08-ACL and QoS Command Reference
HomeSupportResource CenterSwitchesS6890 SeriesS6890 SeriesTechnical DocumentsReference GuidesCommand ReferencesH3C S6890 Switch Series Command References(R28xx)-6W10008-ACL and QoS Command Reference
02-QoS commands
02-QoS commands 431.16 KB
QoS policy commands· 1
Traffic class commands· 1
description· 1
display traffic classifier 1
if-match· 2
traffic classifier 10
Traffic behavior commands· 10
accounting· 10
car 11
display traffic behavior 12
filter 13
mac-address mac-learning enable· 14
nest top-most 15
packet-rate· 16
redirect 16
remark dot1p· 17
remark drop-precedence· 18
remark dscp· 18
remark local-precedence· 20
remark qos-local-id· 20
remark service-class· 21
remark service-vlan-id· 22
traffic behavior 22
QoS policy commands· 23
classifier behavior 23
control-plane· 24
display qos policy· 24
display qos policy control-plane· 26
display qos policy control-plane pre-defined· 27
display qos policy diagnosis control-plane· 29
display qos policy diagnosis global 30
display qos policy diagnosis interface· 32
display qos policy diagnosis l2vpn-ac· 35
display qos policy global 36
display qos policy interface· 38
display qos policy l2vpn-ac· 41
display qos vlan-policy· 42
display qos vlan-policy diagnosis· 43
qos apply policy· 45
qos apply policy global 47
qos policy· 48
qos vlan-policy· 50
reset qos policy control-plane· 50
reset qos policy global 51
reset qos vlan-policy· 51
Priority mapping commands· 53
Priority map commands· 53
display qos map-table· 53
dot1p-trust-tc· 54
import 55
qos map-table· 55
Priority trust mode commands· 56
display qos trust interface· 56
qos trust 57
Port priority commands· 57
qos priority· 57
GTS and rate limit commands· 59
GTS commands· 59
display qos gts interface· 59
qos gts· 59
Rate limit commands· 60
display qos lr interface· 60
qos lr 61
Congestion management commands· 62
Common commands· 62
display qos queue interface· 62
SP commands· 62
display qos queue sp interface· 62
qos sp· 63
WRR commands· 64
display qos queue wrr interface· 64
qos wrr 65
qos wrr { byte-count | weight } 65
qos wrr group sp· 67
WFQ commands· 67
display qos queue wfq interface· 67
qos bandwidth queue· 68
qos wfq· 69
qos wfq { byte-count | weight } 70
qos wfq group sp· 71
Queue scheduling profile commands· 72
bandwidth queue· 72
display qos qmprofile configuration· 72
display qos qmprofile interface· 74
qos apply qmprofile· 74
qos qmprofile· 75
queue· 76
Congestion avoidance commands· 78
WRED commands· 78
display qos wred interface· 78
display qos wred table· 78
qos wred apply· 80
qos wred queue table· 80
queue· 81
queue ecn· 82
queue weighting-constant 83
Aggregate CAR commands· 84
car name· 84
display qos car name· 84
qos car 85
reset qos car name· 86
Queue-based accounting commands· 87
display qos queue-statistics interface outbound· 87
display statistic mode· 88
reset qos queue-statistics interface outbound· 89
statistic mode queue· 89
QoS policy commands
description
Use description to configure a description for a traffic class.
No description is configured for a traffic class.
Traffic class view
text: Specifies a description, a case-sensitive string of 1 to 127 characters.
# Configure the description as classifier for traffic class class1.
[Sysname-classifier-class1] description classifier
Use display traffic classifier to display traffic classes.
user-defined: Specifies user-defined traffic classes.
classifier-name: Specifies a traffic class by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a traffic class, this command displays all traffic classes.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays the traffic classes for the master device.
# Display all user-defined traffic classes.
  User-defined classifier information:
   Classifier: 1 (ID 100)
     Operator: AND
     Rule(s) :
      If-match acl 2000
   Classifier: 2 (ID 101)
     Operator: AND
     Rule(s) :
      If-match protocol ipv6
   Classifier: 3 (ID 102)
     Operator: AND
     Rule(s) :
      -none-
Classifier
Traffic class name and its match criteria.
Operator
Match operator you set for the traffic class. If the operator is AND, the traffic class matches the packets that match all its match criteria. If the operator is OR, the traffic class matches the packets that match any of its match criteria.
Rule(s)
Match criteria.
if-match
Use if-match to define a match criterion.
Use undo if-match to delete a match criterion.
if-match match-criteria
undo if-match match-criteria
No match criterion is configured.
Traffic class view
match-criteria: Specifies a match criterion. Table 2 shows the available match criteria.
Table 2 Available match criteria
Option
acl [ ipv6 | mac | user-defined ] { acl-number | name acl-name } [ inner ]
Matches an ACL.
The value range for the acl-number argument is as follows:
·     2000 to 3999 for IPv4 ACLs.
·     2000 to 3999 for IPv6 ACLs.
·     4000 to 4999 for Layer 2 MAC ACLs.
·     5000 to 5999 for user-defined ACLs.
The acl-name argument is a case-insensitive string of 1 to 63 characters, which must start with an English letter. To avoid confusion, make sure the argument is not all.
You can use the inner keyword to match the inner header information of VXLAN packets. For example, a rule permit ip source 10.0.0.0 0.255.255.255 statement matches the inner source IP address of VXLAN packets if the inner keyword is specified in the if-match acl command. The statement matches the source IP address of non-VXLAN packets or the outer source IP address of VXLAN packets if the inner keyword is not specified.
If you specify the inner keyword in the if-match acl command, you must also specify it when executing the undo if-match acl command.
If no VPN instance is specified in an ACL rule, the ACL rule takes effect on both non-VPN packets and VPN packets.
any
Matches all packets.
control-plane protocol protocol-name&<1-8>
Matches control plane protocols.
The protocol-name&<1-8> argument specifies a space-separated list of up to eight system-defined control plane protocols. For available system-defined control plane protocols, see Table 3.
control-plane protocol-group protocol-group-name
Matches a control plane protocol group.
The protocol-group-name argument can be critical, important, management, monitor, normal, or redirect.
customer-dot1p dot1p-value&<1-8>
Matches 802.1p priority values in inner VLAN tags of double-tagged packets.
The dot1p-value&<1-8> argument specifies a space-separated list of up to eight 802.1p priority values. The value range for the dot1p-value argument is 0 to 7.
customer-vlan-id vlan-id-list
Matches VLAN IDs in inner VLAN tags of double-tagged packets.
The vlan-id-list argument specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN or a range of VLANs in the form of vlan-id1 to vlan-id2. The value for vlan-id2 must be greater than or equal to the value for vlan-id1. The value range for the vlan-id argument is 1 to 4094.
destination-mac mac-address
Matches a destination MAC address.
This option takes effect only on Ethernet interfaces.
dscp dscp-value&<1-8>
Matches DSCP values.
The dscp-value&<1-8> argument specifies a space-separated list of up to eight DSCP values. The value range for the dscp-value argument is 0 to 63 or keywords shown in Table 5.
forwarding-layer bridge
Matches Layer 2 forwarded packets.
inbound-interface interface-type interface-number
Matches an input interface specified by its type and number.
ip-precedence ip-precedence-value&<1-8>
Matches IP precedence values.
The ip-precedence-value&<1-8> argument specifies a space-separated list of up to eight IP precedence values. The value range for the ip-precedence-value argument is 0 to 7.
mpls-exp exp-value&<1-8>
Matches MPLS EXP values.
The exp-value&<1-8> argument specifies a space-separated list of up to eight EXP values. The value range for the exp-value argument is 0 to 7.
mpls-label { label-value&<1-8> | label-value1 to label-value2 }
Matches MPLS labels.
The label-value&<1-8> argument specifies a space-separated list of up to eight MPLS label values. The label-value1 to label-value2 option specifies a range of MPLS label values. The value for label-value2 must be greater than or equal to the value for label-value1. The value range for the label-value argument is 0 to 1048575.
mpls { l2vpn | l3vpn }
Matches the MPLS VPN type:
·     l2vpn—Matches L2VPN packets.
·     l3vpn—Matches L3VPN packets.
Matches a protocol.
The protocol-name argument can be ip or ipv6.
qos-local-id local-id-value
Matches a local QoS ID in the range of 1 to 4095.
second-mpls-exp exp-value&<1-8>
Matches inner MPLS EXP values.
The exp-value&<1-8> argument is a space-separated list of up to eight EXP values. The value range for the exp-value argument is 0 to 7.
second-mpls-label { label-value&<1-8> | label-value1 to label-value2 }
Matches inner MPLS labels.
service-dot1p dot1p-value&<1-8>
Matches 802.1p priority values in outer VLAN tags.
service-vlan-id vlan-id-list
Matches VLAN IDs in outer VLAN tags.
You can use this option to match single-tagged packets.
source-mac mac-address
Matches a source MAC address.
traffic-type { unicast | unknown-unicast | broadcast | multicast }
Matches the packet type:
·     unicast—Matches unicast packets.
·     unknown-unicast—Matches unknown unicast packets.
·     broadcast—Matches broadcast packets.
·     multicast—Matches multicast packets.
For a traffic class to match multiple packet types, you must specify the OR operator when creating the class.
vlan-tag { double | none | single }
Matches the VLAN tagging mode:
·     double—Matches double-tagged packets.
·     none—Matches packets with no tags.
·     single—Matches single-tagged packets.
vxlan { any | vxlan-id }
Matches a VXLAN ID.
Table 3 Available system-defined control plane protocols
Protocol
arp
ARP packets
arp-snooping
ARP snooping packets
bfd
BFD packets
bgp
BGP packets
bgp4+
IPv6 BGP packets
default
Protocol packets other than the packet types listed in this table
dhcp
DHCP packets
dhcp-snooping
DHCP snooping packets
dhcp6
IPv6 DHCP packets
dldp
DLDP packets
dot1x
802.1X packets
hoplimit-expires
Hop-limit expire packets
icmp
ICMP packets
icmp6
ICMPv6 packets
igmp
IGMP packets
ip-option
IPv4 packets with the Options field
ipv6-option
IPv6 packets with the Options field
isis
IS-IS packets
lacp
LACP packets
lldp
LLDP packets
mvrp
MVRP packets (including GVRP packets)
ospf-multicast
OSPF multicast packets
ospf-unicast
OSPF unicast packets
ospf3-multicast
OSPFv3 multicast packets
ospf3-unicast
OSPFv3 unicast packets
pim-multicast
PIM multicast packets
pim-unicast
PIM unicast packets
pim6-multicast
IPv6 PIM multicast packets
pim6-unicast
IPv6 PIM unicast packets
radius
RADIUS packets
snmp
SNMP packets
ssh
SSH packets
stp
STP packets
tacacs
TACACS packets
telnet
Telnet packets
ttl-expires
TTL expire packets
vrrp
VRRP packets
vrrp6
IPv6 VRRP packets
In a traffic class with the logical OR operator, you can configure multiple if-match commands for any of the available match criteria.
When you configure a match criterion that can have multiple values in one if-match command, follow these restrictions and guidelines:
·     You can specify up to eight values for any of the following match criteria in one if-match command:
¡     Control plane protocol.
¡     802.1p priority.
¡     DSCP.
¡     IP precedence.
¡     MPLS EXP.
¡     MPLS label.
¡     VLAN ID.
·     If a packet matches one of the specified values, it matches the if-match command.
·     To delete a criterion that has multiple values, the specified values in the undo if-match command must be the same as those specified in the if-match command. The order of the values can be different.
