11-Network Management and Monitoring Command Reference
HomeSupportReference GuidesCommand ReferencesH3C S6520X-EI[HI][SI] & S6520-SI & S5560X-HI Switch Series Command References-R65xx-6W10311-Network Management and Monitoring Command Reference
06-PoE commands
06-PoE commands 159.19 KB
PoE commands
Only the PoE models support the PoE feature.
apply poe-profile
Use apply poe-profile to apply a PoE profile to a power interface (PI).
Use undo apply poe-profile to restore the default.
apply poe-profile { index index | name profile-name }
undo apply poe-profile { index index | name profile-name }
No PoE profile is applied to PIs.
PI view
index index: Specifies a PoE profile by its index number in the range of 1 to 100.
name profile-name: Specifies a PoE profile by its name, a case-sensitive string of 1 to 15 characters.
# Apply the PoE profile named forIPphone to Smartrate-Ethernet 1/0/1.
[Sysname] interface Smartrate-Ethernet 1/0/1
[Sysname-Smartrate-Ethernet1/0/1] apply poe-profile name forIPphone
apply poe-profile interface
display poe-profile
Use apply poe-profile interface to apply a PoE profile to PIs.
Use undo apply poe-profile interface to remove the PoE profile application from PIs.
apply poe-profile { index index | name profile-name } interface interface-range
undo apply poe-profile { index index | name profile-name } interface interface-range
No PoE profile is applied to a PI.
interface-range: Specifies a range of Ethernet interfaces in the form of interface-type interface-number [ to interface-type interface-number ], where interface-type interface-number represents the interface type and interface number. The start interface number must be smaller than the end interface number. If an interface in the specified range does not support PoE, it is ignored when the PoE profile is applied.
[Sysname] apply poe-profile name forIPphone interface Smartrate-Ethernet 1/0/1
# Apply the PoE profile with index number 1 to PIs Smartrate-Ethernet 1/0/2 to Smartrate-Ethernet 1/0/6.
[Sysname] apply poe-profile index 1 interface smartrate-ethernet 1/0/2 to smartrate-ethernet 1/0/6
apply poe-profile
display poe-profile interface
display poe device
Use display poe device to display general PSE information.
display poe device [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, the command displays general PSE information about all PSEs in the IRF fabric.
# Display general PSE information.
<Sysname> display poe device
 PSE ID  Slot No. SSlot No. PortNum  MaxPower(W)  State  Model
 4        1          0          24        900              Off     LSP8POEJ
PSE ID
ID of the PSE.
Slot No.
Slot number of the PSE.
SSlot No.
Sub-slot number of the PSE.
PortNum
Number of PIs on the PSE.
MaxPower(W)
Maximum power of the PSE.
PSE status:
·     On—The PSE is supplying power.
·     Off—The PSE is not supplying power.
·     Faulty—The PSE has failed.
Model
PSE model.
display poe interface
Use display poe interface to display power supplying information for PIs.
display poe interface [ interface-type interface-number ]
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays power supplying information for all PIs.
# Display power supplying information for Smartrate-Ethernet 1/0/1.
<Sysname> display poe interface Smartrate-Ethernet 1/0/1
 PoE Status                 : Enabled
 Power Priority             : Low
 Oper                       : Off
 IEEE Class                 : 0
 Detection Status           : Searching
 Power Mode                 : Signal
 Current Power              : 0        mW
 Average Power              : 0        mW
 Peak Power                 : 0        mW
 Max Power                  : 100000   mW
 Electric Current           : 0        mA
 Voltage                    : 0.0      V
 PD Description             :
 Legacy PD Detection        : Disabled
PoE Status
PoE status:
·     Enabled.
·     Disabled.
Power Priority
Power supply priority:
·     Critical (highest).
·     High.
·     Low.
Oper
Operating status:
·     Off—PoE is disabled.
·     On—Power is being supplied to the PI correctly.
·     Power-lack—Remaining guaranteed power is insufficient for a critical PI.
·     Power-deny—The PSE refuses to supply power. The power required by the PD is higher than the configured power.
·     Power-itself—The PD is using another power supply.
·     Power-limit—The PSE is supplying power to the PD based on the configured power though the PD requires more power than the configured power.
IEEE Class
Class of power that the PI supplies to a PD.
If the PI does not support supplying power to a PD, this field displays a hyphen (-).
