- 09-Application security
- 01-IPS Configuration Examples
- 02-URL Filtering Configuration Examples
- 03-Anti-Virus Configuration Examples
- 04-Data Filtering Configuration Examples
- 05-File Filtering Configuration Examples
- 06-Application Audit and Management Configuration Examples
- 07-Application Rate Limiting Configuration Examples
06-Application Audit and Management Configuration Examples | 77.65 KB |
H3C Access Controllers |
Comware 7 Application Audit and Management Configuration Examples |
Copyright © 2021 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
The following information provides examples for configuring application audit and management.
The following information applies to Comware 7-based access controllers and access points. Procedures and information in the examples might be slightly different depending on the software or hardware version of the access controllers and access points.
The following information is provided based on the assumption that you have basic knowledge of application audit and management.
Example: Configuring application audit and management
As shown in Figure 1, the switch assigns IP addresses to the AP and the client. The AP and the AC establish a CAPWAP tunnel through VLAN 100, and the client accesses the wireless network through VLAN 200. The working hours of the company are 8:00:00 through 18:00:00 from Monday to Friday.
Configure an application audit and management policy on the AC to meet the following requirements:
· Permit login from all QQ accounts during working hours.
· Generate audit logs.
This configuration example is supported only in E5568P01 and later.
Use the serial ID labeled on the AP's rear panel to specify an AP.
Procedures
Configuring the AC
1. Configure interfaces on the AC:
# Create VLAN 100 and VLAN-interface 100, and assign an IP address to VLAN-interface 100.
<AC> system-view
[AC] vlan 100
[AC-vlan100] quit
[AC-Vlan-interface100] ip address 192.1.1.1 24
[AC-Vlan-interface100] quit
# Create VLAN 200 and VLAN-interface 200, and assign an IP address to VLAN-interface 200.
[AC] vlan 200
[AC-vlan200] quit
[AC-Vlan-interface200] ip address 192.2.1.1 24
[AC-Vlan-interface200] quit
# Configure GigabitEthernet 1/0/1 as a trunk port, remove it from VLAN 1, assign it to VLAN 100 and VLAN 200, and set its PVID to VLAN 100.
[AC-GigabitEthernet1/0/1] undo port trunk permit vlan 1
[AC-GigabitEthernet1/0/1] port trunk permit vlan 100 200
[AC-GigabitEthernet1/0/1] port trunk pvid vlan 100
1. Configure wireless services:
# Create service template 1 and enter service template view.
[AC] wlan service-template 1
# Set the SSID to service.
[AC-wlan-st-1] ssid service
# Assign clients coming online through the service template to VLAN 200.
[AC-wlan-st-1] vlan 200
# Enable the service template..
[AC-wlan-st-1] quit
2. Configure the AP:
# Create an AP named ap1, with model WAP722S-HI.
[AC] wlan ap ap1 model WAP722S-HI
# Set the serial ID to 219801A2F98205P0031.
[AC-wlan-ap-ap1] serial-id 219801A2F98205P0031
# Enter radio view of radio 1, and bind service template 1 to the radio.
[AC-wlan-ap-ap1] radio 1
[AC-wlan-ap-ap1-radio-1] service-template 1
# Enable radio 1.
[AC-wlan-ap-ap1-radio-1] quit
# Enter radio view of radio 2, and bind service template 1 to the radio.
[AC-wlan-ap-ap1] radio 2
[AC-wlan-ap-ap1-radio-2] service-template 1
# Enable radio 2.
[AC-wlan-ap-ap1-radio-2] radio enable
[AC-wlan-ap-ap1-radio-2] quit
[AC-wlan-ap-ap1] quit
3. Configure a time range named work to cover 8:00:00 through 18:00:00 from Monday to Friday.
[Device] time-range work 08:00 to 18:00 working-day
4. Create an IPv4 address object group named audit, and configure an IPv4 address object with the IPv4 address of 192.2.1.0 and mask length of 24..
