- 09-Application security
- 01-IPS Configuration Examples
- 02-URL Filtering Configuration Examples
- 03-Anti-Virus Configuration Examples
- 04-Data Filtering Configuration Examples
- 05-File Filtering Configuration Examples
- 06-Application Audit and Management Configuration Examples
- 07-Application Rate Limiting Configuration Examples
01-IPS Configuration Examples | 77.27 KB |
H3C Access Controllers |
Comware 7 IPS Configuration Examples |
Copyright © 2021 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
The following information provides examples for configuring IPS.
The following information applies to Comware 7-based access controllers and access points. Procedures and information in the examples might be slightly different depending on the software or hardware version of the access controllers and access points.
The following information is provided based on the assumption that you have basic knowledge of IPS.
Example: Configuring IPS
As shown in Figure 1, the switch acts as a DHCP server to assign IP addresses to the AP and client. The AP and AC establish CAPWAP tunnels in VLAN 100. The client accesses the wireless network in VLAN 200.
Configure the AC to use the default IPS policy for attack detection and prevention.
This configuration example is supported only in E5568P01 and later.
Use the serial ID labeled on the AP's rear panel to specify an AP.
Procedures
Configuring the AC
1. Configure interfaces on the AC:
# Create VLAN 100 and VLAN-interface 100, and assign an IP address to the VLAN interface. The AP will obtain this IP address to establish CAPWAP tunnels with the AC.
<AC> system-view
[AC] vlan 100
[AC-vlan100] quit
[AC-Vlan-interface100] ip address 192.1.1.1 24
[AC-Vlan-interface100] quit
# Create VLAN 200 and VLAN-interface 200, and assign an IP address to the VLAN interface. The client will access the wireless network in this VLAN.
[AC] vlan 200
[AC-vlan200] quit
[AC-Vlan-interface200] ip address 192.2.1.1 24
[AC-Vlan-interface200] quit
# Set the link type of GigabitEthernet 1/0/1 (the port connected to the switch) to trunk. Prevent traffic from VLAN 1 from passing through the port and allow traffic from VLAN 100 and VLAN 200 to pass through the port. Set the PVID of the port to 100.
[AC-GigabitEthernet1/0/1] undo port trunk permit vlan 1
[AC-GigabitEthernet1/0/1] port trunk permit vlan 100 200
[AC-GigabitEthernet1/0/1] port trunk pvid vlan 100
2. Configure a wireless service:
# Create service template 1 and enter service template view.
[AC] wlan service-template 1
# Set the SSID to service.
[AC-wlan-st-1] ssid service
# Assign the client to VLAN 200 after it comes online.
[AC-wlan-st-1] vlan 200
# Enable the service template.
[AC-wlan-st-1] quit
3. Configure the AP:
# Create a manual AP named ap1, and specify the AP model.
[AC] wlan ap ap1 model WAP722S-HI
# Set the serial ID to 219801A2F98205P00031.
[AC-wlan-ap-ap1] serial-id 219801A2F98205P0031
# Enter the view of radio 1 and bind service template 1 to the radio.
[AC-wlan-ap-ap1] radio 1
[AC-wlan-ap-ap1-radio-1] service-template 1
# Enable radio 1.
[AC-wlan-ap-ap1-radio-1] quit
# Enter the view of radio 2 and bind service template 1 to the radio.
[AC-wlan-ap-ap1] radio 2
[AC-wlan-ap-ap1-radio-2] service-template 1
# Enable radio 2.
[AC-wlan-ap-ap1-radio-2] radio enable
[AC-wlan-ap-ap1-radio-2] quit
[AC-wlan-ap-ap1] quit
4. Configure an IP address object group named ipsfilter and specify subnet 192.2.1.0/24 for the object group.
[AC] object-group ip address ipsfilter
[AC-obj-grp-ip-ipsfilter] network subnet 192.2.1.0 24
[AC-obj-grp-ip-ipsfilter] quit
5. Apply the default IPS policy to a DPI application profile and activate the IPS policy settings:
# Create a DPI application profile named sec and enter its view. Apply the default IPS policy to the DPI application profile and set the policy mode to protect.
[AC] app-profile sec
[AC-app-profile-sec] ips apply policy default mode protect
[AC-app-profile-sec] quit
# Activate the IPS policy settings.
[AC] inspect activate
6. Configure a security policy:
# Enter IPv4 security policy view.
[AC] security-policy ip
# Create a rule named ipsfilter to permit the traffic destined for IP addresses in IP address object group ipsfilter and apply DPI application profile sec to the security group.
