03-SR-TE policy commands | 209.06 KB |
display bgp routing-table ipv4 sr-policy
display segment-routing te forwarding
display segment-routing te policy
display segment-routing te policy statistics
display segment-routing te policy-group
display segment-routing te segment-list
forwarding statistics interval
reset segment-routing te forwarding statistics
sr-policy backup hot-standby enable
address-family ipv4 sr-policy
Use address-family ipv4 sr-policy to create the BGP IPv4 SR-TE policy address family and enter its view, or enter the view of the existing BGP IPv4 SR-TE policy address family.
Use undo address-family ipv4 sr-policy to delete the BGP IPv4 SR-TE policy address family and all the configuration in the BGP IPv4 SR-TE policy address family.
The BGP IPv4 SR-TE policy address family does not exist.
BGP instance view
The configuration in BGP IPv4 SR-TE policy address family view applies only to routes and peers in the BGP IPv4 SR-TE policy address family.
# In BGP instance view, create the BGP IPv4 SR-TE policy address family and enter its view.
[Sysname] bgp 100
[Sysname-bgp-default] address-family ipv4 sr-policy
[Sysname-bgp-default-srpolicy-ipv4]
advertise ebgp enable
Use advertise ebgp enable to advertise SR-TE policy routes to EBGP peers.
Use advertise ebgp enable to restore the default.
undo advertise ebgp enable
SR-TE policy routes are not advertised to EBGP peers.
By default, only IBGP peers exchange SR-TE policy routes. Execute this command to advertise SR-TE policy routes to EBGP peers.
# Advertise SR-TE policy routes to EBGP peers.
[Sysname] bgp 100
[Sysname-bgp-default] address ipv4 sr-policy
[Sysname-bgp-default-srpolicy-ipv4] advertise ebgp enable
backup hot-standby
Use backup hot-standby to configure hot standby for an SR-TE policy.
Use undo backup hot-standby to restore the default.
backup hot-standby { disable | enable }
Hot standby is not configured for an SR-TE policy.
SR-TE policy view
disable: Disables hot standby for the SR-TE policy.
enable: Enables hot standby for the SR-TE policy.
The hot standby feature takes the candidate path with the greatest preference value in the SR-TE policy as the primary path and that with the second greatest preference value as the standby path. When the forwarding paths corresponding to all SID lists of the primary path fails, the standby path immediately takes over to minimize service interruption.
You can enable hot standby for all SR-TE policies globally in SR TE view or for a specific SR-TE policy in SR-TE policy view. The policy-specific configuration takes precedence over the global configuration. An SR-TE policy uses the global configuration only when it has no policy-specific configuration.
# Enable hot standby for SR-TE policy 1.
[Sysname] segment-routing
[Sysname-segment-routing] traffic-engineering
[Sysname-sr-te] policy 1
[Sysname-sr-te-policy-1] backup hot-standby enable
binding-sid
Use binding-sid to configure an BSID for an SR-TE policy.
Use undo binding-sid to delete the BSID.
binding-sid mpls mpls-label
undo binding-sid
No BSID is configured for an SR-TE policy.
SR-TE policy view
mpls mpls-label: Specifies the BSID value, which is an MPLS label value. The value range for the mpls-label argument is 16 to 1048575. However, the effective value range is 81535 to 91774 on the device. Specify a BSID value in the effective value range. If you specify a BSID value that is in the first mentioned value range but not in the effective value range, the system displays the following message: Configuration succeeded but the BSID is not available for use. Reason: The BSID is not in the range of 81535 to 91774.
You can use this command to manually configure a BSID for an SR-TE policy or leave the SR-TE policy to obtain a BSID automatically. If an SR-TE policy has only color and endpoint configuration, the SR-TE policy will automatically request a BSID.
The manually configured BSID has a higher priority over the automatically obtained BSID.
If you configure an MPLS label as the BSID but the label is not in the range of the SRGB or SRLB or is already used by a protocol, the configuration does not take effect. For more information about SRGB or SRLB, see MPLS SR configuration in Segment Routing Configuration Guide.
The candidate paths of the same SR-TE policy have the same BSID.
# Set the BSID of SR-TE policy srpolicy to 15000.
[Sysname-sr-te] policy srpolicy
[Sysname-sr-te-policy-srpolicy] binding-sid mpls 15000
color end-point
candidate-paths
Use candidate-paths to create and enter the candidate path view for an SR-TE policy, or enter the existing candidate path view.
Use undo candidate-paths to delete the candidate path view and all the configurations in the view.
candidate-paths
The candidate path view for an SR-TE policy does not exist.
