- 01-Fundamentals Configuration Guide
- 01-CLI configuration
- 02-RBAC configuration
- 03-Login management configuration
- 04-FTP and TFTP configuration
- 05-File system management configuration
- 06-Configuration file management configuration
- 07-Software upgrade configuration
- 08-ISSU configuration
- 09-GIR configuration
- 10-Automatic configuration
- 11-Preprovisioning feature configuration
- 12-Device management configuration
- 13-Tcl configuration
- 14-Python configuration
- 15-License management
| 12-Device management configuration | 325.04 KB |
Device management tasks at a glance
Configuring the system identifier
Restrictions and guidelines for configuring the system time
System time configuration tasks at a glance
Setting the system time at the CLI
Obtaining the UTC time through a time protocol
Setting the daylight saving time
Enabling displaying the copyright statement
Disabling password recovery capability
Disabling BootWare menu access
Setting the system operating mode
Setting the TCAM operating mode
Setting the packet parsing mode
Setting the UNI operating mode
Setting the port status detection timer
Setting memory alarm thresholds
Configuring resource monitoring
Setting the temperature alarm thresholds
Configuring hardware failure detection and protection
Specifying the actions to be taken for hardware failures
Enabling hardware failure protection for aggregation groups
Configuring parity error logging for entries on forwarding chips
Configuring consistency error logging for software and hardware forwarding entries
Power supply management tasks at a glance
Enabling power supply management
Specifying the number of redundant power supplies
Enabling power supply sleeping
Configuring the exception monitoring mode for power supplies
Verifying and diagnosing transceiver modules
Diagnosing transceiver modules
Specifying an ITU channel number for a transceiver module
Configuring transceiver monitoring
Configuring an asset profile for a physical component
Isolating switching fabric modules
Suppressing removal interrupt signals from switching fabric modules
Enabling shutdown of service ports
Enabling power on/off management of cards
Restrictions and guidelines for device reboot
Rebooting the device immediately at the CLI
Rebooting the X86 server unit of the LSXM1X86SUPE1 cloud SEU
Restoring the factory-default configuration
Display and maintenance commands for device management configuration
Managing the device
This chapter describes how to configure basic device parameters and manage the device.
All device management tasks are optional. You can perform any of the tasks in any order.
· Configuring basic parameters
¡ Configuring the system identifier
¡ Enabling displaying the copyright statement
· Configuring security parameters
¡ Disabling password recovery capability
¡ Disabling BootWare menu access
· Adjusting device capacities
¡ Setting the system operating mode
¡ Setting the TCAM operating mode
¡ Setting the packet parsing mode
¡ Setting the UNI operating mode
¡ Setting the port status detection timer
· Monitoring the device
¡ Setting memory alarm thresholds
¡ Configuring resource monitoring
¡ Setting the temperature alarm thresholds
¡ Configuring hardware failure detection and protection
¡ Managing resources
¡ Verifying and diagnosing transceiver modules
¡ Specifying an ITU channel number for a transceiver module
¡ Configuring transceiver monitoring
· Maintaining the device
¡ Configuring an asset profile for a physical component
¡ Isolating switching fabric modules
¡ Suppressing removal interrupt signals from switching fabric modules
¡ Enabling shutdown of service ports
¡ Enabling power on/off management of cards
¡ Restoring the factory-default configuration
Configuring the device name
A device name (also called hostname) identifies a device in a network and is used in CLI view prompts. For example, if the device name is Sysname, the user view prompt is <Sysname>.
On an underlay network, the device uses the device name that you have configured for it. If you do not configure a device name for the device but automated underlay network deployment is enabled, the device uses the device name assigned by the VCF fabric feature. For more information about VCF fabric, see VCF fabric configuration in Network Management and Monitoring Configuration Guide.
1. Enter system view.
sysname sysname
By default, the device name is H3C.
Configure a system identifier for the device to indicate the location, functionality, or user-defined identifier of the device.
2. Configure the system identifier for the device.
sysid system-id
By default, the device does not have a system identifier.
Configuring the system time
About the system time
Correct system time is essential to network management and communication. Configure the system time correctly before you run the device on the network.
The device can use one of the following methods to obtain the system time:
· Uses the locally set system time, and then uses the clock signals generated by its built-in crystal oscillator to maintain the system time.
· Periodically obtains the UTC time from an NTP/PTP source, and uses the UTC time, time zone, and daylight saving time to calculate the system time. For more information about NTP and PTP, see Network Management and Monitoring Configuration Guide.
The system time calculated by using the UTC time from a time source is more precise.
After you use the clock protocol none command, the clock datetime command determines the system time, whether or not the time zone or daylight saving time has been configured.
If you configure or change the time zone or daylight saving time after the device obtains the system time, the device recalculates the system time. To view the system time, use the display clock command.
This feature is supported only on the default MDC. All MDCs on the device use the same system time.
To configure the system time, perform the following tasks:
1. Configuring the system time
¡ Setting the system time at the CLI
¡ Obtaining the UTC time through a time protocol
2. (Optional.) Setting the time zone
Make sure each network device uses the time zone of the place where the device resides.
3. (Optional.) Setting the daylight saving time
Make sure each network device uses the daylight saving time parameters of the place where the device resides.
2. Configure the device to use the local system time.
clock protocol none
By default, the device uses the NTP time source specified on the default MDC.
If you execute the clock protocol command multiple times, the most recent configuration takes effect.
3. Return to user view.
4. Set the local system time.
clock datetime time date
By default, the system time is UTC time 00:00:00 01/01/2011.
CAUTION: This command changes the system time, which affects execution of system time-related features (for example, scheduled tasks) and collaborative operations of the device with other devices (for example, log reporting and statistics collection). Before executing this command, make sure you fully understand its impact on your live network. |
2. Specify the system time source.
clock protocol { ntp | ptp } mdc mdc-id
3. Configure time protocol parameters.
For more information about NTP and PTP configuration, see Network Management and Monitoring Configuration Guide.
2. Set the time zone.
By default, the system uses the UTC time zone.
2. Set the daylight saving time.
By default, the daylight saving time is not set.
This feature enables the device to display the copyright statement in the following situations:
· When a Telnet or SSH user logs in.
· When a console user quits user view. This is because the device automatically tries to restart the user session.
If you disable displaying the copyright statement, the device does not display the copyright statement in any situations.
2. Enable displaying the copyright statement.
copyright-info enable
By default, displaying the copyright statement is enabled.
Configuring banners
Banners are messages that the system displays when a user logs in.