When you configure ACL-based match criteria, follow these restrictions and guidelines:
·     The ACL must already exist.
·     An ACL can only match the following inner header information of VXLAN packets:
¡     Source IP address.
¡     Destination IP address.
¡     Source port number.
¡     Destination port number.
¡     Transport protocol type.
·     The ACL is used for classification only and the permit/deny actions in ACL rules are ignored. Actions taken on matching packets are defined in traffic behaviors.
You can use both AND and OR operators to define the match relationships between the criteria for a class. For example, you can define relationships among three match criteria in traffic class classA as follows:
traffic classifier classB operator and
if-match criterion 1
if-match criterion 2
traffic classifier classA operator or
if-match criterion 3
If a traffic class in a QoS policy includes the customer-vlan-id match criterion, the QoS policy can be applied only to interfaces.
If a traffic class includes both the control-plane protocol or control-plane protocol-group criterion and other criteria, the QoS policy that contains the traffic class cannot be applied correctly.
If any traffic class in a QoS policy includes the control-plane protocol or control-plane protocol-group match criterion, the QoS policy can be applied only to a control plane.
For the customer-vlan-id and service-vlan-id match criteria, you can configure multiple values in one if-match command.
# Define a match criterion for traffic class class1 to match the packets with a destination MAC address of 0050-ba27-bed3.
# Define a match criterion for traffic class class2 to match the packets with a source MAC address of 0050-ba27-bed2.
# Define a match criterion for traffic class class1 to match the double-tagged packets with 802.1p priority 3 in the inner VLAN tag.
# Define a match criterion for traffic class class1 to match the packets with 802.1p priority 5 in the outer VLAN tag.
[Sysname-classifier-class1] if-match service-dot1p 5
# Define a match criterion for traffic class class1 to match advanced ACL 3101.
# Define a match criterion for traffic class class1 to match the ACL named flow.
# Define a match criterion for traffic class class1 to match advanced IPv6 ACL 3101.
# Define a match criterion for traffic class class1 to match the IPv6 ACL named flow.
# Define a match criterion for traffic class class1 to match all packets.
# Define a match criterion for traffic class class1 to match the packets with a DSCP value of 1, 6, or 9.
[Sysname] traffic classifier class1 operator or
[Sysname-classifier-class1] if-match dscp 1 6 9
# Define a match criterion for traffic class class1 to match the packets with an IP precedence value of 1 or 6.
[Sysname-classifier-class1] if-match ip-precedence 1 6
# Define a match criterion for traffic class class1 to match IP packets.
# Define a match criterion for traffic class class1 to match double-tagged packets with VLAN ID 1, 6, or 9 in the inner VLAN tag.
# Define a match criterion for traffic class class1 to match the packets with VLAN ID 2, 7, or 10 in the outer VLAN tag.
[Sysname-classifier-class1] if-match service-vlan-id 2 7 10
# Define a match criterion for traffic class class1 to match the packets with a local QoS ID of 3.
[Sysname-classifier-class1] if-match qos-local-id 3
# Define a match criterion for traffic class class1 to match packets with MPLS labels in the range of 1 to 10000.
[Sysname-classifier-class1] if-match mpls-label 1 to 10000
# Define a match criterion for traffic class class1 to match MPLS L2VPN packets.
[Sysname-classifier-class1] if-match mpls l2vpn
# Define a match criterion for traffic class class1 to match Layer 2 forwarded packets.
[Sysname-classifier-class1] if-match forwarding-layer bridge
# Define a match criterion for traffic class class1 to match ARP protocol packets.
[Sysname-classifier-class1] if-match control-plane protocol arp
# Define a match criterion for traffic class class1 to match packets of the protocols in protocol group normal.
[Sysname-classifier-class1] if-match control-plane protocol-group normal
# Define a match criterion for traffic class class1 to match multicast packets.
[Sysname-classifier-class1] if-match traffic-type multicast
# Define a match criterion for traffic class class1 to match double-tagged packets.
[Sysname-classifier-class1] if-match vlan-tag double
 # Define a match criterion for traffic class class1 to match the packets with VXLAN 10.
[Sysname-classifier-class1] if-match vxlan 10
traffic classifier
Use traffic classifier to create a traffic class and enter its view, or enter the view of an existing traffic class.
Use undo traffic classifier to delete a traffic class.
No traffic classes exist.
classifier-name: Specifies a name for the traffic class, a case-sensitive string of 1 to 31 characters.
operator: Sets the operator to logic AND (the default) or OR for the traffic class.
and: Specifies the logic AND operator. The traffic class matches the packets that match all its criteria.
or: Specifies the logic OR operator. The traffic class matches the packets that match any of its criteria.
# Create a traffic class named class1.
accounting
Use accounting to configure a traffic accounting action in a traffic behavior.
Use undo accounting to restore the default.
accounting [ byte | packet ] *
undo accounting
No traffic accounting action is configured.
Traffic behavior view
byte: Counts traffic in bytes.
packet: Counts traffic in packets.
If you do not specify the byte or packet keyword, the device counts traffic in packets.
# Configure a traffic accounting action in traffic behavior database to count traffic in bytes.
[Sysname-behavior-database] accounting byte
car
Use car to configure a CAR action in absolute value in a traffic behavior.
Use undo car to restore the default.
car cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ]
car cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ]
undo car
No CAR action is configured.
cir committed-information-rate: Specifies the committed information rate (CIR) in the range of 8 to 160000000 kbps, in increments of 8.
cbs committed-burst-size: Specifies the committed burst size (CBS) in bytes. The value range for committed-burst-size is 512 to 256000000, in increments of 512. The default value for this argument is the product of 62.5 and the CIR and must be an integral multiple of 512. When the product is not an integral multiple of 512, it is rounded up to the nearest integral multiple of 512 that is greater than the product. A default value greater than 256000000 is converted to 256000000.
ebs excess-burst-size: Specifies the excess burst size (EBS) in bytes. The value range for excess-burst-size is 0 to 256000000, in increments of 512. If the PIR is configured, the default EBS is the product of 62.5 and the PIR and must be an integral multiple of 512. When the product is not an integral multiple of 512, it is rounded up to the nearest integral multiple of 512. A default value greater than 256000000 is converted to 256000000.
pir peak-information-rate: Specifies the peak information rate (PIR) in the range of 8 to 160000000 kbps, in increments of 8.
You can apply a QoS policy that contains a traffic policing action to the inbound or outbound direction of an interface, VLANs, a control plane, or globally. However, the traffic policing action takes effect only when the QoS policy is applied to the inbound direction.
To use two rates for traffic policing, configure the car command with the pir peak-information-rate option. To use one rate for traffic policing, configure the car command without the pir peak-information-rate option.
If you execute the car command multiple times in the same traffic behavior, the most recent configuration takes effect.
# Configure a CAR action in traffic behavior database:
·     Set the CIR to 200 kbps, CBS to 51200 bytes, and EBS to 0.
[Sysname-behavior-database] car cir 200 cbs 51200 ebs 0
Use display traffic behavior to display traffic behaviors.
user-defined: Specifies user-defined traffic behaviors.
behavior-name: Specifies a behavior by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a traffic behavior, this command displays all traffic behaviors.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays the traffic behaviors for the master device.
# Display all user-defined traffic behaviors.
  User-defined behavior information:
    Behavior: 1 (ID 100)
      Marking:
        Remark dscp 3
      Committed Access Rate:
        CIR 112 (kbps), CBS 5120 (Bytes), EBS 512 (Bytes)
    Behavior: 2 (ID 101)
      Accounting enable: Packet
      Filter enable: Permit
      Marking:
        Remark mpls-exp 4
      Redirecting:
        Redirect to the CPU
    Behavior: 3 (ID 102)
      -none-
Behavior
Name and contents of a traffic behavior.
Marking
Information about priority marking.
Remark dscp
Action of setting the DSCP value for packets.
Information about the CAR action.
Accounting enable
Class-based accounting action.
Filter enable
Traffic filtering action.
Remark mpls-exp
Action of setting the MPLS EXP value for packets.
Redirecting
Information about traffic redirecting. For information about marking actions, see "redirect."
none
No other traffic behavior is configured.
filter
Use filter to configure a traffic filtering action in a traffic behavior.
Use undo filter to restore the default.
filter { deny | permit }
undo filter
No traffic filtering action is configured.
deny: Drops packets.
permit: Transmits packets. The permitted packets can be processed by other class-behavior associations in the same QoS policy.
# Configure a traffic filtering action as deny in traffic behavior database.
Use mac-address mac-learning enable to enable MAC address learning for a traffic behavior.
Use undo mac-address mac-learning enable to disable MAC address learning for a traffic behavior.
MAC address learning is enabled for a traffic behavior.
To prevent the MAC address table from being saturated when the device is experiencing attacks, disable MAC address learning. For example, you can disable MAC address learning to prevent the device from being attacked by a large number of frames with different source MAC addresses.
Disabling MAC address learning in a traffic behavior takes effect only if the QoS policy is applied to the inbound direction of an interface or globally.
Disabling MAC address learning has the following impacts:
·     The device does not learn new MAC addresses of packets that match the QoS policy and therefore cannot update MAC address changes in real time.
·     The device floods packets that do not match an entry in the MAC address table.
As a best practice, configure broadcast storm suppression on the interface that has the QoS policy applied. For information about broadcast storm suppression, see Layer 2—LAN Switching Configuration Guide.
·     The device does not delete existing MAC addresses until the aging timer expires.
To delete the existing MAC addresses, delete them manually or wait for the aging timer to expire.
# Disable MAC address learning in traffic behavior data.
[Sysname-behavior-data] undo mac-address mac-learning enable
nest top-most
Use nest top-most to configure an outer VLAN tag adding action in a traffic behavior.
Use undo nest top-most to restore the default.
nest top-most vlan vlan-id
undo nest top-most
No outer VLAN tag adding action is configured.
vlan-id vlan-id: Specifies the VLAN ID to be added in the outer VLAN tag, in the range of 1 to 4094.
For a QoS policy that contains a nesting action to take effect on a Type H card, make sure both the downlink port and uplink port permit the single-tagged packets matching the QoS policy. The double-tagged packets are forwarded in the device based on the inner VLAN tag.
If a QoS policy contains an outer VLAN tag adding action, apply it only to the incoming traffic of an interface.
If you execute the nest top-most command multiple times in the same traffic behavior, the most recent configuration takes effect.
An outer VLAN tag adding action takes effect only when the QoS policy is applied to the inbound direction of an interface, VLANs, or globally.
This command does not take effect on packets forwarded by a VXLAN overlay network.
# Configure traffic behavior b1 to add an outer VLAN tag with VLAN ID 123.
[Sysname] traffic behavior b1
[Sysname-behavior-b1] nest top-most vlan 123
packet-rate
Use packet-rate to configure a protocol packet rate limiting action in a traffic behavior.
Use undo packet-rate to restore the default.
packet-rate value
undo packet-rate
No protocol packet rate limiting action is configured.
value: Specifies the protocol packet rate in pps. The value range for this argument is 1 to 1048575. The device converts the specified value to the nearest integral multiple of 43 that is not 0.
Protocol packet rate limiting can protect the CPU against protocol packet attacks.
A protocol packet rate limiting action takes effect only when the QoS policy is applied to a control plane.
If you execute the packet-rate command multiple times in the same traffic behavior, the most recent configuration takes effect.
