- 07-Layer 3—IP Routing Configuration Guide
- 01-Basic IP routing configuration
- 02-Static routing configuration
- 03-RIP configuration
- 04-OSPF configuration
- 05-IS-IS configuration
- 06-BGP configuration
- 07-Policy-based routing configuration
- 08-IPv6 static routing configuration
- 09-RIPng configuration
- 10-OSPFv3 configuration
- 11-IPv6 policy-based routing configuration
- 12-Guard route configuration
- 13-Routing policy configuration
- 14-MTR configuration
- 15-DCN configuration
- 16-RIR configuration
08-IPv6 static routing configuration | 149.24 KB |
Configuring IPv6 static routing
Configuring an IPv6 static route
Configuring BFD for IPv6 static routes
About BFD for IPv6 static routes
Restrictions and guidelines for BFD
Configuring BFD control packet mode
Configuring BFD echo packet mode
Display and maintenance commands for IPv6 static routing
IPv6 static routing configuration examples
Example: Configuring basic IPv6 static route
Example: Configuring BFD for IPv6 static routes (direct next hop)
Example: Configuring BFD for IPv6 static routes (indirect next hop)
Configuring an IPv6 default route
About IPv6 static routing
Static routes are manually configured and cannot adapt to network topology changes. If a fault or a topological change occurs in the network, the network administrator must modify the static routes manually. IPv6 static routing works well in a simple IPv6 network.
1. Enter system view.
2. Configure an IPv6 static route.
Public network:
ipv6 route-static ipv6-address prefix-length { interface-type interface-number [ next-hop-address ] | next-hop-address | vpn-instance d-vpn-instance-name next-hop-address } [ permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ description text ]
By default, no IPv6 static route is configured.
VPN:
ipv6 route-static vpn-instance s-vpn-instance-name ipv6-address prefix-length { interface-type interface-number [ next-hop-address ] | vpn-instance d-vpn-instance-name next-hop-address } [ permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ description text ]
ipv6 route-static vpn-instance s-vpn-instance-name ipv6-address prefix-length nexthop-address [ public ] [ permanent ] [ preference preference ] [ tag tag-value ] [ description text ]
3. (Optional.) Set the default preference for IPv6 static routes.
ipv6 route-static default-preference default-preference
The default setting is 60.
Deleting IPv6 static routes
To delete an IPv6 static route, use the undo ipv6 route-static command. To delete all IPv6 static routes including the default route, use the delete ipv6 static-routes all command.
2. Delete all IPv6 static routes, including the default route.
delete ipv6 [ vpn-instance vpn-instance-name ] static-routes all
BFD provides a general purpose, standard, and medium- and protocol-independent fast failure detection mechanism. It can uniformly and quickly detect the failures of the bidirectional forwarding paths between two routers for protocols, such as routing protocols and MPLS. BFD for IPv6 static routes tests the reachability of the next hop for each IPv6 static route. If a next hop is unreachable, BFD deletes the associated IPv6 static route.
For more information about BFD, see High Availability Configuration Guide.
When you configure BFD for IPv6 static routes, follow these restrictions and guidelines:
· If you specify a source IPv6 address for BFD packets on the local device, you must specify that IPv6 address as the next hop IPv6 address on the peer device.
· If you specify a non-P2P output interface and a direct next hop, specify the bfd-source ipv6-address option as a best practice. Make sure the source IPv6 address of BFD packets meets the following requirements:
¡ The address is the same as the IPv6 address of the output interface.
¡ The address is on the same network segment as the next hop IPv6 address of the same type.
For example, if the next hop IPv6 address is a link-local address, the source IPv6 address of BFD packets must also be a link-local address.
· Enabling BFD for a flapping route could worsen the situation.
This mode uses BFD control packets to detect the status of a link bidirectionally at a millisecond level.
BFD control packet mode can be applied to IPv6 static routes with a direct next hop or with an indirect next hop.
Restrictions and guidelines for BFD control packet mode
If you configure BFD control packet mode at the local end, you must also configure this mode at the peer end.
Configuring BFD control packet mode for an IPv6 static route (direct next hop)
2. Configure BFD control packet mode for an IPv6 static route.
ipv6 route-static [ vpn-instance s-vpn-instance-name ] ipv6-address prefix-length interface-type interface-number next-hop-address bfd control-packet [ bfd-source ipv6-address ] [ preference preference ] [ tag tag-value ] [ description text ]
By default, BFD control packet mode for an IPv6 static route is not configured.
Configuring BFD control packet mode for an IPv6 static route (indirect next hop)
ipv6 route-static [ vpn-instance s-vpn-instance-name ] ipv6-address prefix-length [ vpn-instance d-vpn-instance-name ] { next-hop-address bfd control-packet bfd-source ipv6-address } [ preference preference ] [ tag tag-value ] [ description text ]
With BFD echo packet mode enabled for a static route, the output interface sends BFD echo packets to the destination device, which loops the packets back to test the link reachability.
You do not need to configure BFD echo packet mode at the peer end.
Do not use BFD for a static route with the output interface in spoofing state.