The system supports the following banners:
· Legal banner—Appears after the copyright statement. To continue login, the user must enter Y or press Enter. To quit the process, the user must enter N. Y and N are case insensitive.
· Message of the Day (MOTD) banner—Appears after the legal banner and before the login banner.
· Login banner—Appears only when password or scheme authentication is configured.
· Shell banner—Appears for a user when the user accesses user view.
The system displays the banners in the following order: legal banner, MOTD banner, login banner, and shell banner.
Banner input methods
You can configure a banner by using one of the following methods:
· Input the entire command line in a single line.
The banner cannot contain carriage returns. The entire command line, including the command keywords, the banner, and the delimiters, can have a maximum of 511 characters. The delimiters for the banner can be any printable character but must be the same. You cannot press Enter before you input the end delimiter.
For example, you can configure the shell banner "Have a nice day." as follows:
<System> system-view
[System] header shell %Have a nice day.%
· Input the command line in multiple lines.
The banner can contain carriage returns. A carriage return is counted as two characters.
To input a banner configuration command line in multiple lines, use one of the following methods:
¡ Press Enter after the final command keyword, type the banner, and end the final line with the delimiter character %. The banner plus the delimiter can have a maximum of 1999 characters.
For example, you can configure the banner "Have a nice day." as follows:
Have a nice day.%
¡ After you type the final command keyword, type any printable character as the start delimiter for the banner and press Enter. Then, type the banner and end the final line with the same delimiter. The banner plus the end delimiter can have a maximum of 1999 characters.
[System] header shell A
Please input banner content, and quit with the character 'A'.
Have a nice day.A
¡ After you type the final command keyword, type the start delimiter and part of the banner. Make sure the final character of the final string is different from the start delimiter. Then, press Enter, type the rest of the banner, and end the final line with the same delimiter. The banner plus the start and end delimiters can have a maximum of 2002 characters.
[System] header shell AHave a nice day.
A
2. Configure the legal banner.
header legal text
3. Configure the MOTD banner.
header motd text
4. Configure the login banner.
header login text
5. Configure the shell banner.
header shell text
Password recovery capability controls console user access to the device configuration and SDRAM from BootWare menus. For more information about BootWare menus, see the release notes.
If password recovery capability is enabled, a console user can access the device configuration without authentication to configure a new password.
If password recovery capability is disabled, console users must restore the factory-default configuration before they can configure new passwords. Restoring the factory-default configuration deletes the next-startup configuration files.
To enhance system security, disable password recovery capability.
(In standalone mode.) (In IRF mode.) To access the device configuration without authentication, you must connect to the active MPU and access the BootWare menu while the MPU is starting up.
2. Disable password recovery capability.
undo password-recovery enable
By default, password recovery capability is enabled.
By default, anyone can press Ctrl+B during device startup to access the BootWare menu, load software, and manage storage media. To prevent unauthorized access, disable BootWare menu access.
To disable BootWare menu access, execute the following command in user view:
undo bootrom-access enable
By default, access to the BootWare menu is enabled.
Disabling USB interfaces
You can use USB interfaces to upload or download files. By default, all USB interfaces are enabled. You can disable USB interfaces as needed.
Before using this command, use the umount command to unmount all USB partitions. For more information about this command, see Fundamentals Command Reference.
2. Disable USB interfaces.
usb disable
Supported features and feature specifications vary by system operating mode.
The device can operate in one of the following modes:
· advance—Advanced mode. This mode is used to support FCoE. It does not support EVPN or VXLAN.
· bridgee—Enhanced Layer 2 mode. It supports L2VPN but does not support FCoE, PVLAN, tunneling, or VXLAN.
· standard—Standard mode. This mode does not support FCoE. Typically, this mode is used.
Change to the system operating mode takes effect after a device reboot.
2. Set the system operating mode.
system-working-mode { advance | bridgee | standard }
By default, the device operates in standard mode.
The ternary content addressable memory (TCAM) provides an extended memory space for the device to store ARP, ACL, and routing entries. The TCAM operating mode determines the types of entries that the TCAM stores.
Table 1 describes the TCAM operating modes and the supported entry types on HF cards.
Table 1 TCAM operating modes and supported entry types on HF cards
TCAM operating mode |
HF card |
ACL mode |
Stores IPv4 ACLs. |
IPv6 mode |
Stores ARP entries, ND entries, IPv4 routing entries, and IPv6 routing entries. For the HF card, this mode is the same as the routing mode. |
Mixed mode |
Stores IPv4 ACLs, ARP entries, ND entries, IPv4 routing entries, and IPv6 routing entries. |
Normal mode |
Does not store any entries. |
Routing mode |
Stores ARP entries, ND entries, IPv4 routing entries, and IPv6 routing entries. |
2. Set the TCAM operating mode.
hardware-resource tcam { acl | ipv6 | mix | normal | routing }
By default, the TCAM operating mode is routing.
3. Save the running configuration to the next-startup configuration file.
save
To avoid configuration loss, use the save command to save the running configuration before a reboot. For more information about the save command, see Fundamentals Command Reference.
4. Return to user view.
5. Delete the .mdb next-startup configuration file.
delete
For more information about the delete command, see Fundamentals Command Reference.
6. Reboot the device.
Reboot
In some scenarios, the device cannot parse incoming user packets correctly. To resolve the issue, you can set the packet parsing mode to network tap so the device redirects incoming user packets to certain ports to parse the packets correctly.
Use the network tap mode with caution. This mode might affect the following features: link aggregation hash, ECMP hash, redirect, and VLAN mapping.
For a packet parsing mode change to take effect, save the running configuration and reboot the device.
2. Set the packet parsing mode.
hardware-resource parser { normal | network-tap }
By default, the packet parsing mode is normal.
A user–network interface (UNI) is a user-side interface for ARP and ND entries to share hardware forwarding entries. You can configure the UNI operating mode to change the sharing method, as shown in Table 2.
Table 2 UNI operating modes for hardware forwarding entry sharing
UNI operating mode |
Normal mode |
IPv4 ARP entries that have the same 44 bits from the left in MAC addresses share the same hardware resource entry. IPv6 ND entries with the same MAC address share the same hardware resource entry. ARP entries and ND entries do not share resources. |
Enhanced mode |
IPv4 ARP entries with the same MAC address share the same hardware resource entry. IPv6 ND entries with the same MAC address share the same hardware resource entry. ARP and ND entries with the same MAC address share the same hardware resource entry. |
Ultra-enhanced mode |
This mode is available only for HF cards with FPGA. In this mode, the following rules apply: · IPv4 ARP entries that have the same 44 bits from the left in MAC addresses share the same hardware resource entry. · IPv6 ND entries that have the same 44 bits from the left in MAC addresses share the same hardware resource entry. · ARP entries and ND entries that have the same 44 bits from the left in MAC addresses share the same hardware resource entry. |
The ultra-enhanced mode is available only for HF cards.