Detection Status
Power detection status:
·     Disabled—The PoE function is disabled.
·     Searching—The PI is searching for the PD.
·     Delivering power—The PI is supplying power to the PD.
·     Fault—A fault occurred during the test.
·     Test—The PI is supplying power forcibly to the PD.
·     Other fault—A fault has caused the PSE to enter the idle status.
·     PD disconnected—The PD is disconnected.
Power Mode
Power transmission mode. The value is Signal, indicating that power is transmitted over the signal pairs of a twisted pair cable.
Current Power
Current power, including PD consumption power and transmission loss.
Average Power
Average power.
Peak Power
Peak power.
Max Power
Maximum power.
Electric Current
Current.
Voltage
Voltage.
PD Description
Type and location description for the PD connected to the PI.
Legacy PD Detection
Whether non-standard PD detection is enabled:
·     Enabled.
·     Disabled.
PoE force power Status
Whether forced power supply is enabled:
·     Enabled.
·     Disabled.
# Display power supplying information for all PIs.
Interface    PoE       Priority  CurPower  Oper     IEEE  Detection
                                      (W)                 Class Status
 SGE1/0/1     Enabled   Low       0.0       Off       0     Searching
 SGE1/0/2     Enabled   Low       0.0       Off       0     Searching
 SGE1/0/3     Disabled  Low       0.0       Off       0     Disabled
 SGE1/0/4     Disabled  Low       0.0       Off       0     Disabled
 SGE1/0/5     Disabled  Low       0.0       Off       0     Disabled
 SGE1/0/6     Disabled  Low       0.0       Off       0     Disabled
 SGE1/0/7     Disabled  Low       0.0       Off       0     Disabled
 SGE1/0/8     Disabled  Low       0.0       Off       0     Disabled
 SGE1/0/9     Disabled  Low       0.0       Off       0     Disabled
 SGE1/0/10    Disabled  Low       0.0       Off       0     Disabled
 SGE1/0/11    Disabled  Low       0.0       Off       0     Disabled
 SGE1/0/12    Disabled  Low       0.0       Off       0     Disabled
 SGE1/0/13    Disabled  Low       0.0       Off       0     Disabled
 SGE1/0/14    Disabled  Low       0.0       Off       0     Disabled
 SGE1/0/15    Disabled  Low       0.0       Off       0     Disabled
 SGE1/0/16    Disabled  Low       0.0       Off       0     Disabled
 SGE1/0/17    Disabled  Low       0.0       Off       0     Disabled
 SGE1/0/18    Disabled  Low       0.0       Off       0     Disabled
 SGE1/0/19    Disabled  Low       0.0       Off       0     Disabled
 SGE1/0/20    Disabled  Low       0.0       Off       0     Disabled
 SGE1/0/21    Disabled  Low       0.0       Off       0     Disabled
 SGE1/0/22    Disabled  Low       0.0       Off       0     Disabled
 SGE1/0/23    Disabled  Low       0.0       Off       0     Disabled
 SGE1/0/24    Disabled  Low       0.0       Off       0     Disabled
   ---  On State Ports: 0; Used: 0.0(W); Remaining: 900.0(W)  ---
Interface name.
PoE
PoE status:
·     Enabled.
·     Disabled.
Priority
Power priority:
·     High.
·     Low.
CurPower
Current power.
Oper
Operating status:
IEEE Class
Detection Status
·     Disabled—PoE function is disabled.
·     Delivering Power—The PI is supplying power for the PD.
·     Test—The PI is undergoing a test.
On State Ports
Number of PIs that are supplying power.
Used
Power consumed by the current PI.
Remaining
Total remaining power of all PSEs configured with a maximum power.
display poe interface power
Use display poe interface power to display power information for PIs.
display poe interface power [ interface-type interface-number ]
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays power information for all PIs.
