10-Segment Routing Command Reference
HomeSupportResource CenterRoutersCR19000 Core SeriesCR19000 Core SeriesTechnical DocumentsReference GuidesCommand ReferencesH3C CR19000 Core Router Series Command References-E3521-5W10010-Segment Routing Command Reference
05-SRv6-TE policy commands
05-SRv6-TE policy commands 185.44 KB
address-family ipv6 sr-policy
Use address-family ipv6 sr-policy to create the BGP IPv6 SR policy address family and enter its view, or enter the view of the existing BGP IPv6 SR policy address family.
Use undo address-family ipv6 sr-policy to delete the BGP IPv6 SR policy address family and all the configuration in the BGP IPv6 SR policy address family.
The BGP IPv6 SR policy address family does not exist.
BGP instance view
The configuration in BGP IPv6 SR policy address family view applies only to routes and peers in the BGP IPv6 SR policy address family.
# In BGP instance view, create the BGP IPv6 SR policy address family and enter its view.
[Sysname] bgp 100
[Sysname-bgp-default] address-family ipv6 sr-policy
[Sysname-bgp-default-srpolicy-ipv6]
advertise ebgp enable
Use advertise ebgp enable to enable advertising SRv6-TE policy routes to EBGP peers.
Use undo advertise ebgp enable to restore the default.
SRv6-TE policy routes are not advertised to EBGP peers.
By default, SRv6-TE policy routes are advertised among IBGP peers. To advertise SRv6-TE policy routes to EBGP peers, you must execute this command to enable the advertisement capability.
# Enable advertising SRv6-TE policy routes to EBGP peers.
[Sysname] bgp 100
[Sysname-bgp-default] address ipv6 sr-policy
[Sysname-bgp-default-srpolicy-ipv6] advertise ebgp enable
binding-sid
Use binding-sid to configure a BSID for an SRv6-TE policy.
Use undo binding-sid to delete the BSID.
binding-sid ipv6 ipv6-address
undo binding-sid
No BSID is configured for an SRv6-TE policy.
SRv6-TE policy view
ipv6 ipv6-address: Specifies the BSID value, which is an IPv6 address.
You can use this command to manually configure a BSID for an SRv6-TE policy or leave the SRv6-TE policy to obtain a BSID automatically. If an SRv6-TE policy has only color and endpoint configuration, the SRv6-TE policy will automatically request a BSID.
The manually configured BSID has a higher priority over the automatically obtained BSID.
The BSID configured by this command must be on the locator specified for SRv6-TE policies in SRv6 TE view. Otherwise, the SRv6-TE policy cannot forward packets.
# Set the BSID of SRv6-TE policy srv6policy to 1000::1.
[Sysname] segment-routing ipv6
[Sysname-segment-routing-ipv6] traffic-engineering
[Sysname-srv6-te] policy srv6policy
[Sysname-srv6-te-policy-srv6policy] binding-sid ipv6 1000::1
candidate-paths
Use candidate-paths to create and enter the candidate path view for an SRv6-TE policy, or enter the existing SRv6-TE policy candidate path view.
Use undo candidate-paths to delete the SRv6-TE policy candidate path view and all the configurations in the view.
candidate-paths
The candidate path view for an SRv6-TE policy does not exist.
SRv6-TE policy view
# Create the SRv6-TE policy candidate paths instance and enter its view.
[Sysname-srv6-te-policy-srv6policy] candidate-paths
[Sysname-srv6-te-policy-srv6policy-path]
color end-point
Use color end-point to configure the color and endpoint attributes of an SRv6-TE policy.
Use undo color to delete the color and endpoint settings of an SRv6-TE policy.
color color-value end-point ipv6 ipv6-address
undo color
The color and endpoint attributes of an SRv6-TE policy are not configured.
SRv6-TE policy view
color-value: Specifies the color attribute value, in the range of 1 to 4294967295.
Ipv6-address: Specifies the endpoint IPv6 address.
Different SRv6-TE policies cannot have the same color or endpoint IP address.