For a UNI operating mode change to take effect, perform the following tasks:
1. Save the running configuration to the next-startup configuration file.
2. Delete the .mdb binary file for the next-startup configuration file.
3. Reboot the device.
2. Set the UNI operating mode.
hardware-resource uni { normal | enhance-uni | ultra-uni }
By default, the UNI operating mode is normal.
Display and maintenance commands for UNI operating mode configuration
To display UNI operating mode information, execute the following command in any view:
display hardware-resource uni
The device starts a port status detection timer when a port is shut down by a protocol. Once the timer expires, the device brings up the port so the port status reflects the port's physical status.
2. Set the port status detection timer.
shutdown-interval time
The default setting is 30 seconds.
Monitoring CPU usage
To monitor CPU usage, the device performs the following operations:
· Samples CPU usage at 1-minute intervals, and compares the samples with CPU usage thresholds to identify the CPU usage status and send alarms or notifications accordingly.
· Samples CPU core usage at 1-minute intervals, and compares the samples with CPU core usage thresholds to identify the CPU core usage status. If a sample is greater than the threshold, the device sends a log message.
· Samples and saves CPU usage at a configurable interval if CPU usage tracking is enabled. You can use the display cpu-usage history command to display the historical CPU usage statistics in a coordinate system.
The device supports the following CPU usage thresholds:
· Minor threshold—If the CPU usage increases to or above the minor threshold but is less than the severe threshold, the CPU usage enters minor alarm state. The device sends minor alarms periodically until the CPU usage increases above the severe threshold or the minor alarm is removed.
· Severe threshold—If the CPU usage increases above the severe threshold, the CPU usage enters severe alarm state. The device sends severe alarms periodically until the severe alarm is removed.
· Recovery threshold—If the CPU usage decreases below the recovery threshold, the CPU usage enters recovered state. The device sends a recovery notification.
CPU usage alarms and notifications can be sent to NETCONF, SNMP, and the information center to be encapsulated as NETCONF events, SNMP traps and informs, and log messages. For more information, see NETCONF, SNMP, and information center in Network Management and Monitoring Configuration Guide.
Figure 1 CPU alarms and alarm-removed notifications
2. Set the CPU usage alarm thresholds.
In standalone mode:
monitor cpu-usage threshold severe-threshold { minor-threshold minor-threshold recovery-threshold recovery-threshold [ slot slot-number [ cpu cpu-number ] ] | slot slot-number cpu cpu-number [ core core-id-list ] }
In IRF mode:
monitor cpu-usage threshold severe-threshold { minor-threshold minor-threshold recovery-threshold recovery-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
The default settings are as follows:
¡ Severe CPU usage alarm threshold—99%.
¡ Minor CPU usage alarm threshold—80%.
¡ CPU usage recovery threshold—60%.
CAUTION: If you set the severe CPU usage alarm threshold to a too low value, the device will reach the threshold easily. Normal services will be affected. |
3. Set CPU usage alarm resending intervals.
In standalone mode:
In IRF mode:
monitor resend cpu-usage { minor-interval minor-interval | severe-interval severe-interval } * [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
By default, the minor alarm resending interval is 300 seconds and the severe alarm resending interval is 60 seconds.
4. Set the sampling interval for CPU usage tracking.
In standalone mode:
In IRF mode:
monitor cpu-usage interval interval [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
By default, the sampling interval for CPU usage tracking is 1 minute.
5. Enable CPU usage tracking.
In standalone mode:
In IRF mode:
monitor cpu-usage enable [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
By default, CPU usage tracking is enabled.
To ensure correct operation and improve memory efficiency, the system monitors the amount of free memory space in real time. If the amount of free memory space decreases below the minor, severe, or critical alarm threshold, the system issues an alarm to affected service modules and processes.
The system can also issue an early warning to warn you of an approaching insufficient-memory condition.
The system monitors the amount of free memory space. You can use the display memory command to display memory usage information.
As shown in the following table and figure, the system supports these free-memory thresholds:
· Sufficient-memory threshold.
· Early-warning threshold.
· Normal state threshold.
· Minor alarm threshold.
· Severe alarm threshold.
· Critical alarm threshold.
Table 3 Memory alarm notifications and memory alarm-removed notifications
Notification |
Triggering condition |
Remarks |
Early-warning notification |
The amount of free memory space decreases below the early-warning threshold. |
After generating and sending an early-warning notification, the system does not generate and send any additional early-warning notifications until the early warning is removed. |
Minor alarm notification |
The amount of free memory space decreases below the minor alarm threshold. |
After generating and sending a minor alarm notification, the system does not generate and send any additional minor alarm notifications until the minor alarm is removed. |
Severe alarm notification |
The amount of free memory space decreases below the severe alarm threshold. |
After generating and sending a severe alarm notification, the system does not generate and send any additional severe alarm notifications until the severe alarm is removed. |
Critical alarm notification |
The amount of free memory space decreases below the critical alarm threshold. |
After generating and sending a critical alarm notification, the system does not generate and send any additional critical alarm notifications until the critical alarm is removed. |
Critical alarm-removed notification |
The amount of free memory space increases above the severe alarm threshold. |
N/A |
Severe alarm-removed notification |
The amount of free memory space increases above the minor alarm threshold. |
N/A |
Minor alarm-removed notification |
The amount of free memory space increases above the normal state threshold. |
N/A |
Early-warning-removed notification |
The amount of free memory space increases above the sufficient-memory threshold. |
N/A |
Figure 2 Memory alarm notifications and alarm-removed notifications
If a memory alarm occurs, delete unused configuration items or disable some features to increase the free memory space. Because the memory space is insufficient, some configuration items might not be able to be deleted.
2. Set the memory usage threshold.
In standalone mode:
In IRF mode:
memory-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] usage memory-threshold
By default, the memory usage threshold is 100%.
3. Set the free-memory thresholds.
In standalone mode:
In IRF mode:
memory-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] [ ratio ] minor minor-value severe severe-value critical critical-value normal normal-value [ early-warning early-warning-value secure secure-value ]
¡ Minor alarm threshold—256 MB.
¡ Severe alarm threshold—192 MB.
