- 06-Wireless authentication
- 01-Local Portal Authentication Configuration Examples
- 02-HTTPS-Based Local Portal Authentication Configuration Examples
- 03-Remote Portal Authentication Configuration Examples
- 04-Local Portal Authentication through LDAP Server Configuration Examples
- 05-Local Portal Authentication and SSID-based Authentication Page Pushing Configuration Examples
- 06-Local Portal MAC-Trigger Authentication Configuration Examples
- 07-Portal MAC-Trigger Authentication Configuration Examples
- 08-Local Forwarding Mode and Local Portal MAC-Trigger Authentication Configuration Examples
- 09-Local Portal Authentication (IPv6) Configuration Examples
- 10-Local Portal Authentication through LDAP Server (IPv6) Configuration Examples
- 11-Remote Portal Authentication (IPv6) Configuration Examples
- 12-Portal MAC-Trigger Authentication (IPv6) Configuration Example
- 13-Remote Portal Authentication with User Profile Authorization Configuration Examples
- 14-WiFiDog Portal Authentication Configuration Examples
- 15-Portal Fail-Permit Configuration Examples
- 16-Local MAC Authentication Configuration Examples
- 17-MAC Authentication and PSK Authentication Configuration Examples
- 18-Remote MAC and Portal Authentication and Transparent Authentication Configuration Examples
- 19-Remote AP and Remote Portal MAC-Trigger Authentication Configuration Examples
- 20-MAC Authentication with Guest VLAN Assignment Configuration Examples
- 21-MAC Authentication with Guest VLAN Assignment (IPv6) Configuration Examples
- 22-Local MAC-Then-802.1X Authentication Configuration Examples
- 23-Local 802.1X Authentication Configuration Examples
- 24-Local RADIUS-Based 802.1X Authentication in EAP Relay Mode Configuration Examples
- 25-Remote 802.1X Authentication Configuration Examples
- 26-Remote 802.1X Authentication (IPv6) Configuration Examples
- 27-Remote 802.1X Authentication in WPA3-Enterprise Mode Configuration Examples
- 28-802.1X Authentication with ACL Assignment Through IMC Server Configuration Examples
- 29-802.1X Authentication with User Profile Assignment Through IMC Server Configuration Examples
- 30-EAD Authentication Configuration Examples
- 31-EAD Authentication (IPv6) Configuration Examples
11-Remote Portal Authentication (IPv6) Configuration Examples | 699.28 KB |
H3C Access Controllers |
Comware 7 Remote Portal Authentication |
Copyright © 2021 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
The following information provides examples for configuring IPv6 remote portal authentication.
The following information applies to Comware 7-based access controllers and access points. Procedures and information in the examples might be slightly different depending on the software or hardware version of the access controllers and access points.
The following information is provided based on the assumption that you have basic knowledge of AAA, portal, and WLAN.
Example: Configuring IPv6 remote portal authentication
As shown in Figure 1, the switch acts as both a DHCP server and a DHCPv6 server. The AP and the client obtain IPv4 and IPv6 addresses from the switch.
To implement remote portal authentication, perform the following tasks:
· Configure direct portal authentication.
· Configure a portal authentication server and a portal Web server on IMC.
· Configure a RADIUS server as the authentication server and accounting server.
Analysis
To allow an authenticated user to access network resources on any Layer 2 ports in its access VLAN without re-authentication, enable portal roaming.
To avoid possible authentication failure caused by frequent logins and logouts of portal clients in a short time, disable the Rule ARP entry feature for portal clients.
For the RADIUS server to dynamically change user authorization information or forcibly disconnect users, enable the RADIUS session-control feature.
To allow portal users to access both IPv4 and IPv6 networks after passing one type (IPv4 or IPv6) of portal authentication, enable portal to support IPv4/IPv6 dual stack.
Use the serial ID labeled on the AP's rear panel to specify an AP.
Make sure the types of the portal authentication server and portal Web server specified on the AC are the same as those actually used.
