the interface.
isis ipv6 tag tag
By default, the IPv6 IS-IS tag value of the interface is not configured.
When IS-IS advertises an IPv6 prefix with a tag value, it adds the tag to the IPv6 reachability information TLV, regardless of the link cost style.
The hello multiplier is the number of hello packets a neighbor must miss before it declares that the router is down.
If a neighbor receives no hello packets from the router within the advertised hold time, it considers the router down and recalculates the routes. The hold time is the hello multiplier multiplied by the hello interval.
On a broadcast link, Level-1 and Level-2 hello packets are advertised separately. You must set a hello multiplier for each level.
On a P2P link, Level-1 and Level-2 hello packets are advertised in P2P hello packets. You do not need to specify Level-1 or Level-2.
3.     Specify the hello multiplier.
isis timer holding-multiplier value [ level-1 | level-2 ]
The default setting is 3.
After being disabled from sending and receiving hello packets, an interface cannot form any neighbor relationship, but can advertise directly connected networks in LSPs through other interfaces. This can save bandwidth and CPU resources, and ensures that other routers know networks directly connected to the interface.
3.     Disable the interface from sending and receiving IS-IS packets.
isis silent
By default, the interface can send and receive IS-IS packets.
IS-IS messages cannot be fragmented at the IP layer because they are directly encapsulated in frames. Any two IS-IS neighboring routers must negotiate a common MTU. To avoid sending big hellos to save bandwidth, enable the interface to send small hello packets without CLVs.
3.     Enable the interface to send small hello packets without CLVs.
isis small-hello
By default, the interface sends standard hello packets.
Setting LSP lengths
IS-IS messages cannot be fragmented at the IP layer because they are directly encapsulated in frames. IS-IS routers in an area must send LSPs smaller than the smallest interface MTU in the area.
If the IS-IS routers have different interface MTUs, configure the maximum size of generated LSP packets to be smaller than the smallest interface MTU in the area. Without the configuration, the routers must dynamically adjust the LSP packet size to fit the smallest interface MTU, which takes time and affects other services.
3.     Specify the maximum length of generated Level-1 LSPs or Level-2 LSPs.
lsp-length originate size [ level-1 | level-2 ]
By default, the maximum length of generated Level-1 LSPs or Level-2 LSPs is 1497 bytes.
4.     Specify the maximum length of received LSPs.
lsp-length receive size
By default, the maximum length of received LSPs is 1497 bytes.
Changed LSPs can trigger SPF recalculation. To advertise the changed LSPs before the router recalculates routes for faster network convergence, enable LSP flash flooding.
3.     Enable LSP flash flooding.
flash-flood [ flood-count flooding-count | max-timer-interval flooding-interval | [ level-1 | level-2 ] ] *
By default, LSP flash flooding is disabled.
3.     Enable LSP fragment extension.
lsp-fragments-extend [ level-1 | level-1-2 | level-2 ]
By default, LSP fragment extension is disabled.
The MTUs of all interfaces running the IS-IS process must not be less than 512. Otherwise, LSP fragment extension does not take effect.
4.     Configure a virtual system ID.
virtual-system virtual-system-id
By default, no virtual system ID is configured.
Configure a minimum of one virtual system to generate extended LSP fragments.
As shown in Figure 8, many P2P links exist, Devices A, B, C and D run IS-IS. When Device A generates an LSP, it floods the LSP out of VLAN-interface10, VLAN-interface20, and VLAN-interface30. After Device D receives the LSP from VLAN-interface30, it floods it out of VLAN-interface10 and VLAN-interface20 to Device B and Device C. However, Device B and Device C have already received the LSP from Device A. Repeated LSP flooding consumes extra bandwidth.
Figure 8 Network diagram of a fully meshed network
To avoid this problem, you can add interfaces to a mesh group or block some interfaces.
·     An interface in a mesh group floods a received LSP only to interfaces not in the mesh group.
·     A blocked interface sends LSPs only after receiving LSP requests.
Before you configure this task, you must consider redundancy for interfaces in case LSP packets cannot be flooded because of link failures.
3.     Limit LSP flooding.
¡     Add the interface to a mesh group.
isis mesh-group mesh-group-number
¡     Block the interface.
isis mesh-group mesh-blocked
By default, the interface does not belong to any mesh group and is not blocked.
The commands take effect only on P2P interfaces.
An IS-IS P2P interface can have a peer on a different network. Perform this task to configure an IS-IS P2P interface to establish neighbor relationship only with a peer on the same network.
3.     Enable source address check for hello packets on a P2P interface.
isis peer-ip-check
By default, an IS-IS P2P interface can have a peer on a different network.
The command applies only to P2P interfaces.
A topology change causes IS-IS routing convergence. To improve convergence speed, you can assign convergence priorities to IS-IS routes. Convergence priority levels are critical, high, medium, and low. The higher the convergence priority, the faster the convergence speed.
By default, IS-IS host routes have medium convergence priority, and other IS-IS routes have low convergence priority.
Configuring convergence priorities for specific IPv4 IS-IS routes
3.     Assign convergence priorities to specific IPv4 IS-IS routes.
¡     Assign a convergence priority to IPv4 IS-IS routes matching the specified prefix list.
prefix-priority { critical | high | medium } { prefix-list prefix-list-name | tag tag-value }
¡     Assign a convergence priority to IPv4 IS-IS routes by using a route policy.
By default, IPv4 IS-IS routes, except IS-IS host routes, have the low convergence priority.
Configuring convergence priorities for specific IPv6 IS-IS routes
4.     Assign convergence priorities to specific IPv6 IS-IS routes.
By default, IPv6 IS-IS routes, except IS-IS host routes, have the low convergence priority.
By setting the overload bit in sent LSPs, a router informs other routers of failures that make it unable to select routes and forward packets.
When an IS-IS router cannot record the complete LSDB, for example, because of memory insufficiency, it will calculate wrong routes. To make troubleshooting easier, temporarily isolate the router from the IS-IS network by setting the overload bit.
Setting the LSDB overload bit for IPv4 IS-IS
3.     Set the overload bit.
set-overload [ on-startup [ [ start-from-nbr system-id [ timeout1 [ nbr-timeout ] ] ] | timeout2 | wait-for-bgp [ timeout3 ] ] ] [ allow { external | interlevel } * ]
By default, the overload bit is not set.
Setting the LSDB overload bit for IPv6 IS-IS
4.     Set the overload bit.
set-overload [ on-startup [ [ start-from-nbr system-id [ timeout1 [ nbr-timeout ] ] ] | timeout2 | wait-for-bgp4+ [ timeout3 ] ] ] [ allow { external | interlevel } * ]
Isolation is a method used for network device maintenance. It gracefully removes a device from the packet forwarding path for maintenance and gracefully adds the device to the network after maintenance.
To reduce impact on traffic forwarding, you can isolate a device before upgrading it. IS-IS isolation works as follows:
1.     After IS-IS isolation is enabled for a device, IS-IS sets the overload bit in the LSPs advertised by the device and sets the link cost to the maximum value.
2.     Each neighbor of the device reselects an optimal route based on the LSPs and stops forwarding traffic to the device. The device is fully isolated from the network and you can upgrade the device.
3.     After the maintenance, disable IS-IS isolation on the device to gracefully add it back to the network by resetting its overload bit and restoring its link cost.
3.     Configure IS-IS isolation.
a.     Enable IS-IS isolation to gracefully remove the device from the network.
isolate enable
b.     Disable IS-IS isolation to gracefully add the device to the network.
undo isolate enable
By default, IS-IS isolation is disabled.
The ATT bit is used to identify the connection status between a Level-1 area and other areas. By default, a Level-1-2 router sets the ATT bit for Level-1 LSPs as follows:
·     The Level-1-2 router sets the ATT bit in Level-1 LSPs to inform the Level-1 routers that it can reach other areas. After a Level-1 router receives a Level-1 LSP with the ATT bit set, it generates a default route destined for the Level-1-2 router.
·     The Level-1-2 router does not set the ATT bit in Level-1 LSPs if it can reach only one area.
To edit the default ATT bit setting rule for a Level-1-2 router, perform the following tasks as needed:
·     To enable ATT bit setting for all Level-1 LSPs, execute the set-att always command on the Level-1-2 router.