¡ Critical alarm threshold—128 MB.
¡ Normal state threshold—320 MB.
¡ Early-warning threshold—384 MB.
¡ Sufficient-memory threshold—448 MB.
4. Set memory depletion alarm resending intervals.
In standalone mode:
In IRF mode:
monitor resend memory-threshold { critical-interval critical-interval | early-warning-interval early-warning-interval | minor-interval minor-interval | severe-interval severe-interval } * [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
The following are the default settings:
¡ Early warning resending interval—1 hour.
¡ Minor alarm resending interval—12 hours.
¡ Severe alarm resending interval—3 hours.
¡ Critical alarm resending interval—1 hour.
The resource monitoring feature enables the device to monitor the available amounts of types of resources, for example, the space for ARP entries. The device samples the available amounts periodically and compares the samples with resource depletion thresholds to identify the resource depletion status.
The device supports a minor resource depletion threshold and a severe resource depletion threshold for each supported resource type.
· If the available amount is equal to or less than the minor resource depletion threshold but greater than the severe resource depletion threshold, the resource type is in minor alarm state.
· If the available amount is equal to or less than the severe resource depletion threshold, the resource type is in severe alarm state.
· If the available amount increases above the minor resource depletion threshold, the resource type is in recovered state.
When a resource type enters severe alarm state, the device issues a severe alarm. If the resource type stays in severe alarm state, the device resends severe alarms periodically.
When a resource type enters minor alarm state, the device issues a minor alarm. If the resource type stays in minor alarm state or changes from severe alarm state to minor alarm state, the device identifies whether resending of minor resource depletion alarms is enabled. If the feature is disabled, the device does not issue additional minor alarms. If the feature is enabled, the device resends minor alarms periodically.
Resource depletion alarms can be sent to NETCONF, SNMP, and the information center to be encapsulated as NETCONF events, SNMP traps and informs, and log messages. For more information, see NETCONF, SNMP, and information center in Network Management and Monitoring Configuration Guide.
Figure 3 Resource depletion alarms and alarm-removed notifications
2. Set resource depletion thresholds.
In standalone mode:
In IRF mode:
resource-monitor resource resource-name chassis chassis-number slot slot-number cpu cpu-number by-percent minor-threshold minor-threshold severe-threshold severe-threshold
The default settings vary by resource type. Use the display resource-monitor command to display the resource depletion thresholds.
3. Specify destinations for resource depletion alarms.
By default, resource depletion alarms are sent to NETCONF, SNMP, and the information center.
4. Enable resending of minor resource depletion alarms.
resource-monitor minor resend enable
By default, resending of minor resource depletion alarms is enabled.
The device monitors its temperature based on the following thresholds:
· Low-temperature threshold.
· High-temperature warning threshold.
· High-temperature alarming threshold.
When the device temperature drops below the low-temperature threshold or reaches the high-temperature warning or alarming threshold, the device performs the following operations:
· Sends log messages and traps.
· Sets LEDs on the device panel.
2. Configure the temperature alarm thresholds.
In standalone mode:
temperature-limit slot slot-number { hotspot | inflow } sensor-number lowlimit warninglimit [ alarmlimit ]
In IRF mode:
temperature-limit chassis chassis-number slot slot-number { hotspot | inflow } sensor-number lowlimit warninglimit [ alarmlimit ]
The defaults vary by temperature sensor model. To view the defaults, execute the undo temperature-limit and display environment commands in turn.
The high-temperature alarming threshold must be higher than the high-temperature warning threshold, and the high-temperature warning threshold must be higher than the low-temperature threshold.
The device can automatically detect hardware failures on components, cards, and the forwarding plane, and take actions in response.
The device can take the following actions in response to hardware failures:
· isolate—Performs the following tasks as appropriate to reduce impact from the failures:
¡ Shuts down the relevant ports.
¡ Prohibits loading software for the relevant cards.
¡ Isolates the relevant cards.
¡ Powers off the relevant cards.
· reset—Restarts the relevant components or cards to recover from failures.
· warning—Sends traps to report the failures.
You can configure this feature only on the default MDC. However, the configuration takes effect on all MDCs.
2. Specify the action to be taken in response to a type of hardware failures.
hardware-failure-detection { board | chip | forwarding } { off | isolate | reset | warning }
By default, the system takes the action of warning in response to hardware failures.
2. Set the action to be taken in response to failures on the forwarding plane to isolate.
hardware-failure-detection forwarding isolate
By default, the system takes the action of warning in response to forwarding-plane failures.
This command is supported only on the default MDC.
3. Enable hardware failure protection for aggregation groups.
hardware-failure-protection aggregation
By default, hardware failure protection is disabled for aggregation groups.
About parity error logging for entries on forwarding chips
The device automatically detects parity errors in entries on forwarding chips. The parity error logging feature collects parity error statistics periodically, and generates a log message if the number of parity errors reaches the logging threshold.
2. Set the parity error statistics period for entries on forwarding chips.
parity-error monitor period value
The default parity error statistics period is 60 seconds for entries on forwarding chips.
3. Set the parity error logging threshold for entries on forwarding chips.
parity-error monitor threshold value
The default parity error logging threshold is 5000 for entries on forwarding chips.
4. Enable parity error logging for entries on forwarding chips.
parity-error monitor log enable
By default, parity error logging is disabled for entries on forwarding chips.
To forward packets, the device generates hardware forwarding entries in forwarding chips and software forwarding entries in memory at the same time. The device automatically detects whether the hardware forwarding entries and the software forwarding entries are consistent.
The consistency error logging for software and hardware forwarding entries enables the device to collect statistics for consistency errors periodically. If the number of consistency errors reaches or exceeds the logging threshold, the device generates a log message.
2. Set the statistics period for consistency errors between software and hardware forwarding entries.
parity-error consistency-check period value
The default statistics period is 3600 seconds.
3. Set the logging threshold for consistency errors between software and hardware forwarding entries.
parity-error consistency-check threshold value
The default logging threshold is 10.
4. Enable consistency error logging for software and hardware forwarding entries.
parity-error consistency-check log enable
By default, consistency error logging is disabled for software and hardware forwarding entries.
Managing power supply
About power supply management
Power supplies might have problems such as overload overcurrent, overvoltage, overtemperature, and short circuit. Some power supplies use a hardware protection measure, for example, powering off the device, to protect the entire device from being damaged. The hardware protection measure helps protect the device but causes service outage. The power supply management feature can minimize service outage while protecting the device against overload problems.