By default, the portal Web server URL redirected to users does not carry parameters. You can configure the parameters to be carried in the redirection URL as needed.
Procedures
Configuring IMC
This example uses the IMC server to describe the RADIUS server and portal server configuration. The IMC server runs on IMC PLAT 7.1, IMC EIA 7.1, and IMC EIP 7.1.
Configuring the RADIUS server
1. Add an access device.
a. Log in to IMC and click the User tab.
b. From the navigation tree, select User Access Policy > Access Device Management > Access Device.
c. Click Add.
The Add Access Device page opens.
d. In the Access Configuration area, set the shared key to radius, which must be the same as that configured on the AC.
e. In the Device List area, perform the following operations:
- Click Add Manually to open the Add Access Device Manually page. Enter the start IPv4 address 192.168.1.1 and then click OK.
- Click Add IPv6 Dev to open the Add Access Device Manually page. Enter the start IPv6 address 2001::1 and then click OK.
f. Use the default settings for other parameters.
g. Click OK.
Figure 2 Adding an access device
2. Add an access policy.
a. From the navigation tree, select User Access Policy > Access Policy.
b. Click Add.
The Add Access Policy page opens.
c. Enter the access policy name.
d. Select a service group. This example uses the default group (Ungrouped).
e. Use the default settings for other parameters.
f. Click OK.
Figure 3 Adding an access policy
3. Add an access service.
a. From the navigation tree, select User Access Policy > Access Service.
b. Click Add.
The Add Access Service page opens.
c. Enter the service name.
d. Select the access policy configured in the previous step as the default access policy.
f. Click OK.
Figure 4 Adding an access service
4. Add an access user.
a. From the navigation tree, select Access User > All Access Users.
b. Click Add.
The Add Access User page opens.
c. Click Select to select an existing access user or click Add User to add a new access user.
d. Set the password.
e. Select the access service configured in the previous step.
g. Click OK.
Figure 5 Adding an access user
Configuring the portal server
1. Configure the portal authentication server:
a. From the navigation tree, select User Access Policy > Portal Service > Server to open the portal server configuration page, as shown in Figure 6.
b. Configure the portal server parameters as needed.
This example uses the default settings.
c. Click OK.
Figure 6 Configuring the portal server
2. Configure IP address groups:
a. From the navigation tree, select User Access Policy > Portal Service > IP Group.
b. Click Add.
The Add IP Group page opens.
c. Enter an IP group name.
d. Select No from the IPv6 field for an IPv4 address group and Yes for an IPv6 address group.
e. Enter the start IP address and end IP address of the IP group.
Make sure the client IP address is in the IP group.
f. Select a service group.
This example uses the default group Ungrouped.
g. Select Normal from the Action list.
This step is required only for adding an IPv4 address group.
h. Click OK.
Figure 7 Adding an IPv4 address group
Figure 8 Adding an IPv6 address group
3. Add portal devices:
a. From the navigation tree, select User Access Policy > Portal Service > Device.
b. Click Add.
The Add Device page opens.
c. Enter a device name.
d. Select a portal version.
For adding an IPv4 portal device, select Portal 2.0. For adding an IPv6 portal device, select Portal 3.0.
e. Enter the IP address of the AC's interface connected to the client.
f. Set whether to support the portal server heartbeat and user heartbeat functions.
In this example, select No for both Support Server Heartbeat and Support User Heartbeat.
g. Enter the key, which must be the same as that configured on the AC.
h. Select Directly Connected for Access Method.
i. Use the default settings for other parameters.
j. Click OK.
Figure 9 Adding an IPv4 portal device
Figure 10 Adding an IPv6 portal device
4. Associate the portal devices with the IP address groups:
a. Click the Port Group icon in the Operation field of devices NAS4 and NAS6, as shown in Figure 11.
b. Click Add to open the Add Port Group page.
c. Enter the port group name.
d. Select the configured IP address group.
