Strategy Partner :
03-Appendix B LEDs
1 Appendix B LEDs
The device uses similar LEDs. This section uses the LEDs on the L1090 load balancer as an example.
Figure1-1 LEDs
(1) Ethernet copper port LED |
(2) Ethernet fiber port LED |
(3) System status LED |
(4) Power supply status LED |
(5) Interface module status LED |
Table1-2 LED description
LED |
Mark |
Status |
10/100/1000BASE-T |
Off |
No link is present. |
Steady green |
A link is present. |
Flashing green |
The port is receiving and sending data. |
1000BASE-X |
Off |
Steady green |
A 1000 Mbps link is present. |
Flashing green |
The port is receiving and sending data at 1000 Mbps. |
10GBASE-R |
Off |
Steady green |
A 10 Gbps link is present. |
Flashing green |
The port is receiving and sending data at 10 Gbps. |
System status LED |
SYS |
Off |
The device is not powered on or has failed. |
Slow flashing green |
The device is operating correctly. |
Fast flashing green |
The device is loading software. |
PWR0, PWR1 |
Off |
No power supply is present or the power supply has failed. |
Steady green |
The power supply is operating correctly. |
SLOT1, SLOT2, SLOT 3, SLOT 4 |
Off |
No interface module is present or the interface module has failed. |
Steady green |
The interface module is operating correctly. |
Coperation Event & Solution
- H3C SecPath L10X0 Load Balancer Installation Guide-6W100-Appendix B LEDs.pdf