# Configure the color as 20 and endpoint IPv6 address as 1000::1 for SRv6-TE policy srv6policy.
[Sysname-srv6-te-policy-srv6policy] color 20 end-point ipv6 1000::1
display bgp routing-table ipv6 sr-policy
Use display bgp routing-table ipv6 sr-policy to display route information of a BGP SRv6-TE policy.
display bgp [ instance instance-name ] routing-table ipv6 sr-policy [ sr-policy-prefix [ advertise-info ] | [ color color-value ] [ end-point ipv6 ipv6-address ] | peer ipv6-address { advertised-routes | received-routes } [ statistics ] [ color color-value ] [ end-point ipv6 ipv6-address ] | statistics [ color color-value ] [ end-point ipv6 ipv6-address ] ]
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a BGP instance, this command displays information about the default instance.
sr-policy-prefix: Specifies a BGP SRv6-TE policy route prefix, which is a case-insensitive string of 1 to 512 characters in the format of SRv6-TE policy route/prefix length.
color color-value: Specifies the color attribute value of a BGP SRv6-TE policy, in the range of 1 to 4294967295.
end-point ipv6 ipv6-address: Specifies the endpoint IPv6 address of a BGP SRv6-TE policy.
advertise-info: Displays advertisement information about BGP SRv6-TE policy routes.
peer ipv6-address: Specifies a peer by its IPv6 address.
advertised-routes: Displays detailed information about the BGP SRv6-TE policy routes advertised to the specified peer.
received-routes: Displays detailed information about the BGP SRv6-TE policy routes received from the specified peer.
statistics: Displays route statistics.
If you do not specify any parameters, this command displays brief information about all BGP SRv6-TE policy routes.
# Display brief information about all BGP SRv6-TE policy routes.
<Sysname> display bgp routing-table ipv6 sr-policy
 Total number of routes: 1
 Status codes: * - valid, > - best, d - dampened, h - history
               a – additional-path
>i Network : [46][46][8::8]/192
   NextHop : 1::2                                  LocPrf    : 100
   PrefVal : 0                                     MED       : 0
   Path/Ogn: i
Status codes
Status codes of the route.
Origin
Origin of the route:
·     i – IGP—Originated in the AS.
·     e – EGP—Learned through an EGP.
·     ? – incomplete—Unknown origin.
Network
BGP SRv6-TE policy route, comprised of the following elements:
·     SRv6-TE policy candidate path preference.
·     SRv6-TE policy color attribute value.
·     Endpoint IPv6 address.
NextHop
Next hop IP address.
LocPrf
Local preference value.
PrefVal
Preferred value of the route.
MED
Multi-Exit Discriminator attribute value.
Path/Ogn
AS_PATH and ORIGIN attributes of the route:
·     AS_PATH—Records the ASs the route has passed.
·     ORIGIN—Identifies the origin of the route.
# Display detailed information about BGP SRv6-TE policy route [46][46][8::8]/192.
<Sysname> display bgp routing-table ipv6 sr-policy [46][46][8::8]/192
BGP local router ID: 5.5.5.1
Local AS number: 100
Paths: 1 available, 1 best
 BGP routing table information of [46][46][8::8]/192
 Imported route.
 Original nexthop: ::
 Output interface: NULL0
 Route age       : 19h45m02s
 OutLabel        : NULL
 RxPathID        : 0x0
 TxPathID        : 0x0
 Org-validation  : Valid
 AS-path         : (null)
 Origin          : igp
 Attribute value : MED 0, localpref 100, pref-val 32768
 State           : valid, local, best
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 Tunnel encapsulation info:
    Type: 15 (SR policy)
     Policy name: p1
     Binding SID: 2::6
     Preference: 100
     Path: 1
      Weight: 1
      SIDs: {2::2}
Paths
Route information:
·     available—Number of valid routes.
·     best—Number of optimal routes.
Information of the BGP SRv6-TE policy route [46][46][8::8]/192, where:
·     [46] is the SRv6-TE policy candidate path preference
·     [46] is the SRv6-TE policy color attribute value.
·     [8::8] is the endpoint IPv6 address.
From
IP address of the BGP peer that advertised the route.
Rely Nexthop
Recursive nexthop IP address. If no next hop is found by route recursion, this field displays not resolved.
Original nexthop
Original nexthop IP address. If the route was obtained from a BGP update message, the original next hop is the nexthop IP address in the message.
Route age
Time elapsed since the last update for the route.
OutLabel
Outgoing label of the route.
RxPathID
Received Add-Path ID of the route.
TxPathID
Advertised Add-Path ID of the route.
Org-validation
BGP RPKI validation state:
·     Valid.
·     Not found.
·     Invalid.
AS-path
AS_PATH attribute of the route.
Origin
·     igp—Originated in the AS.
·     egp—Learned through an EGP.
·     incomplete—Unknown origin.
Attribute value
BGP path attributes:
·     MED—MED value.