# Configure traffic behavior copp to rate limit the protocol packets sent to the CPU to 1600 pps.
[Sysname] traffic behavior copp
[Sysname-behavior-copp] packet-rate 1600
redirect
Use redirect to configure a traffic redirecting action in a traffic behavior.
Use undo redirect to restore the default.
redirect { cpu | interface interface-type interface-number | tunnel-group group-id }
undo redirect { cpu | interface interface-type interface-number | tunnel-group }
No traffic redirecting action is configured.
cpu: Redirects traffic to the CPU.
interface interface-type interface-number: Redirects traffic to an interface specified by its type and number.
tunnel-group group-id: Redirects traffic to a tunnel group specified by its ID. The value range for the group-id argument is 1 to 32. For information about tunnel groups, see tunneling in Layer 3—IP Services Configuration Guide.
If you execute the redirect command multiple times in the same traffic behavior, the most recent configuration takes effect.
The redirecting action in a QoS policy takes effect only on Layer 2 packets, and does not take effect on Layer 3 packets.
# Configure redirecting traffic to Ten-GigabitEthernet 1/0/1 in traffic behavior database.
[Sysname-behavior-database] redirect interface ten-gigabitethernet 1/0/1
# Configure redirecting traffic to tunnel group 1 in traffic behavior aa.
[Sysname] traffic behavior aa
[Sysname-behavior-aa] redirect tunnel-group 1
classifier behavior
group (Layer 3—IP Services Command Reference)
qos policy
traffic behavior
remark dot1p
Use remark dot1p to configure an 802.1p priority marking action in a traffic behavior.
Use undo remark dot1p to restore the default.
remark dot1p dot1p-value
undo remark dot1p
No 802.1p priority marking action is configured.
dot1p-value: Specifies the 802.1p priority to be marked for packets, in the range of 0 to 7.
# Configure traffic behavior database to mark matching traffic with 802.1p 2.
[Sysname-behavior-database] remark dot1p 2
Use remark drop-precedence to configure a drop priority marking action in a traffic behavior.
Use undo remark drop-precedence to restore the default.
remark drop-precedence drop-precedence-value
No drop priority marking action is configured.
drop-precedence-value: Specifies the drop priority to be marked for packets, in the range of 0 to 2.
A drop priority marking action takes effect only when the QoS policy is applied to the inbound direction.
If you execute the remark drop-precedence command multiple times in the same traffic behavior, the most recent configuration takes effect.
# Configure traffic behavior database to mark matching traffic with drop priority 2.
[Sysname-behavior-database] remark drop-precedence 2
remark dscp
Use remark dscp to configure a DSCP marking action in a traffic behavior.
Use undo remark dscp to restore the default.
remark dscp dscp-value
undo remark dscp
No DSCP marking action is configured.
dscp-value: Specifies a DSCP value, which can be a number from 0 to 63 or a keyword in Table 5.
Table 5 DSCP keywords and values
Keyword
DSCP value (binary)
DSCP value (decimal)
af11
001010
10
af12
001100
12
af13
001110
14
af21
010010
18
af22
010100
20
af23
010110
22
af31
011010
26
af32
011100
28
af33
011110
30
af41
100010
34
af42
100100
36
af43
100110
38
cs1
001000
8
cs2
010000
16
cs3
011000
24
cs4
100000
32
cs5
101000
40
cs6
110000
48
cs7
111000
56
default
000000
0
ef
101110
46
# Configure traffic behavior database to mark matching traffic with DSCP 6.
Use remark local-precedence to configure a local precedence marking action in a traffic behavior.
Use undo remark local-precedence to restore the default.
remark local-precedence local-precedence-value
No local precedence marking action is configured.
local-precedence-value: Specifies the local precedence to be marked for packets, in the range of 0 to 7.
A local precedence marking action takes effect only when the QoS policy is applied to the inbound direction.
# Configure traffic behavior database to mark matching traffic with local precedence 2.
remark qos-local-id
Use remark qos-local-id to configure a local QoS ID marking action in a traffic behavior.
Use undo remark qos-local-id to restore the default.
remark qos-local-id local-id-value
No local QoS ID marking action is configured.
local-id-value: Specifies the local QoS ID to be marked for packets, in the range of 1 to 4095.
You can use one QoS policy to mark the local QoS ID for packets in the inbound direction. Then, you can use another QoS policy to apply other QoS features in the outbound direction based on the marked local QoS ID.
If you execute the remark qos-local-id command multiple times in the same traffic behavior, the most recent configuration takes effect.
# Configure the action of marking packets with local QoS ID 2.
[Sysname-behavior-database] remark qos-local-id 2
Use remark service-class to configure an MPLS TE service class marking action in a traffic behavior.
Use undo remark service-class to restore the default.
remark service-class service-class-value
No MPLS TE service class marking action is configured.
service-class-value: Specifies the MPLS TE service class to be marked for packets. The value range for this argument is 0 to 7.
This command is used only in CBTS to mark the MPLS TE service class for packets. For more information about CBTS, see MPLS TE in MPLS Configuration Guide.
You can use the mpls te service-class command to set an MPLS TE service class value for a tunnel. For more information about this command, see MPLS TE commands in MPLS Command Reference.
A QoS policy that contains the remark service-class command can only be applied globally.
If you execute the remark service-class command multiple times in the same traffic behavior, the most recent configuration takes effect.
The traffic class associated with the MPLS TE service class marking action can match packets by using only the DSCP value.
# Configure the action of marking MPLS TE service class 2 for packets.
[Sysname-behavior-data] remark service-class 2
Use remark service-vlan-id to configure an SVLAN marking action in a traffic behavior.
Use undo remark service-vlan-id to restore the default.
No SVLAN marking action is configured.
vlan-id: Specifies an SVLAN ID in the range of 1 to 4094.
# Configure traffic behavior b1 to mark matching packets with SVLAN 222.
[Sysname-behavior-b1] remark service-vlan-id 222
traffic behavior
Use traffic behavior to create a traffic behavior and enter its view, or enter the view of an existing traffic behavior.
Use undo traffic behavior to delete a traffic behavior.
No traffic behaviors exist.
behavior-name: Specifies a name for the traffic behavior, a case-sensitive string of 1 to 31 characters.
# Create a traffic behavior named behavior1.
[Sysname-behavior-behavior1]
QoS policy commands
classifier behavior
Use classifier behavior to associate a traffic behavior with a traffic class in a QoS policy.
Use undo classifier to delete a class-behavior association from a QoS policy.
classifier classifier-name behavior behavior-name [ mode { dcbx | loose } | insert-before before-classifier-name ] *
No traffic behavior is associated with a traffic class.
QoS policy view
behavior-name: Specifies a traffic behavior by its name, a case-sensitive string of 1 to 31 characters.
mode dcbx: Specifies that the class-behavior association applies only to the DCBX. For more information about DCBX, see Layer 2—LAN Switching Configuration Guide.
mode loose: Specifies that a class-behavior association is applied in loose mode. This keyword takes effect only when a QoS policy is applied to a control plane.
insert-before before-classifier-name: Inserts the new traffic class before an existing traffic class in the QoS policy. The before-classifier-name argument specifies an existing traffic class by its name, a case-sensitive string of 1 to 31 characters. If you do not specify the insert-before before-classifier-name option, the new traffic class is placed at the end of the QoS policy.
A traffic class can be associated only with one traffic behavior in a QoS policy.
If the specified traffic class or traffic behavior does not exist, the system defines a null traffic class or traffic behavior.
The mode loose keyword allows you to limit the rate of protocol packets from a specific interface to the control plane. The configuration procedure is as follows:
1.     Create an ACL, and configure a rule to match protocol packets.
2.     Create a traffic class with AND operator, and execute the commands in the if-match acl and if-match inbound-interface traffic class.
3.     Create a traffic behavior, configure an action.
4.     Create a QoS policy, and associate the traffic class and the traffic behavior and specify the mode loose keyword.
5.     Apply the QoS policy to a control plane.
The applied QoS policy takes effect on only the protocol packets from the interface specified in the if-match inbound-interface command to the control plane.
# Associate traffic class database with traffic behavior test in QoS policy user1.
[Sysname] qos policy user1
# Associate traffic class database with traffic behavior test in QoS policy user1, and insert traffic class database before an existing traffic class named class-a.
[Sysname-qospolicy-user1] classifier database behavior test insert-before class-a
qos policy
control-plane
Use control-plane to enter control plane view.
# Enter the control plane view of slot 3.
[Sysname] control-plane slot 3
[Sysname-cp-slot3]
display qos policy
Use display qos policy to display QoS policies.
display qos policy user-defined [ accounting | remarking ] [ policy-name [ classifier classifier-name ] ] [ slot slot-number ]
user-defined: Specifies user-defined QoS policies.
accounting: Specifies accounting-type QoS policies.
remarking: Specifies marking-type QoS policies.
policy-name: Specifies a QoS policy by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a QoS policy, this command displays all user-defined QoS policies.
classifier classifier-name: Specifies a traffic class by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a traffic class, this command displays all traffic classes.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays the QoS policies for the master device.
If you do not specify the accounting or remarking keyword, this command displays generic QoS policies.
# Display all user-defined generic QoS policies.
  User-defined QoS policy information:
  Policy: 1 (ID 100)
     Behavior: 1
      Marking:
        Remark dscp 3
        CIR 112 (kbps), CBS 51200 (Bytes), EBS 512 (Bytes)
     Behavior: 2
      Marking:
        Remark dot1p 4
     Behavior: 3
      -none-
# Display user-defined accounting-type QoS policies.
<Sysname> display qos policy user-defined accounting
  Accounting policy: 1 (ID 100)
     Behavior: 1
# Display user-defined marking-type QoS policies.
<Sysname> display qos policy user-defined remarking
  Marking policy: 1 (ID 100)
     Behavior: 1
      Marking:
        Remark dscp 3
Table 6 Command output
Information about a user-defined QoS policy.
System-defined QoS policy information
Information about a system-defined QoS policy.
Accounting policy
User-defined accounting-type QoS policy name.
Marking policy
User-defined marking-type QoS policy name.
For the description of other fields, see Table 1 and Table 4.
Use display qos policy control-plane to display QoS policies applied to a control plane.
# Display the QoS policy applied to the control plane of slot 1.
<Sysname> display qos policy control-plane slot 1
Control plane slot 1
  Direction: Inbound
  Policy: 1
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Marking:
        Remark dscp 3
   Classifier: 2
     Operator: AND
     Rule(s) :
     Behavior: 2
      Accounting enable:
        0 (Packets)
      Marking:
        Remark dscp 3
   Classifier: 3
     Operator: AND
     Rule(s) :
      -none-
     Behavior: 3
      -none-
Table 7 Command output
Direction
Direction in which the QoS policy is applied.
Use display qos policy control-plane pre-defined to display predefined control plane QoS policies.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays predefined control plane QoS policies for all member devices.