SR-TE policy view
# Create the SR-TE policy candidate paths instance and enter its view.
[Sysname-sr-te-policy-srpolicy] candidate-paths
[Sysname-sr-te-policy-srpolicy-path]
color end-point
Use color end-point to configure the color and endpoint attributes of an SR-TE policy.
Use undo color to delete the color and endpoint settings of an SR-TE policy.
color color-value end-point ipv4 ipv4-address
undo color
The color and endpoint attributes of an SR-TE policy are not configured.
SR-TE policy view
color-value: Specifies the color attribute value, in the range of 1 to 4294967295.
ipv4-address: Specifies the endpoint IP address.
Different SR policies cannot have the same color and they can have the same endpoint IP address.
# Configure the color as 20 and endpoint IP address as 10.0.0.1 for SR-TE policy srpolicy.
[Sysname-sr-te-policy-srpolicy] color 20 end-point ipv4 10.0.0.1
binding-sid
color match dscp
Use color match dscp to create color-to-DSCP mappings for an SR-TE policy group.
Use undo color match dscp to delete color-to-DSCP mappings for the SR-TE policy group.
color color-value match dscp { ipv4 | ipv6 } dscp-value-list
undo color color-value match dscp { ipv4 | ipv6 } dscp-value-list
color color-value match dscp { ipv4 | ipv6 } default
undo color color-value match dscp { ipv4 | ipv6 } [ default ]
No color-to-DSCP mappings are created for an SR-TE policy group.
SR-TE policy group view
ipv4: Specifies DSCP values of IPv4 packets.
ipv6: Specifies DSCP values of IPv6 packets.
dscp-value-list: Specifies a space-separated list of up to 32 DSCP value items. Each item specifies a DSCP value in the range of 0 to 63 or a range of DSCP values in the form of dscp-value1 to dscp-value2. The value for the dscp-value2 argument must be greater than the value for the dscp-value1 argument.
default: Specifies a default color-to-DSCP mapping. Packets that do not match any mappings are steered to the default SR-TE policy for forwarding.
You can map the color values of only valid SR-TE policies to DSCP values.
You can configure color-to-DSCP mappings separately for the IPv4 address family and IPv6 address family. For a specific address family, a DSCP value can be mapped to only one color value.
Use the color match dscp default command to specify the default SR-TE policy for an address family. If no SR-TE policy in an SR-TE policy group matches a specific DSCP value, the default SR-TE policy is used to forward packets containing the DSCP value. Only one default SR-TE policy can be specified for an address family.
When the device receives an IPv4 or IPv6 packet that does not match any color-to-DSCP mapping, the device selects a valid SR-TE policy for the packet in the following order:
1. The default SR-TE policy specified for the same address family as the packet.
2. The default SR-TE policy specified for the other address family.
3. The SR-TE policy mapped to the smallest DSCP value in the same address family as the packet.
4. The SR-TE policy mapped to the smallest DSCP value in the other address family.
# Map DSCP value 30 to color value 20 for SR-TE policy group 10 so that IPv4 packets with a matching DSCP value are steered to the associated SR-TE policy.
[Sysname-sr-te] policy-group 10
[Sysname-sr-te-policy-group-10] color 20 match dscp ipv4 30
Use display bgp routing-table ipv4 sr-policy to display route information of an BGP IPv4 SR-TE policy.
display bgp [ instance instance-name ] routing-table ipv4 sr-policy [ sr-policy-prefix [ advertise-info ] | [ color color-value ] [ end-point ipv4 ipv4-address ] | peer ipv4-address { advertised-routes | received-routes } [ statistics ] [ color color-value ] [ end-point ipv4 ipv4-address ] | statistics [ color color-value ] [ end-point ipv4 ipv4-address ] ]
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a BGP instance, this command displays information about the default instance.
sr-policy-prefix: Specifies a BGP SR-TE policy route prefix, which is a case-insensitive string of 1 to 512 characters in the format of SR-TE policy route/mask length.
advertise-info: Displays advertisement information about BGP IPv4 SR-TE policy routes.
color color-value: Specifies the color attribute value, in the range of 1 to 4294967295.
end-point ipv4 ipv4-address: Specifies the endpoint IPv4 address.
peer ipv4-address: Specifies a peer by its IP address.
advertised-routes: Displays detailed information about the BGP IPv4 SR-TE policy routes advertised to the specified peer.
received-routes: Displays detailed information about the BGP IPv4 SR-TE policy routes received from the specified peer.
statistics: Displays route statistics.
If you do not specify any parameters, this command displays brief information about all BGP IPv4 SR-TE policy routes.