The IP address used by the user to access the network must be within this IP address group.
f. Click OK.
Figure 12 Adding an IPv4 port group
Figure 13 Adding an IPv6 port group
Committing configuration changes
# From the navigation tree, select User Access Policy > Service Parameters > Validate System Configuration to commit the configuration changes.
Configuring the AC
1. Configure interfaces on the AC:
# Create VLAN 100 and VLAN-interface 100. Assign an IPv4 address and an IPv6 address to the VLAN interface. The AC will establish a CAPWAP tunnel with the AP in this VLAN.
<AC> system-view
[AC] vlan 100
[AC-vlan100] quit
[AC-Vlan-interface100] ip address 192.168.1.1 24
[AC-Vlan-interface100] ipv6 address 2001::1 64
[AC-Vlan-interface100] quit
# Create VLAN 200 and VLAN-interface 200. Assign an IPv4 address and an IPv6 address to the VLAN interface. The AC will use VLAN 200 for client access.
[AC] vlan 200
[AC-vlan200] quit
[AC-Vlan-interface200] ip address 192.168.2.1 24
[AC-Vlan-interface200] ipv6 address 2004::1 64
[AC-Vlan-interface200] quit
# Configure GigabitEthernet1/0/1 (the port connected to the switch) as a trunk port, and assign the port to VLAN 1, VLAN 100, and VLAN 200.
[AC-GigabitEthernet1/0/1] port trunk permit vlan 1 100 200
2. Configure a static IPv4 route and a static IPv6 route to the IMC server:
[AC] ip route-static 192.168.3.0 255.255.255.0 192.168.2.2
[AC] ipv6 route-static 2003:: 64 2004::2
3. Configure a wireless service:
# Create a service template named st1 and enter its view.
[AC] wlan service-template st1
# Set the SSID of service template st1 to service.
[AC-wlan-st-st1] ssid service
# Assign clients coming online through service template st1 to VLAN 200.
[AC-wlan-st-service] vlan 200
# Enable snooping ND packets and snooping DHCPv6 packets on service template st1.
[AC-wlan-st-st1] client ipv6-snooping nd-learning enable
[AC-wlan-st-st1] client ipv6-snooping dhcpv6-learning enable
# Enable service template st1.
[AC–wlan-st-st1] service-template enable
[AC-wlan-st-st1] quit
# Create an AP named office with model WA4320i-CAN and set its serial ID to 219801A0CNC138011454.
[AC] wlan ap office model WA4320i-ACN
[AC-wlan-ap-office] serial-id 219801A0CNC138011454
# Deploy configuration file map.txt to the AP.
[AC-wlan-ap-office] map-configuration map.txt
# Enter the view of radio 2.
[AC-wlan-ap-office] radio 2
# Bind service template st1 to radio 2 in AP office.
[AC-wlan-ap-office-radio-2] service-template st1
# Enable radio 2.
[AC-wlan-ap-office-radio-2] radio enable
[AC-wlan-ap-office-radio-2] quit
[AC-wlan-ap-office] quit
4. Configure an IPv4 RADIUS scheme:
# Create a RADIUS scheme named rs1 and enter its view.
[AC] radius scheme rs1
# Specify the primary authentication server and primary accounting server, and configure the keys for communication with the servers.