·     To disable a Level-1 router from generating a default route upon receiving an ATT-bit-set Level-1 LSP from the Level-1-2 router, you can perform one of the following tasks:
¡     Execute the ignore-att command on the Level-1 router.
¡     Execute the set-att never command on the Level-1-2 router.
Configuring IS-IS not to calculate the default route through the ATT bit
3.     Configure IS-IS not to calculate the default route through the ATT bit.
ignore-att
By default, IS-IS uses the ATT bit to calculate the default route.
Setting the ATT bit of IPv4 Level-1 LSPs
2.     Enter IS-IS view
3.     Set the ATT bit of Level-1 LSPs.
set-att { always | never }
By default, the Level-1-2 router sets the ATT bit for IPv4 Level-1 LSPs in accordance with the default ATT bit setting rule.
Setting the ATT bit of IPv6 Level-1 LSPs
4.     Set the ATT bit of IPv6 Level-1 LSPs.
By default, the Level-1-2 router sets the ATT bit for IPv6 Level-1 LSPs in accordance with the default ATT bit setting rule.
A 6-byte system ID in hexadecimal notation uniquely identifies a router or host in an IS-IS network. To make a system ID easy to read, the system allows you to use host names to identify devices. It also provides mappings between system IDs and host names.
The mappings can be configured manually or dynamically.
·     Static system ID to host name mapping—You must manually configure a mapping for each router in the network. When a new router is added to the network or a mapping must be modified, you must configure all routers manually.
·     Dynamic system ID to host name mapping—You only need to configure a host name for each router in the network. Each router advertises the host name in a dynamic host name CLV to other routers so all routers in the network can have all mappings. To help check the origin of LSPs in the LSDB, you can configure a name for the DIS in a broadcast network.
Follow these guidelines when you configure the mappings:
·     To view host names rather than system IDs by using the display isis lsdb command, you must enable dynamic system ID to host name mapping.
·     If you configure both dynamic mapping and static mapping on a router, the host name specified for dynamic mapping applies.
Configuring a static system ID to host name mapping
3.     Configure a system ID to host name mapping for a remote IS.
is-name map sys-id map-sys-name
By default, no system ID to host name mapping is configured for a remote IS.
A system ID can correspond to only one host name.
Configuring dynamic system ID to host name mapping
3.     Specify a host name for the IS and enable dynamic system ID to host name mapping.
is-name sys-name
By default, dynamic system ID to host name mapping is disabled and no host name is specified for the router.
6.     Configure a DIS name.
isis dis-name symbolic-name
By default, no DIS name is configured.
This command takes effect only on a router enabled with dynamic system ID to host name mapping.
This command is not available on P2P interfaces.
With this feature enabled, the router delivers logs about neighbor state changes to its information center. The information center processes the logs according to user-defined output rules (whether to output logs and where to output). For more information about the information center, see Network Management and Monitoring Configuration Guide.
3.     Enable the logging of neighbor state changes.
log-peer-change
By default, the logging of neighbor state changes is enabled.
This task includes the following configurations:
·     Bind an IS-IS process to MIB so that you can use network management software to manage the specified IS-IS process.
·     Enable IS-IS notifications to report important events.
To report critical IS-IS events to an NMS, enable SNMP notifications for IS-IS. For SNMP notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see the network management and monitoring configuration guide for the device.
2.     Bind MIB to an IS-IS process.
isis mib-binding process-id
By default, MIB is bound to the IS-IS process with the smallest process ID.
3.     Enable IS-IS notification sending.
snmp-agent trap enable isis [ adjacency-state-change | area-mismatch | authentication | authentication-type | buffsize-mismatch | id-length-mismatch | lsdboverload-state-change | lsp-corrupt | lsp-parse-error | lsp-size-exceeded | manual-address-drop | max-seq-exceeded | maxarea-mismatch | own-lsp-purge | protocol-support | rejected-adjacency | skip-sequence-number | version-skew ] *
By default, IS-IS notification sending is enabled.
4.     Enter IS-IS view.
5.     Configure the context name for the SNMP object for managing IS-IS.
By default, no context name is set for the SNMP object for managing IS-IS.
Enabling ISPF
When the network topology changes, Incremental Shortest Path First (ISPF) computes only the affected part of the SPT, instead of the entire SPT.
Enabling IPv4 IS-IS ISPF
3.     Enable IPv4 IS-IS ISPF.
ispf enable
By default, IPv4 IS-IS ISPF is enabled.
Enabling IPv6 IS-IS ISPF
4.     Enable IPv6 IS-IS ISPF.
ispf enable
By default, IPv6 IS-IS ISPF is enabled.
Perform this task to disable an interface from advertising its prefix in LSPs. This enhances network security by preventing IP routing to the interval nodes and speeds up network convergence.
Enabling IPv4 IS-IS prefix suppression
3.     Enable IPv4 IS-IS prefix suppression on the interface.
isis prefix-suppression
By default, IPv4 IS-IS prefix suppression is disabled on the interface.
This command is also applicable to the secondary IP address of the interface.
Enabling IPv6 IS-IS prefix suppression
3.     Enable IPv6 IS-IS prefix suppression on the interface.
isis ipv6 prefix-suppression
By default, IPv6 IS-IS prefix suppression is disabled on the interface.
Prefix Independent Convergence (PIC) enables the device to speed up network convergence by ignoring the number of prefixes.
Restrictions and guidelines for IS-IS PIC
Follow these restrictions and guidelines when you configure IS-IS PIC:
·     When both IS-IS PIC and IS-IS FRR are configured, IS-IS FRR takes effect.
·     IS-IS PIC applies only to LSPs sent by neighbors.
Enabling IS-IS PIC
3.     Enable PIC for IS-IS.
By default, IS-IS PIC is enabled.
Enabling BFD control packet mode for IS-IS PIC
3.     Enable BFD control packet mode for IS-IS PIC.
isis primary-path-detect bfd ctrl
By default, BFD control packet mode is disabled for IS-IS PIC.
To use BFD (control packet mode) to detect primary link failures, you must enable BFD control packet mode on both ends of the link.
Enabling BFD echo packet mode for IS-IS PIC
2.     Configure the source IP address of BFD echo packets.
bfd echo-source-ip ip-address
By default, the source IP address of BFD echo packets is not configured.
The source IP address cannot be on the same network segment as any local interface's IP address.
For more information, see High Availability Command Reference.
3.     Enter interface view.
4.     Enable BFD echo packet mode for IS-IS PIC.
isis primary-path-detect bfd echo
By default, BFD echo packet mode is disabled for IS-IS PIC.
To use BFD (echo packet mode) to detect primary link failures, you only need to enable BFD echo packet mode on one end of the link.
To enhance the security of an IS-IS network, you can configure IS-IS authentication. IS-IS authentication involves neighbor relationship authentication, area authentication, and routing domain authentication.
With neighbor relationship authentication configured, an interface adds the key in the specified mode into hello packets to the peer and checks the key in the received hello packets. If the authentication succeeds, it forms the neighbor relationship with the peer.
The authentication mode and key at both ends must be identical.
To prevent packet exchange failure in case of an authentication key change, configure the interface not to check the authentication information in the received packets.
The keychain authentication mode supports only the HMAC-MD5 algorithm.
3.     Specify the authentication mode and key.
isis authentication-mode { { gca key-id { hmac-sha-1 | hmac-sha-224 | hmac-sha-256 | hmac-sha-384 | hmac-sha-512 } [ nonstandard ] | md5 | simple } { cipher | plain } string | keychain keychain-name } [ level-1 | level-2 ] [ ip | osi ]
By default, the authentication mode and key are not configured.
4.     (Optional.) Configure the interface not to check the authentication information in the received hello packets.
isis authentication send-only [ level-1 | level-2 ]
When the authentication mode and key are configured, the interface checks the authentication information in the received packets by default.
Area authentication prevents the router from installing routing information from untrusted routers into the Level-1 LSDB. The router encapsulates the authentication key in the specified mode in Level-1 packets (LSP, CSNP, and PSNP). It also checks the key in received Level-1 packets.
To prevent packet exchange failure in case of an authentication key change, configure IS-IS not to check the authentication information in the received packets.
Routers in an area must have the same authentication mode and key.
