H3C MSR3610-I ICT Converged Gateway Series Hardware Information and Specifications-6W100
HomeSupportRoutersMSR3610-I[IE] SeriesProduct LiteratureHardware Information & SpecificationsH3C MSR3610-I ICT Converged Gateway Series Hardware Information and Specifications-6W100
02-LEDs
02-LEDs 355.52 KB
1 LEDs
LEDs
Figure1-1 MSR3610-I-DP/3610-I-XS/3610-IE-DP/3610-IE-ES/3610-IE-XS/3610-IE-EAD LEDs
(1) System status LED (SYS)
(2) Power status LED (PWR1)
(3) Power status LED (PWR2)
(4) LEDs for Ethernet copper ports GE0 to GE7
(5) LEDs for Ethernet fiber ports SFP0 and SFP1
(6) Power button/LED
(7) Drive LED (HD)
Figure1-2 MSR3610-I-IG/3610-IE-IG LEDs
(4) PoE status LED
(5) LEDs for Ethernet copper ports GE0 to GE7
(6) LEDs for Ethernet fiber ports SFP0 and SFP1
(7) Power button/LED
(8) Drive LED (HD)
LED descriptions
Table1-1 LED descriptions
LED
Status
Fast flashing green
BIOS stage
BIOS has started successfully.
Slow flashing yellow
The memory does not exist or system initialization has failed.
Fast flashing yellow
The extended segment does not exist.
Off
The system hardware is faulty or the device has no power input.
Steady green
BootWare stage
The SDRAM is performing self-test.
Fast flashing green
The system software image is being decompressed.
Slow flashing green
Comware is starting up and the system is operating correctly.
Steady yellow
The system software image does not exist.
The SDRAM has failed the self-test.
Off
No power input, or exceptions have occurred.
Fast flashing green (5 seconds)
Comware stage
The USB disk completed auto configuration.
Fast flashing yellow (10 seconds)
The USB disk has failed auto configuration.
Power button LED
Fast flashing red
The power button is being pressed to start up the Comware system.
Slow flashing red
BIOS is starting up.
Slow flashing green
BIOS has started and BootWare is starting up.
Steady green
The Comware system has started and the device is operating.
Fast flashing green
The power button is being pressed to power off the Comware system.
Steady red
The Comware system is being shutting down.
Off
The Comware system has been shut down.
Power status LED (PWR1 or PWR2)
Steady green
The power system is operating correctly.
Off
No power is being input.
PoE status LED
Steady green
Normal PoE input.
Flashing green
Abnormal PoE input.
Off
No PoE input.
Ethernet copper port LED
Steady green
A 1000 Mbps link is present.
Flashing green
The port is receiving or transmitting data at 1000 Mbps.
Steady yellow
A 10/100 Mbps link is present.
Flashing yellow
The port is receiving or transmitting data at 10/100 Mbps.
Off
No link is present.
Ethernet fiber port LED
Steady green
Flashing green
Steady yellow
A 100 Mbps link is present.
Flashing yellow
The port is receiving or transmitting data at 100 Mbps.
Off
No link is present.
Hard disk LED (HD)
Steady green
The hard disk has completed initialization.
Flashing green
The hard disk is transmitting or receiving data.
Steady yellow
The hard disk is faulty.
Off
No hard disk is present or the hard disk is faulty.