# Display power information for Smartrate-Ethernet 1/0/1.
<Sysname> display poe interface power Smartrate-Ethernet 1/0/1
Interface    Current   Peak      Max       PD Description
               (W)       (W)       (W)
 SGE1/0/1     0.0       0.0       100.0
# Display power information for all PIs.
               (W)       (W)       (W)
 SGE1/0/2     0.0       0.0       100.0
 SGE1/0/3     0.0       0.0       100.0
 SGE1/0/4     0.0       0.0       100.0
 SGE1/0/5     0.0       0.0       100.0
 SGE1/0/6     0.0       0.0       100.0
 SGE1/0/7     0.0       0.0       100.0
 SGE1/0/8     0.0       0.0       100.0
 SGE1/0/9     0.0       0.0       100.0
 SGE1/0/10    0.0       0.0       100.0
 SGE1/0/11    0.0       0.0       100.0
 SGE1/0/12    0.0       0.0       100.0
 SGE1/0/13    0.0       0.0       100.0
 SGE1/0/14    0.0       0.0       100.0
 SGE1/0/15    0.0       0.0       100.0
 SGE1/0/16    0.0       0.0       100.0
 SGE1/0/17    0.0       0.0       100.0
 SGE1/0/18    0.0       0.0       100.0
 SGE1/0/19    0.0       0.0       100.0
 SGE1/0/20    0.0       0.0       100.0
 SGE1/0/21    0.0       0.0       100.0
 SGE1/0/22    0.0       0.0       100.0
 SGE1/0/23    0.0       0.0       100.0
 SGE1/0/24    0.0       0.0       100.0
Interface name.
CurPower
Current power.
PeakPower
Peak power.
MaxPower
Maximum power.
PD Description
Type and location description for the PD connected to a PI.
Ports On
Used
Power consumed by all PIs.
Remaining
Total remaining power of all PSEs configured with a maximum power. This field displays 0 if no PSE is configured with a maximum power (all PSEs participate in dynamic power allocation).
display poe pse
Use display poe pse to display detailed PSE information.
display poe pse [ pse-id ]
pse-id: Specifies a PSE by its ID. The device is a single-PSE device. This command displays same information whether you specify this argument or not.
# Display detailed PSE information.
<Sysname> display poe pse
PSE ID                           : 4
 Slot No.                         : 1
 SSlot No.                        : 0
 PSE Model                        : LSP8POEJ
 PSE Status                       : Enabled
 Current Power                    : 0.0      W
 Average Power                    : 0.0      W
 Peak Power                       : 0.0      W
 Max Power                        : 900.0    W
 Remaining Guaranteed Power       : 900.0    W
 PSE CPLD Version                 : -
 PSE Software Version             : 1654
 PSE Hardware Version             : 57633
 PSE Legacy PD Detection          : Disabled
 Power Utilization Threshold      : 80
 PD Power Policy                  : Disabled
 PD Disconnect-Detection Mode     : DC
 PD High Inrush                   : Enabled
Table 5 Command output
PSE ID
ID of the PSE.
SSlot No.
Sublsot number of the PSE.
PSE Status
PoE status of the PSE:
·     Enabled.
·     Disabled.
PSE Fast Power Supply
Whether PSE fast power supply is enabled:
·     Enabled.
·     Disabled.
Power Priority
Power priority of the PSE.
Current Power
Current power of the PSE.
Average Power
Average power of the PSE.
Peak Power
Peak power of the PSE.
Max Power
Remaining guaranteed power of the PSE = Maximum guaranteed power of the PSE – Total maximum power of all critical PIs of the PSE.
PSE CPLD Version
PSE CPLD version number.
PSE software version number.
PSE hardware version number.
Legacy PD Detection
Nonstandard PD detection status:
·     Enabled.
·     Disabled.
PSE power alarm threshold.
PD Power Policy
PD power management policy mode.
PD disconnection detection mode.
PD High Inrush
Whether inrush current drawn by PDs is allowed:
·     Enabled—Allowed.
·     Disabled—Not allowed.
display poe pse interface
Use display poe pse interface to display the PoE status of all PIs on a PSE.
display poe pse pse-id interface
pse pse-id: Specifies a PSE ID. To display PSE ID and slot mappings, use the display poe device command.
# Display the status of all PIs on PSE 4.
<Sysname> display poe pse 4 interface
                                     (W)                  Class Status
Table 6 Command output
Interface name.
PoE
PoE status:
·     Enabled.
·     Disabled.
Priority
Priority:
·     High.
·     Low.
CurPower
Current power.
Oper
Operating status:
IEEE Class
Detection Status
·     Delivering Power—The PI is supplying power to the PD.
·     Other Fault—A fault has caused the PSE to enter the idle status.
·     PD Disconnected—The PD is disconnected.
On State Ports
Used
Power consumed by PIs on the PSE.