The power supply management feature constantly monitors the available power and the system loads. If a potential power supply overload problem is found, this feature takes protective measures immediately to remove requirements for power supply hardware protection. Examples of protective measures include sending a notification, starting redundant power supplies, and powering off certain interface cards.
To manage power supply, perform the following tasks:
1. Enabling power supply management
2. (Optional.) Specifying the number of redundant power supplies
To avoid overload problems, you can install redundant power supplies.
3. (Optional.) Powering on or off a card
You can manually power on or off cards.
4. (Optional.) Enabling power supply sleeping
This feature decreases energy consumption.
5. (Optional.) Configuring the exception monitoring mode for power supplies
2. Enable power supply management.
In standalone mode:
power-supply policy enable
In IRF mode:
power-supply policy chassis chassis-number enable
By default, power supply management is enabled.
To avoid overload problems, you can install redundant power supplies. For example, if the device requires a minimum of N power supplies to operate correctly, you can install M power supplies (M > N). The M power supplies operate in load balance mode. When a power supply fails, the load is rebalanced among the other power supplies.
After you specify the number of redundant power supplies, the device compares the maximum power consumption of a newly added card with the remaining power.
· If the remaining power is sufficient for the card, the device powers on the card.
· If the power is insufficient, the device does not power on the card. You can add power supplies or scale the number of redundant power supplies down.
This feature takes effect only if power supply management is enabled.
2. Specify the number of redundant power supplies.
In standalone mode:
power-supply policy redundant module-count
In IRF mode:
power-supply policy chassis chassis-number redundant module-count
The default setting is 0.
You can manually power on or off cards. To view the power supply status, use the display power-supply command.
To power on or power off a card, you must enable power supply management first.
(In IRF mode.) To avoid IRF split, do not power off an interface card that contains the only active physical IRF port.
Powering on a card
To power on a card, execute one of the following commands in user view:
In standalone mode:
power-supply on slot slot-number
In IRF mode:
power-supply on chassis chassis-number slot slot-number
Powering off a card
To power off a card, execute one of the following commands in user view:
In standalone mode:
power-supply off slot slot-number
In IRF mode:
power-supply off chassis chassis-number slot slot-number
CAUTION: A card will not send or receive packets after you power off it. Execute this command with caution. |
This feature enables the device to monitor the remaining power in real time.
· If the remaining power is greater than the power of a power supply, the device places the power supply into sleeping state.
· When the remaining power becomes insufficient, the device wakes up a sleeping power supply.
This feature is supported only on switches that contain the PSR2400-54A, PSR2400-54D, or PSR3000-54A power module.
This feature takes effect only when power supply management is enabled.
Power supply modules in sleeping state cannot act as the backup power supplies. When an operating power supply fails or is removed, the device might not be able to operate correctly.
To view the operating status of power supplies, execute the display power command.
2. Enable power supply sleeping.
power-supply surplus-power enable
The enhanced exception monitoring mode for the power supplies occupies lots of system resources.
2. Configure the exception monitoring mode for the power supplies.
power-exception-monitor { normal | enhanced }
By default, the normal exception monitoring mode applies to the power supplies.
Verifying transceiver modules
You can use one of the following methods to verify the genuineness of a transceiver module:
· Display the key parameters of a transceiver module, including its transceiver type, connector type, central wavelength of the transmit laser, transfer distance, and vendor name.
· Display its electronic label. The electronic label is a profile of the transceiver module and contains the permanent configuration, including the serial number, manufacturing date, and vendor name. The data was written to the transceiver module or the device's storage component during debugging or testing of the transceiver module or device.
The device regularly checks transceiver modules for their vendor names. If a transceiver module does not have a vendor name or the vendor name is not H3C, the device repeatedly outputs traps and log messages. For information about logging rules, see Network Management and Monitoring Configuration Guide.
To verify transceiver modules, execute the following commands in any view:
· Display the key parameters of transceiver modules.
· Display the electrical label information of transceiver modules.
The device provides the alarm and digital diagnosis functions for transceiver modules. When a transceiver module fails or is not operating correctly, you can perform the following tasks:
· Check the alarms that exist on the transceiver module to identify the fault source.
· Examine the key parameters monitored by the digital diagnosis function, including the temperature, voltage, laser bias current, TX power, and RX power.
To diagnose transceiver modules, execute the following commands in any view:
· Display transceiver alarms.
· Display the current values of the digital diagnosis parameters on transceiver modules.
ITU numbers and identifies fiber signals by wavelength and frequency. A transceiver module sends signals of a specific wavelength and frequency based on the specified ITU channel number.
This feature is required in dense wavelength division multiplexing scenarios.
This feature is supported only on the SFP-XG-LH80-Tunable transceiver module.
The ITU channel number is saved in a register on the transceiver module. It is not saved to the configuration file.
2. Enter Ethernet interface view.
3. Specify an ITU channel number.
itu-channel channel-number
By default, the ITU channel number is 1.
After transceiver monitoring is enabled, the device samples the parameters of transceiver modules periodically, including the input power and output power of transceiver modules. If a sampled value reaches the alarm threshold, the device generates a log to notify users.
2. Set the transceiver monitoring interval.
transceiver monitor interval interval
By default, the transceiver monitoring interval is 600 seconds.
3. Enable transceiver monitoring.
transceiver monitor enable
By default, transceiver monitoring is disabled.
Scheduling a task
About task scheduling
You can schedule the device to automatically execute a command or a set of commands without administrative interference.
You can configure a periodic schedule or a non-periodic schedule. A non-periodic schedule is not saved to the configuration file and is lost when the device reboots. A periodic schedule is saved to the startup configuration file and is automatically executed periodically.
· To assign a command (command A) to a job, you must first assign the job the command or commands for entering the view of command A.
· Make sure all commands in a schedule are compliant to the command syntax. The system does not check the syntax when you assign a command to a job.
· A schedule cannot contain any one of these commands: telnet, ftp, ssh2, and monitor process.
· A schedule does not support user interaction. If a command requires a yes or no answer, the system always assumes that a Y or Yes is entered. If a command requires a character string input, the system assumes that either the default character string (if any) or a null string is entered.
· A schedule is executed in the background, and no output (except for logs, traps, and debug information) is displayed for the schedule.
2. Create a job.
scheduler job job-name
3. Assign a command to the job.
command id command
By default, no command is assigned to a job.
You can assign multiple commands to a job. A command with a smaller ID is executed first.
4. Exit to system view.
5. Create a schedule.
6. Assign a job to the schedule.
job job-name
By default, no job is assigned to a schedule.