# Display the predefined control plane QoS policy of slot 1.
<Sysname> display qos policy control-plane pre-defined slot 1
Pre-defined policy information slot 1
  Protocol          Priority   Bandwidth          Group
  Default           N/A        1000 (pps)         N/A
  IS-IS             18         1000 (pps)         critical
  VRRP              19         1000 (pps)         important
  OSPF Multicast    18         1000 (pps)         critical
  OSPF Unicast      18         1000 (pps)         critical
  IGMP              11         500 (pps)          important
  OSPFv3 Unicast    18         1000 (pps)         critical
  OSPFv3 Multicast  18         1000 (pps)         critical
  VRRPv6            19         1000 (pps)         important
  ARP               2          1000 (pps)         normal
  DHCP Snooping     10         300 (pps)          redirect
  DHCP              10         300 (pps)          normal
  802.1x            3          500 (pps)          important
  STP               17         300 (pps)          critical
  LACP              22         300 (pps)          critical
  MVRP              15         300 (pps)          critical
  BGP               16         1000 (pps)         critical
  ICMP              3          500 (pps)          monitor
  TTL Expires       5          300 (pps)          monitor
  IPOPTION          5          300 (pps)          normal
  BGPv6             16         1000 (pps)         critical
  Hop Limit Expires 5          300 (pps)          monitor
  IPOPTIONv6        5          300 (pps)          normal
  LLDP              14         300 (pps)          important
  DLDP              16         300 (pps)          critical
  TELNET            1          800 (pps)          management
  SSH               1          800 (pps)          management
  TACACS            1          800 (pps)          management
  RADIUS            1          800 (pps)          management
  HTTP              3          500 (pps)          management
  HTTPS             3          500 (pps)          management
  SNMP              4          800 (pps)          management
  ARP Snooping      2          1000 (pps)         redirect
  ICMPv6            3          300 (pps)          monitor
  DHCPv6            10         300 (pps)          normal
  BFD               21         1000 (pps)         critical
Table 8 Command output
Pre-defined control plane policy
Contents of the predefined control plane QoS policy.
Protocols other than those listed.
Group
Protocol group of the protocol.
For descriptions of other fields, see Table 3.
Use display qos policy diagnosis control-plane to display diagnostic information about QoS policies applied to a control plane.
display qos policy diagnosis control-plane slot slot-number
# Display diagnostic information about the QoS policy applied to the control plane of slot 2.
<Sysname> display qos policy diagnosis control-plane slot 2
Control plane slot 2
  Direction: Inbound
  Policy: 1
   Classifier: 1 (Incomplete)
     Operator: AND
     Rule(s) :
      If-match acl 2000 (Incomplete)
       Failed Rule ID: 0, 3, 5, 50
     Behavior: 1
      Marking:
        Remark dscp 3
        CIR 112 (kbps), CBS 7000 (Bytes), EBS 512 (Bytes)
   Classifier: 2
     Operator: AND
     Rule(s) :
     Behavior: 2
      Accounting enable:
      Marking:
        Remark mpls-exp 4
   Classifier: 3
     Operator: AND
     Rule(s) :
      -none-
     Behavior: 3
      -none-
Table 9 Command output
Direction
Traffic class application result:
·     Incomplete—Some contents of the traffic class were applied successfully.
·     Failed—All contents of the traffic class failed to be applied.
Match criterion application result:
·     Incomplete—Some contents of the match criterion were applied successfully.
·     Failed—All contents of the match criterion failed to be applied.
Failed rule ID
ACL rules that failed to be applied.
Use display qos policy diagnosis global to display diagnostic information about QoS policies applied globally.
display qos [ accounting | remarking ] policy diagnosis global [ slot slot-number ] [ inbound | outbound ]
inbound: Specifies the QoS policy applied in the inbound direction.
outbound: Specifies the QoS policy applied in the outbound direction.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays diagnostic information about globally applied QoS policies for the master device.
If you do not specify the accounting or remarking keyword, this command displays diagnostic information about generic QoS policies.
If you do not specify a direction, this command displays diagnostic information about both QoS policies.
# Display diagnostic information about generic QoS policies applied globally.
<Sysname> display qos policy diagnosis global
  Direction: Inbound
  Policy: 1
     Operator: AND
     Rule(s) :
     Behavior: 1
      Marking:
        Remark dscp 3
   Classifier: 2
     Operator: AND
     Rule(s) :
     Behavior: 2
      Accounting enable:
      Marking:
        Remark mpls-exp 4
   Classifier: 3
     Operator: AND
     Rule(s) :
      -none-
     Behavior: 3
      -none-
# Display diagnostic information about accounting-type QoS policies applied globally.
<Sysname> display qos accounting policy diagnosis global
  Direction: Inbound
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match protocol ipv4
     Behavior: 1
# Display diagnostic information about mirroring-type QoS policies applied globally.
<Sysname> display qos remarking policy diagnosis global
  Direction: Inbound
  Marking policy: 1
   Classifier: 1
     Operator: AND
     Rule(s) :
     Behavior: 1
      Marking:
        Remark dscp 3
Table 10 Command output
Direction
Policy
User-defined generic QoS policy name.
Accounting policy
Marking policy
Failed rule ID
Use display qos policy diagnosis interface to display diagnostic information about the QoS policies applied to interfaces.
display qos [ accounting | remarking ] policy diagnosis interface [ interface-type interface-number ] [ slot slot-number ] [ inbound | outbound ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify an IRF member device, this command displays diagnostic information about QoS policies for the master device. Only logical interfaces support this option.
inbound: Specifies the QoS policy applied to incoming traffic.
outbound: Specifies the QoS policy applied to outgoing traffic.
If you do not specify a direction, this command displays diagnostic information about the QoS policy applied to incoming traffic and the QoS policy applied to outgoing traffic.
# Display diagnostic information about the generic QoS policy applied to the incoming traffic of  Ten-GigabitEthernet 1/0/1.
<Sysname> display qos policy diagnosis interface ten-gigabitethernet 1/0/1 inbound
  Direction: Inbound
  Policy: 1
     Operator: AND
     Rule(s) :
     Behavior: 1
      Marking:
        Remark dscp 3
        Green action  : pass
        Yellow action : pass
        Red action    : discard
   Classifier: 2
     Operator: AND
     Rule(s) :
      If-match not protocol ipv6
     Behavior: 2
      Marking:
        Remark mpls-exp 4
   Classifier: 3
     Operator: AND
     Rule(s) :
      -none-
     Behavior: 3
      -none-
# Display diagnostic information about the accounting-type QoS policy applied to the incoming traffic of  Ten-GigabitEthernet 1/0/1.
<Sysname> display qos accounting policy diagnosis interface ten-gigabitethernet 1/0/1 inbound
  Direction: Inbound
     Operator: AND
     Rule(s) :
     Behavior: 1
# Display diagnostic information about the marking-type QoS policy applied to the incoming traffic of  Ten-GigabitEthernet 1/0/1.
<Sysname> display qos remarking policy diagnosis interface ten-gigabitethernet 1/0/1 inbound
  Direction: Inbound
  Marking policy: 1
     Operator: AND
     Rule(s) :
     Behavior: 1
      Marking:
        Remark dscp 3
Table 11 Command output
Direction
Policy
Accounting policy
Marking policy
Failed rule ID
Use display qos policy diagnosis l2vpn-ac to display diagnostic information about the QoS policies applied to the inbound direction of Ethernet service instances.
display qos policy diagnosis l2vpn-ac [ interface interface-type interface-number [ service-instance instance-id ] [ slot slot-number ] ] [ inbound ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays diagnostic information about QoS policies applied to Ethernet service instances on all interfaces.
service-instance instance-id: Specifies an Ethernet service instance by its ID in the range of 1 to 4096. If you do not specify an Ethernet service instance, this command displays diagnostic information about QoS policies applied to all Ethernet service instances on an interface.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify an IRF member device, this command displays QoS policy diagnostic information for all member devices. Only Layer 2 aggregate interfaces support this option.
# Display diagnostic information about the QoS policy applied to the incoming traffic of Ethernet service instance 1 on Ten-GigabitEthernet 1/0/1.
<Sysname> display qos policy diagnosis l2vpn-ac interface ten-gigabitethernet 1/0/1 service-instance 1 inbound
Interface: Ten-GigabitEthernet1/0/1    Service instance ID: 1
  Direction: Inbound
  Policy: 1
     Operator: AND
     Rule(s) :
     Behavior: 1
      Marking:
        Remark dscp 3
   Classifier: 2
     Operator: AND
     Rule(s) :
     Behavior: 2
      Marking:
        Remark mpls-exp 4
   Classifier: 3
     Operator: AND
     Rule(s) :
      -none-
     Behavior: 3
      -none-
Table 12 Command output
Direction
Failed rule ID
For the description of fields, see Table 1 and Table 4.
Use display qos policy global to display QoS policies applied globally.
display qos [ accounting | remarking ] policy global [ slot slot-number ] [ inbound | outbound ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays global QoS policies for the master device.
If you do not specify the accounting or remarking keyword, this command displays information about generic QoS policies.
If you do not specify a direction, this command displays both inbound and outbound global QoS policies.
# Display generic QoS policies applied globally.
<Sysname> display qos policy global
  Direction: Inbound
  Policy: 1
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Marking:
        Remark dscp 3
        Green action  : pass
   Classifier: 2
     Operator: AND
     Rule(s) :
     Behavior: 2
      Accounting enable:
        0 (Packets)
      Marking:
        Remark dscp 3
   Classifier: 3
     Operator: AND
     Rule(s) :
      -none-
     Behavior: 3
      -none-
# Display information about accounting-type QoS policies applied globally.
<Sysname> display qos accounting policy global
  Direction: Inbound
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
# Display information about marking-type QoS policies applied globally.
<Sysname> display qos remarking policy global
  Direction: Inbound
  Marking policy: 1
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Marking:
        Remark dscp 3
Table 13 Command output
Direction
Policy
User-defined generic QoS policy name or system-defined QoS policy name.
Accounting policy
Marking policy
Use display qos policy interface to display the QoS policies applied to interfaces.
display qos [ accounting | remarking ] policy interface [ interface-type interface-number ] [ slot slot-number ] [ inbound | outbound ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify an IRF member device, this command displays QoS policies on the master device. Only logical interfaces support this option.
If you do not specify the accounting or remarking keyword, this command displays generic QoS policies applied.
If you do not specify a direction, this command displays the QoS policy applied to incoming traffic and the QoS policy applied to outgoing traffic.
# Display the generic QoS policy applied to the incoming traffic of Ten-GigabitEthernet 1/0/1.
<Sysname> display qos policy interface ten-gigabitethernet 1/0/1 inbound
  Direction: Inbound
  Policy: 1
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Marking:
        Remark dscp 3
   Classifier: 3
     Operator: AND
     Rule(s) :
      -none-
     Behavior: 3
      -none-
# Display information about the accounting-type QoS policy applied to the incoming traffic of  Ten-GigabitEthernet 1/0/1.
<Sysname> display qos accounting policy interface ten-gigabitethernet 1/0/1 inbound
  Direction: Inbound
  Accounting Policy: 1
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Accounting enable:
        0 (Packets)
# Display information about the marking-type QoS policy applied to the incoming traffic of  Ten-GigabitEthernet 1/0/1.
<Sysname> display qos remarking policy interface ten-gigabitethernet 1/0/1 inbound
  Direction: Inbound
  Marking policy: 1
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Marking:
        Remark dscp 3
# Display the QoS policies applied to all interfaces.
  Direction: Inbound
  Mode     : Share
  Policy: a
   Classifier: a
     Operator: AND
     Rule(s) :
      If-match any
     Behavior: a
      Mirroring:
        Mirror to the interface: Ten-GigabitEthernet1/0/2
        CIR 112 (kbps), CBS 51200 (Bytes), EBS 0 (Bytes)
Interface: Ten-GigabitEthernet1/0/3
  Direction: Inbound
  Policy: b
   Classifier: b
     Operator: AND
     Rule(s) :
      If-match any
     Behavior: b
Interface: Ten-GigabitEthernet1/0/4
  Direction: Inbound
  Mode     : Share
  Policy: a
   Classifier: a
     Operator: AND
     Rule(s) :
      If-match any
     Behavior: a
      Mirroring:
        Mirror to the interface: Ten-GigabitEthernet1/0/5
Table 14 Command output
Direction
Policy
Accounting policy
Marking policy
Mode
Sharing mode for QoS and ACL resources.