3.     Specify the area authentication mode and key.
area-authentication-mode { { gca key-id { hmac-sha-1 | hmac-sha-224 | hmac-sha-256 | hmac-sha-384 | hmac-sha-512 } [ nonstandard ] | md5 | simple } { cipher | plain } string | keychain keychain-name } [ ip | osi ]
By default, the area authentication mode and key are not configured.
4.     (Optional.) Configure the interface not to check the authentication information in the received Level-1 packets, including LSPs, CSNPs, and PSNPs.
area-authentication send-only
Routing domain authentication prevents untrusted routing information from entering into a routing domain. A router with the authentication configured encapsulates the key in the specified mode into Level-2 packets (LSP, CSNP, and PSNP) and check the key in received Level-2 packets.
Routers in the backbone must have the same authentication mode and key.
3.     Specify the routing domain authentication mode and key.
domain-authentication-mode { { gca key-id { hmac-sha-1 | hmac-sha-224 | hmac-sha-256 | hmac-sha-384 | hmac-sha-512 } [ nonstandard ] | md5 | simple } { cipher | plain } string | keychain keychain-name } [ ip | osi ]
By default, the routing domain authentication mode and key are not configured.
4.     (Optional.) Configure the interface not to check the authentication information in the received Level-2 packets, including LSPs, CSNPs, and PSNPs.
domain-authentication send-only
GR ensures forwarding continuity when a routing protocol restarts or an active/standby switchover occurs.
Two routers are required to complete a GR process. The following are router roles in a GR process.
·     GR restarter—Graceful restarting router. It must have GR capability.
·     GR helper—A neighbor of the GR restarter. It assists the GR restarter to complete the GR process. By default, the device acts as the GR helper.
Configure IS-IS GR on the GR restarter.
GR restarter uses the following timers:
·     T1 timer—Specifies the times that GR restarter can send a Restart TLV with the RR bit set. When rebooted, the GR restarter sends a Restart TLV with the RR bit set to its neighbor. If the GR restarter receives a Restart TLV with the RA set from its neighbor before the T1 timer expires, the GR process starts. Otherwise, the GR process fails.
·     T2 timer—Specifies the LSDB synchronization interval. Each LSDB has a T2 timer. The Level-1-2 router has a Level-1 timer and a Level-2 timer. If the LSDBs have not synchronized before the two timers expire, the GR process fails.
·     T3 timer—Specifies the GR interval. The GR interval is set as the holdtime in hello PDUs. Within the interval, the neighbors maintain their adjacency with the GR restarter. If the GR process has not completed within the holdtime, the neighbors tear down the neighbor relationship and the GR process fails.
Follow these restrictions and guidelines when you configure IS-IS GR timers:
·     The product of the T1 timer and the number of times that the T1 timer can expire must be smaller than the T2 timer.
·     The T2 timer must be smaller than the T3 timer.
·     IS-IS GR and IS-IS NSR are mutually exclusive. Do not configure them at the same time.
3.     Enable IS-IS GR.
graceful-restart
By default, the GR capability for IS-IS is disabled.
4.     (Optional.) Suppress the SA bit during restart.
graceful-restart suppress-sa
By default, the SA bit is not suppressed.
By enabling the GR restarter to suppress the Suppress-Advertisement (SA) bit in the hello PDUs, the neighbors will still advertise their adjacency with the GR restarter.
5.     (Optional.) Configure the T1 timer.
graceful-restart t1 seconds count count
By default, the T1 timer is 3 seconds and can expire 10 times.
6.     (Optional.) Configure the T2 timer.
graceful-restart t2 seconds
By default, the T2 timer is 60 seconds.
7.     (Optional.) Configure the T3 timer.
graceful-restart t3 seconds
By default, the T2 timer is 300 seconds.
After an active/standby switchover, the GR restarter obtains routing information from its neighbors, and the IS-IS process must learn all the routes. If the network topology changes during the switchover, removed routes cannot be updated to the device, which can result in blackhole routes.
NSR solves the problem by backing up IS-IS link state information from the active process to the standby process. After an active/standby switchover, NSR can complete link state recovery and route regeneration without requiring the cooperation of other devices.
IS-IS NSR and IS-IS GR are mutually exclusive. Do not configure them at the same time.
3.     Enable IS-IS NSR.
non-stop-routing
By default, IS-IS NSR is disabled.
IS-IS NSR takes effect on a per-process basis. As a best practice, enable NSR for each IS-IS process.
BFD provides a single mechanism to quickly detect and monitor the connectivity of links between IS-IS neighbors, reducing network convergence time. For more information about BFD, see High Availability Configuration Guide.
Configuring BFD for IPv4 IS-IS
3.     Enable BFD on an IPv4 IS-IS interface.
isis bfd enable
By default, an IPv4 IS-IS interface is not enabled with BFD.
Configuring BFD for IPv6 IS-IS
3.     Enable BFD on an IPv6 IS-IS interface.
isis ipv6 bfd enable
By default, an IPv6 IS-IS interface is not enabled with BFD.
A link or router failure on a path can cause packet loss. IS-IS FRR enables fast rerouting to minimize the failover time.
Figure 9 Network diagram for IS-IS FRR
In Figure 9, after you enable FRR on Router B, IS-IS automatically calculates or designates a backup next hop when a link failure is detected. In this way, packets are directed to the backup next hop to reduce traffic recovery time. Meanwhile, IS-IS calculates the shortest path based on the new network topology, and forwards packets over the path after network convergence.
You can assign a backup next hop for IS-IS FRR through the following ways:
·     Enable IS-IS FRR to calculate a backup next hop through Loop Free Alternate (LFA) calculation.
·     Designate a backup next hop with a routing policy for routes matching specific criteria.
The LFA calculation of FRR and that of TE are mutually exclusive.
Configuring IPv4 IS-IS FRR to calculate a backup next hop through LFA calculation
3.     (Optional.) Disable LFA calculation on the interface.
isis fast-reroute lfa-backup exclude
By default, the interface participates in LFA calculation, and can be elected as a backup interface.
5.     Enter IS-IS IPv4 unicast address family view.
6.     Enable IS-IS FRR to calculate a backup next hop through LFA calculation.
fast-reroute lfa
By default, IS-IS FRR is disabled.
Configuring IPv4 IS-IS FRR using a routing policy
6.     Enable IPv4 IS-IS FRR using a routing policy.
¡     Create a routing policy and specify a backup next hop.
apply fast-reroute backup-interface
For more information about the apply fast-reroute backup-interface command and routing policy, see Layer 3—IP Routing Configuration Guide.
¡     Configure IPv4 IS-IS FRR.
By default, IPv4 IS-IS FRR is disabled.
Enabling BFD control packet mode for IPv4 IS-IS FRR
3.     Enable BFD control packet mode for IPv4 IS-IS FRR.
By default, BFD control packet mode is disabled for IPv4 IS-IS FRR.
Enabling BFD echo packet mode for IPv4 IS-IS FRR
4.     Enable BFD echo packet mode for IPv4 IS-IS FRR.
By default, BFD echo packet mode is disabled for IPv4 IS-IS FRR.
Configuring IPv6 IS-IS FRR to calculate a backup next hop through LFA calculation
isis ipv6 fast-reroute lfa-backup exclude
5.     Enter IS-IS view.
6.     Enter IS-IS IPv6 address family view.
7.     Enable IPv6 IS-IS FRR to calculate a backup next hop through LFA calculation.
fast-reroute lfa
By default, IPv6 IS-IS FRR is disabled.
Configuring IPv6 IS-IS FRR using a routing policy
7.     Enable IPv6 IS-IS FRR using a routing policy.
apply ipv6 fast-reroute backup-interface
For more information about the apply ipv6 fast-reroute backup-interface command and routing policy, see Layer 3—IP Routing Configuration Guide.
¡     Configure IPv6 IS-IS FRR.
Enabling BFD control packet mode for IPv6 IS-IS FRR
3.     Enable BFD control packet mode for IPv6 IS-IS FRR.
isis ipv6 primary-path-detect bfd ctrl
By default, BFD control packet mode is disabled for IPv6 IS-IS FRR.
Enabling BFD echo packet mode for IPv6 IS-IS FRR
2.     Configure the source IPv6 address of BFD echo packets.
bfd echo-source-ipv6 ip-address
By default, the source IPv6 address of BFD echo packets is not configured.