You can assign multiple jobs to a schedule. The jobs will be executed concurrently.
7. Assign user roles to the schedule.
user-role role-name
By default, a schedule has the user role of the schedule creator.
You can assign a maximum of 64 user roles to a schedule. A command in a schedule can be executed if it is permitted by one or more user roles of the schedule.
8. Specify the execution time for the schedule.
Choose one option as needed:
¡ Execute the schedule at specific points of time.
time at time date
¡ Execute the schedule after a period of time.
time once delay time
¡ Execute the schedule at the specified time on every specified day in a month or week.
¡ Execute the schedule periodically from the specified time on.
time repeating [ at time [date ] ] interval interval
By default, no execution time is specified for a schedule.
The time commands overwrite each other. The most recently used command takes effect.
9. (Optional.) Set the schedule log file size limit.
scheduler logfile size value
By default, the schedule log file size limit is 16 KB.
The schedule log file stores log messages for execution results of commands in jobs. After the limit is reached, the system deletes the oldest log messages to store the new log messages. If the remaining space of the log file is not enough for a single log message, the system truncates the message and does not store the extra part.
Example: Scheduling a task
As shown in Figure 4, two interfaces of the device are connected to users.
To save energy, configure the device to perform the following operations:
· Enable the interfaces at 8:00 a.m. every Monday through Friday.
· Disable the interfaces at 18:00 every Monday through Friday.
# Enter system view.
# Configure a job for disabling interface FortyGigE 1/0/1.
[Sysname] scheduler job shutdown-FortyGigE1/0/1
[Sysname-job-shutdown-FortyGigE1/0/1] command 1 system-view
[Sysname-job-shutdown-FortyGigE1/0/1] command 2 interface fortygige 1/0/1
[Sysname-job-shutdown-FortyGigE1/0/1] command 3 shutdown
[Sysname-job-shutdown-FortyGigE1/0/1] quit
# Configure a job for enabling interface FortyGigE 1/0/1.
[Sysname] scheduler job start-FortyGigE1/0/1
[Sysname-job-start-FortyGigE1/0/1] command 1 system-view
[Sysname-job-start-FortyGigE1/0/1] command 2 interface fortygige 1/0/1
[Sysname-job-start-FortyGigE1/0/1] command 3 undo shutdown
[Sysname-job-start-FortyGigE1/0/1] quit
# Configure a job for disabling interface FortyGigE 1/0/2.
[Sysname] scheduler job shutdown-FortyGigE1/0/2
[Sysname-job-shutdown-FortyGigE1/0/2] command 1 system-view
[Sysname-job-shutdown-FortyGigE1/0/2] command 2 interface fortygige 1/0/2
[Sysname-job-shutdown-FortyGigE1/0/2] command 3 shutdown
[Sysname-job-shutdown-FortyGigE1/0/2] quit
# Configure a job for enabling interface FortyGigE 1/0/2.
[Sysname] scheduler job start-FortyGigE1/0/2
[Sysname-job-start-FortyGigE1/0/2] command 1 system-view
[Sysname-job-start-FortyGigE1/0/2] command 2 interface fortygige 1/0/2
[Sysname-job-start-FortyGigE1/0/2] command 3 undo shutdown
[Sysname-job-start-FortyGigE1/0/2] quit
# Configure a periodic schedule for enabling the interfaces at 8:00 a.m. every Monday through Friday.
[Sysname] scheduler schedule START-pc1/pc2
[Sysname-schedule-START-pc1/pc2] job start-FortyGigE1/0/1
[Sysname-schedule-START-pc1/pc2] job start-FortyGigE1/0/2
[Sysname-schedule-START-pc1/pc2] time repeating at 8:00 week-day mon tue wed thu fri
[Sysname-schedule-START-pc1/pc2] quit
# Configure a periodic schedule for disabling the interfaces at 18:00 every Monday through Friday.
[Sysname] scheduler schedule STOP-pc1/pc2
[Sysname-schedule-STOP-pc1/pc2] job shutdown-FortyGigE1/0/1
[Sysname-schedule-STOP-pc1/pc2] job shutdown-FortyGigE1/0/2
[Sysname-schedule-STOP-pc1/pc2] time repeating at 18:00 week-day mon tue wed thu fri
[Sysname-schedule-STOP-pc1/pc2] quit
# Display the configuration information of all jobs.
[Sysname] display scheduler job
Job name: shutdown-FortyGigE1/0/1
shutdown
Job name: shutdown-FortyGigE1/0/2
shutdown
Job name: start-FortyGigE1/0/1
Job name: start-FortyGigE1/0/2
# Display the schedule information.
[Sysname] display scheduler schedule
Schedule name : START-pc1/pc2
Schedule type : Run on every Mon Tue Wed Thu Fri at 08:00:00
Start time : Wed Sep 28 08:00:00 2011
Last execution time : Wed Sep 28 08:00:00 2011
Last completion time : Wed Sep 28 08:00:03 2011
Execution counts : 1
Job name Last execution status
start-FortyGigE1/0/1 Successful
start-FortyGigE1/0/2 Successful
Schedule name : STOP-pc1/pc2
Schedule type : Run on every Mon Tue Wed Thu Fri at 18:00:00
Start time : Wed Sep 28 18:00:00 2011
Last execution time : Wed Sep 28 18:00:00 2011
Last completion time : Wed Sep 28 18:00:01 2011
shutdown-FortyGigE1/0/1 Successful
shutdown-FortyGigE1/0/2 Successful
# Display schedule log information.
[Sysname] display scheduler logfile
Job name : start-FortyGigE1/0/1
Execution time : Wed Sep 28 08:00:00 2011
Completion time : Wed Sep 28 08:00:02 2011
<Sysname>system-view
[Sysname]interface fortygige 1/0/1
[Sysname-FortyGigE1/0/1]undo shutdown
Job name : start-FortyGigE1/0/2
[Sysname]interface fortygige 1/0/2
[Sysname-FortyGigE1/0/2]undo shutdown
Job name : shutdown-FortyGigE1/0/1
Execution time : Wed Sep 28 18:00:00 2011
Completion time : Wed Sep 28 18:00:01 2011
[Sysname-FortyGigE1/0/1]shutdown
Job name : shutdown-FortyGigE1/0/2
[Sysname-FortyGigE1/0/2]shutdown
For device asset management, you can configure an asset profile for each physical component.