This field appears only if a QoS policy is applied with the share-mode keyword.
Use display qos policy l2vpn-ac to display the QoS policies applied to Ethernet service instances.
display qos policy l2vpn-ac [ interface interface-type interface-number [ service-instance instance-id ] [ slot slot-number ] ] [ inbound ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays QoS policies applied to Ethernet service instances on all interfaces.
service-instance instance-id: Specifies an Ethernet service instance by its ID in the range of 1 to 4096. If you do not specify an Ethernet service instance, this command displays QoS policies applied to all Ethernet service instances on an interface.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify an IRF member device, this command displays QoS policy information for all member devices. Only Layer 2 aggregate interfaces support this option.
inbound: Specifies the QoS policies applied to incoming traffic. If you do not specify this keyword, the command execution results are the same.
# Display the QoS policy applied to the incoming traffic of Ethernet service instance 1 on Ten-GigabitEthernet 1/0/1.
<Sysname> display qos policy l2vpn-ac interface ten-gigabitethernet 1/0/1 service-instance 1 inbound
  Direction: Inbound
  Policy: p
   Classifier: c
     Operator: AND
     Rule(s) :
      If-match any
     Behavior: b
        CIR 88 (kbps), CBS 5632 (Bytes), EBS 0 (Bytes)
        Green packets : 0 (Packets)
        Red packets   : 0 (Packets)
Use display qos vlan-policy to display QoS policies applied to VLANs.
name policy-name: Specifies a QoS policy by its name, a case-sensitive string of 1 to 31 characters.
vlan vlan-id: Specifies a VLAN by its ID in the range of 1 to 4094.
inbound: Displays QoS policies applied to incoming traffic.
outbound: Displays QoS policies applied to outgoing traffic.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays QoS policies applied to VLANs for the master device.
If you do not specify a direction, this command displays QoS policies applied to VLANs in both the inbound and outbound directions.
# Display QoS policies applied to VLAN 2.
<Sysname> display qos vlan-policy vlan 2
Vlan 2
  Direction: Inbound
  Policy: 1
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Marking:
        Remark dscp 3
   Classifier: 2
     Operator: AND
     Rule(s) :
     Behavior: 2
      Accounting enable:
        0 (Packets)
      Marking:
        Remark dscp 3
   Classifier: 3
     Operator: AND
     Rule(s) :
      -none-
     Behavior: 3
      -none-
Table 15 Command output
Direction
Use display qos vlan-policy diagnosis to display diagnostic information about QoS policies applied to VLANs.
display qos vlan-policy diagnosis { name policy-name | vlan [ vlan-id ] } [ slot slot-number ] [ inbound | outbound ]
inbound: Specifies QoS policies applied to incoming traffic.
outbound: Specifies QoS policies applied to outgoing traffic.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays diagnostic information about QoS policies applied to VLANs for the master device.
If you do not specify a direction, this command displays diagnostic information about QoS policies applied to VLANs in both the inbound and outbound directions.
# Display diagnostic information about QoS policies applied to VLAN 2.
<Sysname> display qos vlan-policy diagnosis vlan 2
Vlan 2
  Direction: Outbound
  Policy: 1
     Operator: AND
     Rule(s) :
     Behavior: 1
      Marking:
        Remark dscp 3
   Classifier: 2
     Operator: AND
     Rule(s) :
     Behavior: 2
      Accounting enable:
      Marking:
        Remark mpls-exp 4
   Classifier: 3
     Operator: AND
     Rule(s) :
      -none-
     Behavior: 3
      -none-
Table 16 Command output
Direction
Failed rule ID
qos apply policy
Use qos apply policy to apply a QoS policy to an Ethernet service instance, interface, or control plane.
Use undo qos apply policy to remove an applied QoS policy.
qos apply [ accounting | remarking ] policy policy-name { inbound | outbound } [ share-mode ]
undo qos apply [ accounting | remarking ] policy policy-name { inbound | outbound }
No QoS policy is applied.
Control plane view
Ethernet service instance view
accounting: Specifies an accounting-type QoS policy. This keyword is supported only in interface view.
remarking: Specifies a marking-type QoS policy. This keyword is supported only in interface view.
inbound: Applies the QoS policy to incoming traffic.
outbound: Applies the QoS policy to outgoing traffic. This keyword is not supported in Ethernet service instance view or control plane view.
share-mode: Applies the QoS policy in sharing mode to a Layer 2 or Layer 3 Ethernet interface. In this mode, all Layer 2 or Layer 3 Ethernet interfaces on an IRF member device with the same QoS policy applied in one direction share one QoS and ACL resource. The device has four QoS and ACL resources that can be shared in each direction. The device supports the sharing mode for packet filtering, QoS policy, and policy-based routing. Policy-based routing supports the sharing mode only in the inbound direction. If all QoS and ACL resources that can be shared are used, they can be reused after they are released.
You can use the following commands to match protocol packets sent to the CPU for a QoS policy applied to a control plane:
·     if-match control-plane protocol
·     if-match control-plane protocol-group
·     if-match acl
When you use the if-match acl command to match protocol packets sent to the CPU, follow these restrictions and guidelines:
¡     The used ACL must be an advanced ACL.
¡     You must specify TCP or UDP for the protocol argument in the rule.
¡     You must specify a source port or destination port by using the eq operator in the rule.
For example, an IPv4 advanced ACL that contains a rule permit tcp source-port eq 80 statement can match TCP packets sent to the CPU.
For configuration commands for Ethernet service instances, see MPLS L2VPN or VPLS in MPLS Command Reference or see VXLAN Command Reference.
If you specify the share-mode keyword when applying a QoS policy to an interface, follow these restrictions and guidelines:
·     All interfaces that share one QoS and ACL resource evenly share the set CIR if a traffic policing action is configured in the QoS policy.
If the share-mode keyword is not specified, the bandwidth of each interface can be limited to the CIR.
·     You cannot specify the share-mode keyword when applying an ACL to the same direction of the interface. For more information about applying an ACL to an interface, see the packet-filter (interface view) command in ACL commands.
The display qos policy interface command output for an interface also contains packet statistics for all interfaces that share the QoS and ACL resource with the interface.
You cannot change the sharing mode dynamically after a QoS policy is applied to an interface. To change the sharing mode for an applied QoS policy, perform the following tasks:
1.     Remove the QoS policy from the interface.
2.     Reapply the QoS policy with or without the share-mode keyword specified.
A maximum of three QoS policies (one for each type) can be applied to one direction of an interface. Different actions can be taken on the same traffic class if QoS policies of different types are applied to an interface.
A traffic behavior takes effect only on matching Layer 3 packets and does not take effect on matching Layer 2 packets if the following conditions exist:
·     The associated traffic class contains an IPv4 ACL.
·     The QoS policy is applied to the outbound direction of an interface.
·     The associated traffic class contains an IPv6 ACL.
·     The dscp dscp option is configured in an ACL rule.
A QoS policy cannot be applied to the outbound direction of an interface if the following conditions exist:
·     A traffic class contains an IPv6 ACL.
·     The source IPv6 address and destination IPv6 address match criteria are configured in a rule of the ACL.
# Apply generic QoS policy TEST1 to the outgoing traffic of Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] qos apply policy TEST1 outbound
# Apply accounting-type QoS policy TEST2 to the outgoing traffic of Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] qos apply accounting policy TEST2 outbound
# Apply marking-type QoS policy TEST4 to the outgoing traffic of Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] qos apply remarking policy TEST4 outbound
# Apply QoS policy TEST5 to the incoming traffic of the control plane of slot 3.
[Sysname-cp-slot3] qos apply policy TEST5 inbound
# Apply QoS policy test to the incoming traffic of Ethernet service instance 200.
[Sysname-GigabitEthernet1/0/1] service-instance 200
[Sysname-GigabitEthernet1/0/1-srv200] qos apply policy test inbound
# Apply QoS policy TEST10 in sharing mode to the outgoing traffic of Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1]qos apply policy TEST10 outbound share-mode
qos apply policy global
Use qos apply policy global to apply a QoS policy globally.
Use undo qos apply policy global to remove a globally applied QoS policy.
qos apply [ accounting | remarking ] policy policy-name global { inbound | outbound }
undo qos apply [ accounting | remarking ] policy policy-name global { inbound | outbound }
No QoS policy is applied globally.
inbound: Applies the QoS policy to the incoming packets on all interfaces.
outbound: Applies the QoS policy to the outgoing packets on all interfaces.
A global QoS policy takes effect on all incoming or outgoing traffic depending on the direction in which the QoS policy is applied.
A maximum of three QoS policies (one generic, one accounting-type, and one marking-type) can be applied to one direction globally.
If you do not specify the accounting or remarking keyword, this command applies a generic QoS policy globally.
·     The QoS policy is applied to the outbound direction globally.
A QoS policy cannot be applied to the outbound direction globally if the following conditions exist:
# Globally apply generic QoS policy user1 to the incoming traffic.
[Sysname] qos apply policy user1 global inbound
qos policy
Use qos policy to create a QoS policy and enter its view, or enter the view of an existing QoS policy.
Use undo qos policy to delete a QoS policy.
qos [ accounting | remarking ] policy policy-name
undo qos [ accounting | remarking ] policy policy-name
No QoS policies exist.
accounting: Identifies the QoS policy as an accounting-type QoS policy.
remarking: Identifies the QoS policy as a marking-type QoS policy.
policy-name: Specifies a name for the QoS policy, a case-sensitive string of 1 to 31 characters.
If you do not specify the accounting or remarking keyword when creating a QoS policy, a generic QoS policy is created.
QoS policies of different types cannot use the same policy name.
Do not use the accounting or remarking word or the first letters of any one of them as a policy name. If you do so, no information is displayed when you execute the display qos policy user-defined policy-name command, because the system will recognize such a policy name as a command keyword.
A generic QoS policy can be applied to all supported destinations and can contain all actions. An accounting-type QoS policy can be applied to only interfaces or globally and can contain only class-based accounting actions. A marking-type QoS policy can be applied to only interfaces or globally and can contain only marking actions.
To delete a QoS policy that has been applied to an object, you must first remove the QoS policy from the object.
# Create a QoS policy named user1.
# Create an accounting-type QoS policy named user2.
[Sysname] qos accounting policy user2
[Sysname-qospolicy-user2]
# Create a marking-type QoS policy named user3.
[Sysname] qos remarking policy user3
[Sysname-qospolicy-user3]
classifier behavior
qos apply policy
qos vlan-policy
qos vlan-policy
Use qos vlan-policy to apply a QoS policy to the specified VLANs.
Use undo qos vlan-policy to remove a QoS policy from the specified VLANs.
undo qos vlan-policy policy-name vlan vlan-id-list { inbound | outbound }
No QoS policy is applied to a VLAN.
vlan vlan-id-list: Specifies a space-separated list of up to eight VLAN IDs or a VLAN ID range in the form of vlan-id1 to vlan-id2. The value for vlan-id2 must be greater than or equal to the value for vlan-id1. The value range for the vlan-id argument is 1 to 4094.
inbound: Applies the QoS policy to incoming packets.
outbound: Applies the QoS policy to outgoing packets.
# Apply QoS policy test to the incoming traffic of VLAN 200, VLAN 300, VLAN 400, and VLAN 500.
[Sysname] qos vlan-policy test vlan 200 300 400 500 inbound
reset qos policy control-plane
Use reset qos policy control-plane to clear the statistics of the QoS policy applied to a control plane.