# Display brief information about all BGP IPv4 SR-TE policy routes.
<Sysname> display bgp routing-table ipv4 sr-policy
Total number of routes: 1
Status codes: * - valid, > - best, d - dampened, h - history
a – additional-path
* >i Network : [10][1][9.9.9.9]/96
NextHop : 2.1.1.2 LocPrf : 100
PrefVal : 0 OutLabel : NULL
MED : 0
Path/Ogn: i
Status codes |
Status codes of the route. |
Origin |
Origin of the route: · i – IGP—Originated in the AS. · e – EGP—Learned through an EGP. · ? – incomplete—Unknown origin. |
Network |
BGP IPv4 SR-TE policy route, comprised of the following elements: · SR-TE policy candidate path preference. · SR-TE policy color attribute value. · Endpoint IP address. |
NextHop |
Next hop IP address. |
LocPrf |
Local preference value. |
PrefVal |
Preferred value of the route. |
OutLabel |
Outgoing label of the route. |
MED |
Multi-Exit Discriminator attribute value. |
Path/Ogn |
AS_PATH and ORIGIN attributes of the route: · AS_PATH—Records the ASs the route has passed. · ORIGIN—Identifies the origin of the route. |
# Display detailed information about BGP IPv4 SR-TE policy route [102][2][5.6.7.8]/96.
<Sysname> display bgp routing-table ipv4 sr-policy [102][2][5.6.7.8]/96
BGP local router ID: 2.2.2.2
Local AS number: 1
Paths: 1 available, 1 best
BGP routing table information of [102][2][5.6.7.8]:
Rely nexthop : 0.0.0.0
Original nexthop: 3.1.1.2
Route age : 00h33m33s
OutLabel : NULL
RxPathID : 0x0
TxPathID : 0x0
AS-path : 2
Origin : igp
State : valid, external, best
IP precedence : N/A
QoS local ID : N/A
Traffic index : N/A
Tunnel encapsulation info:
Type: 15 (SR Policy)
Preference: 102
Binding SID: 15000
Path: 1
Weight: 1
SIDs: {3}
Paths |
Route information: · available—Number of valid routes. · best—Number of optimal routes. |
BGP routing table information of [102][2][5.6.7.8] |
Information of the BGP IPv4 SR-TE policy route [102][2][5.6.7.8], where: · [102] is the SR-TE policy candidate path preference · [2] is the SR-TE policy color attribute value. · [5.6.7.8] is the endpoint IP address. |
From |
IP address of the BGP peer that advertised the route. |
Rely Nexthop |
Recursive nexthop IP address. If no next hop is found by route recursion, this field displays not resolved. |
Original nexthop |
Original nexthop IP address. If the route was obtained from a BGP update message, the original next hop is the nexthop IP address in the message. |
Route age |
Time elapsed since the last update for the route. |
OutLabel |
RxPathID |
Received Add-Path ID of the route. |
TxPathID |
Advertised Add-Path ID of the route. |
AS-path |
AS_PATH attribute of the route. |
Origin |
Origin of the route: · igp—Originated in the AS. · egp—Learned through an EGP. · incomplete—Unknown origin. |
Attribute value |
BGP path attributes: · MED—MED value. · localpref—Local preference value. · pref-val—Preferred value. · pre—Protocol preference. |
State |
Current state of the route. Options include: · valid—Valid route. · internal—Internal route. · external—External route. · local—Locally generated route. · synchronize—Synchronized route. · best—Optimal route. · delay—Delayed route. The route will be delayed for optimal route selection. This value is available only in detailed information of the route. · not preferred for reason—Reason why the route is not selected as the optimal route. For more information, see Table 3. |
IP precedence |
IP precedence of the route, in the range of 0 to 7. N/A indicates that the route does not support this field. |
QoS local ID |
QoS local ID of the route, in the range of 1 to 4095. N/A indicates that the route does not support this field. |
Traffic index |
Traffic index in the range of 1 to 64. N/A indicates that the route does not support this field. |
Type: 15 (SR Policy) |
The tunnel encryption type is 15, which represents SR-TE policy. |
Preference |
Candidate path preference. |
Binding SID |
BSID value |
Path |
Candidate path. |
Weight |
Weight of the SID list. |
SIDs |
List of SIDs. |
Table 3 Reason why the route is not selected as the optimal route
Reason |
preferred-value |
Routes with larger preferred values exist. |
local-preference |
Routes with larger local preference values exist. |
as-path |
Routes with smaller AS_PATH attribute values exist. |
origin |
There are routes whose origin has a higher priority. The route origins are IGP, EGP, and INCOMPLETE in descending order of priority. |
med |
Routes with smaller MED values exist. |
remote-route |
There are routes whose remote-route attribute has a higher priority. BGP selects the optimal route from remote routes in this order: · Route learned from an EBGP peer. · Route learned from a confederation EBGP peer. · Route learned from a confederation IBGP peer. · Route learned from an IBGP peer. |
igp-cost |
Routes with smaller IGP metrics exist. |
relydepth |
Routes with smaller recursion depth values exist. |
rfc5004 |
A route received from an EBGP peer is the current optimal route. BGP does not change the optimal route when it receives routes from other EBGP peers. |
router-id |
Routes with smaller router IDs exist. If one of the routes is advertised by a route reflector, BGP compares the ORIGINATOR_ID of the route with the router IDs of other routes. Then, BGP selects the route with the smallest ID as the optimal route. |