2. Configure an asset profile for a physical component.
In standalone mode:
set asset-info { chassis | fan fan-id | power power-id | slot slot-number } { csn csn-number | custom name value | department department | description description | location location | service-date date | state state }
In IRF mode:
set asset-info chassis chassis-number { chassis | fan fan-id | power power-id | slot slot-number } { csn csn-number | custom name value | department department | description description | location location | service-date date | state state }
Isolating a switching fabric module isolates the module from the data plane. An isolated switching fabric module continues to communicate with the MPU, and can forward traffic immediately after the isolation is canceled. The isolation does not affect protocol packet parsing and protocol calculation on the control plane.
You can isolate switching fabric modules to identify whether switching fabric modules can forward traffic correctly.
Before replacing a switching fabric module, you can isolate the module to prevent packet loss.
To use an isolated switching fabric module or channel, use the undo switch-fabric isolate command to cancel the isolation.
2. Isolate a switching fabric module or channel.
In standalone mode:
switch-fabric isolate slot slot-number [ channel channel-number ]
In IRF mode:
switch-fabric isolate chassis chassis-number slot slot-number [ channel channel-number ]
By default, a switching fabric module is not isolated and can forward traffic.
CAUTION: · Use this command only if required. If the device has multiple switching fabric modules, isolating a switching fabric module decreases the forwarding bandwidth and reduces the forwarding performance. · Do not isolate the only switching fabric module of the device. · Do not reboot the device when a switching fabric module is isolated. |
Typically, removing a switching fabric module triggers one removal interrupt signal. Upon receiving the signal, the system switches traffic on the switching fabric module to other switching fabric modules to ensure service continuity. Upon hardware failure or signal interference, however, removal interrupt signals might be frequently triggered. To prevent the interrupt signals from affecting system operation, use this feature to suppress the interrupt signals.
2. Suppress removal interrupt signals from switching fabric modules.
switch-fabric removal-signal-suppression
By default, removal interrupt signals from switching fabric modules are not suppressed.
CAUTION: Suppressing removal interrupt signals from switching fabric modules might result in packet loss and service outage. |
This task is typically used in active/standby dual host scenarios (such as VRRP). After the task is executed, the system will shut down all service ports on the active device when the connection between the MPU and the service modules on the active device times out, or no fabric modules are detected. As a consequence, all services will be switched to the standby device rapidly.
2. Enable shutdown of all service ports.
monitor { handshake-timeout | fab-absent } disable-port
After the power-monitor enable command is executed, the system performs the following operations:
· Check the total system power and the power distribution on the cards to determine whether to power on cards.
· Check the card temperature and fan tray conditions to determine whether to power off cards.
If power on/off management of cards is disabled, the device will not manage the power-on and -off of the cards, and all cards are powered on by default.
Disabling power on/off management of cards might result in unpredictable risks. Perform this task with caution.
2. Enable power on/off management of cards.
In standalone mode:
In IRF mode:
power-monitor enable chassis chassis-number
By default, power on/off management of cards is enabled.
Isolating a service module
When a service module fails, you can use this feature to isolate it to prevent it from affecting traffic forwarding. An isolated service module does not receive traffic.
A service module reboot cancels the isolation of the service module.
To display service module operating status, execute the display device command. An isolated service module is in Offline state.
2. Isolate a service module.
In standalone mode:
switch-linecard isolate slot slot-number
In IRF mode:
switch-linecard isolate chassis chassis-number slot slot-number
Enabling chip reset
This task enables the system to reset a chip when an alarm indicating that the chip is faulty is generated.
2. Enable chip reset.
monitor chipblock reset [ logging ]
By default, chip reset is enabled.
About device reboot
The following device reboot methods are available:
· Schedule a reboot at the CLI, so the device automatically reboots at the specified time or after the specified period of time.
· Reboot the standby MPU by using restart standby.
This feature is available only in standalone mode.
· Immediately reboot the device at the CLI.
· Power off and then power on the device. This method might cause data loss, and is the least-preferred method.
· To reboot the X86 server unit of the LSXM1X86SUPE1 cloud SEU, use the x86-server reboot command. To reboot the switching control unit, use the reboot command.
Using the CLI, you can reboot the device from a remote host.
For data security, the device does not reboot while it is performing file operations.
Perform the following steps in any view:
1. Verify that the next-startup configuration file is correctly specified.
display startup
For more information about the display startup command, see Fundamentals Command Reference.
2. Verify that the startup image files are correctly specified.
display boot-loader
If one main startup image file is damaged or does not exist, you must specify another main startup image file before rebooting the device.
For more information about the display boot-loader command, see Fundamentals Command Reference.
save
To avoid configuration loss, save the running configuration before a reboot.
To reboot the device immediately at the CLI, execute one of the following commands in user view:
In standalone mode:
In IRF mode:
CAUTION: · A device reboot might result in service interruption. Before using this command, make sure you fully understand its impact on your live network. · Use the force keyword to reboot the device only when the system is faulty or fails to start up normally. A forced device reboots might cause file system damage. Before using the force keyword to reboot the device, make sure you understand its impact. |
Rebooting the standby MPU
Using this feature has the same effect as specifying the slot number for the reboot slot slot-number command and executing the command. This feature does not require you to specify an argument and is easier to use.
2. Reboot the standby MPU.
restart standby
Scheduling a device reboot
(In standalone mode.) The automatic reboot configuration is canceled if an active/standby switchover occurs.
(In IRF mode.) The automatic reboot configuration is effective on all member devices. It will be canceled if a switchover between the global active MPU and a global standby MPU occurs.
The device supports only one device reboot schedule. If you execute the scheduler reboot command multiple times, the most recent configuration takes effect.
To schedule a reboot, execute one of the following commands in user view:
· scheduler reboot at time [ date ]
· scheduler reboot delay time
By default, no device reboot time is specified.
CAUTION: A device reboot might cause service interruption. |
This feature is used only for rebooting the X86 server unit of the LSXM1X86SUPE1 cloud SEU. To reboot the switching control unit, use the reboot command.
Execute one of the following commands in user view:
In standalone mode:
x86-server reboot slot slot-number
In IRF mode:
x86-server reboot chassis chassis-number slot slot-number
If you want to use the device in a different scenario or you cannot troubleshoot the device by using other methods, use this task to restore the factory-default configuration.
This task does not delete .bin files and license files.
CAUTION: This task restores the device to the factory default settings. Perform this task with caution. |
1. Execute the following command in user view to restore the factory-default configuration for the device:
restore factory-default
2. Reboot the device.
reboot
When the command prompts you to choose whether to save the running configuration, enter N. If you choose to save the running configuration, the device loads the saved configuration at startup.