# Clear the statistics of the QoS policy applied to the control plane of slot 1.
<Sysname> reset qos policy control-plane slot 1
reset qos policy global
Use reset qos policy global to clear statistics for QoS policies applied globally.
reset qos [ accounting | remarking ] policy global [ inbound | outbound ]
inbound: Specifies the QoS policy applied to the inbound direction globally.
outbound: Specifies the QoS policy applied to the outbound direction globally.
If you do not specify a direction, this command clears statistics for the global QoS policies in both directions.
If you do not specify the accounting or remarking keyword, this command clears statistics for generic QoS policies.
# Clear statistics for the generic QoS policy applied to the inbound direction globally.
<Sysname> reset qos policy global inbound
reset qos vlan-policy
Use reset qos vlan-policy to clear the statistics for QoS policies applied to VLANs.
vlan vlan-id: Specifies a VLAN ID in the range of 1 to 4094.
If you do not specify a direction, this command clears the statistics of the QoS policies in both directions of the VLAN.
# Clear the statistics of QoS policies applied to VLAN 2.
<Sysname> reset qos vlan-policy vlan 2
Priority mapping commands
Priority map commands
display qos map-table
Use display qos map-table to display the configuration of priority maps.
display qos map-table [  dot1p-dp | dot1p-dscp | dot1p-lp | dscp-dot1p| dscp-dp | dscp-dscp | dscp-exp |exp-dot1p | exp-dscp ]
The device provides the following types of priority map.
Table 17 Priority maps
Priority mapping
dot1p-dp
802.1p-drop priority map.
dot1p-dscp
802.1p-DSCP priority map.
dot1p-lp
802.1p-local priority map.
dscp-dot1p
DSCP-802.1p priority map.
dscp-dp
DSCP-drop priority map.
dscp-dscp
DSCP-DSCP priority map.
dscp-exp
DSCP-EXP priority map.
exp-dot1p
EXP-802.1p priority map.
exp-dscp
EXP-DSCP priority map.
If you do not specify a priority map, this command displays the configuration of all priority maps.
# Display the configuration of the 802.1p-local priority map.
MAP-TABLE NAME: dot1p-lp   TYPE: pre-define
IMPORT  :  EXPORT
   0    :    2
   1    :    0
   2    :    1
   3    :    3
   4    :    4
   5    :    5
   6    :    6
   7    :    7
Table 18 Command output
MAP-TABLE NAME
Name of the priority map.
TYPE
Type of the priority map.
IMPORT
Input values of the priority map.
EXPORT
Output values of the priority map.
dot1p-trust-tc
Use dot1p-trust-tc to modify the 802.1p priority of outgoing packets to the local precedence value.
Use undo dot1p-trust-tc to restore the default.
dot1p-trust-tc slot slot-number
undo dot1p-trust-tc slot slot-number
The 802.1p priority of outgoing packets is not modified.
For the remark dot1p command to take effect, this command must be executed.
After an incoming packet is marked according to the remark dot1p command, it is assigned to a queue according to the default dot1p-lp priority map. The 802.1p priority of the packet is modified as its local precedence value before it is sent out.
If you modify the default dot1p-lp priority map, the outgoing packet is enqueued to a different queue, and its 802.1p priority is modified to a different local precedence value.
# Modify the 802.1p priority of outgoing packets to the local precedence value on member device 3.
[Sysname] dot1p-trust-tc slot 3
remark dot1p
import
Use import to configure mappings for a priority map.
Use undo import to restore the specified or all mappings to the default for a priority map.
The default priority maps are used. For more information, see ACL and QoS Configuration Guide.
Priority map view
import-value-list: Specifies a list of input values.
export-value: Specifies the output value.
all: Restores all mappings in the priority map to the default.
# Configure the 802.1p-local priority map to map 802.1p priority values 4 and 5 to local priority 1.
[Sysname] qos map-table dot1p-lp
[Sysname-maptbl-dot1p-lp] import 4 5 export 1
qos map-table
Use qos map-table to enter the specified priority map view.
qos map-table { dot1p-dp | dot1p-dscp | dot1p-lp | dscp-dot1p| dscp-dp | dscp-dscp | dscp-exp |exp-dot1p | exp-dscp }
For the description of the keywords, see Table 17.
# Enter 802.1p-local priority map view.
import
Priority trust mode commands
display qos trust interface
Use display qos trust interface to display the priority trust mode and port priorities of an interface.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the priority trust mode and port priorities of all interfaces.
# Display the priority trust mode and port priority of Ten-GigabitEthernet 1/0/1.
<Sysname> display qos trust interface ten-gigabitethernet 1/0/1
 Port priority trust information
  Port priority:4
  Port dscp priority: -
  Port priority trust type: dscp
Table 19 Command output
Interface type and interface number.
Port priority
Port priority set for the interface.
Port dscp priority
DSCP value rewritten for packets. If you have not rewritten the DSCP value of packets, this field displays a hyphen (-).
Priority trust mode on the interface:
·     dot1p—Uses the 802.1p priority of received packets for mapping.
·     dscp—Uses the DSCP precedence of received IP packets for mapping.
qos trust
Use qos trust to configure the priority trust mode for an interface.
Use undo qos trust to restore the default.
qos trust { dot1p | dscp }
undo qos trust
An interface trusts the 802.1p priority in incoming packets.
Layer 2/Layer 3 Ethernet interface view
dot1p: Uses the 802.1p priority in incoming packets for priority mapping.
dscp: Uses the DSCP value in incoming packets for priority mapping.
For a VXLAN tunnel interface to trust the DSCP priority in the inner IP header of VXLAN packets, configure the qos trust dscp command on its physical interface.
# Set the priority trust mode to 802.1p priority on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] qos trust dot1p
Port priority commands
qos priority
Use qos priority to change the port priority of an interface.
Use undo qos priority to restore the default.
qos priority [ dscp ] priority-value
undo qos priority [ dscp ]
The port priority is 0.
dscp: Specifies a DSCP value in the range of 0 to 63.
priority-value: Specifies a priority value. If the dscp keyword is not specified, this argument specifies the port priority in the range of 0 to 7. If the dscp keyword is specified, this argument specifies the DSCP value to be set for packets, in the range of 0 to 63.
# Set the port priority of Ten-GigabitEthernet 1/0/1 to 2.
[Sysname-Ten-GigabitEthernet1/0/1] qos priority 2
GTS and rate limit commands
GTS commands
display qos gts interface
Use display qos gts interface to display the GTS configuration for interfaces.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the GTS configuration for all interfaces.
# Display the GTS configuration for all interfaces.
 Rule: If-match queue 1
  CIR 512 (kbps), CBS 51200 (Bytes)
Table 20 Command output
Interface name, including the interface type and interface number.
Rule
Match criteria.
CIR
CIR in kbps.
CBS
CBS in bytes.
qos gts
Use qos gts to set GTS parameters on an interface.
Use undo qos gts to delete the GTS configuration on an interface.
undo qos gts queue queue-id
No GTS parameters are configured.
queue queue-id: Shapes the packets in a queue specified by its ID. The value range for queue-id is 0 to 7.
cir committed-information-rate: Specifies the CIR in kbps. The value range for committed-information-rate is 8 to 10000000 for 10-GE interfaces, 8 to 40000000 for 40-GE interfaces, and 8 to 100000000 for 100-GE interfaces. The specified value must be a multiple of 8.
cbs committed-burst-size: Specifies the CBS in bytes. The value range for committed-burst-size is 512 to 16000000, in increments of 512. The default value for this argument is the product of 62.5 and the CIR and must be an integral multiple of 512. When the product is not an integral multiple of 512, it is rounded up to the nearest integral multiple of 512 that is greater than the product. A default value greater than 16000000 is converted to 16000000.
# Shape the packets of queue 1 on HundredGigE 1/0/1 (CIR 6400 kbps and CBS 51200 bytes).
[Sysname-HundredGigE1/0/1] qos gts queue 1 cir 6400 cbs 51200
Rate limit commands
display qos lr interface
Use display qos lr interface to display the rate limit configuration for interfaces.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the rate limit configuration for all interfaces.
# Display the rate limit configuration for all interfaces.
 Direction: Outbound
  CIR 2000 (kbps), CBS 20480 (Bytes)
Table 21 Command output
Direction
Direction in which the rate limit configuration is applied.
CIR
CIR in kbps.
CBS
CBS in bytes.
qos lr
Use qos lr to configure rate limiting on an interface.
Use undo qos lr to delete the rate limit configuration on an interface.
qos lr outbound cir committed-information-rate [ cbs committed-burst-size ]
undo qos lr  outbound
No rate limit is configured.
outbound: Limits the rate of outgoing packets.
cbs committed-burst-size: Specifies the CBS in bytes. The value range for committed-burst-size is 512 to 128000000, in increments of 512. The default value for this argument is the product of 62.5 and the CIR and must be a multiple of 512. When the product is not a multiple of 512, it is rounded up to the nearest integral multiple of 512 that is greater than the product. A default value greater than 128000000 is converted to 128000000.
# Limit the rate of outgoing packets on Ten-GigabitEthernet 1/0/1, with CIR 256 kbps and CBS 51200 bytes.
[Sysname-Ten-GigabitEthernet1/0/1] qos lr outbound cir 256 cbs 51200
Congestion management commands
Common commands
display qos queue interface
Use display qos queue interface to display the queuing information for interfaces.
display qos queue interface [ interface-type interface-number ]
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the queuing information for all interfaces.
# Display the queuing information for all interfaces.
<Sysname> display qos queue interface
 Output queue: Strict Priority queuing
Interface: Ten-GigabitEthernet1/0/2
Table 22 Command output
Output queue
Type of the current output queue.
Group
Number of the group that holds the queue.
Weight
Packet-count scheduling weight of the queue. N/A is displayed for a queue that uses the SP scheduling algorithm.
Byte-count
Byte-count scheduling weight of the queue. N/A is displayed for a queue that uses the SP scheduling algorithm.
SP commands
display qos queue sp interface
Use display qos queue sp interface to display the SP queuing configuration of an interface.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the SP queuing configuration of all interfaces.
# Display the SP queuing configuration of Ten-GigabitEthernet 1/0/1.
<Sysname> display qos queue sp interface ten-gigabitethernet 1/0/1
Table 23 Command output
Output queue
qos sp
Use qos sp to enable SP queuing on an interface.
Use undo qos sp to restore the default.
qos sp
undo qos sp
An interface uses SP queuing.
Interface view
# Enable SP queuing on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] qos sp
WRR commands
display qos queue wrr interface
Use display qos queue wrr interface to display the WRR queuing configuration of an interface.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the WRR queuing configuration of all interfaces.
# Display the WRR queuing configuration of Ten-GigabitEthernet 1/0/1.
<Sysname> display qos queue wrr interface ten-gigabitethernet 1/0/1
 Output queue: Weighted Round Robin queuing
 Queue ID        Queue name      Group           Weight
 0               be              1               1
 1               af1             1               1
 2               af2             1               1
 3               af3             1               1
 4               af4             1               1
 5               ef              1               1
 6               cs6             1               1
 7               cs7             sp              N/A
Table 24 Command output
Output queue
Group
ID of the group a queue is assigned to.
Weight
Packet-count queue scheduling weight of a queue. N/A is displayed for a queue that uses the SP scheduling algorithm.
qos wrr
Use qos wrr to enable WRR queuing on an interface.