The source IPv6 address cannot be on the same network segment as any local interface's IPv6 address.
4.     Enable BFD echo packet mode for IPv6 IS-IS FRR.
isis ipv6 primary-path-detect bfd echo
By default, BFD echo packet mode is disabled for IPv6 IS-IS FRR.
Display and maintenance commands for IS-IS
Displaying and maintaining IPv4 IS-IS
Display IS-IS process information.
display isis [ process-id ]
Display IS-IS GR log information.
(In standalone mode.)
display isis event-log graceful-restart slot slot-number
(In IRF mode.)
display isis event-log graceful-restart chassis chassis-number slot slot-number
Display IS-IS LSP log information.
display isis event-log lsp { purged | refreshed } [ level-1 | level-2 ] [ process-id ]
Display IS-IS NSR log information.
display isis event-log non-stop-routing slot slot-number
(In IRF mode.)
display isis event-log non-stop-routing chassis chassis-number slot slot-number
Display IPv4 IS-IS route calculation log information.
display isis event-log spf [ ipv4 ] [ [ level-1 | level-2 ] | verbose ] * [ process-id ]
Display the IS-IS GR status.
display isis graceful-restart status [ level-1 | level-2 ] [ process-id ]
Display IS-IS interface information.
display isis interface [ [ interface-type interface-number ] [ verbose ] | statistics ] [ process-id ]
Display IS-IS LSDB information.
display isis lsdb [ [ level-1 | level-2 ] | local | lsp-id lspid | [ lsp-name lspname ] | verbose ] * [ process-id ]
Display IS-IS LSDB statistics.
display isis lsdb statistics [ level-1 | level-2 ] [ process-id ]
Display IS-IS mesh group information.
display isis mesh-group [ process-id ]
Display the host name to system ID mapping table.
display isis name-table [ process-id ]
Display the IS-IS NSR status.
display isis non-stop-routing status
Display IS-IS packet statistics.
display isis packet { csnp | hello | lsp | psnp } [ verbose ] [ interface-type interface-number ] [ process-id ]
Display IS-IS neighbor information.
display isis peer [ statistics | verbose ] [ process-id ]
Display IPv4 IS-IS redistributed route information.
display isis redistribute [ ipv4 [ ip-address mask-length ] ] [ level-1 | level-2 ] [ process-id ]
Display IS-IS IPv4 routing information.
display isis route [ ipv4 [ ip-address mask-length ] ] [ [ level-1 | level-2 ] | verbose ] * [ process-id ]
Display IS-IS IPv4 topology information.
display isis spf-tree [ ipv4 ] [ [ level-1 | level-2 ] | verbose ] * [ process-id ]
Display IPv4 IS-IS statistics.
display isis statistics [ ipv4 ] [ level-1 | level-1-2 | level-2 ] [ process-id ]
Display OSI connection information.
display osi [ slot slot-number ]
(In IRF mode.)
display osi [ chassis chassis-number slot slot-number ]
Display OSI connection statistics.
display osi statistics [ slot slot-number ]
(In IRF mode.)
display osi statistics [ chassis chassis-number slot slot-number ]
Clear IS-IS process data structure information.
reset isis all [ process-id ] [ graceful-restart ]
Clear IS-IS GR log information.
reset isis event-log graceful-restart slot slot-number
(In IRF mode.)
reset isis event-log graceful-restart chassis chassis-number slot slot-number
Clear IS-IS LSP log information.
reset isis event-log lsp { purged | refreshed } [ process-id ]
Clear IS-IS NSR log information.
reset isis event-log non-stop-routing slot slot-number
(In IRF mode.)
reset isis event-log non-stop-routing chassis chassis-number slot slot-number
Clear IS-IS route calculation log information.
reset isis event-log spf [ process-id ]
Clear IS-IS packet statistics.
reset isis packet [ csnp | hello | lsp | psnp ] by-interface [ interface-type interface-number ] [ process-id ]
Clear the data structure information of an IS-IS neighbor.
reset isis peer system-id [ process-id ]
Clear OSI connection statistics.
reset osi statistics
Displaying and maintaining IPv6 IS-IS
Display IPv6 IS-IS route calculation log information.
display isis event-log spf ipv6 [ [ level-1 | level-2 ] | verbose ] * [ process-id ]
Display IPv6 IS-IS redistributed route information.
display isis redistribute ipv6 [ ipv6-address mask-length ] [ level-1 | level-2 ] [ process-id ]
Display IPv6 IS-IS routing information.
display isis route ipv6 [ ipv6-address ] [ [ level-1 | level-2 ] | verbose ] * [ process-id ]
Display IPv6 IS-IS topology information.
display isis spf-tree ipv6 [ [ level-1 | level-2 ] | verbose ] * [ process-id ]
Display IPv6 IS-IS statistics.
display isis statistics ipv6 [ level-1 | level-1-2 | level-2 ] [ process-id ]
(In IRF mode.)
(In IRF mode.)
IS-IS configuration examples
Example: Configuring basic IS-IS
As shown in Figure 10, Switch A, Switch B, Switch C, and Switch D reside in an IS-IS AS.
Switch A and B are Level-1 switches, Switch D is a Level-2 switch, and Switch C is a Level-1-2 switch. Switch A, Switch B, and Switch C are in Area 10, and Switch D is in Area 20.
Figure 10 Network diagram
IMPORTANT
IMPORTANT:
By default, interfaces on the device are disabled (in ADM or Administratively Down state). To have an interface operate, you must use the undo shutdown command to enable that interface.