cluster-list |
Routes with smaller CLUSTER_LIST attribute values exist. |
peer-address |
Routes advertised by peers with lower IP addresses exist. |
received |
Earlier learned routes exist. |
# Displays advertisement information about the BGP IPv4 SR-TE policy route [102][2][5.6.7.8]/96.
<Sysname> display bgp routing-table ipv4 sr-policy [102][2][5.6.7.8]/96 advertise-info
Local AS number: 1
Paths: 1 best
BGP routing table information of [102][2][5.6.7.8]/96(TxPathID:0):
Advertised to peers (2 in total):
2.1.1.2
3.3.3.3
Paths |
Number of optimal paths to reach the destination network. |
BGP routing table information of [102][2][5.6.7.8]/96(TxPathID:0) |
Advertisement information about the BGP IPv4 SR-TE policy route [102][2][5.6.7.8]/96. TxPathID represents the advertised Add-Path ID of the route. |
Advertised to peers (2 in total) |
Indicates the peers to which the route has been advertised. The number in the parentheses indicates the total number of the peers. |
# Display statistics about the BGP IPv4 SR-TE policy routes advertised to peer 2.1.1.2.
<Sysname> display bgp routing-table ipv4 sr-policy peer 10.2.1.2 advertised-routes statistics
Advertised routes total: 2
# Display statistics about the BGP IPv4 SR-TE policy routes received from peer 2.1.1.2.
<Sysname> display bgp routing-table ipv4 sr-policy peer 2.1.1.2 received-routes statistics
Received routes total: 1
Table 5 Command output
Advertised routes total |
Total number of routes advertised to the specified peer. |
Received routes total |
Total number of routes received from the specified peer. |
# Display statistics about BGP IPv4 SR-TE policy routes.
<Sysname> display bgp routing-table ipv4 sr-policy statistics
Total number of routes: 3
Use display segment-routing te forwarding to display SR TE forwarding information.
display segment-routing te forwarding [ policy { name policy-name | { color color-value | end-point ipv4 ip-address } * } ] [ verbose ]
policy: Displays SR TE forwarding information of the specified SR-TE policy. If you do not specify an SR-TE policy, this command displays SR TE forwarding information of all SR policies.
name policy-name: Specifies the name of an SR-TE policy, a case-sensitive string of 1 to 59 characters.
color color-value: Specifies the color of an SR-TE policy, in the range of 1 to 4294967295.
end-point ipv4 ip-address: Specifies the endpoint IPv4 address of an SR-TE policy.
verbose: Displays detailed SR TE forwarding information. If you do not specify this keyword, the command displays brief SR TE forwarding information.
To use this command to display SR TE traffic forwarding statistics, make sure SR TE traffic forwarding statistics is enabled.
# Display brief forwarding information of all SR policies.
<Sysname> display segment-routing te forwarding
Total forwarding entries: 1
Policy name/ID: p1/0
Binding SID: 15200
Policy NID: 0x01400001
Main path:
Seglist ID: 1
Seglist NID: 0x01700002
Weight: 50
Outgoing NID: 0x01600003
OutLabels: 3
Interface: GE1/2/0/1
NextHop: 1.2.0.2
Outgoing NID: 0x01600004
OutLabels: 3
Interface: GE1/2/0/2
NextHop: 1.2.1.2
Backup path:
Seglist ID: 1
Seglist NID: 0x01700001
Weight: 100
Outgoing NID: 0x01600001
OutLabels: 3
NextHop: 1.2.0.2
Outgoing NID: 0x01600002
OutLabels: 3
NextHop: 1.2.1.2
# Display detailed forwarding information of all SR policies.
<Sysname> display segment-routing te forwarding verbose
Policy name/ID: 1/0
Binding SID: 15000
Inbound statistics:
Total octets: 1060000
Total packets: 10000
Erroneous packets: 0
Dropped packets: 0
Outbound statistics:
Total octets: 1200000
Dropped packets: 0
Main path:
SegList ID: 1
SegList NID: 0x01700002
Weight: 1
Dropped packets: 0
OutLabels: 3
NextHop: 90.12.0.1
Path ID: 0
Label stack: {3}
Outgoing NID : 0x01600002
OutLabels: 3
NextHop: 90.15.0.1
Path Id: 1
Label stack: {3}
Dropped packets: 0
Backup path:
SegList ID: 1
Seglist NID:0x01700001
Weight:1
OutLabels: 3
NextHop: 90.12.0.1
Path Id: 2
Label stack: {3}
Outgoing NID : 0x01600004
OutLabels: 3
NextHop: 90.15.0.1
Path Id: 3
Label stack: {3}
Table 6 Command output
Binding SID |
Label value of the ingress node. |
Policy NID |
NHLFE entry index of the SR-TE policy. |
Inbound statistics |
Inbound traffic statistics, that is, the traffic statistics about the BSID. |
Total octets |
Total number of forwarded bytes. |
Total packets |
Total number of forwarded packets. |
Erroneous packets |
Number of erroneous packets. |
Dropped packets |
Number of dropped packets. |
Main path |
Main traffic forwarding path. |
Backup path |
Backup traffic forwarding path. |
Seglist ID |
SID list ID. |
Seglist NID |
NHLFE entry index of the SID list. |
OutLabel |
Outgoing label value. |
Brief name of the outgoing interface. |
Nexthop |
Nexthop IP address. |
Path ID |
ID of the SR-TE policy candidate path |
Weight |
Weight of the path. |
Label stack |
Stack of labels from top to bottom. |
Outbound statistics |
Outbound traffic statistics, that is, the traffic statistics about the NID. |
Use display segment-routing te policy to display SR-TE policy information.
display segment-routing te policy [ name policy-name | down | up | { color color-value | end-point ipv4 ip-address } * ]
name policy-name: Specifies an SR-TE policy by its name, a case-sensitive string of 1 to 59 characters.
down: Specifies the SR policies in down state.
up: Specifies the SR policies in up state.
If you do not specify any parameters, this command displays information about all SR policies.
# Display information about all SR policies.
<Sysname> display segment-routing te policy
Name/ID: abc/0
Color: 10
Endpoint: 4.4.4.4
Name from BGP: abc
BSID:
Mode: Explicit Type: Type 1 Request state: Succeeded
Current BSID: 15000 Explicit BSID: 15000 Dynamic BSID: -
Reference counts: 3
Flags: A/BS/NC
Status: Up
Up time: 2019-10-25 11:16:15
Down time: 2019-10-25 11:16:00
Hot-standby: Not configured
BFD: Not configured
PolicyNid: 20971521
Candidate paths state: Configured
Candidate paths statistics:
CLI paths: 1 BGP paths: 0 PCEP paths: 0
Candidate paths:
Preference : 10
CPathName: abc
Instance ID: 0 ASN: 0 Node address: 0.0.0.0
Peer address: 0.0.0.0
Optimal: Y Flags: V/A
Explict SID list:
ID: 1 Name: abc
Weight: 1 NID: 24117249
State: Up BFD state: Path inactive
Table 7 Command output
Name/ID |
SR-TE policy name/ID. |
Color |
Color attribute of the SR-TE policy. A value of 0 means that the color attribute is not configured. |
Endpoint |
Endpoint IP address of the SR-TE policy. If the endpoint is not configured, this field displays None. |
Name from BGP |
SR-TE policy name obtained through BGP. The SR-TE policy name is not displayed if it is not obtained. |
BSID |
SID value of the ingress node. |
Mode |
BSID configuration mode: · Explicit—Manually configured. · Dynamic—Dynamically requested. · None—Not configured. |
Type |
BSID type: · None—Not configured. · TYPE_1—MPLS label. |
Request state |
BSID request state: · Failed. · Succeeded. |
Explicit BSID |
Manually configured BSID. |
Dynamic BSID |
Dynamically requested BSID. If the BSID is not dynamically requested, this field displays a hyphen (-). |
Reference counts |
Number of times that the SR-TE policy has been referenced. |
Flags |
SR-TE policy flags: · A—Active SR-TE policy. · C—Optimal SR-TE policy. · N—In optimal SR-TE policy selection progress. · BA—Requesting BSID. · BS—Selecting optimal BSID. · D—Deleted SR-TE policy. · CF—Conflicted with an existing BSID. · NC—Manually configured SR-TE policy. · NB—SR-TE policy obtained from a BGP route. · W—The number of SR-TE policies has exceeded the maximum capacity. |
Status |
SR-TE policy status: · Up—Active state. · Down—Inactive state. |
Up time |
Time when the SR-TE policy came up. |
Down time |
Time when the SR-TE policy went down. |
Hot-standby |
Status of the hot standby feature: Enabled, Disabled, or Not configured. |
BFD |
Status of the SBFD feature: Enabled, Disabled, or Not configured. |
PolicyNid |
Candidate paths status |
Whether candidate paths are configured: · Configured. · Not configured. |
Candidate paths statistics |
Number of candidate paths. |
