- 03-Layer 2—LAN Switching Configuration Guide
- 01-MAC address table configuration
- 02-Bulk interface configuration
- 03-Ethernet interface configuration
- 04-Ethernet link aggregation configuration
- 05-DRNI configuration
- 06-Port isolation configuration
- 07-VLAN configuration
- 08-MVRP configuration
- 09-Loopback, null, and inloopback interface configuration
- 10-VLAN mapping configuration
- 11-Loop detection configuration
- 12-Spanning tree configuration
- 13-LLDP configuration
- 14-Service loopback group configuration
- 15-Layer 2 forwarding configuration
| 15-Layer 2 forwarding configuration | 32.56 KB |
Configuring cut-through Layer 2 forwarding
About cut-through Layer 2 forwarding
Restrictions and guidelines for cut-through Layer 2 forwarding configuration
A cut-through forwarding-enabled device forwards a frame after it receives the first 64 bytes of the frame. This feature reduces the transmission time of a frame and enhances forwarding performance.
With cut-through forwarding, the device forwards CRC-error frames because it starts forwarding frames before their CRC field is received.
1. Enter system view.
2. Enable cut-through forwarding.
cut-through enable
By default, cut-through forwarding is disabled.