1.     Configure IP addresses for interfaces. (Details not shown.)
2.     Configure IS-IS:
# Configure Switch A.
[SwitchA] isis 1
[SwitchA-isis-1] is-level level-1
[SwitchA-isis-1] network-entity 10.0000.0000.0001.00
[SwitchA-isis-1] quit
[SwitchA-Vlan-interface100] isis enable 1
# Configure Switch B.
[SwitchB] isis 1
[SwitchB-isis-1] is-level level-1
[SwitchB-isis-1] network-entity 10.0000.0000.0002.00
[SwitchB-isis-1] quit
[SwitchB-Vlan-interface200] isis enable 1
# Configure Switch C.
[SwitchC] isis 1
[SwitchC-isis-1] network-entity 10.0000.0000.0003.00
[SwitchC-isis-1] quit
[SwitchC-Vlan-interface100] isis enable 1
[SwitchC-Vlan-interface200] isis enable 1
[SwitchC-Vlan-interface300] isis enable 1
[SwitchC-Vlan-interface300] quit
# Configure Switch D.
<SwitchD> system-view
[SwitchD] isis 1
[SwitchD-isis-1] is-level level-2
[SwitchD-isis-1] network-entity 20.0000.0000.0004.00
[SwitchD-isis-1] quit
[SwitchD] interface vlan-interface 100
[SwitchD-Vlan-interface100] isis enable 1
[SwitchD-Vlan-interface100] quit
[SwitchD] interface vlan-interface 300
[SwitchD-Vlan-interface300] isis enable 1
[SwitchD-Vlan-interface300] quit
# Display the IS-IS LSDB on each switch to verify the LSPs.
[SwitchA] display isis lsdb
                       Database information for IS-IS(1)
                          Level-1 Link State Database
LSPID                 Seq Num      Checksum   Holdtime   Length  ATT/P/OL
0000.0000.0001.00-00* 0x00000004   0xdf5e     1096       68      0/0/0
0000.0000.0002.00-00  0x00000004   0xee4d     1102       68      0/0/0
0000.0000.0002.01-00  0x00000001   0xdaaf     1102       55      0/0/0
0000.0000.0003.00-00  0x00000009   0xcaa3     1161       111     1/0/0
0000.0000.0003.01-00  0x00000001   0xadda     1112       55      0/0/0
[SwitchB] display isis lsdb
0000.0000.0001.00-00  0x00000006   0xdb60     988         68      0/0/0
0000.0000.0002.00-00* 0x00000008   0xe651     1189        68      0/0/0
0000.0000.0002.01-00* 0x00000005   0xd2b3     1188        55      0/0/0
0000.0000.0003.00-00  0x00000014   0x194a     1190        111     1/0/0
0000.0000.0003.01-00  0x00000002   0xabdb     995         55      0/0/0
[SwitchC] display isis lsdb
0000.0000.0001.00-00  0x00000006   0xdb60     847         68      0/0/0
0000.0000.0002.00-00  0x00000008   0xe651     1053        68      0/0/0
0000.0000.0002.01-00  0x00000005   0xd2b3     1052        55      0/0/0
0000.0000.0003.00-00* 0x00000014   0x194a     1051        111     1/0/0
0000.0000.0003.01-00* 0x00000002   0xabdb     854         55      0/0/0
                          Level-2 Link State Database
0000.0000.0003.00-00* 0x00000012   0xc93c     842         100     0/0/0
0000.0000.0004.00-00  0x00000026   0x331      1173        84      0/0/0
0000.0000.0004.01-00  0x00000001   0xee95     668         55      0/0/0
[SwitchD] display isis lsdb
0000.0000.0003.00-00  0x00000013   0xc73d        1003          100     0/0/0
0000.0000.0004.00-00* 0x0000003c   0xd647        1194          84      0/0/0
0000.0000.0004.01-00* 0x00000002   0xec96        1007          55      0/0/0
# Display the IS-IS routing information on each switch.
[SwitchA] display isis route
                         Level-1 IPv4 Forwarding Table
 IPv4 Destination     IntCost    ExtCost ExitInterface   NextHop         Flags
 10.1.1.0/24          10         NULL    Vlan100         Direct          D/L/-
 10.1.2.0/24          20         NULL    Vlan100         10.1.1.1        R/-/-
 192.168.0.0/24       20         NULL    Vlan100         10.1.1.1        R/-/-
 0.0.0.0/0            10         NULL    Vlan100         10.1.1.1        R/-/-
[SwitchC] display isis route
 192.168.0.0/24       10         NULL    Vlan300         Direct          D/L/-
 10.1.2.0/24          10         NULL    Vlan200         Direct          D/L/-
                         Level-2 IPv4 Forwarding Table
 192.168.0.0/24       10         NULL                                    D/L/-
 10.1.1.0/24          10         NULL                                    D/L/-
 10.1.2.0/24          10         NULL                                    D/L/-
 172.16.0.0/16        20         NULL    Vlan300         192.168.0.2     R/-/-
[SwitchD] display isis route
 10.1.1.0/24          20         NULL    Vlan300         192.168.0.1     R/-/-
 10.1.2.0/24          20         NULL    Vlan300         192.168.0.1     R/-/-
 172.16.0.0/16        10         NULL    Vlan100         Direct          D/L/-
The output shows that the routing table of Level-1 switches contains a default route with the next hop as the Level-1-2 switch. The routing table of Level-2 switch contains both routing information of Level-1 and Level-2.
Example: Configuring DIS election
As shown in Figure 11, Switches A, B, C, and D reside in IS-IS area 10 on a broadcast network (Ethernet). Switch A and Switch B are Level-1-2 switches, Switch C is a Level-1 switch, and Switch D is a Level-2 switch.
Change the DIS priority of Switch A to make it elected as the Level-1-2 DIS router.
Figure 11 Network diagram
IMPORTANT
IMPORTANT:
2.     Enable IS-IS:
[SwitchA] isis 1
[SwitchB] isis 1
[SwitchB-Vlan-interface100] isis enable 1
[SwitchC] isis 1
[SwitchC-isis-1] is-level level-1
[SwitchD] isis 1
[SwitchD-isis-1] network-entity 10.0000.0000.0004.00
# Display information about IS-IS neighbors on Switch A.
[SwitchA] display isis peer
                          Peer information for IS-IS(1)
  System ID: 0000.0000.0002
  Interface: Vlan-interface100       Circuit Id: 0000.0000.0003.01
  State: Up     HoldTime: 21s        Type: L1(L1L2)     PRI: 64
  System ID: 0000.0000.0003
  State: Up     HoldTime: 27s        Type: L1           PRI: 64
  Interface: Vlan-interface100       Circuit Id: 0000.0000.0004.01
  State: Up     HoldTime: 28s        Type: L2(L1L2)     PRI: 64
  System ID: 0000.0000.0004
  State: Up     HoldTime: 30s        Type: L2          PRI: 64
# Display information about IS-IS interfaces on Switch A.
[SwitchA] display isis interface
  Index     IPv4 state      IPv6 state     Circuit ID   MTU   Type   DIS
  00001     Up              Down           1            1497  L1/L2  No/No
# Display information about IS-IS interfaces on Switch C.
[SwitchC] display isis interface
  00001     Up              Down           1            1497  L1/L2  Yes/No
# Display information about IS-IS interfaces on Switch D.
[SwitchD] display isis interface
  00001     Up              Down           1            1497  L1/L2  No/Yes
The output shows that when the default DIS priority is used, Switch C is the DIS for Level-1, and Switch D is the DIS for Level-2. The pseudonodes of Level-1 and Level-2 are 0000.0000.0003.01 and 0000.0000.0004.01.
#Configure the DIS priority of Switch A.
[SwitchA-Vlan-interface100] isis dis-priority 100
# Display IS-IS neighbors on Switch A.
  Interface: Vlan-interface100       Circuit Id: 0000.0000.0001.01
  00001     Up              Down           1            1497  L1/L2  Yes/Yes
The output shows that after the DIS priority configuration, Switch A becomes the DIS for Level-1-2, and the pseudonode is 0000.0000.0001.01.
# Display information about IS-IS neighbors and interfaces on Switch C.
[SwitchC] display isis peer
  State: Up     HoldTime: 25s        Type: L1           PRI: 64
  System ID: 0000.0000.0001
  State: Up     HoldTime: 7s         Type: L1           PRI: 100
# Display information about IS-IS neighbors and interfaces on Switch D.
[SwitchD] display isis peer
  State: Up     HoldTime: 9s         Type: L2           PRI: 100
  State: Up     HoldTime: 28s        Type: L2           PRI: 64
Example: Configuring IS-IS route redistribution
As shown in Figure 12, Switch A, Switch B, Switch C, and Switch D reside in the same AS. They use IS-IS to interconnect. Switch A and Switch B are Level-1 routers, Switch D is a Level-2 router, and Switch C is a Level-1-2 router.
Redistribute RIP routes into IS-IS on Switch D.
Figure 12 Network diagram
IMPORTANT
IMPORTANT:
2.     Configure basic IS-IS:
[SwitchA] isis 1
[SwitchB] isis 1
[SwitchC] isis 1
[SwitchD] isis 1
[SwitchD] interface interface vlan-interface 300
[SwitchD] interface interface vlan-interface 400
[SwitchD-Vlan-interface400] isis enable 1
# Display IS-IS routing information on each switch.
 10.1.1.0/24          10         NULL    VLAN100         Direct          D/L/-
 10.1.2.0/24          20         NULL    VLAN100         10.1.1.1        R/-/-
 192.168.0.0/24       20         NULL    VLAN100         10.1.1.1        R/-/-
 0.0.0.0/0            10         NULL    VLAN100         10.1.1.1        R/-/-
 10.1.2.0/24          10         NULL    VLAN200         Direct          D/L/-
 192.168.0.0/24       10         NULL    VLAN300         Direct          D/L/-
 10.1.1.0/24          20         NULL    VLAN300         192.168.0.1     R/-/-
 10.1.2.0/24          20         NULL    VLAN300         192.168.0.1     R/-/-
3.     Run RIPv2 between Switch D and Switch E, and configure IS-IS to redistribute RIP routes on Switch D:
# Configure RIPv2 on Switch D.
[SwitchD] rip 1
[SwitchD-rip-1] network 10.0.0.0
[SwitchD-rip-1] version 2
[SwitchD-rip-1] undo summary
# Configure RIPv2 on Switch E.
[SwitchE] rip 1
[SwitchE-rip-1] network 10.0.0.0
[SwitchE-rip-1] version 2
[SwitchE-rip-1] undo summary
# Configure IS-IS to redistribute RIP routes on Switch D.
[SwitchD-rip-1] quit
[SwitchD] isis 1
[SwitchD–isis-1] address-family ipv4
[SwitchD–isis-1-ipv4] import-route rip level-2
# Display IS-IS routing information on Switch C.
 10.1.4.0/24          20         NULL    VLAN300         192.168.0.2     R/L/-
 10.1.5.0/24          10         0       VLAN300         192.168.0.2     R/L/-
 10.1.6.0/24          10         0       VLAN300         192.168.0.2     R/L/-
Example: Configuring IS-IS authentication
As shown in Figure 13, Switch A, Switch B, Switch C, and Switch D reside in the same IS-IS routing domain. Run IS-IS among them.