CLI paths |
Number of manually configured candidate paths. |
BGP paths |
Number of candidate paths obtained through BGP SR policy routes. |
PCEP paths |
This field is not supported in the current software version. Number of candidate paths obtained through Path Computation Element Protocol (PCEP). |
Candidate paths |
SR-TE policy candidate path information. |
Preference |
SR-TE policy candidate path preference. |
CPathName |
Name of the candidate path obtained through BGP routes. This field displays N/A if the candidate path name is not obtained. |
Instance ID |
BGP instance ID. A value of 0 indicates that the device does not obtain SR-TE policy information from BGP peers. |
ASN |
AS number. A value of 0 indicates that the device does not obtain SR-TE policy information from BGP peers. |
Node address |
BGP node address. For a manually configured SR-TE policy, the node address is 0.0.0.0. For an SR-TE policy obtained from a BGP peer, the node address is the Router ID of the BGP peer. |
Peer address |
BGP peer address. For a manually configured SR-TE policy, the peer address is 0.0.0.0. For an SR-TE policy obtained from a BGP peer, the peer address is the address of the BGP peer. |
Optimal |
Whether the path is the optimal path: · Y—Yes. · N—No. |
Flags |
Flags of the SR-TE policy candidate path: · V—Valid candidate path. · A—Active candidate path. · None—No candidate path. |
Explict SID list |
Explicit SID list in the candidate path of the SR-TE policy. |
ID |
SID list index. |
Name |
SID list name. |
Weight |
Weight of the SID list in the candidate path. |
NID |
State |
SID list state: Up or Down. |
BFD state |
SBFD state of the SID list: · Up—The SBFD session is up. · Down—The SBFD session is down. · Path inactive—No SID list is available in the candidate path. · Unknown—The SBFD detection result is unknown. |
Use display segment-routing te policy statistics to display SR-TE policy statistics.
# Display SR-TE policy statistics.
<Sysname> display segment-routing te policy statistics
Total policies: 4 (2 up 2 down)
Configured: 2
From BGP: 2 (Added 2, deleted 0)
Total candidate paths: 6
Configured: 3
From BGP: 3 (Added 3, delete 0)
Total SID lists: 6
Configured: 3
From BGP: 3
Table 8 Command output
Total policies |
Total number of SR policies: · up—Number of SR policies in up state. · down—Number of SR policies in down state. |
Configured |
Number of manually configured SR policies. |
From BGP |
Number of SR policies learned through BGP. · Added—Number of BGP-added SR policies. · deleted—Number of BGP-deleted SR policies. |
Total candidate paths |
Total number of SR-TE policy candidate paths. |
Total SID lists |
Total number of SID lists. |
Use display segment-routing te policy-group to display SR-TE policy group information.
display segment-routing te policy-group [ group-id ] [ verbose ]
group-id: Specifies an SR-TE policy group by its ID in the range of 1 to 4294967295. If you do not specify this argument, the command displays information about all SR-TE policy groups.
verbose: Displays detailed SR-TE policy group information. If you do not specify this keyword, the command displays brief SR-TE policy group information.
# Display brief information about all SR-TE policy groups.
<Sysname> display segment-routing te policy-group
Total number of policy groups: 3
GroupID GroupState Endpoint UPMappings TotalMappings
1 Up 1.1.1.1 1 1
2 Up 2.2.2.2 1 1
3 Up 3.3.3.3 1 1
# Display detailed information about all SR-TE policy groups.
<Sysname> display segment-routing te policy-group verbose
Total number of policy groups: 1
GroupID: 1 GroupState: Down
GroupNID: 25165825 Referenced: 1
Flags: None
Endpoint: 1.1.1.1 Up/Total mappings: 0/30
Color Type DSCP
1 IPv4 3, 10~20, default
2 IPv4 30, 40, 60
1 IPv6 3, 10~20, default
2 IPv6 30, 40, 60
Table 9 Command output
Total number of policy groups |
Total number of SR-TE policy groups. |
GroupID |
SR-TE policy group ID. |
GroupState |
SR-TE policy group state: Down or Up. |
GroupNID |
NHLFE entry index of the SR-TE policy group. |
Referenced |
Number of times the SR-TE policy group has been used. |
Flags |
SR-TE policy group flags: · A—Assign the NHLFE entry index of the SR-TE policy group. · F—Issue the NHLFE entry of the SR-TE policy group. · W—Waiting for assigning the NHLFE entry index of the SR-TE policy group. · D—Delete the SR-TE policy group. · None—The SR-TE policy group is in initial state. |
Endpoint |
Destination node IP address of the SR-TE policy group. None indicates not configured. |
UPMappings |
Number of valid color-to-DSCP mappings in the SR-TE policy group. |
TotalMappings |
Total number of color-to-DSCP mappings in the SR-TE policy group. |
Up/Total mappings |
Valid color-to-DSCP mappings/total number of color-to-DSCP mappings in the SR-TE policy group. |
Color |
Color value |
Type |
Packet type: IPv4 or IPv6. |
DSCP |
DSCP value. |
Use display segment-routing te segment-list to display SR-TE SID list information.