·     localprefLocal preference value.
·     pref-val—Preferred value.
·     pre—Protocol preference.
Current state of the route. Options include:
·     valid—Valid route.
·     internal—Internal route.
·     external—External route.
·     local—Locally generated route.
·     synchronize—Synchronized route.
·     best—Optimal route.
·     delay—Delayed route. The route will be delayed for optimal route selection. This value is available only in detailed information of the route.
·     not preferred for reason—Reason why the route is not selected as the optimal route. For more information, see Table 3.
IP precedence
IP precedence of the route, in the range of 0 to 7. N/A indicates that the route does not support this field.
QoS local ID
QoS local ID of the route, in the range of 1 to 4095. N/A indicates that the route does not support this field.
Traffic index
Traffic index in the range of 1 to 64. N/A indicates that the route does not support this field.
Type: 15 (SR Policy)
The tunnel encryption type is 15, which represents SR policy.
Preference
Candidate path preference.
Binding SID
BSID value
Path
Candidate path.
Weight
Weight of the SID list.
SIDs
List of SIDs.
Table 3 Reason why the route is not selected as the optimal route
Reason
preferred-value
Routes with larger preferred values exist.
local-preference
Routes with larger local preference values exist.
as-path
Routes with smaller AS_PATH attribute values exist.
origin
There are routes whose origin has a higher priority. The route origins are IGP, EGP, and INCOMPLETE in descending order of priority.
med
Routes with smaller MED values exist.
remote-route
There are routes whose remote-route attribute has a higher priority.
BGP selects the optimal route from remote routes in this order:
·     Route learned from an EBGP peer.
·     Route learned from a confederation EBGP peer.
·     Route learned from a confederation IBGP peer.
·     Route learned from an IBGP peer.
igp-cost
Routes with smaller IGP metrics exist.
relydepth
Routes with smaller recursion depth values exist.
rfc5004
A route received from an EBGP peer is the current optimal route. BGP does not change the optimal route when it receives routes from other EBGP peers.
router-id
Routes with smaller router IDs exist.
If one of the routes is advertised by a route reflector, BGP compares the ORIGINATOR_ID of the route with the router IDs of other routes. Then, BGP selects the route with the smallest ID as the optimal route.
cluster-list
Routes with smaller CLUSTER_LIST attribute values exist.
peer-address
Routes advertised by peers with lower IP addresses exist.
received
Earlier learned routes exist.
# Displays advertisement information about the BGP SRv6-TE policy route [46][46][8::8]/192.
<Sysname> display bgp routing-table ipv6 sr-policy [46][46][8::8]/192 advertise-info
 BGP local router ID: 2.2.2.2
 Local AS number: 1
 Paths:   1 best
 BGP routing table information of [46][46][8::8]/192(TxPathID:0):
 Advertised to peers (2 in total):
    1::1
    3::3
Paths
Number of optimal paths to reach the destination network.
Advertisement information about the BGP SRv6-TE policy route [46][46][8::8]/192. TxPathID represents the advertised Add-Path ID of the route.
Indicates the peers to which the route has been advertised. The number in the parentheses indicates the total number of the peers.
# Display statistics about the BGP SRv6-TE policy routes advertised to peer 2::2.
<Sysname> display bgp routing-table ipv6 sr-policy peer 2::2 advertised-routes statistics
 Advertised routes total: 2
# Display statistics about the BGP SRv6-TE policy routes received from peer 2::2.
<Sysname> display bgp routing-table ipv6 sr-policy peer 2::2 received-routes statistics
 Received routes total: 1
Table 5 Command output
Total number of routes advertised to the specified peer.
Total number of routes received from the specified peer.
# Display statistics about BGP SRv6-TE policy routes.
<Sysname> display bgp routing-table ipv6 sr-policy statistics
 Total number of routes: 3
display segment-routing ipv6 te forwarding
Use display segment-routing ipv6 te forwarding to display SRv6 TE forwarding information.
display segment-routing ipv6 te forwarding [ policy { name policy-name | { color color-value | end-point ipv6 ipv6-address } * } ] [ verbose ]
policy: Displays forwarding information of the specified SRv6-TE policy. If you do not specify an SRv6-TE policy, this command displays forwarding information of all SRv6-TE policies.
name policy-name: Specifies the name of an SRv6-TE policy, a case-sensitive string of 1 to 59 characters.
color color-value: Specifies the color of an SRv6-TE policy, in the range of 0 to 4294967295.
end-point ipv6 ip-address: Specifies the endpoint IPv6 address of an SRv6-TE policy.
verbose: Displays detailed SRv6 TE forwarding information. If you do not specify this keyword, the command displays brief SRv6 TE forwarding information.