Switch A, Switch B, and Switch C belong to Area 10, and Switch D belongs to Area 20.
·     Configure neighbor relationship authentication between neighbors.
·     Configure area authentication in Area 10 to prevent untrusted routes from entering into the area.
·     Configure routing domain authentication on Switch C and Switch D to prevent untrusted routes from entering the routing domain.
Figure 13 Network diagram
IMPORTANT
IMPORTANT:
[SwitchA] isis 1
[SwitchB] isis 1
[SwitchC] isis 1
[SwitchD] isis 1
[SwitchD-isis-1] network-entity 20.0000.0000.0001.00
3.     Configure neighbor relationship authentication between neighbors:
# Set the authentication mode to MD5 and set the plaintext key to eRq on VLAN-interface 100 of Switch A and on VLAN-interface 100 of Switch C.
[SwitchA-Vlan-interface100] isis authentication-mode md5 plain eRg
[SwitchC-Vlan-interface100] isis authentication-mode md5 plain eRg
# Set the authentication mode to MD5 and set the plaintext key to t5Hr on VLAN-interface 200 of Switch B and on VLAN-interface 200 of Switch C.
[SwitchB-Vlan-interface200] isis authentication-mode md5 plain t5Hr
[SwitchC-Vlan-interface200] isis authentication-mode md5 plain t5Hr
# Set the authentication mode to MD5 and set the plaintext key to hSec on VLAN-interface 300 of Switch D and on VLAN-interface 300 of Switch C.
[SwitchC-Vlan-interface300] isis authentication-mode md5 plain hSec
[SwitchD-Vlan-interface300] isis authentication-mode md5 plain hSec
4.     Set the area authentication mode to MD5 and set the plaintext key to 10Sec on Switch A, Switch B, and Switch C.
[SwitchA] isis 1
[SwitchA-isis-1] area-authentication-mode md5 plain 10Sec
[SwitchB] isis 1
[SwitchB-isis-1] area-authentication-mode md5 plain 10Sec
[SwitchC] isis 1
[SwitchC-isis-1] area-authentication-mode md5 plain 10Sec
5.     Set routing domain authentication mode to MD5 and set the plaintext key to 1020Sec on Switch C and Switch D.
[SwitchC] isis 1
[SwitchC-isis-1] domain-authentication-mode md5 plain 1020Sec
[SwitchD] isis 1
[SwitchD-isis-1] domain-authentication-mode md5 plain 1020Sec
Example: Configuring IS-IS GR
As shown in Figure 14, Switch A, Switch B, and Switch C belong to the same IS-IS routing domain.
Figure 14 Network diagram
IMPORTANT
IMPORTANT:
1.     Configure IP addresses and subnet masks for interfaces. (Details not shown.)
2.     Configure IS-IS on the switches to make sure Switch A, Switch B, and Switch C can communicate with each other at layer 3 and dynamic route update can be implemented among them with IS-IS. (Details not shown.)
3.     Enable IS-IS GR on Switch A.
[SwitchA] isis 1
[SwitchA-isis-1] graceful-restart
[SwitchA-isis-1] return
# Restart the IS-IS process on Switch A.
<SwitchA> reset isis all 1 graceful-restart
Reset IS-IS process? [Y/N]:y
# Check the GR state of the IS-IS process on Switch A.
<SwitchA> display isis graceful-restart status
Restart status: COMPLETE
Restart phase: Finish
SA Bit: supported
                          Level-1 restart information
Total number of interfaces: 1
Number of waiting LSPs: 0
                          Level-2 restart information
Example: Configuring IS-IS NSR
As shown in Figure 15, Switch S, Switch A, and Switch B belong to the same IS-IS routing domain.
·     Run IS-IS on all the switches to interconnect them with each other.
·     Enable IS-IS NSR on Switch S to ensure forwarding continuity between Switch A and Switch B when an active/standby switchover occurs on Switch S.
Figure 15 Network diagram
IMPORTANT
IMPORTANT:
1.     Configure the IP addresses and subnet masks for interfaces on the switches. (Details not shown.)
2.     Configure IS-IS on the switches to make sure Switch S, Switch A, and Switch B can communicate with each other at Layer 3 and dynamic route update can be implemented among them with IS-IS. (Details not shown.)
3.     Enable IS-IS NSR on Switch S.
<SwitchS> system-view
[SwitchS] isis 1
[SwitchS-isis-1] non-stop-routing
[SwitchS-isis-1] return
# Reoptimize process placement on Switch S to trigger an active/standby switchover.
[SwitchS] placement reoptimize
Service Group(instance name)                      Cur location  New location
rib                                               0/0           0/0
staticroute                                       0/0           0/0
rib6                                              0/0           0/0
staticroute6                                      0/0           0/0
isis                                              0/0           1/0
Continue? [y/n]:y
Re-optimization of the placement start. You will be notified on completion.
Re-optimization of the placement complete. Use 'display placement' to view the new placement.
# During the switchover period, display IS-IS neighbor information on Switch A to verify the neighborship between Switch A and Switch S.
<SwitchA> display isis peer
 Interface: vlan100                 Circuit Id: 0000.0000.0001.01
 State: Up     HoldTime:  25s       Type: L1(L1L2)     PRI: 64
 State: Up     HoldTime:  27s       Type: L2(L1L2)     PRI: 64
# Display IS-IS routing information on Switch A to verify that Switch A has a route to the loopback interface of Switch B.
<SwitchA> display isis route
 12.12.12.0/24        10         NULL    vlan100         Direct          D/L/-
 22.22.22.22/32       10         NULL    Loop0           Direct          D/-/-
 14.14.14.0/32        10         NULL    vlan100         12.12.12.2      R/L/-
 44.44.44.44/32       10         NULL    vlan100         12.12.12.2      R/L/-
# Display IS-IS neighbor information on Switch B to verify the neighborship between Switch B and Switch S.
<SwitchB> display isis peer
 Interface: vlan200                 Circuit Id: 0000.0000.0001.01
# Display IS-IS routing information on Switch B to verify that Switch B has a route to the loopback interface of Switch A.
<SwitchB> display isis route
 14.14.14.0/24        10         NULL    vlan200         Direct          D/L/-
 44.44.44.44/32       10         NULL    Loop0           Direct          D/-/-
 12.12.12.0/32        10         NULL    vlan200         14.14.14.4      R/L/-
 22.22.22.22/32       10         NULL    vlan200         14.14.14.4      R/L/-
The output shows that the neighbor information and routing information on Switch A and Switch B have not changed during the active/standby switchover on Switch S. The neighbors are unaware of the switchover.
Example: Configuring BFD for IS-IS
·     As shown in Figure 16, run IS-IS on Switch A, Switch B and Switch C so that they can reach each other at the network layer.
·     After the link over which Switch A and Switch B communicate through the Layer-2 switch fails, BFD can quickly detect the failure and notify IS-IS of the failure. Switch A and Switch B then communicate through Switch C.
