H3C SecPath L10X0 Load Balancer Installation Guide-6W100
HomeSupportSecurityH3C SecPath L1000Install & UpgradeInstallation GuidesH3C SecPath L10X0 Load Balancer Installation Guide-6W100
Strategy Partner :
00-Preface
Preface
The installation guide describes the procedure for installing H3C SecPath L10X0 load balancer. It covers preparing for installation, installing the load balancer, logging in to the load balancer, hardware replacement, hardware management and maintenance, and troubleshooting.
·     Audience
·     Conventions
·     Documentation feedback
Audience
·     Network planners
·     Field technical support and servicing engineers
·     Network administrators working with the H3C SecPath L10X0 load balancer
Conventions
Command conventions
Convention
Boldface
Italic
{ x | y | ... }
[ x | y | ... ]
{ x | y | ... } *
Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select at least one.
[ x | y | ... ] *
&<1-n>
GUI conventions
Convention
Boldface
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK.
Symbols
Convention
WARNING WARNING!
CAUTION CAUTION:
IMPORTANT IMPORTANT:
TIP TIP:
Network topology icons
Convention
Represents an access point.
We appreciate your comments.
00-Preface
Coperation Event & Solution
  • H3C SecPath L10X0 Load Balancer Installation Guide-6W100-Preface.pdf