[AC-security-policy-ip] rule name ipsfilter
[AC-security-policy-ip-10-ipsfilter] destination-ip ipsfilter
[AC-security-policy-ip-10-ipsfilter] action pass
[AC-security-policy-ip-10-ipsfilter] profile sec
[AC-security-policy-ip-10-ipsfilter] quit
# Activate rule matching acceleration.
[AC-security-policy-ip] accelerate enhanced enable
[AC-security-policy-ip] quit
Configuring the switch
1. Configure interfaces on the switch:
# Create VLANs 100 and 200, create VLAN-interface 100 and VLAN-interface 200, and assign IP addresses to VLAN-interface 100 and VLAN-interface 200. The switch will use VLAN 100 to forward the traffic on CAPWAP tunnels between the AC and APs, and use VLAN 200 to forward client traffic.
<Switch> system-view
[Switch] vlan 100
[Switch-vlan100] quit
[Switch-Vlan-interface100] ip address 192.1.1.2 24
[Switch] vlan 200
[Switch-vlan200] quit
[Switch] interface vlan-interface 200
[Switch-Vlan-interface200] ip address 192.2.1.2 24
[Switch-Vlan-interface200] quit
# Configure GigabitEthernet 1/0/1 that connects the switch to the AC as a trunk port.
# Remove the trunk port from VLAN 1, and assign the port to VLAN 100 and VLAN 200.
[Switch-GigabitEthernet1/0/1] undo port trunk permit vlan 1
[Switch-GigabitEthernet1/0/1] port trunk permit vlan 100 200
# Specify the PVID of the trunk port as VLAN 100.
[Switch-GigabitEthernet1/0/1] port trunk pvid vlan 100
# Configure GigabitEthernet 1/0/2 that connects the switch to the AP as a trunk port, and assign the port to VLAN 100.
[Switch-GigabitEthernet1/0/2] port link-type trunk
# Remove the trunk port from VLAN 1, and assign the port to VLAN 100.
[Switch-GigabitEthernet1/0/2] undo port trunk permit vlan 1
[Switch-GigabitEthernet1/0/2] port trunk permit vlan 100
[Switch-GigabitEthernet1/0/2] port trunk pvid vlan 100
# Enable PoE on the trunk port.
2. Configure DHCP:
# Enable DHCP.
[Switch] dhcp enable
# Create a DHCP address pool named vlan100 to assign IP addresses and other configuration parameters to clients on subnet 192.1.1.0/24.
[Switch] dhcp server ip-pool vlan100
[Switch-dhcp-pool-vlan100] network 192.1.1.0 mask 255.255.255.0
# Exclude IP addresses 192.1.1.1 and 192.1.1.2 from dynamic allocation.
[Switch-dhcp-pool-vlan100] forbidden-ip 192.1.1.1 192.1.1.2
# Specify a gateway.
[Switch-dhcp-pool-vlan100] gateway-list 192.1.1.1
[Switch-dhcp-pool-vlan100] quit
# Create a DHCP address pool named vlan200 to assign IP addresses and other configuration parameters to clients on subnet 192.2.1.0/24.
[Switch] dhcp server ip-pool vlan200
[Switch-dhcp-pool-vlan200] network 192.2.1.0 mask 255.255.255.0
# Exclude IP addresses 192.2.1.1 and 192.2.1.2 from dynamic allocation.
[Switch-dhcp-pool-vlan200] forbidden-ip 192.2.1.1 192.2.1.2
# Specify a gateway and a DNS server.
[Switch-dhcp-pool-vlan200] gateway-list 192.2.1.2
[Switch-dhcp-pool-vlan200] dns-list 192.2.1.2
[Switch-dhcp-pool-vlan200] quit
# Verify that the AC can use the default IPS policy to detect and prevent known network attacks. (Details not shown.)
Configuration files
· AC:
vlan 100
vlan 200
0 network subnet 192.2.1.0 255.255.255.0
ssid service
vlan 200
interface Vlan-interface100
ip address 192.1.1.1 255.255.255.0
interface Vlan-interface200
ip address 192.2.1.1 255.255.255.0
app-profile sec
serial-id 219801A2F98205P00031
radio 1
radio enable
service-template 1
radio 2
radio enable
service-template 1
security-policy ip
rule 10 name ipsfilter
action pass
profile sec
· Switch:
dhcp enable
vlan 100
vlan 200
dns-list 192.2.1.2
ip address 192.1.1.2 255.255.255.0
ip address 192.2.1.2 255.255.255.0
poe enable
Related documentation
· IPS Command Reference in H3C Access Controllers Command References
· IPS Configuration Guide in H3C Access Controllers Configuration Guides
· Security Policy Command Reference in H3C Access Controllers Command References
· Security Policy Configuration Guide in H3C Access Controllers Configuration Guides