Figure 16 Network diagram
Table 4 Interface and IP address assignment
Device
IP address
Device
IP address
Switch A
Vlan-int10
10.1.0.102/24
Switch B
Vlan-int10
10.1.0.100/24
Vlan-int11
11.1.1.1/24
Vlan-int13
13.1.1.1/24
Loop0
121.1.1.1/32
Loop0
120.1.1.1/32
Switch C
Vlan-int11
11.1.1.2/24
Vlan-int13
13.1.1.2/24
IMPORTANT
IMPORTANT:
[SwitchA] isis
[SwitchA-LoopBack0] isis enable
[SwitchA-LoopBack0] quit
[SwitchA-Vlan-interface10] isis enable
[SwitchA-Vlan-interface11] isis enable
[SwitchB] isis
[SwitchB-LoopBack0] isis enable
[SwitchB-LoopBack0] quit
[SwitchB-Vlan-interface10] isis enable
[SwitchB] interface vlan-interface 13
[SwitchB-Vlan-interface13] isis enable
[SwitchB-Vlan-interface13] quit
[SwitchC] isis
[SwitchC] interface vlan-interface 11
[SwitchC-Vlan-interface11] isis enable
[SwitchC-Vlan-interface11] quit
[SwitchC] interface vlan-interface 13
[SwitchC-Vlan-interface13] isis enable
[SwitchC-Vlan-interface13] quit
3.     Configure BFD functions:
# Enable BFD and configure BFD parameters on Switch A.
[SwitchA] bfd session init-mode passive
[SwitchA-Vlan-interface10] isis bfd enable
[SwitchA-Vlan-interface10] bfd min-receive-interval 500
[SwitchA-Vlan-interface10] bfd min-transmit-interval 500
[SwitchA-Vlan-interface10] bfd detect-multiplier 7
# Enable BFD and configure BFD parameters on Switch B.
[SwitchB] bfd session init-mode active
[SwitchB-Vlan-interface10] isis bfd enable
[SwitchB-Vlan-interface10] bfd min-receive-interval 500
[SwitchB-Vlan-interface10] bfd min-transmit-interval 500
[SwitchB-Vlan-interface10] bfd detect-multiplier 8
[SwitchB-Vlan-interface10] return
# Display the BFD session information on Switch A.
<SwitchA> display bfd session
 LD/RD          SourceAddr      DestAddr        State    Holdtime    Interface
 3/1            192.168.0.102   192.168.0.100   Up       1700ms      Vlan10
# Display routes destined for 120.1.1.1/32 on Switch A.
<SwitchA> display ip routing-table 120.1.1.1 verbose
Summary Count : 1
Destination: 120.1.1.1/32
   Protocol: IS_L1
 Process ID: 1
  SubProtID: 0x1                    Age: 04h20m37s
       Cost: 10              Preference: 10
      IpPre: N/A             QosLocalID: N/A
        Tag: 0                    State: Active Adv
  OrigTblID: 0x0                OrigVrf: default-vrf
    TableID: 0x2                 OrigAs: 0
      NibID: 0x26000002          LastAs: 0
     AttrID: 0xffffffff        Neighbor: 0.0.0.0
      Flags: 0x1008c        OrigNextHop: 192.168.0.100
      Label: NULL           RealNextHop: 192.168.0.100
    BkLabel: NULL             BkNextHop: N/A
    SRLabel: NULL             BkSRLabel: NULL
  Tunnel ID: Invalid          Interface: Vlan-interface10
BkTunnel ID: Invalid        BkInterface: N/A
   FtnIndex: 0x0           TrafficIndex: N/A
  Connector: N/A                 PathID: 0x0
The output shows that Switch A and Switch B communicate through VLAN-interface 10. Then the link over VLAN-interface 10 fails.
Summary Count : 1
   Protocol: IS_L1
 Process ID: 1
       Cost: 20              Preference: 10
      Flags: 0x1008c        OrigNextHop: 10.1.1.100
      Label: NULL           RealNextHop: 10.1.1.100
  Tunnel ID: Invalid          Interface: Vlan-interface11
The output shows that Switch A and Switch B communicate through VLAN-interface 11.
Example: Configuring IS-IS FRR
As shown in Figure 17, Switch A, Switch B, and Switch C belong to the same IS-IS routing domain. Configure IS-IS FRR so that when the Link A fails, traffic can be switched to Link B immediately.
Figure 17 Network diagram
Table 5 Interface and IP address assignment
Device
IP address
Device
IP address
Switch A
Vlan-int100
12.12.12.1/24
Switch B
Vlan-int101
24.24.24.4/24
Vlan-int200
13.13.13.1/24
Vlan-int200
13.13.13.2/24
Loop0
1.1.1.1/32
Loop0
4.4.4.4/32
Switch C
Vlan-int100
12.12.12.2/24
Vlan-int101
24.24.24.2/24
IMPORTANT
IMPORTANT:
1.     Configure IP addresses and subnet masks for interfaces on the switches. (Details not shown.)
2.     Configure IS-IS on the switches to make sure Switch A, Switch B, and Switch C can communicate with each other at Layer 3. (Details not shown.)
3.     Configure IS-IS FRR:
Enable IS-IS FRR to calculate a backup next hop through LFA calculation, or designate a backup next hop by using a referenced routing policy.
¡     (Method 1.) Enable IS-IS FRR to calculate a backup next hop through LFA calculation:
[SwitchA] isis 1
[SwitchA-isis-1] address-family ipv4
[SwitchA-isis-1-ipv4] fast-reroute lfa
[SwitchA-isis-1-ipv4] quit
[SwitchB] isis 1
[SwitchB-isis-1] address-family ipv4
[SwitchB-isis-1-ipv4] fast-reroute lfa
[SwitchB-isis-1-ipv4] quit
¡     (Method 2.) Enable IS-IS FRR to designate a backup next hop by using a referenced routing policy:
[SwitchA-route-policy-frr-10] if-match ip address prefix-list abc
[SwitchA-route-policy-frr-10] apply fast-reroute backup-interface vlan-interface 100 backup-nexthop 12.12.12.2
[SwitchA] isis 1
[SwitchA-isis-1-ipv4] fast-reroute route-policy frr
[SwitchB] ip prefix-list abc index 10 permit 1.1.1.1 32
[SwitchB-route-policy-frr-10] if-match ip address prefix-list abc
[SwitchB-route-policy-frr-10] apply fast-reroute backup-interface vlan-interface 101 backup-nexthop 24.24.24.2
[SwitchB] isis 1
[SwitchB-isis-1-ipv4] fast-reroute route-policy frr
# Display route 4.4.4.4/32 on Switch A to view the backup next hop information.
[SwitchA] display ip routing-table 4.4.4.4 verbose
Summary Count : 1
Destination: 4.4.4.4/32
   Protocol: IS_L1
 Process ID: 1
      Flags: 0x1008c        OrigNextHop: 13.13.13.2
      Label: NULL           RealNextHop: 13.13.13.2
    BkLabel: NULL             BkNextHop: 12.12.12.2
  Tunnel ID: Invalid          Interface: Vlan-interface200
BkTunnel ID: Invalid        BkInterface: Vlan-interface100
# Display route 1.1.1.1/32 on Switch B to view the backup next hop information.
[SwitchB] display ip routing-table 1.1.1.1 verbose
Summary Count : 1
Destination: 1.1.1.1/32
   Protocol: IS_L1
 Process ID: 1
      Flags: 0x1008c        OrigNextHop: 13.13.13.1
      Label: NULL           RealNextHop: 13.13.13.1
    BkLabel: NULL             BkNextHop: 24.24.24.2
BkTunnel ID: Invalid        BkInterface: Vlan-interface101
IPv6 IS-IS configuration examples
Example: Configuring IPv6 IS-IS basics
As shown in Figure 18, Switch A, Switch B, Switch C, and Switch D, all enabled with IPv6, reside in the same AS. Configure IPv6 IS-IS on the switches so that they can reach each other.
Switch A and Switch B are Level-1 switches, Switch D is a Level-2 switch, and Switch C is a Level-1-2 switch.