Remaining
Remaining power of the PSE.
display poe pse interface power
Use display poe pse interface power to display power information for PIs on a PSE.
display poe pse pse-id interface power
pse pse-id: Specifies a PSE by its ID. To display PSE ID and slot mappings, use the display poe device command.
# Display power information for PIs on PSE 4.
<Sysname> display poe pse 4 interface power
               (W)       (W)       (W)
Table 7 Command output
Interface name.
Current
Current power.
Peak
Peak power.
Max
Maximum power.
PD Description
Type and location description for the PD connected with a PI.
Ports On
Used
Remaining
display poe-profile
Use display poe-profile to display information about the PoE profile.
display poe-profile [ index index | name profile-name ]
If you do not specify a profile, the command displays information about all PoE profiles.
# Display information about all PoE profiles.
<Sysname> display poe-profile
 PoE Profile     Index   ApplyNum  Interfaces     Configuration
 forIPphone      1        4           SGE1/0/1        poe enable
                                        SGE1/0/2        poe priority critical
                                        SGE1/0/3
                                        SGE1/0/4
 forAP            2        2           SGE1/0/5        poe enable
                                        SGE1/0/6        poe max-power 14000
   ---  Total PoE profiles: 2, total ports: 6  ---
# Display information about the PoE profile with index number 1.
<Sysname> display poe-profile index 1
 forIPphone      1        6          SGE1/0/1       poe enable
                                       SGE1/0/3
                                       SGE1/0/4
                                       SGE1/0/5
                                       SGE1/0/6
   ---  Total ports: 6  ---
Table 8 Command output
PoE Profile
Name of the PoE profile.
Index
Index number of the PoE profile.
ApplyNum
Number of PIs to which the PoE profile is applied.
Interfaces
Interface name of the PI to which the PoE configuration is applied.
Configuration
Configurations of the PoE profile.
Total PoE profiles
Number of PoE profiles.
Total ports
Number of PIs to which all PoE profiles are applied.
Use display poe-profile interface to display information about the PoE profile on a PI.
display poe-profile interface interface-type interface-number
# Display information about the PoE profile on Smartrate-Ethernet 1/0/1.
<Sysname> display poe-profile interface Smartrate-Ethernet 1/0/1
 PoEProfile     Index   ApplyNum  Interface   Effective configuration
The Effective configuration field displays the configurations that have taken effect. For the descriptions of other fields, see Table 8.
poe ai enable
Use poe ai enable to enable AI-driven PoE.
Use undo ai poe enable to disable AI-driven PoE.
poe ai enable
undo poe ai enable
AI-driven PoE is disabled.
With AI-driven PoE enabled, the device automatically recovers the PI when one PI fails. If more than one PI fails simultaneously, the device recovers the PIs one by one in ascending order of PI number.
AI-driven PoE automatically adjusts the power supply parameters to fit the power needs. If you disable AI-driven PoE, the system reverts the parameters to the settings before the adjustment.
AI-driven PoE takes effect only on PSEs that run firmware V147 or later.
·     Firmware earlier than V147—You must use the poe update command to upgrade the PSE firmware and then enable AI-driven PoE on it.
·     Firmware V147 or later—You do not need to re-enable AI-driven PoE after upgrading the firmware.
# Enable AI-driven PoE.
[Sysname] poe ai enable
poe update
PoE detection-mode
Use poe detection-mode to configure the PD detection mode.
Use undo poe detection-mode to restore the default.
poe detection-mode { none | simple | strict }
The PD detection mode is strict.
PI view
none: Enables the device to supply power to PDs that are correctly connected to the device without causing short circuit.
simple: Enables the device to supply power to PDs that comply with basic requirements of 802.3af or 802.3at.
strict: Enables the device to supply power to PDs that comply with all requirements of 802.3af or 802.3at.
CAUTION
CAUTION:
A non-PD device might be damaged when power is supplied to it. To avoid device damage, do not specify the none keyword when the PI connects to a non-PD device.
To configure the detection mode for nonstandard PDs, first execute the poe legacy enable command to enable detection for nonstandard PDs.
# Configure the simple detection mode for Smartrate-Ethernet1/0/1.
[Sysname] interface smartrate-ethernet1/0/1
[Sysname-Smartrate-Ethernet1/0/1] poe detection-mode simple
poe legacy enable
poe enable
Use poe enable to enable PoE on a PI.