# Display brief information about all SRv6-TE policies.
<Sysname> display segment-routing ipv6 te forwarding
Total forwarding entries: 1
Policy name/ID: p1/0
 Binding SID: 8000::1
 Forwarding index: 0x80300001
 Main path:
   Seglist ID: 1
     Seglist forwarding index: 0x80200001
     Weight: 1
     Outgoing forwarding index: 0x80100001
       Interface: GE1/2/0/1
       Nexthop: FE80::6CCE:CBFF:FE91:206
# Display detailed information about all SRv6-TE policies.
<Sysname> display segment-routing ipv6 te forwarding verbose
 Inbound statistics:
   Total octets: 525
   Total packets: 1
   Erroneous packets: 0
   Dropped packets: 0
 Outbound statistics:
   Total octets: 750
   Total packets: 1
   Dropped packets: 0
 Main path:
   Seglist ID: 1
     Weight: 1
       Total octets: 750
       Total packets: 1
       Dropped packets: 0
         Path ID: 1
         SID list: {44::44, 45::45}
         Total octets: 750
         Total packets: 1
         Dropped packets: 0
Table 6 Command output
Total number of SRv6 TE forwarding entries.
Policy name/ID
Name/ID of an SRv6-TE policy.
Binding SID
SID value of the ingress node.
Forwarding index
Index of the SRv6-TE policy forwarding entry.
Inbound statistics
Statistics on inbound traffic (the traffic received by the BSID).
Total octets
Total number of octets forwarded.
Total packets
Total number of packets forwarded.
Erroneous packets
Number of erroneous packets.
Dropped packets
Number of dropped packets.
Outbound statistics
Statistics on outbound traffic.
Main path
Main path for traffic forwarding.
Seglist ID
ID of the SID list.
Forwarding entry index of the SID list.
Weight
The nexthop forwarding entry index of the first address in the SID list.
Brief name of the outgoing interface.
Nexthop
Next hop IPv6 address.
Path ID
ID of the SRv6-TE policy candidate path.
SID list
List of SIDs.
display segment-routing ipv6 te policy
Use display segment-routing ipv6 te policy to display SRv6-TE policy information.
display segment-routing ipv6 te policy [ name policy-name | down | up | { color color-value | end-point ipv6 ipv6-address } * ]
name policy-name: Specifies an SRv6-TE policy by its name, a case-sensitive string of 1 to 59 characters.
down: Specifies the SRv6-TE policies in down state.
up: Specifies the SRv6-TE policies in up state.
color color-value: Specifies the color of an SRv6-TE policy, in the range of 1 to 4294967295.
end-point ipv6 ipv6-address: Specifies the endpoint IPv6 address of an SRv6-TE policy.
If you do not specify any parameters, this command displays information about all SRv6-TE policies.
# Display information about all SRv6-TE policies.
<Sysname> display segment-routing ipv6 te policy
Name/ID: p1/0
 Color: 10
 Endpoint: 1000::1
 Name from BGP: <none>
 BSID:
  Mode: Dynamic              Type: Type_2              Request state: Succeeded
  Current BSID: 5000::2      Explicit BSID: -          Dynamic BSID: 5000::2
 Reference counts: 3
 Flags: A/BS/NC
 Status: Up
 Up time: 2020-03-09 16:09:40
 Down time: 2020-03-09 16:09:13
 Statistics: Enabled
 Forwarding index: 2150629377
 Candidate paths state: Configured
 Candidate paths statistics:
  CLI paths: 1       BGP paths: 0     PCEP paths: 0
 Candidate paths:
  Preference : 20
   CpathName: <none>
   Instance ID: 0               ASN: 0              Node address: 0.0.0.0
   Peer address: 0.0.0.0
   Optimal: Y                   Flags: V/A
   Explicit SID list:
    ID: 1                      Name: Sl1
    Weight: 1                  Forwarding index: 2149580801
    State: Up
Table 7 Command output
Name/ID
SRv6-TE policy name/ID.
Color
Color attribute of the SRv6-TE policy. A value of 0 means that the color attribute is not configured.
Endpoint
Endpoint IPv6 address of the SRv6-TE policy. If the endpoint is not configured, this field displays None.
