08-ACL and QoS Command Reference
HomeSupportResource CenterSwitchesS6890 SeriesS6890 SeriesTechnical DocumentsReference GuidesCommand ReferencesH3C S6890 Switch Series Command References(R28xx)-6W10008-ACL and QoS Command Reference
03-MPLS QoS commands
03-MPLS QoS commands 51.89 KB
MPLS QoS commands
if-match mpls-exp
Use if-match mpls-exp to define a criterion to match the EXP field in the first (topmost) MPLS label.
Use undo if-match mpls-exp to delete the match criterion.
if-match mpls-exp exp-value&<1-8>
undo if-match mpls-exp exp-value&<1-8>
No criterion is defined to match the EXP field in the first (topmost) MPLS label.
Traffic class view
exp-value&<1-8>: Specifies a space-separated list of up to eight EXP values. The value range for the exp-value argument is 0 to 7. If the same EXP value is specified multiple times, the system considers them as one. If a packet matches one of the defined MPLS EXP values, it matches the if-match clause.
# Define a criterion to match packets with EXP value 3 or 4 in the topmost MPLS label.
[Sysname] traffic classifier database
[Sysname-classifier-database] if-match mpls-exp 3 4
if-match mpls-label
Use if-match mpls-label to define a criterion to match the topmost MPLS label.
Use undo if-match mpls-label to delete the match criterion.
if-match mpls-label { label-value&<1-8> | label-value1 to label-value2 }
undo if-match mpls-label { label-value&<1-8> | label-value1 to label-value2 }
No criterion is defined to match the topmost MPLS label.
Traffic class view
label-value&<1-8>: Specifies a space-separated list of up to eight MPLS label values. The value range for the label-value argument is 0 to 1048575.
label-value1 to label-value2: Specifies a range of MPLS label values. The value for label-value2 must be greater than or equal to the value for label-value1. The value range for the label-value argument is 0 to 1048575.
You can configure multiple MPLS label values in one command.
·     If the same MPLS label value is specified multiple times, the system considers them as one.
·     If a packet matches one of the defined MPLS label values, it matches the if-match clause.
# Define a criterion to match packets with topmost MPLS label values in the range of 1 to 1000.
[Sysname-classifier-database] if-match mpls-label 1 to 1000
if-match second-mpls-exp
Use if-match second-mpls-exp to define a criterion to match the EXP field in the second MPLS label.
Use undo if-match second-mpls-exp to delete the match criterion.
if-match second-mpls-exp exp-value&<1-8>
undo if-match second-mpls-exp exp-value&<1-8>
No criterion is defined to match the EXP field in the second MPLS label.
Traffic class view
exp-value&<1-8>: Specifies a space-separated list of up to eight EXP values. The value range for the exp-value argument is 0 to 7. If the same MPLS EXP value is specified multiple times, the system considers them as one. If a packet matches one of the defined MPLS EXP values, it matches the if-match clause.
# Define a criterion to match packets with EXP value 3 or 4 in the second MPLS label.
[Sysname-classifier-database] if-match second-mpls-exp 3 4
if-match second-mpls-label
Use if-match second-mpls-label to define a criterion to match the second MPLS label.
Use undo if-match second-mpls-label to delete the match criterion.
if-match second-mpls-label { label-value&<1-8> | label-value1 to label-value2 }
undo if-match second-mpls-label { label-value&<1-8> | label-value1 to label-value2 }
No criterion is defined to match the second MPLS label.
Traffic class view
# Define a criterion to match packets with the second MPLS label value in the range of 1 to 1000.
[Sysname-classifier-database] if-match second-mpls-label 1 to 1000
remark mpls-exp
Use remark mpls-exp to configure an EXP value marking action in a traffic behavior.
Use undo remark mpls-exp to delete the action.
remark mpls-exp exp-value
No EXP value marking action is configured in a traffic behavior.
Traffic behavior view
exp-value: Specifies an EXP value in the range of 0 to 7.
If an MPLS packet has multiple labels, this command marks the topmost label.
# Set the EXP value to 0 for MPLS packets.
[Sysname-behavior-database] remark mpls-exp 0
  • Become a Partner
  • Partner Resources