Use undo poe enable to disable PoE on a PI.
poe enable
undo poe enable
PoE is disabled on a PI.
PI view
PoE profile view
If a PoE profile has been applied to a PI, remove the application before configuring the PI in PoE profile view.
If a PI has been configured, remove the configuration before configuring the PI in PI view.
# Enable PoE on a PI in PI view.
[Sysname-Smartrate-Ethernet1/0/1] poe enable
# Enable PoE on a PI in PoE profile view.
[Sysname] poe-profile abc
[Sysname-poe-profile-abc-1] poe enable
poe-profile
poe force-power
Use poe force-power to enable forced power supply.
Use undo poe force-power to disable forced power supply.
poe force-power
Forced power supply is disabled.
PI view
CAUTION
CAUTION:
This command enables the device to supply power to a PD directly without performing a detection of the PD. To avoid damaging the PD, make sure the power provided by the device meets the PD specifications before executing this command.
Before supplying power to a PD, the device performs a detection of the PD. It supplies power to the PD only after the PD passes the detection. If the PD fails the detection but the power provided by the device meets the PD specifications, you can execute this command to enable forced power supply to the PD.
# Enable forced power supply.
[Sysname-Smartrate-Ethernet1/0/1] poe force-power
The PD might be damaged if the power provided by the device does not meet the PD power specifications. Continue? [Y/N]:y
poe high-inrush enable
Use poe high-inrush enable to allow inrush current drawn by PDs.
Use undo poe high-inrush enable to restore the default.
poe high-inrush enable pse pse-id
undo poe high-inrush enable pse pse-id
Inrush current drawn by PDs is not allowed.
CAUTION
CAUTION:
Inrush current might damage the device components. Use this command with caution.
Inrush current might occur at PD startup and trigger PSE self-protection, As a result, the PSE stops supplying power to the PDs. To continue power supply to the PDs, configure this feature to allow inrush current drawn by PDs.
IEEE 802.3af and IEEE 802.3at define specifications for inrush current. The device supports the IEEE 802.3af and IEEE 802.3at specifications for inrush current.
# Allow inrush current drawn by PDs.
[Sysname] poe high-inrush enable pse 4
display poe pse
poe legacy enable (interface view)
Use poe legacy enable to enable nonstandard PD detection for a PI.
Use undo poe legacy enable to disable nonstandard PD detection for a PI.
poe legacy enable
Nonstandard PD detection is disabled for a PI.
Interface view
The device supports PSE-based and PI-based nonstandard PD detection. If you enable nonstandard PD detection both in system view and interface view, the configuration in system view takes effect.
As a best practice for disabling nonstandard PD detection for all PIs successfully in one operation, disable this feature in both system view and interface view.
# Enable nonstandard PD detection for a PI.
[Sysname] interface smartrate-ethernet 1/0/1
[Sysname-Smartrate-Ethernet1/0/1] poe legacy enable
poe legacy enable (system view)
Use poe legacy enable to enable the PSE to detect nonstandard PDs.
Use undo poe legacy enable to disable the PSE from detecting nonstandard PDs.
poe legacy enable pse pse-id
undo poe legacy enable pse pse-id
Nonstandard PD detection is disabled.
# Enable PSE 4 to detect nonstandard PDs.
[Sysname] poe legacy enable pse 4
display poe pse
poe max-power
Use poe max-power to set the maximum PI power.
Use undo poe max-power to restore the default.
poe max-power max-power
undo poe max-power
The maximum PI power is 100000 milliwatts.
PI view
PoE profile view
max-power: Sets the maximum PI power in milliwatts by an increment. The value in the range of 1000 to 100000.
# Set the maximum PI power to 12000 milliwatts in PI view.
[Sysname-Smartrate-Ethernet1/0/1] poe max-power 12000
# Set the maximum PI power to 12000 milliwatts in PoE profile view.
[Sysname-poe-profile-abc-1] poe max-power 12000
poe max-power (system view)
Use poe max-power to set the maximum PSE power.
poe pse pse-id max-power max-power
undo poe pse pse-id max-power
The maximum PSE power depends on the power supply model.
max-power: Sets the maximum PSE power in watts by an increment.
To avoid the PSE power overload situation, make sure the total power of all PSEs is less than the maximum PoE power.
The maximum power of the PSE must be greater than or equal to the total maximum power of all its critical PIs on the PSE to guarantee these PIs power.