Name from BGP
Name of the SRv6-TE policy obtained from BGP. If no SRv6-TE policy was obtained from BGP, this field display <none>.
BSID
Mode
BSID configuration mode:
·     Explicit—Manually configured.
·     Dynamic—Dynamically requested.
·     None—Not configured.
BSID type:
·     Type_2—IPv6 address.
Request state
BSID request state:
·     Failed.
·     Succeeded.
·     Conflicted.
Explicit BSID
Manually configured BSID.
Dynamic BSID
Dynamically requested BSID.
Reference counts
Number of times that the SRv6-TE policy has been referenced.
Flags
SRv6-TE policy flags:
·     A—Active SRv6-TE policy.
·     C—Optimal SRv6-TE policy.
·     N—In optimal SRv6-TE policy selection progress.
·     BA—Requesting BSID.
·     BS—Optimal BSID.
·     D—Deleted SRv6-TE policy.
·     CF—Conflicted with an existing BSID.
·     NC—Manually configured SRv6-TE policy.
·     NB—SRv6-TE policy obtained from a BGP route.
·     W—The number of SRv6-TE policies has exceeded the maximum capacity.
Up time
Date and time when the SRv6-TE policy became up.
Down time
Date and time when the SRv6-TE policy became down.
Statistics
Traffic statistics status for the SRv6-TE policy:
·     Disabled.
·     Enabled.
·     Not configured.
Forwading index
Forwarding entry index of the SRv6-TE policy.
Whether candidate paths are configured:
·     Configured.
·     Not configured.
Candidate paths statistics by path origin.
CLI paths
Number of manually configured candidate paths.
BGP paths
Number of candidate paths obtained from BGP SRv6 Policy routes.
PCEP paths
Number of candidate paths obtained from PCEP.
Candidate paths
SRv6-TE policy candidate path information.
Preference
CPathName
Name of the candidate path obtained from a BGP route. If no path name was obtained, this field displays N/A.
Instance ID
BGP instance ID. A value of 0 indicates that the device does not obtain SRv6-TE policy information from BGP peers.
ASN
AS number. A value of 0 indicates that the device does not obtain SRv6-TE policy information from BGP peers.
Node address
BGP node address.
For an SRv6-TE policy obtained from a BGP peer, the node address is the Router ID of the BGP peer.
For an SRv6-TE policy obtained in other methods, the node address is 0.0.0.0.
Peer address
BGP peer address.
For an SRv6-TE policy obtained from a BGP peer, the peer address is the address of the BGP peer.
For an SRv6-TE policy obtained in other methods, the peer address is 0.0.0.0.
Optimal
Whether the path is the optimal path:
·     Y—Yes.
·     N—No.
Flags
Flags of the SRv6-TE policy candidate path:
·     V—Valid candidate path.
·     A—Active candidate path.
·     None—No candidate path.
Explicit SID list
Explicit SID list in the candidate path of the SRv6-TE policy.
ID
SID list ID.
Name
SID list name.
Weight
Weight of the SID list in the candidate path.
Forwarding index
SID list state:
·     UP.
·     DOWN.
display segment-routing ipv6 te policy statistics
Use display segment-routing ipv6 te policy statistics to display SRv6-TE policy statistics.
# Display SRv6-TE policy statistics.
<Sysname> display segment-routing ipv6 te policy statistics
Total policies: 0 (0 up 0 down)
    Configured: 0
    From BGP: 0 (Added 0, deleted 0)
Total candidate paths: 0
    Configured: 0
Total SID lists: 0
    Configured: 0
    From BGP: 0
Table 8 Command output
Total policies
Total number of SRv6-TE policies:
·     up—Number of SRv6-TE policies in up state.
·     down—Number of SRv6-TE policies in down state.
Configured
Number of manually configured SR policies.
From BGP
Number of SR policies learned through BGP.
·     Added—Number of BGP-added SRv6-TE policies.
·     deleted—Number of BGP-deleted SRv6-TE policies.
Total number of SRv6-TE policy candidate paths.
Total SID lists
Total number of SID lists.
display segment-routing ipv6 te segment-list
Use display segment-routing ipv6 te segment-list to display SRv6-TE SID list information.
display segment-routing ipv6 te segment-list [ name seglist-name | id id-value ]
name segment-list-name: Specifies a SID list by its name, a case-sensitive string of 1 to 128 characters.
id id-value: Specifies a SID list by its ID. The value range for the SID list ID is 1 to 4294967295.