Use undo qos wrr to restore the default.
qos wrr { byte-count | weight }
undo qos wrr { byte-count | weight }
byte-count: Allocates bandwidth to queues in bytes.
weight: Allocates bandwidth to queues in packets.
You must use the qos wrr command to enable WRR queuing before you can configure WRR queuing parameters for a queue on an interface.
# Enable packet-count WRR queuing on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] qos wrr weight
# Enable byte-count WRR queuing on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] qos wrr byte-count
Use qos wrr { byte-count | weight } to configure the WRR queuing parameters for a queue on an interface.
qos wrr queue-id group 1 { byte-count | weight } schedule-value
undo qos wrr queue-id
All queues on a WRR-enabled interface are in WRR group 1, and queues 0 through 7 have a weight of 1, 2, 3, 4, 5, 6, 7, and 8, respectively.
queue-id: Specifies a queue by its ID. The value range for this argument is 0 to 7 or keywords in Table 25.
Table 25 The number-keyword map for the queue-id argument
Number
Keyword
0
be
1
af1
2
af2
3
af3
4
af4
5
ef
6
cs6
7
cs7
group 1: Specifies WRR group 1. Only WRR group 1 is supported in the current software version.
schedule-value: Specifies a scheduling weight. The value range for this argument is 1 to 127.
# Enable packet-based WRR queuing on Ten-GigabitEthernet 1/0/1, assign queue 0 to WRR group 1, and specify scheduling weight 10 for queue 0.
[Sysname-Ten-GigabitEthernet1/0/1] qos wrr 0 group 1 weight 10
qos wrr
qos wrr group sp
Use qos wrr group sp to assign a queue to the SP group.
Use undo qos wrr group sp to remove a queue from the SP group.
qos wrr queue-id group sp
All queues on a WRR-enabled interface are in WRR group 1.
This command is available only on a WRR-enabled interface. Queues in the SP group are scheduled with SP. The SP group has higher scheduling priority than the WRR groups.
You must use the qos wrr command to enable WRR queuing before you can configure this command on an interface.
# Enable WRR queuing on Ten-GigabitEthernet 1/0/1, and assign queue 0 to the SP group.
[Sysname-Ten-GigabitEthernet1/0/1] qos wrr 0 group sp
qos wrr
WFQ commands
display qos queue wfq interface
Use display qos queue wfq interface to display the WFQ configuration of an interface.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the WFQ configuration of all interfaces.
# Display the WFQ configuration of Ten-GigabitEthernet 1/0/1.
<Sysname> display qos wfq interface ten-gigabitethernet 1/0/1
 Output queue: Hardware Weighted Fair Queuing
 Queue ID        Queue name      Group           Byte count      Min Bandwidth
 0               be              1               1               64
 1               af1             1               1               64
 2               af2             1               1               64
 3               af3             1               1               64
 4               af4             1               1               64
 5               ef              1               1               64
 6               cs6             1               1               64
 7               cs7             1               1               64
Table 26 Command output
Output queue
Group
ID of the group that holds the queue.
Byte-count
Weight
Packet-count queue scheduling weight of the queue. N/A is displayed for a queue that uses the SP scheduling algorithm.
Min Bandwidth
Minimum guaranteed bandwidth for the queue.
qos bandwidth queue
Use qos bandwidth queue to set the minimum guaranteed bandwidth for a queue on an interface.
Use undo qos bandwidth queue to restore the default.
undo qos bandwidth queue queue-id
The minimum guaranteed bandwidth for a queue is 64 kbps.
min bandwidth-value: Sets the minimum guaranteed bandwidth in kbps. The bandwidth-value argument has the following value ranges: 8 to 10000000 for 10-GE interfaces, 8 to 40000000 for 40-GE interfaces, 8 to 100000000 for 100-GE interfaces.
The minimum guaranteed bandwidth is the amount of bandwidth guaranteed for a queue when the interface is congested.
You must use the qos wfq command to enable WFQ before you can configure this command on an interface.
If you configure the outbound rate limit on the interface, the actual minimum guaranteed bandwidth will be slightly different from the set value.
# Set the minimum guaranteed bandwidth to 100 kbps for queue 0 on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] qos wfq weight
[Sysname-Ten-GigabitEthernet1/0/1] qos bandwidth queue 0 min 100
qos wfq
qos wfq
Use qos wfq to enable WFQ on an interface.
Use undo qos wfq to restore the default.
qos wfq { byte-count | weight }
undo qos wfq { byte-count | weight }
You must use the qos wfq command to enable WFQ before you can configure WFQ queuing parameters for a queue on an interface.
# Enable packet-count WFQ on Ten-GigabitEthernet 1/0/1.
# Enable byte-count WFQ on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] qos wfq byte-count
Use qos wfq { byte-count | weight } to assign a queue to a WFQ group with a certain scheduling weight.
qos wfq queue-id group 1 { byte-count | weight } schedule-value
undo qos wfq queue-id
All queues on a WFQ-enabled interface are in WFQ group 1 and have a weight of 1.
group 1: Specifies WFQ group 1. Only WFQ group 1 is supported in the current software version.
You must use the qos wfq command to enable WFQ before you configure this command.
# Enable byte-count WFQ on Ten-GigabitEthernet 1/0/1, and specify scheduling weight 10 for queue 0.
[Sysname-Ten-GigabitEthernet1/0/1] qos wfq 0 group 1 byte-count 10
qos bandwidth queue
qos wfq
qos wfq group sp
Use qos wfq group sp to assign a queue to the SP group.
Use undo qos wfq group sp to remove a queue from the SP group.
qos wfq queue-id group sp
All queues on a WFQ-enabled interface are in WFQ group 1.
This command is available only on a WFQ-enabled interface. Queues in the SP group are scheduled with SP, instead of WFQ. The SP group has higher scheduling priority than the WFQ groups.
# Enable WFQ on Ten-GigabitEthernet 1/0/1, and assign queue 0 to the SP group.
[Sysname-Ten-GigabitEthernet1/0/1] qos wfq 0 group sp
qos bandwidth queue
qos wfq
Queue scheduling profile commands
bandwidth queue
Use bandwidth queue to set the minimum guaranteed bandwidth for a queue.
Use undo bandwidth queue to restore the default.
undo bandwidth queue queue-id
Queue scheduling profile view
min bandwidth-value: Specifies the minimum guaranteed bandwidth in kbps. The value range for the bandwidth-value argument is 8 to 100000000.
You must configure a queue as a WFQ queue before you set the minimum guaranteed bandwidth for the queue.
# Configure queue 0 as a WFQ queue, and set the minimum guaranteed bandwidth to 100 kbps for queue 0.
[Sysname] qos qmprofile myprofile
[Sysname-qmprofile-myprofile] queue 0 wfq group 1 weight 1
[Sysname-qmprofile-myprofile] bandwidth queue 0 min 100
display qos qmprofile configuration
Use display qos qmprofile configuration to display the queue scheduling profile configuration.
profile-name: Specifies a queue scheduling profile by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a queue scheduling profile, this command displays the configuration of all queue scheduling profiles.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays the queue scheduling profile configuration for the master device.
# Display the configuration of queue scheduling profile myprofile.
<Sysname> display qos qmprofile configuration myprofile
Queue management profile: myprofile (ID 1)
Queue ID  Type  Group   Schedule   Schedule  Min         Max
                        unit       value     bandwidth   bandwidth
be        WFQ   1       weight     1         100         N/A
af1       WFQ    N/A     N/A        N/A       64          N/A
af2       WFQ    N/A     N/A        N/A       64          N/A
af3       WFQ    N/A     N/A        N/A       64          N/A
af4       WFQ    N/A     N/A        N/A       64          N/A
ef        WFQ    N/A     N/A        N/A       64          N/A
cs6       WFQ    N/A     N/A        N/A       64          N/A
cs7       WFQ    N/A     N/A        N/A       64          N/A
Table 27 Command output
Queue scheduling profile name.
Queue scheduling type:
·     SP.
·     WRR.
·     WFQ.
Group
Priority group to which the queue belongs.
The value can only be 1. N/A indicates this field is ignored.
Schedule unit
Scheduling unit: weight or byte-count.
N/A indicates that this field is ignored.
Schedule value
This field indicates:
·     Number of packets for the weight scheduling unit.
·     Number of bytes for the byte-count scheduling unit.
Min bandwidth
Minimum guaranteed bandwidth for the queue. N/A indicates that this field is ignored.
Max bandwidth
This field is not supported in the current software version. Maximum allowed bandwidth for the queue. N/A indicates that this field is ignored.
display qos qmprofile interface
Use display qos qmprofile interface to display the queue scheduling profile applied to an interface.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the queue scheduling profiles applied to all interfaces.
# Display the queue scheduling profile applied to Ten-GigabitEthernet 1/0/1.
<Sysname> display qos qmprofile interface ten-gigabitethernet 1/0/1
Direction: Outbound
Table 28 Command output
Direction
Direction in which the queue scheduling profile is applied.
Name of the queue scheduling profile applied to the interface.
qos apply qmprofile
Use qos apply qmprofile to apply a queue scheduling profile to the outbound direction of an interface.
Use undo qos apply qmprofile to restore the default.
No queue scheduling profile is applied to an interface.
You can apply only one queue scheduling profile to an interface.
# Apply queue scheduling profile myprofile to the outbound direction of Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] qos apply qmprofile myprofile
qos qmprofile
Use qos qmprofile to create a queue scheduling profile and enter its view, or enter the view of an existing queue scheduling profile.
Use undo qos qmprofile to delete a queue scheduling profile.
qos qmprofile profile-name
undo qos qmprofile profile-name
No user-created queue scheduling profiles exist.
profile-name: Specifies a name for the queue scheduling profile, a case-sensitive string of 1 to 31 characters.
To delete a queue scheduling profile already applied to an object, first remove it from the object.
# Create a queue scheduling profile named myprofile and enter queue scheduling profile view.
queue
queue
Use queue to configure queue scheduling parameters.
Use undo queue to delete queue scheduling parameter settings.
queue queue-id { sp | wfq group group-id { weight | byte-count } schedule-value | wrr group group-id { weight | byte-count } schedule-value }
undo queue queue-id
All queues in a queue scheduling profile are SP queues.
sp: Enables SP for the queue.
wfq: Enables WFQ for the queue.
wrr: Enables WRR for the queue.
group group-id: Specifies a WFQ or WRR group by its ID. The group ID can only be 1.
schedule-value: Specifies the scheduling weight. For WRR, the value range is 1 to 15. For WFQ, the value range is 1 to 15 if you have specified the byte-count keyword and 1 to 127 if you have specified the weight keyword.
# Create a queue scheduling profile named myprofile, and configure queue 0 to use SP.
[Sysname-qmprofile-myprofile] queue 0 sp
# Create a queue scheduling profile named myprofile. Configure queue 1 to meet the following requirements:
·     The WRR queuing is used.
·     The WRR group is group 1.
·     The scheduling weight is 10.
[Sysname-qmprofile-myprofile] queue 1 wrr group 1 weight 10
qos qmprofile
Congestion avoidance commands
WRED commands
display qos wred interface
Use display qos wred interface to display the WRED information for interfaces.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the WRED information for all interfaces.
# Display the WRED information for all interfaces.
<Sysname> display qos wred interface
 Current WRED configuration:
 Applied WRED table name: q1
Table 29 Command output
display qos wred table
Use display qos wred table to display the WRED table configuration.
name table-name: Specifies a WRED table by its name, a case-sensitive string of 1 to 32 characters. If you do not specify a WRED table, this command displays the configuration of all WRED tables.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays the WRED table configuration for the master device.