2. Configure the source address of echo packets.
By default, the source address of echo packets is not configured.
The source address of echo packets must be a global unicast address.
For more information about this command, see High Availability Command Reference.
3. Configure BFD echo packet mode for an IPv6 static route.
ipv6 route-static [ vpn-instance s-vpn-instance-name ] ipv6-address prefix-length interface-type interface-number next-hop-address bfd echo-packet [ bfd-source ipv6-address ] [ preference preference ] [ tag tag-value ] [ description text ]
By default, BFD echo packet mode for an IPv6 static route is not configured.
The next hop IPv6 address must be a global unicast address.
Task |
Command |
Display IPv6 static route next hop information. |
display ipv6 route-static nib [ nib-id ] [ verbose ] |
Display IPv6 static routing table information. |
display ipv6 route-static routing-table [ vpn-instance vpn-instance-name ] [ ipv6-address prefix-length ] |
Display IPv6 static route information. |
display ipv6 routing-table protocol static [ inactive | verbose ] |
For more information about the display ipv6 routing-table protocol static [ inactive | verbose ] command, see basic IP routing in Layer 3—IP Routing Command Reference.
As shown in Figure 1, configure IPv6 static routes so that hosts can reach each other.
1. Configure IPv6 addresses for interfaces. (Details not shown.)
2. Configure IPv6 static routes:
# Configure the default IPv6 route on Router A.
[RouterA] ipv6 route-static :: 0 4::2
# Configure two IPv6 static routes on Router B.
<RouterB> system-view
[RouterB] ipv6 route-static 1:: 64 4::1
[RouterB] ipv6 route-static 3:: 64 5::1
# Configure the default IPv6 route on Router C.
<RouterC> system-view
[RouterC] ipv6 route-static :: 0 5::2
3. Configure the IPv6 addresses for all hosts and configure the default gateway of Host A, Host B, and Host C as 1::1, 2::1, and 3::1.
# Display the IPv6 static route information on Router A.
[RouterA] display ipv6 routing-table protocol static
Summary Count : 1
Static Routing table Status : <Active>
Summary Count : 1
Destination: :: Protocol : Static
NextHop : 4::2 Preference: 60
Interface : GE2/0 Cost : 0
Static Routing table Status : <Inactive>
Summary Count : 0
# Display the IPv6 static route information on Router B.
[RouterB] display ipv6 routing-table protocol static
Summary Count : 2
Summary Count : 2
Destination: 1::/64 Protocol : Static
NextHop : 4::1 Preference: 60
Interface : GE1/0 Cost : 0
Destination: 3::/64 Protocol : Static
NextHop : 5::1 Preference: 60
Summary Count : 0
# Use the ping command to test reachability.
Ping6(56 data bytes) 4::1 --> 3::1, press CTRL_C to break
56 bytes from 3::1, icmp_seq=0 hlim=62 time=0.700 ms
56 bytes from 3::1, icmp_seq=1 hlim=62 time=0.351 ms
56 bytes from 3::1, icmp_seq=2 hlim=62 time=0.338 ms
56 bytes from 3::1, icmp_seq=3 hlim=62 time=0.373 ms
56 bytes from 3::1, icmp_seq=4 hlim=62 time=0.316 ms
--- Ping6 statistics for 3::1 ---
round-trip min/avg/max/std-dev = 0.316/0.416/0.700/0.143 ms
As shown in Figure 2:
· Configure an IPv6 static route to subnet 120::/64 on Router A.
· Configure an IPv6 static route to subnet 121::/64 on Router B.
· Enable BFD for both routes.
· Configure an IPv6 static route to subnet 120::/64 and an IPv6 static route to subnet 121::/64 on Router C.
When the link between Router A and Router B through the Layer 2 switch fails, BFD can detect the failure immediately and inform Router A and Router B to communicate through Router C.
Device |
IPv6 address |
Router A |
GE1/0 |
12::1/64 |
Router A |
GE2/0 |
10::102/64 |
Router B |
GE1/0 |
12::2/64 |
Router B |
GE2/0 |
13::1/64 |
Router C |
GE1/0 |
10::100/64 |
Router C |
GE2/0 |
13::2/64 |
2. Configure IPv6 static routes and BFD:
# Configure IPv6 static routes on Router A, and enable BFD control packet mode for the IPv6 static route that traverses GigabitEthernet 1/0.
[RouterA] interface gigabitethernet 1/0
[RouterA-GigabitEthernet1/0] bfd min-transmit-interval 500
[RouterA-GigabitEthernet1/0] bfd min-receive-interval 500
[RouterA-GigabitEthernet1/0] bfd detect-multiplier 9
[RouterA-GigabitEthernet1/0] quit
[RouterA] ipv6 route-static 120:: 64 gigabitethernet 1/0 12::2 bfd control-packet
[RouterA] ipv6 route-static 120:: 64 10::100 preference 65
[RouterA] quit
# Configure IPv6 static routes on Router B, and enable BFD control packet mode for the IPv6 static route that traverses the Layer 2 switch.