If you do not specify a SID list name or ID, this command displays information about all SRv6-TE SID lists.
To view SID list ID information, execute the display segment-routing ipv6 te policy command.
# Display information about all SRv6-TE SID lists.
<Sysname> display segment-routing ipv6 te segment-list
Total Segment lists: 1
Name/ID: A/1
 Origin: CLI
 Status: Up
 Nodes: 1
  Index: 1             SID: 1::2
  Type : Type_2      Flags: None
Table 9 Command output
Total Segment lists
Number of SID lists.
Name/ID
SID list name/ID.
Origin
Origin of the SID list. Options include:
·     CLI—Locally configured in the CLI.
·     BGP—Issued by BGP.
·     PCE—Issued by a PCE. (This option is not supported in the current software version.)
If the SID list does not have a valid origin, this field displays a hyphen (-).
Status
SID list status, Down or Up.
Nodes
Number of nodes in the SID list.
Index
Node index.
SID
SID value (IPv6 address) of the node.
SID type of the node:
Flags
Node flags, which are not defined and displayed as None.
explicit segment-list
Use explicit segment-list to specify a SID list for a candidate path.
Use undo explicit segment-list to delete a SID list of a candidate path or restore the default weight of a SID list.
explicit segment-list segment-list-name [ weight weight-value ]
undo explicit segment-list segment-list-name [ weight ]
No SID lists are specified for an SRv6-TE policy candidate path.
SRv6-TE policy path preference view
segment-list-name: Specifies an SID list name, a case-sensitive string of 1 to 128 characters.
weight weight-value: Specifies a weight for the SID list, in the range of 1 to 4294967295. The default weight is 1.
An SRv6-TE policy uses the SID list specified for the highest-preference candidate path as a traffic forwarding subpath.
An SRv6-TE policy candidate path can have multiple SID lists. All the SID lists can be used to forward traffic for load sharing based on their weights. Assume SID lists a, b, and c are assigned weights x, y, z, respectively. The load of SID list a is x/(x+y+z) of the total traffic.
If you assign weight values for the same SID list multiple times, the most recent configuration takes effect.
# Configure SID list abc for the SRv6-TE policy candidate path with preference 20, and the set the SID list weight to 20.
[Sysname-srv6-te] policy a1
[Sysname-srv6-te-policy-a1] candidate-paths
[Sysname-srv6-te-policy-a1-path] preference 20
[Sysname-srv6-te-policy-a1-path-pref20] explicit segment-list abc weight 20
segment-list
forwarding statistics
Use forwarding statistics to configure traffic forwarding statistics for an SRv6-TE policy.
Use undo forwarding statistics to restore the default.
forwarding statistics { disable | enable }
An SRv6-TE policy uses the traffic forwarding statistics configuration in SRv6 TE view.
SRv6-TE policy view
disable: Disables the SRv6-TE policy forwarding statistics.
enable: Enables the SRv6-TE policy forwarding statistics.
You can configure traffic forwarding statistics for all SRv6-TE policies globally in SRv6 TE view or for a specific SRv6-TE policy in SRv6-TE policy view. The policy-specific configuration takes precedence over the global configuration. An SRv6-TE policy uses the global configuration only when it has no policy-specific configuration.
# Enable traffic forwarding statistics for SRv6-TE policy 1.
[Sysname-srv6-te] policy 1
[Sysname-srv6-te-policy-1] forwarding statistics enable
reset segment-routing ipv6 te forwarding statistics
srv6-policy forwarding statistic enable
srv6-policy forwarding statistic interval
import-route sr-policy
Use import-route sr-policy to enable BGP to redistribute routes from the SRv6-TE policy.
Use undo import-route sr-policy to restore the default.
BGP does not redistribute SRv6-TE policy routes.
After you execute this command, the system will redistribute the local SRv6-TE policy routes to the BGP routing table and advertise the routes to IBGP peers. Then, the peers can forward traffic based on the SRv6-TE policy.
# In BGP IPv6 SR policy address family view, enable BGP to redistribute routes from the SRv6-TE policy.
[Sysname] bgp 100
[Sysname-bgp-default-srpolicy-ipv6] import-route sr-policy
index
Use index to add a node to a SID list.
Use undo index to delete a node from a SID list.
index index-number ipv6 ipv6-address
undo index index-number
No nodes exist in a SID list.
SID list view
index-number: Specifies the node index, in the range of 1 to 65535.
ipv6-address: Specifies the IPv6 address of the node.