display segment-routing te segment-list [ name segment-list-name | id id-value ]
name segment-list-name: Specifies a SID list by its name, a case-sensitive string of 1 to 128 characters.
id id-value: Specifies a SID list by its ID. The value range for the SID list ID is 1 to 4294967295.
If you do not specify a SID list name or ID, this command displays information about all SR-TE SID lists.
To view SID list ID information, execute the display segment-routing te policy command.
# Display information about all SR-TE SID lists.
<Sysname> display segment-routing te segment-list
Total SID lists: 1
Name/ID: abc/1
Origin : CLI
Status : Up
Nodes : 2
Index: 10 Label: 17401
Type : TYPE_1 Flags: None
Index: 20 Label: 18101
Table 10 Command output
Total SID lists |
Number of SID lists. |
Name/ID |
SID list name/ID. |
Origin |
Origin of the SID list. Options include: · CLI—Locally configured in the CLI. · BGP—Issued by BGP. · PCE—Issued by a PCE. (This option is not supported in the current software version.) If the SID list does not have a valid origin, this field displays a hyphen (-). |
Status |
SID list status, Down or Up. |
Nodes |
Number of nodes in the SID list. |
Index |
Node index. |
Label |
Label value of the node. |
Type |
Label type of the node: · None—No label is configured. · TYPE_1—MPLS label. |
Flags |
Node flags, which are not defined and displayed as None. |
end-point
Use end-point to configure the endpoint IP address for the SR-TE policy group.
Use undo end-point to delete the endpoint IP address of the SR-TE policy group.
undo end-point ipv4
No endpoint IP address is configured for the SR-TE policy group.
ipv4 ipv4-address: Specifies the endpoint IP address for the SR-TE policy group.
The SR-TE policies added to the SR-TE policy group must use the same endpoint IP address as the SR-TE policy group.
# Configure the endpoint IP address as 10.1.1.1 for SR-TE policy group 1.
[Sysname] segment-grouting
[Sysname-segment-grouting] traffic-engineering
[Sysname-sr-te-policy-group-1] end-point ipv4 10.1.1.1
explicit segment-list
Use explicit segment-list to specify an SID list for a candidate path.
Use undo explicit segment-list to delete an SID list of a candidate path.
explicit segment-list segment-list-name [ weight weight-value ]
undo explicit segment-list segment-list-name [ weight ]
No SID lists are specified for an SR-TE policy candidate path.
Candidate path preference view
segment-list-name: Specifies an SID list name, a string of 1 to 128 characters.
weight weight-value: Specifies a weight for the SID list, in the range of 1 to 4294967295. The default weight is 1.
An SR-TE policy uses the SID list specified for the highest-preference candidate path as a traffic forwarding subpath.
An SR-TE policy candidate path can have multiple SID lists. All the SID lists can be used to forward traffic for load sharing based on their weights. Assume SID lists a, b, and c are assigned weights x, y, z, respectively. The load of SID list a is x/(x+y+z) of the total traffic.
If you assign weight values for the same SID list multiple times, the most recent configuration takes effect.
# Configure SID list abc for the SR-TE policy candidate path with preference 20, and the set the SID list weight to 20.
[Sysname-sr-te] policy a1
[Sysname-sr-te-policy-a1] candidate-paths
[Sysname-sr-te-policy-a1-path] preference 20
[Sysname-sr-te-policy-a1-path-pref20] explicit segment-list abc weight 20
segment-list
forwarding statistics enable
Use forwarding statistics enable to enable SR TE forwarding statistics.
Use undo forwarding statistics enable to disable SR TE forwarding statistics.
SR TE forwarding statistics is disabled.
SR TE view
# Enable SR TE forwarding statistics.
[Sysname-sr-te] forwarding statistics enable
Use forwarding statistics interval to set the SR TE forwarding statistics interval.
Use undo forwarding statistics interval to restore the default.
forwarding statistics interval interval
The SR TE forwarding statistics interval is 30 seconds.
SR TE view
Interval: Sets the SR TE forwarding statistics interval, in the range of 5 to 65535 seconds.
# Set the SR TE forwarding statistics interval to 90 seconds.
[Sysname-sr-te] forwarding statistics interval 90
import-route
Use import-route sr-policy to enable BGP to redistribute routes from the SR-TE policy.