[AC-radius-rs1] primary authentication 192.168.3.2
[AC-radius-rs1] primary accounting 192.168.3.2
[AC-radius-rs1] key authentication simple radius
[AC-radius-rs1] key accounting simple radius
# Configure the AC to remove the domain name from the usernames sent to the RADIUS servers.
[AC-radius-rs1] user-name-format without-domain
# Specify IP address 192.168.1.1 as the source IP address for outgoing RADIUS packets.
[AC-radius-rs1] nas-ip 192.168.1.1
[AC-radius-rs1] quit
5. Configure an IPv6 RADIUS scheme:
# Create a RADIUS scheme named rs2 and enter its view.
[AC] radius scheme rs2
[AC-radius-rs2] primary authentication ipv6 2003::2
[AC-radius-rs2] primary accounting ipv6 2003::2
[AC-radius-rs2] key authentication simple radius
[AC-radius-rs2] key accounting simple radius
[AC-radius-rs2] user-name-format without-domain
# Specify IPv6 address 2001::1 as the source IP address for outgoing RADIUS packets.
[AC-radius-rs2] nas-ip ipv6 2001::1
[AC-radius-rs2] quit
# Enable the RADIUS session-control feature.
[AC] radius session-control enable
Configure the RADIUS DAS feature:
# Enable the RADIUS DAS feature and enter RADIUS DAS view.
[AC] radius dynamic-author server
# Specify a session-control client at IPv4 address 192.168.3.2 and shared key radius in plaintext form.
[AC-radius-da-server] client ip 192.168.3.2 key simple radius
# Specify a session-control client at IPv6 address 2003::2 and shared key radius in plaintext form.
[AC-radius-da-server] client ipv6 2003::2 key simple radius
[AC-radius-da-server] quit
6. Configure an IPv4 authentication domain:
# Create an ISP domain named dm1 and enter its view.
[AC] domain dm1
# Configure the authentication and authorization methods as RADIUS and the accounting method as none for the ISP domain.
[AC-isp-dm1] authentication portal radius-scheme rs1
[AC-isp-dm1] authorization portal radius-scheme rs1
[AC-isp-dm1] accounting portal none
# Configure the idle cut feature for users in the ISP domain. Log out a user if the user's traffic is less than 1024 bytes in 15 minutes.
[AC-isp-dm1] authorization-attribute idle-cut 15 1024
[AC-isp-dm1] quit
7. Configure an IPv6 authentication domain:
# Create an ISP domain named dm2 and enter its view.
[AC] domain dm2
[AC-isp-dm2] authentication portal radius-scheme rs2
[AC-isp-dm2] authorization portal radius-scheme rs2
[AC-isp-dm2] accounting portal none
[AC-isp-dm2] authorization-attribute idle-cut 15 1024
[AC-isp-dm2] quit
8. Configure portal authentication:
# Create an IPv4 portal authentication server named newptv4, and specify IP address 192.168.3.2 for the authentication server.
[AC] portal server newptv4
[AC-portal-server-newptv4] ip 192.168.3.2 key simple 123456
[AC-portal-server-newptv4] quit
# Create an IPv6 portal authentication server named newptv6, and specify IPv6 address 2003::2 for the authentication server.
[AC] portal server newptv6
[AC-portal-server-newptv6] ipv6 2003::2 key simple 123456
[AC-portal-server-newptv6] quit
# Create an IPv4 portal Web server named newptv4 and specify http://192.168.3.2:8080/portal as the URL of the server.
[AC] portal web-server newptv4
[AC-portal-websvr-newptv4] url http://192.168.3.2:8080/portal
# Add parameters ssid, wlanuserip, and wlanacname to the redirection URL for portal Web server newptv4. Specify the AP's SSID, the IP address of the client, and the AC's name as the value for the ssid, wlanuserip, and wlanacname parameters, respectively.
[AC-portal-websvr-newptv4] url-parameter ssid ssid
[AC-portal-websvr-newptv4] url-parameter wlanuserip source-address
[AC-portal-websvr-newptv4] url-parameter wlanacname value AC
[AC-portal-websvr-newptv4] quit
# Create an IPv6 portal Web server named newptv6 and specify http://[2003::2]:8080/portal as the URL of the server.
[AC] portal web-server newptv6
[AC-portal-websvr-newptv6] url http://[2003::2]:8080/portal
# Add parameters ssid, wlanuserip, and wlanacname to the redirection URL for portal Web server newptv6. Specify the AP's SSID, the IPv6 address of the client, and the AC's name as the value for the ssid, wlanuserip, and wlanacname parameters, respectively.