# Add a node to SID list abc, and set the node index to 1 and IPv6 address to 1000::1.
[Sysname-srv6-te] segment-list abc
[Sysname-srv6-te-sl-abc] index 1 ipv6 1000::1
srv6-policy locator
Use srv6-policy locator to specify a locator for SRv6 TE.
Use undo srv6-policy locator to cancel the locator configuration.
srv6-policy locator locator-name
No locator is specified for SRv6 TE.
SRv6 TE view
locator-name: Specifies a locator by its name, a case-sensitive string of 1 to 31 characters.
The locator specified in SRv6 TE view restricts the BSID range. Only BSIDs within the range of the locator can take effect.
You cannot change the locator for SRv6 TE by repeatedly executing this command. To change the locator, first execute the undo srv6-policy locator command to remove the specified locator and then execute the srv6-policy locator command to specify a new locator.
# Specify locator test1 in SRv6 TE view.
[Sysname-srv6-te] srv6-policy locator test1
policy
Use policy to create an SRv6-TE policy and enter its view, or enter the view of an existing SRv6-TE policy.
Use undo policy to delete an SRv6-TE policy and all the configuration in the SRv6-TE policy.
policy policy-name
undo policy policy-name
No SRv6-TE policies exist.
SRv6 TE view
policy-name: Specifies an SRv6-TE policy name, a case-sensitive string of 1 to 59 characters.
# Create an SRv6-TE policy named srv6policy and enter its view.
[Sysname-srv6-te] policy p1
[Sysname-srv6-te-policy-p1]
preference
Use preference to set the preference for an SRv6-TE policy candidate path and enter SRv6-TE policy path preference view, or enter an existing SRv6-TE policy path preference view.
Use undo preference to delete an SRv6-TE policy candidate path preference and all the configuration in the SRv6-TE policy path preference view.
preference preferenc-value
undo preference preferenc-value
preferenc-value: Specifies a candidate path preference in the range of 1 to 65535. A bigger value represents a higher preference.
A preference represents a candidate path of an SRv6-TE policy.
# Set the preference of an SRv6-TE policy candidate path to 20, and enter SRv6-TE policy path preference view.
Use reset segment-routing ipv6 te forwarding statistics to clear forwarding statistics for all SRv6-TE policies.
# Clear SRv6-TE policy forwarding statistics.
<Sysname> reset segment-routing ipv6 te forwarding statistics
srv6-policy forwarding statistics enable
srv6-policy forwarding statistics interval
router-id filter
Use router-id filter to enable Router ID filtering.
Use undo router-id filter to disable Router ID filtering.
router-id filter
Router ID filtering is disabled.
For the device to process only part of the received SRv6-TE policy routes, you can execute this command to enable filtering the routes by Router ID.
This command enables the device to check the Route Target attribute of a received SRv6-TE policy route. The device accepts the route only if the Route Target attribute contains the Router ID of the local device.
To use Router ID filtering, make sure you add Route Target attributes to SRv6-TE policy routes properly by using routing policy or other methods. Otherwise, Router ID filtering might learn or drop SRv6-TE policy routes incorrectly.
# Enable Router ID filtering.
[Sysname] bgp 100
[Sysname-bgp-default-srpolicy-ipv6] router-id filter
segment-list
Use segment-list to create a SID list and enter its view, or enter the view of an existing SID list.
Use undo segment-list to delete a SID list and all the configuration in the SID list.
undo segment-list segment-list-name
No SID lists exist.
SRv6 TE view
segment-list-name: Specifies the SID list name, a case-sensitive string of 1 to 128 characters.
# Create a SID list named abc and enter its view.
segment-routing ipv6 traffic-engineering
Use segment-routing ipv6 traffic-engineering to enable L3VPN recursion to SRv6-TE policy tunnels.
Use undo segment-routing ipv6 traffic-engineering to restore the default.
segment-routing ipv6 traffic-engineering [ best-effort ] [ evpn ]
undo segment-routing ipv6 traffic-engineering [ best-effort ] [ evpn ]
L3VPN cannot recurse to SRv6-TE policy tunnels.
