02-AP Association with the AC at Layer 2 (IPv6) Configuration Examples | 84.74 KB |
H3C Access Controllers |
Comware 7 AP Association with the AC at Layer 2 (IPv6) |
Copyright © 2021 New H3C Technologies Co., Ltd. All rights reserved.
Example: Configuring an AP to associate with the AC at Layer 2 (IPv6)
Configuring the Layer 2 switch
Introduction
The following information provides an example for configuring APs to associate with the AC at Layer 2 on an IPv6 network.
The following information applies to Comware 7-based access controllers and access points. Procedures and information in the examples might be slightly different depending on the software or hardware version of the access controllers and access points.
The following information is provided based on the assumption that you have basic knowledge of IPv6 basics and WLAN access.
When you configure AP's association with the AC at Layer 2 on an IPv6 network, follow these restrictions and guidelines:
· Use the serial ID labeled on the AP's rear panel to specify an AP.
· To prevent too many packets from entering VLAN 1, configure the switch's interface that connects the switch to the AP to deny packets from VLAN 1.
As shown in Figure 1, the AC acts as a DHCPv6 server to assign IPv6 addresses to the AP, client, and host, and the Layer 2 switch supplies power to the AP through PoE. Assume centralized forwarding is used in this example.
Configure wireless services to enable the client to access the wireless services and communicate with the host.
Procedures
Configuring the AC
1. Configure AC interfaces:
# Create VLAN 100 and VLAN-interface 100, and assign an IPv6 address to the VLAN interface. The AC will use this IPv6 address to establish a CAPWAP tunnel with the AP.
[AC] vlan 100
[AC-vlan100] interface vlan-interface 100
[AC-Vlan-interface100] ipv6 address 1::1:0:0:1/96
# Create VLAN 200 and VLAN-interface 200, and assign an IPv6 address to the VLAN interface. VLAN 200 will be used for client access.
[AC-Vlan-interface100] vlan 200
[AC-vlan200] interface vlan-interface 200
[AC-Vlan-interface200] ipv6 address 1::2:0:0:1/96
# Create VLAN 300 and VLAN-interface 300, and assign an IPv6 address to the VLAN interface. The AC will use this IPv6 address to associate with the host.
[AC-Vlan-interface200] vlan 300
[AC-vlan300] interface vlan-interface 300
[AC-Vlan-interface300] ipv6 address 1::3:0:0:1/96
[AC-Vlan-interface300] quit
# Configure GigabitEthernet 1/0/1 that connects the AC to the switch as a trunk port, remove the port from VLAN 1, and assign the port to VLANs 100, 200, and 300.
[AC-GigabitEthernet1/0/1] undo port trunk permit vlan 1
[AC-GigabitEthernet1/0/1] port trunk permit vlan 100 200 300
# Configure the PVID as VLAN 100.
[AC-GigabitEthernet1/0/1] port trunk pvid vlan 100
2. Configure DHCPv6:
# Enable the DHCPv6 server on VLAN-interface 100, VLAN-interface 200, and VLAN-interface 300, and apply address pools 1, 2, and 3 to these interfaces, respectively.
[AC-Vlan-interface100] ipv6 dhcp select server
[AC-Vlan-interface100] ipv6 dhcp server apply pool 1
[AC-Vlan-interface100] quit
[AC-Vlan-interface200] ipv6 dhcp server apply pool 2
[AC-Vlan-interface200] ipv6 dhcp select server
[AC-Vlan-interface200] quit
[AC] interface vlan-interface 300
[AC-Vlan-interface300] ipv6 dhcp server apply pool 3
[AC-Vlan-interface300] ipv6 dhcp select server
# Disable RA message suppression, and set both the managed address configuration flag (M) and the other stateful configuration flag (O) to 1 in RA advertisements to be sent for the created VLAN interfaces.
[AC-Vlan-interface100] undo ipv6 nd ra halt
[AC-Vlan-interface100] ipv6 nd autoconfig managed-address-flag
[AC-Vlan-interface100] ipv6 nd autoconfig other-flag
[AC-Vlan-interface200] undo ipv6 nd ra halt
[AC-Vlan-interface200] ipv6 nd autoconfig managed-address-flag
[AC-Vlan-interface200] ipv6 nd autoconfig other-flag
[AC-Vlan-interface300] undo ipv6 nd ra halt
[AC-Vlan-interface300] ipv6 nd autoconfig managed-address-flag
[AC-Vlan-interface300] ipv6 nd autoconfig other-flag
# Create DHCPv6 address pool 1 to assign an IPv6 address to the AP, and specify subnet 1::1:0:0:0/96 in the DHCP address pool.
[AC] ipv6 dhcp pool 1
[AC-dhcp6-pool-1] network 1::1:0:0:0/96
[AC-dhcp6-pool-1] quit
# Create DHCPv6 address pool 2 to assign an IPv6 address to the client, and specify subnet 1::2:0:0:0/96 in the DHCP address pool.
[AC] ipv6 dhcp pool 2
[AC-dhcp6-pool-2] network 1::2:0:0:0/96
[AC-dhcp6-pool-2] quit
# Create DHCPv6 address pool 3 to assign an IPv6 address to the host, and specify subnet 1::3:0:0:0/96 in the DHCP address pool.
