H3C MSR3610E-X1[-X1-DP] Routers Hardware Information and Specifications-5W100
HomeSupportResource CenterRoutersMSR3600 Series(Comware V7)MSR3600 Series(Comware V7)Technical DocumentsProduct LiteratureHardware Information & SpecificationsH3C MSR3610E-X1[-X1-DP] Routers Hardware Information and Specifications-5W100
02-LEDs
02-LEDs 135.86 KB
2 LEDs
LEDs
MSR3610E-X1
Figure2-1 MSR3610E-X1 LEDs
(1) System status LED (SYS)
(2) LEDs for GE copper ports GE2 to GE9
(3) LEDs for 10GE fiber ports SFP+10 to SFP+12
(4) LEDs for combo copper ports GE0 and GE1
(5) LEDs for combo fiber ports SFP0 and SFP1
(6) Power status LED (PWR)
(7) CTRL LED (CTRL)
MSR3610E-X1-DP
Figure2-2 MSR3610E-X1-DP LEDs
(1) CTRL LED (CTRL)
(2) System status LED (SYS)
(3) LEDs for GE copper ports GE2 to GE9
(4) LEDs for 10GE fiber port SFP+10 to SFP+12
(5) LEDs for combo copper ports GE0 and GE1
(6) LEDs for combo fiber ports SFP0 and SFP1
(7) Power status LED (PWR2)
(8) Power status LED (PWR1)
LED descriptions
Table2-1 LED descriptions
LED
Status
Flashing green (eight times per second)
The BootWare is running.
Steady green
The Kernel (including Eshell) is running.
Flashing green (once per second)
Comware has started with the configuration file and the router has booted up.
Flashing yellow (once per second)
The memory test has failed. (BootWare stage)
Flashing yellow (eight times per second)
The extended segment does not exist. (BootWare stage)
Steady yellow
The boot.bin file does not exist. (BootWare stage)
Off
The device is powered off, or the power supply or system hardware is faulty.
Steady green
The power supply is operating correctly.
Off
No power input.
GE copper port LED
Combo copper port LED
Steady green
A 1000 Mbps link is present on the port.
Flashing green
Data is being received or transmitted on the port at 1000 Mbps.
Steady yellow
A 10/100 Mbps link is present on the port.
Flashing yellow
Data is being received or transmitted on the port at 10/100 Mbps.
Off
No link is present on the port.
Combo fiber port LED
Steady green
Flashing green
Steady yellow
A 100 Mbps link is present on the port.
Flashing yellow
Data is being received or transmitted on the port at 100 Mbps.
Off
10GE fiber port LED
Steady green
A 10 Gbps link is present on the port.
Flashing green
Data is being received or transmitted on the port at 10 Gbps.
Steady yellow
Flashing yellow
Off
CTRL LED
Steady green
A WebSocket connection is present between the device and controller.
Flashing yellow
The router is connecting to the controller.
Off
No link is present between the router and controller.
  • Become a Partner
  • Partner Resources