BGP-VPN IPv4 unicast address family
BGP-VPN IPv6 unicast address family
best-effort: Enables the best-effort SRv6 forwarding mode. In this mode, L3VPN packets are forwarded by looking up the routing table according to the End.DT4 SID, End.DT6 SID, or End.DT46 SID of the packets in case of SRv6-TE policy failure. If you do not specify this keyword, L3VPN packets will be forwarded by looking up the routing table according to the destination IP address of the packets in case of SRv6-TE policy failure.
evpn: Enables EVPN L3VPN recursion to SRv6-TE policy tunnels. If you do not specify this keyword, the command enables MPLS L3VPN recursion to SRv6-TE policy tunnels.
This command applies to MPLS L3VPN and EVPN L3VPN networks where you want to use an SRv6-TE policy tunnel as the public tunnel to transfer the VPN traffic.
You can specify the best-effort keyword to improve packet forwarding reliability. In the SRv6 best effort mode, the device forwards L3VPN packets as follows:
1.     Forwards L3VPN packets by using an SRv6-TE policy tunnel.
2.     When the SRv6-TE policy tunnel fails, the device forwards L3VPN packets by looking up the routing table according to the End.DT4 SID, End.DT6 SID, or End.DT46 SID of the packets.
3.     If SID-based forwarding fails, the device forwards L3VPN packets by looking up the routing table according to the destination IP address of the packets.
4.     If the destination IP-based forwarding fails, the device drops the packets.
This command is mutually exclusive with the segment-routing ipv6 best-effort command.
# In BGP-VPN IPv4 unicast family view, enable L3VPN recursion to SRv6-TE policy tunnels.
[Sysname] bgp 100
[Sysname-bgp-default-vpn1] address-family ipv4
[Sysname-bgp-default-ipv4-vpn1] segment-routing ipv6 traffic-engineering
sr-policy steering
Use sr-policy steering to configure the traffic steering mode for SRv6-TE policies.
Use undo sr-policy steering to restore the default.
sr-policy steering [ disable | policy-based ]
The device steering data packets to SRv6-TE policies based on colors of the packets.
BGP instance view
disable: Does not forward traffic by using SRv6-TE policies.
policy-based: Steers traffic to an SRv6-TE policy based on the tunnel policy.
The following traffic steering modes are available for SRv6-TE policies:
·     Based on color—The device searches for an SRv6-TE policy whose color and endpoint address match the color and nexthop address of a BGP route. If a matching SRv6-TE policy exists, the device recurse the BGP route to that SRv6-TE policy. Then, when the device receives packets that match the BGP route, it forwards the packets through the SRv6-TE policy.
·     Based on tunnel policy—-On the ingress PE of an MPLS L3VPN or EVPN L3VPN network, create an SRv6-TE policy with endpoint address as an End.DT4 SID, End.DT6 SID, or End.DT46 SID. Configure a preferred tunnel or load sharing tunnel policy that uses the SRv6-TE policy. In this way, the SRv6-TE policy will be used as the public tunnel to carry the packets of a VPN instance. For more information about the tunnel policy configuration, see MPLS Configuration Guide.
# Configure the SRv6-TE traffic steering mode as tunnel policy.
[Sysname] bgp 100
[Sysname-bgp-default] sr-policy steering policy-based
Use srv6-policy forwarding statistics enable to enable traffic forwarding statistics for all SRv6-TE policies.
Use undo srv6-policy forwarding statistics enable to disable traffic forwarding statistics for all SRv6-TE policies.
Traffic forwarding statistics is disabled for all SRv6-TE policies.
SRv6 TE view
# Enable traffic forwarding statistics for all SRv6-TE policies.
[Sysname-srv6-te] srv6-policy forwarding statistics enable
Use srv6-policy forwarding statistics interval to configure the traffic forwarding statistics interval for all SRv6-TE policies.
Use undo srv6-policy forwarding statistics interval to restore the default.
srv6-policy forwarding statistics interval interval
The SRv6-TE policies forwarding statistics interval is 30 seconds.
SRv6 TE view
interval: Specifies the SRv6-TE policy traffic forwarding statistics interval in the range of 5 to 65535, in seconds.
This command takes effect only all SRv6-TE policies.
# Set the SRv6-TE policy traffic forwarding statistics interval to 90 seconds.
[Sysname-srv6-te] srv6-policy forwarding statistics interval 90
traffic-engineering
Use traffic-engineering to create and enter the SRv6 TE view, or enter the existing SR TE view.
Use undo traffic-engineering to delete the SRv6 TE view and all the configuration in the view.
traffic-engineering
The SRv6 TE view does not exist.
SRv6 view
# Create and enter the SRv6 TE view.
[Sysname-srv6-te]
  • Become a Partner
  • Partner Resources
