H3C MSR3610E-X1[-X1-DP] Routers Hardware Information and Specifications-5W100
HomeSupportResource CenterRoutersMSR3600 Series(Comware V7)MSR3600 Series(Comware V7)Technical DocumentsProduct LiteratureHardware Information & SpecificationsH3C MSR3610E-X1[-X1-DP] Routers Hardware Information and Specifications-5W100
01-Chassis Views, Technical Specifications, and compatibility information
1 Chassis views, technical specifications, and compatibility information
Chassis views
The following figures are for illustration only.
MSR3610E-X1
Figure1-1 Front panel
(1) AC power receptacle
(2) USB port
(3) Console port
(4) GE copper ports GE2 to GE9
(5) 10GE fiber ports SFP+10 to SFP+12
(6) GE copper ports GE0 and GE1 (combo interfaces)
(7) GE fiber ports SFP0 and SFP1 (combo interfaces)
Figure1-2 Rear panel
(1) SIC slot 4
(2) SIC slot 3
(3) SIC slot 2
(4) SIC slot 1
(5) Grounding terminal
MSR3610E-X1-DP
Figure1-3 Front panel
(1) AC power receptacle PWR1
(2) AC power receptacle PWR2
(3) USB port
(4) Console port
(5) GE copper ports GE2 to GE9
(6) 10GE fiber ports SFP+10 to SFP+12
(7) GE copper ports GE0 and GE1 (combo interfaces)
(8) GE fiber ports SFP0 and SFP1 (combo interfaces)
Figure1-4 Rear panel
(1) SIC slot 4
(2) SIC slot 3
(3) SIC slot 2
(4) SIC slot 1
Technical specifications
Table1-1 Technical specifications
Item
MSR3610E-X1
MSR3610E-X1-DP
Console port
1
1
GE copper ports
2 (combo interfaces) + 8
GE fiber ports
10GE fiber ports
3
3
USB port
1
1
SIC slots
4
4
AC power receptacles
1
2
Memory
4 GB DDR4
4 GB DDR4
Flash
4 GB EMMC
4 GB EMMC
Dimensions (H × W × D) (excluding mounting brackets and rubber feet)
44.2 × 440 × 320 mm (1.74 × 17.32 × 12.60 in)
Rated AC voltage
100 VAC to 240 VAC @ 50 or 60 Hz
Maximum power consumption
45 W
45 W
Operating temperature
·     Operating: 0°C to 45°C (32°F to 113°F)
·     Storage: –40°C to +70°C (–40°F to +158°F)
Relative humidity (non-condensing)
5% RH to 95% RH, noncondensing
Interface module specifications
The MSR3610E-X1 and MSR3610E-X1-DP routers support SIC interface modules. For more information about the interface module specifications, see H3C MSR Router Series Interface Module Guide.
Link mode of interfaces
For information about link mode change of interfaces on interface modules, see H3C MSR Router Series Interface Module Guide.
Table1-2 Fixed interfaces that can operate only as Layer 3 Ethernet interfaces
Device model
Interfaces
MSR3610E-X1/MSR3610E-X1-DP
Combo 0 (GE0, SFP0), Combo 1 (GE1, SFP1), SFP+10 to SFP+12
Table1-3 Fixed interfaces that can operate only as Layer 2 Ethernet interfaces
Device model
Interfaces
GE6 to GE9
Table1-4 Fixed interfaces that operate as Layer 2 interfaces by default and can be changed to Layer 3 interfaces
Device model
Interfaces
GE2 to GE5
  • Become a Partner
  • Partner Resources