# Set the maximum power of PSE 4 to 150 watts.
[Sysname] poe pse 4 max-power 150
poe max-power (interface view)
poe priority pse
poe pd-description
Use poe pd-description to configure a description for the PD that connects to a PI.
Use undo poe pd-description to restore the default.
poe pd-description text
No description is configured for the PD that connects to a PI.
PI view
text: Configures a description for the PD connected to the PI, a case-sensitive string of 1 to 80 characters.
# Configure the description for the PD as IP Phone for Room 101.
[Sysname-Smartrate-Ethernet1/0/1] poe pd-description IP Phone For Room 101
poe pd-policy priority
Use poe pd-policy priority to enable PI power management.
Use undo poe pd-policy priority to restore the default.
PI power management is disabled.
If PI power management is disabled, the PSE does not supply power to new PDs when PSE power overload occurs.
If PI power management is enabled, when a PSE is overloaded, the PSE allocates power to PDs based on the priority of their PIs.
# Enable PI power management.
[Sysname] poe pd-policy priority
poe priority
poe power-delay
Use poe power-delay to enable PoE delay.
Use undo poe power-delay to disable PoE delay.
IMPORTANT
IMPORTANT:
This command is supported only in R6515P06 and later.
poe power-delay time
PoE delay is disabled.
time: Specifies the delay time in the range of 1 to 3600, in seconds.
The device executes the poe enable command on an interface when any one of the following conditions is met:
·     The poe enable command is configured on the interface.
·     The device reboots with the poe enable command in the configuration file.
·     The interface comes up and the PoE module resumes PoE power supply to the interface.
By default, the PoE module supplies power to an interface immediately after the poe enable command is executed. This command creates a PoE delay timer after the poe enable command is executed and allows the PoE module to supply power to the PI only after the timer expires.
The undo poe enable command is executed immediately upon configuration and is not affected by command.
# Enable PoE delay and set the delay time to 30 seconds.
[Sysname] poe power-delay 30
poe enable
poe priority (interface view)
Use poe priority to set the power supply priority for a PI.
Use undo poe priority to restore the default.
poe priority { critical | high | low }
undo poe priority
The power supply priority of a PI is low.
PI view
PoE profile view
critical: Sets the power supply priority to critical. The PI with critical power priority operates in guaranteed mode. Power is first supplied to the PD connected to the critical PI.
high: Sets the power supply priority to high.
low: Sets the power supply priority to low.
When the PoE power is insufficient, power is first supplied to PIs with higher priority.
For PIs with same power supply priority, the PI with the smallest ID is allocated with power first.
# Set the power supply priority of the PI to critical in PI view.
[Sysname-Smartrate-Ethernet1/0/1] poe priority critical
# Set the power supply priority of the PI to critical in PoE profile view.
[Sysname-poe-profile-abc-1] poe priority critical
[Sysname-poe-profile-abc-1] quit
[Sysname-Smartrate-Ethernet1/0/1] apply poe-profile name abc
poe reset enable
Use poe reset enable to enable PI power cycling upon a system warm reboot.
Use undo poe pse-policy priority to disable PI power cycling upon a system warm reboot.
poe reset enable
undo poe reset enable
PI power cycling upon a system warm reboot is disabled.
During the system warm reboot process (upon execution of the reboot command), the PIs continue supplying power to the PDs but data connections between the PDs and the device are interrupted. After the system reboots, PDs might not re-initiate data connections with the device. Power cycling PIs upon a system warm reboot allows the PDs to re-establish data connections with the device.
# Enable PI power cycling upon a system warm reboot.
[Sysname] poe reset enable
poe standard
Use poe standard { at | bt } to specify a PoE standard for a PI.
Use undo poe standard to restore the default.
undo poe standard
The PI uses the IEEE 802.3bt standard.
PI view
at: Specifies the IEEE 802.3at standard.
bt: Specifies the IEEE 802.3bt standard.
For your configuration to take effect, restore the PI maximum power to the default before you configuring this command.
IEEE released 802.3af (PoE), 802.3at (PoE+), and 802.3bt (PoE++) standards in chronological order. IEEE PoE standards are backward compatible but forwards incompatible. Before supplying power to a PD, an interface will detect the PD, determine the power class for the PD based on its power requirement, and supplies power to the PD based on the power class.