[AC-portal-websvr-newptv6] url-parameter ssid ssid
[AC-portal-websvr-newptv6] url-parameter wlanuserip source-address
[AC-portal-websvr-newptv6] url-parameter wlanacname value AC
[AC-portal-websvr-newptv6] quit
# Enable portal roaming.
[AC] portal roaming enable
# Disable the Rule ARP entry feature for portal clients.
[AC] undo portal refresh arp enable
# Enable validity check on wireless portal clients.
[AC] portal host-check enable
# Enable direct IPv4 portal authentication and direct IPv6 portal authentication on service template st1.
[AC-wlan-st-st1] portal enable method direct
[AC-wlan-st-st1] portal ipv6 enable method direct
# Specify ISP domain dm1 as the portal authentication domain for IPv4 portal users.
[AC-wlan-st-st1] portal domain dm1
# Specify ISP domain dm2 as the portal authentication domain for IPv6 portal users.
[AC-wlan-st-st1] portal ipv6 domain dm2
# Specify IPv4 portal Web server newptv4 and IPv6 portal Web server newptv6 on service template st1 for portal authentication.
[AC-wlan-st-st1] portal apply web-server newptv4
[AC-wlan-st-st1] portal ipv6 apply web-server newptv6
# Enable portal to support IPv4/IPv6 dual stack on service template st1.
[AC-wlan-st-st1] portal dual-stack enable
# Configure the BAS-IP attribute as 192.168.2.1 and the BAS-IPv6 attribute as 2004::1.
[AC-wlan-st-st1] portal bas-ip 192.168.2.1
[AC-wlan-st-st1] portal bas-ipv6 2004::1
# Configure two destination-based portal-free rules to permit the traffic destined for the DNS server.
[AC] portal free-rule 1 destination ip any udp 53
[AC] portal free-rule 2 destination ip any tcp 53
# Configure a source-based portal-free rule. Set the rule number to 3 and the source interface to aggregate interface 1. This rule allows the portal user on the aggregate interface to access network resources without authentication.
[AC] portal free-rule 3 source interface Bridge-Aggregation1
Configuring the switch
1. Configure interfaces on the switch:
# Create VLAN 100. The switch will use this VLAN to forward traffic on the CAPWAP tunnel between the AC and the AP.
<Switch> system-view
[Switch] vlan 100
[Switch-vlan100] quit
# Create VLAN 200. The switch will use this VLAN to forward client traffic.
[Switch] vlan 200
[Switch-vlan200] quit
# Create VLAN 2.
[Switch] vlan 2
[Switch-vlan2] quit
# Configure GigabitEthernet 1/0/1 (the port connected to the AC) as a trunk port and assign the trunk port to VLAN 1, VLAN 100, and VLAN 200.
[Switch-GigabitEthernet1/0/1] port trunk permit vlan 1 100 200
# Configure GigabitEthernet 1/0/2 (the port connected to the AP) as an access port and assign the access port to VLAN 100.
# Enable PoE on the access port.
# Create VLAN-interface 1 and assign an IPv4 address and an IPv6 address to the VLAN interface.
[Switch] interface vlan-interface 1
[Switch-Vlan-interface1] ip address 192.168.3.1 255.255.255.0
[Switch-Vlan-interface1] ipv6 address 2003::1 64
[Switch-Vlan-interface1] quit
# Create VLAN-interface 100 and assign an IPv4 address and an IPv6 address to the VLAN interface.
[Switch-Vlan-interface100] ip address 192.168.1.2 255.255.255.0
[Switch-Vlan-interface100] ipv6 address 2001::2 64
# Create VLAN-interface 200 and assign an IPv4 address and an IPv6 address to the VLAN interface.
[Switch] interface vlan-interface 200
[Switch-Vlan-interface200] ip address 192.168.2.2 255.255.255.0
[Switch-Vlan-interface200] ipv6 address 2004::2 64
[Switch-Vlan-interface200] quit
2. Configure the DHCP server:
# Enable DHCP.
[Switch] dhcp enable
# Configure DHCP address pool named 100 and specify subnet 192.168.1.0/24 and gateway address 192.168.1.1 for the DHCP address pool. The switch will assign an IPv4 in this DHCP address pool to the AP.