# Display the configuration of WRED table 1.
<Sysname> display qos wred table name 1
Table name: 1
Table type: Queue based WRED
QID   gmin  gmax  gprob  ymin  ymax  yprob  rmin  rmax  rprob  exponent  ECN
0     100   1000  10     100   1000  10     100   1000  10     9         N
1     100   1000  10     100   1000  10     100   1000  10     9         N
2     100   1000  10     100   1000  10     100   1000  10     9         N
3     100   1000  10     100   1000  10     100   1000  10     9         N
4     100   1000  10     100   1000  10     100   1000  10     9         N
5     100   1000  10     100   1000  10     100   1000  10     9         N
6     100   1000  10     100   1000  10     100   1000  10     9         N
7     100   1000  10     100   1000  10     100   1000  10     9         N
Table 30 Command output
Table name
Name of a WRED table.
Table type
Type of a WRED table.
QID
Queue ID.
gmin
Lower limit for green packets.
gmax
Upper limit for green packets.
gprob
Drop probability for green packets.
ymin
Lower limit for yellow packets.
ymax
Upper limit for yellow packets.
yprob
Drop probability for yellow packets.
rmin
Lower limit for red packets.
rmax
Upper limit for red packets.
rprob
Drop probability for red packets.
exponent
Exponent for average queue length calculation.
ECN
Indicates whether ECN is enabled for the queue:
·     Y—Enabled.
·     N—Disabled.
qos wred apply
Use qos wred apply to apply a WRED table to an interface.
Use undo qos wred apply to restore the default.
qos wred apply [ table-name ]
undo qos wred apply
No WRED table is applied to an interface, and the tail drop mode is used on an interface.
table-name: Specifies a WRED table by its name, a case-sensitive string of 1 to 32 characters. If you do not specify a WRED table, this command applies the default WRED table to the interface.
# Apply WRED table table1 to Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] qos wred apply table1
qos wred queue table
Use qos wred queue table to create a WRED table and enter its view, or enter the view of an existing WRED table.
Use undo qos wred queue table to delete a WRED table.
undo qos wred queue table table-name
No WRED tables exist.
table table-name: Specifies a name for the WRED table, a case-sensitive string of 1 to 32 characters.
You cannot delete a WRED table in use. To delete it, first remove it from the specified interface.
You can use the display qos wred table command to display the default WRED table, which cannot be modified or deleted.
# Create a queue-based WRED table named queue-table1.
[Sysname-wred-table-queue-table1]
queue
Use queue to configure the drop-related parameters for a queue in the queue-based WRED table.
Use undo queue to restore the default.
queue queue-id [ drop-level drop-level ] low-limit low-limit high-limit high-limit [ discard-probability discard-prob ]
undo queue { queue-id [ drop-level drop-level ] | all }
The lower limit is 250, the upper limit is 1000, and the drop probability is 10%.
WRED table view
all: Specifies all queues.
queue-id: Specifies a queue by its ID. The value range for this argument is 0 to 7.
drop-level drop-level: Specifies a drop level. This argument is a consideration for dropping packets. The value 0 corresponds to green packets, the value 1 corresponds to yellow packets, and the value 2 corresponds to red packets. If you do not specify a drop level, the subsequent configuration takes effect on the packets in the queue regardless of the drop level.
low limit low-limit: Specifies the lower limit for the average queue length. The value range for low-limit is 0 to 16383 KB.
high-limit high-limit: Specifies the upper limit for the average queue length. The upper limit must be greater than the lower limit. The value range for high-limit is 0 to 16383 KB.
discard-probability discard-prob: Specifies the denominator for drop probability calculation. The greater the denominator, the greater the calculated drop probability. The value range for discard-prob is 0 to 100.
When the average queue size is smaller than the lower threshold, no packet is dropped. When the average queue size is between the lower threshold and the upper threshold, the packets are dropped at random. The longer the queue is, the higher the drop probability is. When the average queue size exceeds the upper threshold, subsequent packets are dropped.
# In queue-based WRED table queue-table1, configure the following drop-related parameters for packets in queue 1:
·     The drop level is 1.
·     The lower limit for the average queue length is 10.
·     The upper limit for the average queue length is 20.
·     The drop probability is 30%.
[Sysname-wred-table-queue-table1] queue 1 drop-level 1 low-limit 10 high-limit 20 discard-probability 30
queue ecn
Use queue ecn to enable ECN for a queue.
Use undo queue ecn to restore the default.
queue queue-id ecn
undo queue queue-id ecn
ECN is disabled for a queue.
WRED table view
queue-id: Specifies a queue by its ID in the range of 0 to 7.
When both the receiver and sender support ECN, the device can notify the peer end of the congestion status by identifying and setting the ECN flag. ECN avoids deteriorating congestion.
# In WRED table queue-table1, enable ECN for queue 1.
[Sysname-wred-table-queue-table1] queue 1 ecn
queue weighting-constant
Use queue weighting-constant to specify an exponent for average queue length calculation for a queue.
Use undo queue weighting-constant to restore the default.
queue queue-id weighting-constant exponent
undo queue queue-id weighting-constant
The exponent for average queue length calculation is 9.
WRED table view
weighting-constant exponent: Specifies the WRED exponent for average queue length calculation. The value range for exponent is 0 to 15.
The bigger the exponent is, the less sensitive the average queue size is to real-time queue size changes. The average queue size is calculated using the formula:
Average queue size = previous average queue size × (1-2-n) + current queue size × 2-n,
where n can be configured with the qos wred weighting-constant command.
# In WRED table queue-table1, set the exponent for average queue length calculation to 12 for queue 1.
[Sysname-wred-table-queue-table1] queue 1 weighting-constant 12
Aggregate CAR commands
car name
Use car name to use an aggregate CAR action in a traffic behavior.
Use undo car to restore the default.
car name car-name
undo car
No aggregate CAR action is configured in a traffic behavior.
Traffic behavior view
car-name: Specifies the name of an aggregate CAR action. This argument must start with a letter, and is a case-sensitive string of 1 to 31 characters.
# Use aggregate CAR action aggcar-1 in traffic behavior be1.
display qos car name
display traffic behavior user-defined
Use display qos car name to display information about aggregate CAR actions.
car-name: Specifies an aggregate CAR action by its name. This argument must start with a letter, and is a case-sensitive string of 1 to 31 characters. If you do not specify an aggregate CAR action, this command displays information about all aggregate CAR actions.
# Display information about all aggregate CAR actions.
<Sysname> display qos car name
  Mode: aggregative
   CIR 32 (kbps) CBS: 2048 (Bytes) PIR: 888 (kbps) EBS: 0 (Bytes)
Table 31 Command output
Name
Name of the aggregate CAR action.
Mode
Type of the CAR action, which can be aggregative.
CIR  CBS  PIR  EBS
Parameters for the CAR action.
qos car
Use qos car aggregative to configure an aggregate CAR action.
Use undo qos car to delete an aggregate CAR action.
qos car car-name aggregative cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ]
qos car car-name aggregative cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ]
undo qos car car-name
No aggregate CAR action is configured.
car-name: Specifies the name of the aggregate CAR action. This argument must start with a letter, and is a case-sensitive string of 1 to 31 characters.
cir committed-information-rate: Specifies the CIR in kbps, which is an average traffic rate. The value range for committed-information-rate is 8 to 160000000, in increments of 8.
cbs committed-burst-size: Specifies the CBS in bytes. The value range for committed-burst-size is 512 to 256000000, in increments of 512. The default value for this argument is the product of 62.5 and the CIR and must be an integral multiple of 512. When the product is not an integral multiple of 512, it is rounded up to the nearest integral multiple of 512 that is greater than the product. A default value greater than 256000000 is converted to 256000000.
ebs excess-burst-size: Specifies the EBS in bytes. The value range for excess-burst-size is 0 to 256000000, in increments of 512. If the PIR is configured, the default EBS is the product of 62.5 and the PIR and must be an integral multiple of 512. When the product is not an integral multiple of 512, it is rounded up to the nearest integral multiple of 512. A default value greater than 256000000 is converted to 256000000.
pir peak-information-rate: Specifies the PIR in kbps. The value range for peak-information-rate is 8 to 160000000, in increments of 8.
To use two rates for aggregate CAR, configure the qos car command with the pir peak-information-rate option. To use one rate for aggregate CAR, configure the qos car command without the pir peak-information-rate option.
An aggregate CAR action takes effect only after it is used in a QoS policy.
# Configure aggregate CAR action aggcar-1, where CIR is 25600 and CBS is 512000.
[Sysname] qos car aggcar-1 aggregative cir 25600 cbs 512000
reset qos car name
Use reset qos car name to clear the statistics about aggregate CAR actions.
car-name: Specifies an aggregate CAR action by its name. This argument must start with a letter, and is a case-sensitive string of 1 to 31 characters. If you do not specify an aggregate CAR action, this command clears statistics for all aggregate CAR actions.
# Clear the statistics about aggregate CAR action aggcar-1.
<Sysname> reset qos car name aggcar-1
Queue-based accounting commands
display qos queue-statistics interface outbound
Use display qos queue-statistics interface outbound to display outgoing traffic statistics collected for interfaces on a per-queue basis.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the outgoing traffic statistics for all interfaces.
# Display queue-based outgoing traffic statistics of Ten-GigabitEthernet 1/0/1.
<Sysname> display qos queue-statistics interface ten-gigabitethernet 1/0/1 outbound
 Direction: outbound
 Forwarded: 0 packets, 0 bytes
 Dropped: 1 packets, 1 bytes
 Queue 0
  Total queue length: 0 packets
  Current queue length: 0 packets, 0% use ratio
 Queue 1
 Queue 2
 Queue 3
 Queue 4
 Queue 5
 Queue 6
 Queue 7
Table 32 Command output
Interface for which queue-based traffic statistics are displayed.
Direction
Direction of traffic for which statistics are collected.
Forwarded
(This field is not supported in the current software version.) Counts forwarded traffic both in packets and in bytes.
Dropped
Counts dropped traffic both in packets and in bytes.
Total queue length
Total number of packets allowed in the queue.
Current number of packets in the queue.
use ratio
Utilization ratio of the queue.
reset counters interface (Layer 2—LAN Switching Command Reference)
display statistic mode
Use display statistic mode to display the packet counting mode.
# Display the packet counting mode.
<Sysname> display statistic mode
The packet statistic mode is queue.
statistic mode queue
reset qos queue-statistics interface outbound
Use reset qos queue-statistics interface outbound to clear outgoing queue-based traffic statistics for an interface.
reset qos queue-statistics interface [ interface-type interface-number ] outbound
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command clears the outgoing queue-based traffic statistics for all interfaces.
# Clear the outgoing queue-based traffic statistics for all interfaces.
<Sysname> reset qos queue-statistics interface outbound
# Clear the outgoing queue-based traffic statistics for Ten-GigabitEthernet 1/0/1.
<Sysname> reset qos queue-statistics interface ten-gigabitethernet 1/0/1 outbound
Use statistic mode queue to set the packet counting mode to queue.
Use undo statistic mode queue to restore the default.
undo statistic mode
The packet counting mode is vsi.
After you configure this command and the qos queue-statistics command, the device collects statistics on packets of each queue. You can use the display qos queue-statistics interface outbound command to display the statistics.
# Set the packet counting mode to queue.
[Sysname] statistic mode queue
Do you want to change the packet statistic mode? [Y/N]:y
statistic mode vsi (VXLAN Command Reference)
  • Become a Partner
  • Partner Resources