Execute display commands in any view. Execute the reset scheduler logfile command in user view. Execute the reset version-update-record command in system view.
Task |
Command |
Display device alarm information. |
In standalone mode: display alarm [ slot slot-number ] In IRF mode: display alarm [ chassis chassis-number slot slot-number ] |
Display the asset profile for a physical component. |
In standalone mode: display asset-info { chassis | fan fan-id | power power-id | slot slot-number } [ csn | custom| department | description | location | service-date | state ] In IRF mode: display asset-info chassis chassis-number { chassis | fan fan-id | power power-id | slot slot-number } [ csn | custom| department | description | location | service-date | state ]
Display the BootWare menu access authorization status. |
display bootrom-access |
Display brand information for MPUs. |
display brand |
Display the system time, date, time zone, and daylight saving time. |
display clock |
Display the copyright statement. |
display copyright |
Display CPU usage statistics. The core keyword is mutually exclusive with the control-plane and data-plane keywords. |
In standalone mode: display cpu-usage [ control-plane | data-plane ] [ summary ] [ slot slot-number [ cpu cpu-number [ core { core-number | all } ] ] ] In IRF mode: display cpu-usage [ control-plane | data-plane ] [ summary ] [ chassis chassis-number slot slot-number [ cpu cpu-number [ core { core-number | all } ] ] ] |
Display CPU usage monitoring settings. |
In standalone mode: display cpu-usage configuration [ slot slot-number [ cpu cpu-number ] ] In IRF mode: display cpu-usage configuration [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] |
Display the historical CPU usage statistics in a coordinate system. |
In standalone mode: display cpu-usage history [ job job-id ] [ slot slot-number [ cpu cpu-number ] ] In IRF mode: display cpu-usage history [ job job-id ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] |
Display hardware information. |
In standalone mode: display device[ flash | usb ] [ slot slot-number [ subslot subslot-number ] | verbose ] In IRF mode: display device[ flash | usb ] [ chassis chassis-number [ slot slot-number [ subslot subslot-number ] ] | verbose ] |
Display electronic label information for the device. |
In standalone mode: display device manuinfo [ slot slot-number [ subslot subslot-number ] ] In IRF mode: display device manuinfo [ chassis chassis-number [ slot slot-number [ subslot subslot-number ] ] ] |
Display electronic label information for the chassis backplane. |
In standalone mode: display device manuinfo chassis-only In IRF mode: display device manuinfo chassis chassis-number chassis-only |
Display electronic label information for a fan tray. |
In standalone mode: display device manuinfo fan fan-id In IRF mode: display device manuinfo chassis chassis-number fan fan-id |
Display electronic label information for a power supply. |
In standalone mode: display device manuinfo power power-id In IRF mode: display device manuinfo chassis chassis-number power power-id |
Display or save operating information for features and hardware modules. |
display diagnostic-information [ hardware | infrastructure | l2 | l3 | service ] [ key-info ] [ filename ] |
Display device temperature information. |
In standalone mode: display environment [ slot slot-number | vent ] In IRF mode: display environment [ chassis chassis-number [ slot slot-number ] ] |
Display the operating states of fan trays. |
In standalone mode: display fan [ fan-id ] In IRF mode: display fan [ chassis chassis-number [ fan-id ] ] |
Display hardware failure detection and fix information. |
display hardware-failure-detection |
Display the packet parsing mode. |
display hardware-resource [ parser ] |
Display hardware resource operating mode information. |
display hardware-resource [ tcam ] |
Display UNI operating mode information. |
display hardware-resource [ uni ] |
Display memory usage statistics. |
In standalone mode: display memory [ summary ] [ slot slot-number [ cpu cpu-number ] ] In IRF mode: display memory [ summary ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] |
Display memory alarm thresholds and statistics. |
In standalone mode: display memory-threshold [ slot slot-number [ cpu cpu-number ] ] In IRF mode: display memory-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] |
Display power supply information. |
In standalone mode: display power [ power-id | verbose ] In IRF mode: display power [ chassis chassis-number [ power-id | verbose ] ] |
Display resource monitoring information. |
In standalone mode: display resource-monitor [ resource resource-name ] [ slot slot-number [ cpu cpu-number ] ] In IRF mode: display resource-monitor [ resource resource-name ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] |
Display job configuration information. |
display scheduler job [ job-name ] |
Display job execution log information. |
display scheduler logfile |
Display the automatic reboot schedule. |
display scheduler reboot |
Display schedule information. |
display scheduler schedule [ schedule-name ] |
Display system heath status information. |
In standalone mode: display system health In IRF mode: display display system health [ chassis chassis-number ] |
Display historical system heath status change information. |
In standalone mode: display system health history In IRF mode: display system health history[ chassis chassis-number ] |
Display system stability and status information. |
display system stable state[ mdc { mdc-id | all } ] |
Display system working mode information. |
display system-working-mode |
Display ITU channel information for transceiver modules. This command is supported only on the SFP-XG-LH80-Tunable transceiver module. |
display transceiver itu-channel interface [ interface-type interface-number [ supported-channel ] ] |
Display system version information. |
display version |
Display startup software image upgrade records. |
display version-update-record |
Clear the asset profile for a physical component. |
In standalone mode: reset asset-info { chassis | fan fan-id | power power-id | slot slot-number } [ csn | custom | department | description | location | service-date | state ] In IRF mode: reset asset-info chassis chassis-number { chassis | fan fan-id | power power-id | slot slot-number } [ csn | custom | department | description | location | service-date | state ] |
Clear job execution log information. |
reset scheduler logfile |
Clear startup software image upgrade records. |
reset version-update-record |
NOTE: · Executing the display cpu-usage, display cpu-usage configuration, or display memory command on an MDC displays information for the MDC. · The display device command displays device information about the physical devices, no matter whether you execute the command on the default MDC or on a non-default MDC. · The following commands are supported only on the default MDC: ¡ display device manuinfo ¡ display device manuinfo chassis-only ¡ display device manuinfo fan ¡ display device manuinfo power ¡ display environment ¡ display fan ¡ display power |
NOTE: The following commands are supported only on the default MDC: · display alarm · display bootrom-access · display brand · display dying-gasp host · display fabric utilization · display hardware-failure-detection · display hardware-resource tcam · display lpu-type · display memory-threshold · display power-supply · display rps · display save-power · display system-working-mode · display version-update-record · display voltage · display xbar · reset scheduler logfile · reset version-update-record |