[Switch] dhcp server ip-pool 100
[Switch-dhcp-pool-100] network 192.168.1.0 mask 255.255.255.0
[Switch-dhcp-pool-100] gateway-list 192.168.1.1
# Configure Option 43 that specifies the AC's IPv4 address in hexadecimal notation in DHCP address pool 100.
[Switch-dhcp-pool-100] option 43 hex 8007000001c0a80101
[Switch-dhcp-pool-100] quit
# Configure DHCP address pool named 200 and specify subnet 192.168.2.0/24, gateway address 192.168.2.2, and the DNS server address of the wireless client (the same as the gateway address in this example) for the DHCP address pool. The switch will assign an IPv4 address in this DHCP address pool to the client.
[Switch] dhcp server ip-pool 200
[Switch-dhcp-pool-200] network 192.168.2.0 mask 255.255.255.0
[Switch-dhcp-pool-200] gateway-list 192.168.2.2
[Switch-dhcp-pool-200] dns-list 192.168.2.2
[Switch-dhcp-pool-200] quit
3. Configure the DHCPv6 server:
# Create DHCPv6 address pool named 1 and specify subnet 2001::/64 for the DHCPv6 address pool. The switch will assign an IPv6 address in this DHCP address pool to the AP.
[Switch] ipv6 dhcp pool 1
[Switch-dhcp6-pool-1] network 2001::/64
# Configure Option 52 that specifies the AC's IPv6 address in DHCPv6 address pool 1.
[Switch-dhcp6-pool-1] option 52 hex 20010000000000000000000000000001
[Switch-dhcp6-pool-1] quit
[Switch] ipv6 dhcp server forbidden-address 2001::1
# Apply DHCPv6 address pool 1 to VLAN-interface 100, and enable the DHCPv6 server on the VLAN interface.
[Switch-Vlan-interface100] ipv6 dhcp server apply pool 1
[Switch-Vlan-interface100] ipv6 dhcp select server
# Set the M flag to 1 and the O flag to 1 in RA advertisements to be sent on VLAN-interface 100.
[Switch-Vlan-interface100] ipv6 nd autoconfig managed-address-flag
[Switch-Vlan-interface100] ipv6 nd autoconfig other-flag
# Disable RA message suppression.
[Switch-Vlan-interface100] undo ipv6 nd ra halt
# Create DHCPv6 address pool named 2 and specify subnet 2004::/64 for the DHCPv6 address pool. The switch will assign an IPv6 address in this DHCP address pool to the client.
[Switch] ipv6 dhcp pool 2
[Switch-dhcp6-pool-2] network 2004::/64
[Switch-dhcp6-pool-2] quit
# Exclude IPv6 address 2004::1 in the DHCPv6 address pool from dynamic allocation.
[Switch] ipv6 dhcp server forbidden-address 2004::1
# Apply DHCPv6 address pool 2 to VLAN-interface 200, and enable the DHCPv6 server on the VLAN interface.
[Switch] interface Vlan-interface 200
[Switch-Vlan-interface200] ipv6 dhcp server apply pool 2
[Switch-Vlan-interface200] ipv6 dhcp select server
# Set the M flag to 1 and the O flag to 1 in RA advertisements to be sent on VLAN-interface 200.
[Switch-Vlan-interface200] ipv6 nd autoconfig managed-address-flag
[Switch-Vlan-interface200] ipv6 nd autoconfig other-flag
[Switch-Vlan-interface200] undo ipv6 nd ra halt
1. Verify that the dual-stack client can access network resources after passing IPv4 portal authentication.
a. Use the configured username and password to perform IPv4 portal authentication through a Web browser on the client.
b. Verify that all Web requests of the user will be redirected to the portal authentication page (http://192.168.3.2:8080/portal) before the client passes IPv4 portal authentication. After the user passes IPv4 portal authentication, the user can access network resources. (Details not shown.)
c. Display information about all portal users on the AC after the client passes IPv4 authentication.