Figure 18 Network diagram
IMPORTANT
IMPORTANT:
1.     Configure IPv6 addresses for interfaces. (Details not shown.)
2.     Configure IPv6 IS-IS:
[SwitchA] isis 1
[SwitchA-isis-1] address-family ipv6
[SwitchA-isis-1-ipv6] quit
[SwitchA-Vlan-interface100] isis ipv6 enable 1
[SwitchB] isis 1
[SwitchB-isis-1] address-family ipv6
[SwitchB-isis-1-ipv6] quit
[SwitchB-Vlan-interface200] isis ipv6 enable 1
[SwitchC] isis 1
[SwitchC-isis-1] address-family ipv6
[SwitchC-isis-1-ipv6] quit
[SwitchC-Vlan-interface100] isis ipv6 enable 1
[SwitchC-Vlan-interface200] isis ipv6 enable 1
[SwitchC-Vlan-interface300] isis ipv6 enable 1
[SwitchD] isis 1
[SwitchD-isis-1] address-family ipv6
[SwitchD-isis-1-ipv6] quit
[SwitchD-Vlan-interface300] isis ipv6 enable 1
[SwitchD] interface vlan-interface 301
[SwitchD-Vlan-interface301] isis ipv6 enable 1
[SwitchD-Vlan-interface301] quit
# Display the IPv6 IS-IS routing table on Switch A.
[SwitchA] display isis route ipv6
                         Level-1 IPv6 Forwarding Table
 Destination : ::                                      PrefixLen: 0
 Flag        : R/-/-                                   Cost     : 10
 Next Hop    : FE80::200:FF:FE0F:4                     Interface: Vlan100
 Destination : 2001:1::                                PrefixLen: 64
 Flag        : D/L/-                                   Cost     : 10
 Next Hop    : Direct                                  Interface: Vlan100
 Destination : 2001:2::                                PrefixLen: 64
 Flag        : R/-/-                                   Cost     : 20
 Destination : 2001:3::                                PrefixLen: 64
# Display the IPv6 IS-IS routing table on Switch B.
[SwitchB] display isis route ipv6
 Next Hop    : FE80::200:FF:FE0F:4                     Interface: Vlan200
 Next Hop    : Direct                                  Interface: Vlan200
# Display the IPv6 IS-IS routing table on Switch C.
[SwitchC] display isis route ipv6
 Next Hop    : Direct                                  Interface: Vlan300
                         Level-2 IPv6 Forwarding Table
 Destination : 2001:4::1                               PrefixLen: 64
 Next Hop    : FE80::20F:E2FF:FE3E:FA3D                Interface: Vlan300
# Display the IPv6 IS-IS routing table on Switch D.
[SwitchD] display isis route ipv6
 Next Hop    : FE80::200:FF:FE0F:4                     Interface: Vlan300
 Flag        : D/L/-                                   Cost     : 0
 Next Hop    : Direct                                  Interface: Loop1
Example: Configuring BFD for IPv6 IS-IS
As shown in Figure 19:
·     Configure IPv6 IS-IS on Switch A and Switch B so that they can reach other.
·     Enable BFD on VLAN-interface 10 of Switch A and Switch B.
After the link between Switch B and the Layer 2 switch fails, BFD can quickly detect the failure and notify IPv6 IS-IS of the failure. Then Switch A and Switch B communicate through Switch C.
Figure 19 Network diagram
Device
IPv6 address
Device
IPv6 address
Switch A
Vlan-int10
2001::1/64
Switch B
Vlan-int10
2001::2/64
Vlan-int11
2001:2::1/64
Vlan-int13
2001:3::2/64
Switch C
Vlan-int11
2001:2::2/64
Vlan-int13
2001:3::1/64
IMPORTANT
IMPORTANT:
[SwitchA] isis 1
[SwitchA-Vlan-interface10] isis ipv6 enable 1
[SwitchA-Vlan-interface11] isis ipv6 enable 1
[SwitchB] isis 1
[SwitchB-Vlan-interface10] isis ipv6 enable 1
[SwitchB-Vlan-interface13] isis ipv6 enable 1
[SwitchC] isis 1
[SwitchC-Vlan-interface11] isis ipv6 enable 1
[SwitchC-Vlan-interface13] isis ipv6 enable 1
[SwitchA-Vlan-interface10] isis ipv6 bfd enable
[SwitchA-Vlan-interface10] return
[SwitchB-Vlan-interface10] isis ipv6 bfd enable
[SwitchB-Vlan-interface10] bfd detect-multiplier 6
# Display BFD session information on Switch A.
 Total Session Num: 1            Init Mode: Active
 IPv6 session working in control packet mode:
     Local Discr: 1441                Remote Discr: 1450
       Source IP: FE80::20F:FF:FE00:1202 (link-local address of Vlan-interface10 on Switch A)
  Destination IP: FE80::20F:FF:FE00:1200 (link-local address of Vlan-interface10 on Switch B)
   Session State: Up                     Interface: Vlan10
       Hold Time: 2319ms
# Display routes destined for 2001:4::0/64 on Switch A.
<SwitchA> display ipv6 routing-table 2001:4::0 64
Summary Count : 1
Destination: 2001:4::/64                                 Protocol  : IS_L1
NextHop    : FE80::20F:FF:FE00:1200                      Preference: 15
Interface  : Vlan10                                      Cost      : 10
Summary Count : 1
NextHop    : FE80::BAAF:67FF:FE27:DCD0                   Preference: 15
Interface  : Vlan11                                      Cost      : 20
Example: Configuring IPv6 IS-IS FRR
As shown in Figure 20, Switch A, Switch B, and Switch C belong to the same IS-IS routing domain. Configure IPv6 IS-IS FRR so that when the Link A fails, traffic can be switched to Link B immediately.
Figure 20 Network diagram
Table 7 Interface and IP address assignment
Device
IPv6 address
Device
IPv6 address
Switch A
Vlan-int100
1::1/64
Switch B
Vlan-int101
3::1/64
Vlan-int200
2::1/64
Vlan-int200
2::2/64
Loop0
10::1/128
Loop0
20::1/128
Switch C
Vlan-int100
1::2/64
Vlan-int101
3::2/64
IMPORTANT
IMPORTANT:
1.     Configure IPv6 addresses for interfaces on the switches and enable IPv6 IS-IS. (Details not shown.)
2.     Configure IPv6 IS-IS on the switches to make sure Switch A, Switch B, and Switch C can communicate with each other at Layer 3. (Details not shown.)
3.     Configure IPv6 IS-IS FRR:
Enable IPv6 IS-IS FRR to calculate a backup next hop through LFA calculation, or designate a backup next hop by using a routing policy.
¡     (Method 1.) Enable IPv6 IS-IS FRR to calculate a backup next hop through LFA calculation:
[SwitchA] isis 1
[SwitchA-isis-1-ipv6] fast-reroute lfa
[SwitchB] isis 1
[SwitchB-isis-1-ipv6] fast-reroute lfa
¡     (Method 2.) Enable IPv6 IS-IS FRR to designate a backup next hop by using a routing policy:
[SwitchA] ipv6 prefix-list abc index 10 permit 20::1 128
[SwitchA-route-policy-frr-10] if-match ipv6 address prefix-list abc
[SwitchA-route-policy-frr-10] apply ipv6 fast-reroute backup-interface vlan-interface 100 backup-nexthop 1::2
[SwitchA] isis 1
[SwitchA-isis-1-ipv6] fast-reroute route-policy frr
[SwitchB] ipv6 prefix-list abc index 10 permit 10::1 128
[SwitchB-route-policy-frr-10] if-match ipv6 address prefix-list abc
[SwitchB-route-policy-frr-10] apply ipv6 fast-reroute backup-interface vlan-interface 101 backup-nexthop 3::2
[SwitchB] isis 1
[SwitchB-isis-1-ipv6] fast-reroute route-policy frr
# Display route 20::1/128 on Switch A to view the backup next hop information.
[SwitchA] display ipv6 routing-table 20::1 128 verbose
Summary count : 1
Destination: 20::1/128
   Protocol: IS_L1
 Process ID: 1
  SubProtID: 0x1                    Age: 00h27m45s
       Cost: 10              Preference: 15
  OrigTblID: 0xa                OrigVrf: default-vrf
    TableID: 0xa                 OrigAs: 0
      NibID: 0x24000005          LastAs: 0
     AttrID: 0xffffffff        Neighbor: ::
      Flags: 0x10041        OrigNextHop: FE80::34CD:9FF:FE2F:D02
      Label: NULL           RealNextHop: FE80::34CD:9FF:FE2F:D02
    BkLabel: NULL             BkNextHop: FE80::7685:45FF:FEAD:102
# Display route 10::1/128 on Switch B to view the backup next hop information.
[SwitchB] display ipv6 routing-table 10::1 128 verbose
Summary count : 1
Destination: 10::1/128
   Protocol: IS_L1
 Process ID: 1
  SubProtID: 0x1                    Age: 00h33m23s
      NibID: 0x24000006          LastAs: 0
      Flags: 0x10041        OrigNextHop: FE80::34CC:E8FF:FE5B:C02
      Label: NULL           RealNextHop: FE80::34CC:E8FF:FE5B:C02
  • Become a Partner
  • Partner Resources