[AC] ipv6 dhcp pool 3
[AC-dhcp6-pool-3] network 1::3:0:0:0/96
[AC-dhcp6-pool-3] quit
3. Configure wireless services:
# Create service template 1 and enter its view.
[AC] wlan service-template 1
# Configure the SSID as service.
[AC-wlan-st-1] ssid service
# Enable the service template.
# Enable snooping DHCPv6 packets and ND packets.
[AC-wlan-st-1] client ipv6-snooping dhcpv6-learning enable
[AC-wlan-st-1] client ipv6-snooping nd-learning enable
[AC-wlan-st-1] quit
4. Configure the AP:
# Create manual AP officeap, and specify the AP model and serial ID.
[AC] wlan ap officeap model WA4320i-ACN
[AC-wlan-ap-officeap] serial-id 210235A1Q2C159000018
# Bind service template 1 and VLAN 200 to radio 1.
[AC-wlan-ap-officeap] radio 1
[AC-wlan-ap-officeap-radio-1] service-template 1 vlan 200
# Enable radio 1.
[AC-wlan-ap-officeap-radio-1] radio enable
[AC-wlan-ap-officeap-radio-1] return
# Create VLANs 100, 200, and 300. The switch will use VLAN 100 to forward packets between AC and AP. VLAN 200 will be used for client access. VLAN 300 will be used for host access.
<L2 switch> system-view
[L2 switch] vlan 100
[L2 switch-vlan100] quit
[L2 switch] vlan 200
[L2 switch-vlan200] quit
[L2 switch] vlan 300
[L2 switch-vlan300] quit
# Configure GigabitEthernet 1/0/1 that connects the switch to the AC as a trunk port, configure the PVID as VLAN 100, and assign the port to VLANs 100, 200, and 300.
[L2 switch] interface gigabitEthernet 1/0/1
[L2 switch-GigabitEthernet1/0/1] port link-type trunk
[L2 switch-GigabitEthernet1/0/1] port trunk permit vlan 100 200 300
[L2 switch-GigabitEthernet1/0/1] port trunk pvid vlan 100
[L2 switch-GigabitEthernet1/0/1] quit
[L2 switch] interface gigabitEthernet 1/0/2
[L2 switch-GigabitEthernet1/0/2] port link-type trunk
[L2 switch-GigabitEthernet1/0/2] undo port trunk permit vlan 1
[L2 switch-GigabitEthernet1/0/2] port trunk permit vlan 100 200
[L2 switch-GigabitEthernet1/0/2] port trunk pvid vlan 100
# Enable PoE on GigabitEthernet 1/0/2.
[L2 switch-GigabitEthernet1/0/2] poe enable
[L2 switch-GigabitEthernet1/0/2] quit
# Configure GigabitEthernet 1/0/3 that connects the switch to the host as an access port, and assign the port to VLAN 300.
[L2 switch] interface gigabitEthernet 1/0/3
[L2 switch-GigabitEthernet1/0/3] port access vlan 300
[L2 switch-GigabitEthernet1/0/3] quit
# Verify that the AP is in R/M state.
<AC> display wlan ap all
Total number of APs: 1
Total number of connected APs: 1
Total number of connected manual APs: 1
Total number of connected auto APs: 0
Total number of connected common APs: 1
Total number of connected WTUs: 0
Total number of inside APs: 0
Maximum supported APs: 3072
Remaining APs: 3071
Total AP licenses: 512
Local AP licenses: 512
Server AP licenses: 0
Remaining Local AP licenses: 511
Sync AP licenses: 0
AP information
State : I = Idle, J = Join, JA = JoinAck, IL = ImageLoad
C = Config, DC = DataCheck, R = Run, M = Master, B = Backup
AP name APID State Model Serial ID
officeap 1 R/M WA4320i-ACN 210235A1Q2C159000018
# Verify that the client is connected to radio 1 on AP officeap.
<AC> display wlan client ipv6
Total number of clients: 1
MAC address AP name RID IPv6 address VLAN
784f-43b6-077c ap1 1 1::2:0:0:3 200
# Verify that the client and the host can ping each other successfully.
C:\Users\system32>ping 1::2:0:0:3 -t
Pinging 1::2:0:0:3 with 32 bytes of data:
Reply from 1::2:0:0:3: bytes=32 time=8ms TTL=255
Reply from 1::2:0:0:3: bytes=32 time<1ms TTL=255
Ping statistics for 1::2:0:0:3:
Packets: Sent = 11, Received = 11, Lost = 0 (0% loss),
Minimum = 0ms, Maximum = 8ms, Average = 0ms
Control-C
^C
C:\Users\system32>
Configuration files
· AC:
dhcp enable
vlan 1
vlan 100
vlan 200
vlan 300
ipv6 dhcp pool 1
ipv6 dhcp pool 2
ipv6 dhcp pool 3
ssid service
interface Vlan-interface1
interface Vlan-interface100
interface Vlan-interface200
interface Vlan-interface300
vlan 1
radio 1
radio enable
radio 2
· Layer 2 switch:
vlan 100
vlan 200
vlan 300
undo port trunk permit vlan 1 100 200 300
poe enable
Related documentation
· AP and WT Management Command Reference in H3C Access Controllers Command References
· AP and WT Management Configuration Guide in H3C Access Controllers Configuration Guides
· Network Connectivity Command Reference in H3C Access Controllers Command References
· Network Connectivity Configuration Guide in H3C Access Controllers Configuration Guides