[RouterB] interface gigabitethernet 1/0
[RouterB-GigabitEthernet1/0] bfd min-transmit-interval 500
[RouterB-GigabitEthernet1/0] bfd min-receive-interval 500
[RouterB-GigabitEthernet1/0] bfd detect-multiplier 9
[RouterB-GigabitEthernet1/0] quit
[RouterB] ipv6 route-static 121:: 64 gigabitethernet 1/0 12::1 bfd control-packet
[RouterB] ipv6 route-static 121:: 64 13::2 preference 65
[RouterB] quit
# Configure IPv6 static routes on Router C.
[RouterC] ipv6 route-static 120:: 64 13::1
[RouterC] ipv6 route-static 121:: 64 10::102
# Display BFD sessions on Router A.
<RouterA> display bfd session
Total sessions: 1 Up sessions: 1 Init mode: Active
IPv6 session working in control packet mode:
Local discr: 513 Remote discr: 33
Source IP: 12::1
Destination IP: 12::2
Session state: Up Interface: GE1/0
Hold time: 2012ms
The output shows that the BFD session has been created.
# Display IPv6 static routes on Router A.
<RouterA> display ipv6 routing-table protocol static
Summary Count : 1
Summary Count : 1
Destination: 120::/64 Protocol : Static
NextHop : 12::2 Preference: 60
Summary Count : 0
The output shows that Router A communicates with Router B through GigabitEthernet 1/0. The link over GigabitEthernet 1/0 fails.
Summary Count : 1
Summary Count : 1
NextHop : 10::100 Preference: 65
Summary Count : 0
The output shows that Router A communicates with Router B through GigabitEthernet 2/0.
As shown in Figure 3:
· Router A has a route to interface Loopback 1 (2::9/128) on Router B, and the output interface is GigabitEthernet 1/0.
· Router B has a route to interface Loopback 1 (1::9/128) on Router A, and the output interface is GigabitEthernet 1/0.
· Router D has a route to 1::9/128, and the output interface is GigabitEthernet 1/0. It also has a route to 2::9/128, and the output interface is GigabitEthernet 2/0.
Configure the following:
· Configure an IPv6 static route to subnet 120::/64 and an IPv6 static route to subnet 121::/64 on both Router C and Router D.
When the link between Router A and Router B through Router D fails, BFD can detect the failure immediately and Router A and Router B can communicate through Router C.
Device |
IPv6 address |
Router A |
GE1/0 |
12::1/64 |
Router A |
GE2/0 |
10::102/64 |
Router A |
Loop1 |
1::9/128 |
Router B |
GE1/0 |
11::2/64 |
Router B |
GE2/0 |
13::1/64 |
Router B |
Loop1 |
2::9/128 |
Router C |
GE1/0 |
10::100/64 |
Router C |
GE2/0 |
13::2/64 |
Router D |
GE1/0 |
12::2/64 |
Router D |
GE2/0 |
11::1/64 |
# Configure IPv6 static routes on Router A and enable BFD control packet mode for the IPv6 static route that traverses Router D.
[RouterA] bfd multi-hop min-transmit-interval 500
[RouterA] bfd multi-hop min-receive-interval 500
[RouterA] bfd multi-hop detect-multiplier 9
[RouterA] ipv6 route-static 120:: 64 2::9 bfd control-packet bfd-source 1::9
[RouterA] ipv6 route-static 2::9 128 12::2
[RouterA] quit
# Configure IPv6 static routes on Router B and enable BFD control packet mode for the IPv6 static route that traverses Router D.
[RouterB] bfd multi-hop min-transmit-interval 500
[RouterB] bfd multi-hop min-receive-interval 500
[RouterB] bfd multi-hop detect-multiplier 9
[RouterB] ipv6 route-static 121:: 64 1::9 bfd control-packet bfd-source 2::9
[RouterB] ipv6 route-static 1::9 128 11::1
[RouterB] quit
# Configure IPv6 static routes on Router D.
<RouterD> system-view
[RouterD] ipv6 route-static 120:: 64 11::2
[RouterD] ipv6 route-static 121:: 64 12::1
[RouterD] ipv6 route-static 2::9 128 11::2
[RouterD] ipv6 route-static 1::9 128 12::1
Source IP: 1::9
Destination IP: 2::9
Session state: Up Interface: N/A
Hold time: 2012ms
Summary Count : 1
Summary Count : 1
NextHop : 2::9 Preference: 60
Summary Count : 0
Summary Count : 1
Summary Count : 1
Summary Count : 0
A default IPv6 route is used to forward packets that match no entry in the routing table.
A default IPv6 route can be configured in either of the following ways:
· The network administrator can configure a default route with a destination prefix of ::/0. For more information, see "Configuring IPv6 static routing."
· Some dynamic routing protocols (such as OSPFv3, IPv6 IS-IS, and RIPng) can generate a default IPv6 route. For example, an upstream router running OSPFv3 can generate a default IPv6 route and advertise it to other routers. These routers install the default IPv6 route with the next hop being the upstream router. For more information, see the respective chapters on those routing protocols in this configuration guide.