·     802.3af—Defines four power classes 0 to 3 and provides a maximum power of 12.95 W.
·     802.3at—Adds class 4 in addition to the four power classes defined by 802.3af and provides a maximum power of 25.5 W.
·     802.3bt—Adds classes 5 to 8 in addition to the five power classes defined by 802.3at and provides a maximum power of 71 W.
Specify a PoE standard based on the power requirement of the PD. If the maximum power allowed by the standard is less than that required by the PD, the PI will not supply power to the PD.
If a PI operates in IEEE 802.3bt mode and supplies more than 30 W power, changing the PoE standard for the PI will cause the connected PDs to be power cycled. Be cautious when you modify the configuration of this command.
# Specify the PoE standard as IEEE 802.3at for PI Smartrate-Ethernet 1/0/1.
[Sysname-Smartrate-Ethernet1/0/1] poe standard at
poe track-shutdown
Use poe track-shutdown to disable PoE on shutdown interfaces.
Use undo poe track-shutdown to restore the default.
IMPORTANT
IMPORTANT:
poe track-shutdown
PoE is not disabled on shutdown interfaces.
By default, the device continues power supply to an interface after the interface is shut down by the shutdown command or by an upper layer module such as monitor link. As a result, the PD connected to the shutdown interface operates continuously but fails to access the network.
This command disables the PoE module from supplying power to an interface after the interface is shut down. After the interface comes up, the PoE module resumes power supply to the interface.
The command does not power off an interface that has been shut down but is supplying power to a PD.
# Disable PoE on shutdown interfaces.
[Sysname] poe track-shutdown
poe enable
poe update
Use poe update to upgrade the PSE firmware when the device is operating.
poe update { full | refresh } filename [ pse pse-id ]
full: Upgrades the PSE firmware in full mode.
refresh: Upgrades the PSE firmware in refresh mode.
filename: Specifies the name of the upgrade file, a case-insensitive string of 1 to 64 characters. The specified file must be in the root directory of the file system of the device.
pse pse-id: Specifies a PSE by its ID. If you do not specify a PSE, all PSEs are upgraded.
You can upgrade the PSE firmware in service in either of the following modes:
·     Refresh mode—Updates the PSE firmware without deleting it. You can use the refresh mode in most cases.
·     Full mode—Deletes the current PSE firmware and reloads a new one. Use the full mode if the PSE firmware is damaged and you cannot execute any PoE commands.
# Upgrade the firmware of PSE 4 in service.
[Sysname] poe update refresh POE-168.bin pse 4
poe utilization-threshold
Use poe utilization-threshold to configure a power alarm threshold for the PSE.
Use undo poe utilization-threshold to restore the default power alarm threshold of the PSE.
poe utilization-threshold value pse pse-id
undo poe utilization-threshold pse pse-id
The power alarm threshold for the PSE is 80%.
value: Specifies alarm threshold as a percentage of 1 to 99.
If PSE power usage crosses the threshold multiple times in succession, the system sends notification messages only for the first crossing. For more information, see "Configuring SNMP."
# Set the power alarm threshold of PSE 4 to 90%.
[Sysname] poe utilization-threshold 90 pse 4
poe-profile
Use poe-profile to create a PoE profile and enter its view, or enter the view of an existing PoE profile.
Use undo poe-profile to delete a PoE profile.
poe-profile profile-name [ index ]
undo poe-profile { index index | name profile-name }
No PoE profiles exist.
profile-name: Specifies a PoE profile name, a case-sensitive string of 1 to 15 characters. A PoE configuration file name begins with a letter and must not contain reserved keywords including undo, all, name, interface, user, poe, disable, max-power, mode, priority, or enable.
index: Specifies the index number of a PoE profile, in the range of 1 to 100.
To configure PIs in batches, use the PoE profile.
If you do not specify a profile index, the system automatically assigns an index (starting from 1) to the PoE profile.
If a PoE profile is applied, use the undo apply poe-profile command to remove the application before deleting the PoE profile.
# Create a PoE profile, name it abc, and specify the index number as 3.
[Sysname] poe-profile abc 3
[Sysname-poe-profile-abc-3]
# Create a PoE profile and name it def. Do not specify the index number.
[Sysname] poe-profile def
[Sysname-poe-profile-def-1]
apply poe-profile
poe enable
poe mode
poe priority
  • Become a Partner
  • Partner Resources