[AC] display portal user all
Total portal users: 1
Username: client
AP name: office
Radio ID: 2
SSID: service
Portal server: newptv4
State: Online
VPN instance: N/A
MAC IP VLAN Interface
3829-5a40-9589 192.168.2.3 200 WLAN-BSS1/0/2
Authorization information:
DHCP IP pool: N/A
User profile: N/A
Session group profile: N/A
ACL number: N/A
Inbound CAR: N/A
Outbound CAR: N/A
The output shows that the client has come online.
2. Verify that the dual-stack client can access network resources after passing IPv6 portal authentication.
a. Use the configured username and password to perform IPv6 portal authentication through a Web browser on the client.
b. Verify that all Web accesses of the user are redirected to the portal authentication page (http://[2003::2]:8080/portal) before the client passes IPv6 portal authentication. After the user passes IPv6 portal authentication, the user can access network resources. (Details not shown.)
c. Display the online portal user information on the AC after the client passes authentication.
Username: Client
AP name: office
Radio ID: 2
SSID: service
Portal server: newptv6
State: Online
VPN instance: N/A
3829-5a40-9589 2004::4549:7C7F:392E: 200 WLAN-BSS1/0/2
EE57
DHCP IP pool: N/A
User profile: N/A
ACL number: N/A
Inbound CAR: N/A
Outbound CAR: N/A
Configuration files
· AC:
vlan 100
vlan 200
ssid service
vlan 200
portal domain dm1
interface Vlan-interface100
ipv6 address 2001::1/64
interface Vlan-interface200
ip address 192.168.2.1 255.255.255.0
ipv6 address 2004::1/64
port link-mode bridge
ip route-static 192.168.3.0 24 192.168.2.2
radius scheme rs1
key authentication cipher $c$3$2m4BXR2X65vE59L0SyyHH0tRVpkKDgym9w==
key accounting cipher $c$3$4ieHsnXQVnQ7GwywFS+H0MoQdb6SEmJSRg==
nas-ip 192.168.1.1
radius scheme rs2
key authentication cipher $c$3$8bAMsBFXCGlbmynTi08YCxotgTXYwzES0w==
key accounting cipher $c$3$QeTcfxJGTnPJ98PsCSbLnaZP6KAG6q42aQ==
nas-ip ipv6 2001::1
client ip 192.168.3.2 key cipher $c$3$l9xAYe5vBJQMTOv6quHJFXtZlti404CjBg==
client ipv6 2003::2 key cipher $c$3$ELOjfzKgjUoRbJ/wZX0E9eVdGBFeTQzmHA==
domain dm1
domain dm2
ip 192.168.3.2 key cipher $c$3$XkIMNqFj0It2yZOqdfPeOeasD0Jk4oJQFA==
ipv6 2003::2 key cipher $c$3$9MzqVffE//Ma5x4a4gJOSQKrnSBS5EslXg==
radio 2
radio enable
Return
· Switch:
vlan 1
vlan 100
vlan 200
ipv6 dhcp pool 1
network 2001::/64
ipv6 dhcp pool 2
network 2004::/64
ipv6 address 2003::1/64
ipv6 address 2001::2/64
ipv6 address 2004::2/64
poe enable
Return
Related documentation
· AP and WT Management Command Reference in H3C Access Controllers Command References
· AP and WT Management Configuration Guide in H3C Access Controllers Configuration Guides
· User Access and Authentication Command Reference in H3C Access Controllers Command References
· User Access and Authentication Configuration Guide in H3C Access Controllers Configuration Guides
· WLAN Access Command Reference in H3C Access Controllers Command References
· WLAN Access Configuration Guide in H3C Access Controllers Configuration Guides