[AC] object-group ip address audit
[AC-obj-grp-ip-audit] network subnet 192.2.1.0 24
[AC-obj-grp-ip-audit] quit
5. Configure an application audit and management policy:
# Enter application audit and management view.
[AC] uapp-control
# Create an audit policy named audit-qq and enter its view.
[AC-uapp-control] policy name audit-qq audit
# Specify IPv4 address object group audit as a match criterion for audit policy audit-qq.
[AC-uapp-control-policy-audit-qq] source-address ipv4 audit
# Specify time range work for audit policy audit-qq.
[Device-uapp-control-policy-audit-qq] time-range work
# Configure an audit rule to permit login from all QQ accounts and generate audit logs.
[AC-uapp-control-policy-audit-qq] rule 1 app QQ behavior Login bhcontent any keyword equal any action permit audit-logging
[AC-uapp-control-policy-audit-qq] quit
[AC-uapp-control] quit
# Activate the configuration.
[AC] inspect activate
Configuring the switch
1. Configure interfaces on the switch:
# Create VLANs 100 and 200, create VLAN-interface 100 and VLAN-interface 200, and assign IP addresses to VLAN-interface 100 and VLAN-interface 200. The switch will use VLAN 100 to forward the traffic on CAPWAP tunnels between the AC and APs, and use VLAN 200 to forward client traffic.
<Switch> system-view
[Switch] vlan 100
[Switch-vlan100] quit
[Switch-Vlan-interface100] ip address 192.1.1.2 24
[Switch] vlan 200
[Switch-vlan200] quit
[Switch] interface vlan-interface 200
[Switch-Vlan-interface200] ip address 192.2.1.2 24
[Switch-Vlan-interface200] quit
[Switch-GigabitEthernet1/0/1] undo port trunk permit vlan 1
[Switch-GigabitEthernet1/0/1] port trunk permit vlan 100 200
[Switch-GigabitEthernet1/0/1] port trunk pvid vlan 100
# Configure GigabitEthernet 1/0/2 as a trunk port, remove it from VLAN 1, assign it to VLAN 100, and set its PVID to VLAN 100.
[Switch-GigabitEthernet1/0/2] port link-type trunk
[Switch-GigabitEthernet1/0/2] undo port trunk permit vlan 1
[Switch-GigabitEthernet1/0/2] port trunk permit vlan 100
[Switch-GigabitEthernet1/0/2] port trunk pvid vlan 100
# Enable PoE on GigabitEthernet 1/0/2.
2. Configure DHCP:
# Enable DHCP.
[Switch] dhcp enable
# Create a DHCP address pool named vlan100 to assign IP addresses and other configuration parameters to clients on subnet 192.1.1.0/24.
[Switch] dhcp server ip-pool vlan100
[Switch-dhcp-pool-vlan100] network 192.1.1.0 mask 255.255.255.0
# Exclude IP addresses 192.1.1.1 and 192.1.1.2 from dynamic allocation.
[Switch-dhcp-pool-vlan100] forbidden-ip 192.1.1.1 192.1.1.2
# Specify a gateway.
[Switch-dhcp-pool-vlan100] gateway-list 192.1.1.1
[Switch-dhcp-pool-vlan100] quit
# Create a DHCP address pool named vlan200 to assign IP addresses and other configuration parameters to clients on subnet 192.2.1.0/24.
[Switch] dhcp server ip-pool vlan200
[Switch-dhcp-pool-vlan200] network 192.2.1.0 mask 255.255.255.0
# Exclude IP addresses 192.2.1.1 and 192.2.1.2 from dynamic allocation.
[Switch-dhcp-pool-vlan200] forbidden-ip 192.2.1.1 192.2.1.2
# Specify a gateway and a DNS server.
[Switch-dhcp-pool-vlan200] dns-list 192.2.1.2
[Switch-dhcp-pool-vlan200] gateway-list 192.2.1.2
[Switch-dhcp-pool-vlan200] quit
# Verify that the device permits the login requests and generates audit log messages when QQ accounts attempt to access the Internet. (Details not shown.)
Configuration files
· AC:
vlan 100
vlan 200
0 network subnet 192.2.1.0 255.255.255.0
ssid service
vlan 200
interface Vlan-interface100
ip address 192.1.1.1 255.255.255.0
interface Vlan-interface200
ip address 192.2.1.1 255.255.255.0
serial-id 219801A2F98205P00031
radio 1
radio enable
service-template 1
radio 2
radio enable
service-template 1
uapp-control
time-range work
· Switch:
dhcp enable
vlan 100
vlan 200
dns-list 192.2.1.2
ip address 192.1.1.2 255.255.255.0
ip address 192.2.1.2 255.255.255.0
poe enable
Related documentation
· Application Audit and Management Command Reference in H3C Access Controllers Command References
· Application Audit and Management Configuration Guide in H3C Access Controllers Configuration Guides
· Security Policy Command Reference in H3C Access Controllers Command References
· Security Policy Configuration Guide in H3C Access Controllers Configuration Guides