Use undo import-route sr-policy to restore the default.
BGP does not redistribute SR-TE policy routes.
After you execute this command, the system will redistribute the local SR-TE policy routes to the BGP routing table and advertise the routes to peers. Then, the peers can forward traffic based on the SR-TE policy.
# In BGP SR-TE policy address family view, enable BGP to redistribute routes from the SR-TE policy.
[Sysname] bgp 100
[Sysname-bgp-default-srpolicy-ipv4] import-route sr-policy
index
Use index to add a node to a SID list.
Use undo index to delete a node from a SID list.
index index-number mpls label label-value
undo index index-number
No nodes exist in a SID list.
SID list view
index-number: Specifies the node index, in the range of 1 to 65535.
mpls label label-value: Specifies the MPLS label value of the node, in the range of 0, 3, and 16 to 1048575.
# Add a node to SID list abc, and set the node index to 1 and MPLS label to 1000.
[Sysname-sr-te] segment-list abc
[Sysname-sr-te-sl-abc] index 1 mpls label 1000
policy
Use policy to create an SR-TE policy and enter its view, or enter the view of an existing SR-TE policy.
Use undo policy to delete an SR-TE policy and all the configuration in the SR-TE policy.
policy policy-name
undo policy policy-name
No SR policies exist.
SR TE view
policy-name: Specifies an SR-TE policy name, a case-sensitive string of 1 to 59 characters.
# Create an SR-TE policy named srpolicy and enter its view.
policy-group
Use policy-group to create an SR-TE policy group and enter its view, or enter the view of an existing SR-TE policy group.
Use undo policy-group to delete an SR-TE policy group and all the configuration in the SR-TE policy group.
policy-group group-id
undo policy-group group-id
No SR-TE policy groups exist.
SR TE view
group-name: Specifies an SR-TE policy group by its ID in the range of 1 to 4294967295.
You can add SR-TE policies to an SR-TE policy group to implement SR-TE policy based forwarding according to DSCP values of packets.
# Create SR-TE policy group 1 and enter its view.
preference
Use preference to set the preference for a candidate path and enter candidate path preference view, or enter an existing candidate path preference view.
Use undo preference to delete a candidate path preference and all the configuration in the candidate path preference view.
preference preferenc-value
undo preference preferenc-value
No candidate path preferences are set.
Candidate path view
preferenc-value: Specifies a candidate path preference in the range of 1 to 65535. A bigger value represents a higher preference.
A preference represents a candidate path of an SR-TE policy.
# Set the preference of an SR-TE policy candidate path to 20, and enter candidate path preference view.
Use reset segment-routing te forwarding statistics to clear SR TE forwarding statistics.
# Clear SR TE forwarding statistics.
<Sysname> reset segment-routing te forwarding statistics
router-id filter
Use router-id filter to enable SR-TE policy route filtering by router ID.
Use undo router-id filter to disable SR-TE policy route filtering by router ID.
router-id filter
SR-TE policy route filtering by router ID is disabled.
When a large number of SR-TE policy routes exist in the network, execute this command to enable the device to process only specific SR-TE policy routes.
Upon receiving SR-TE policy routes, the device checks the Route Target (RT) attribute in received SR-TE policy routes. Only the routes containing the local router ID in the RT attribute are accepted.
To avoid incorrect route learning or filtering, configure a routing policy to add an appropriate RT attribute to SR-TE policy routes before executing this command.
# Enable SR-TE policy route filtering by router ID.
[Sysname] bgp 100
[Sysname-bgp-default-srpolicy-ipv4] router-id filter
sbfd
Use sbfd to configure SBFD for an SR-TE policy.
Use undo sbfd to restore the default.
sbfd { disable | enable }
undo sbfd
SBFD is disabled for an SR-TE policy.
SR-TE policy view
disable: Disables SBFD for the SR-TE policy.
enable: Enables SBFD for the SR-TE policy.
This command enables an SR-TE policy to use SBFD to detect availability of SID lists. If all SID lists for the current candidate path are faulty, another candidate path takes over to minimize service interruption.
You can enable SBFD for all SR-TE policies globally in SR TE view or for a specific SR-TE policy in SR-TE policy view. The policy-specific configuration takes precedence over the global configuration. An SR-TE policy uses the global configuration only when it has no policy-specific configuration.
# Enable SBFD for SR-TE policy 1.
[Sysname-sr-te-policy-1] sbfd enable
sr-policy sbfd enable
segment-list
Use segment-list to create a SID list and enter its view, or enter the view of an existing SID list.
Use undo segment-list to delete a SID list and all the configuration in the SID list.
undo segment-list segment-list-name
No SID lists exist.
SR TE view
segment-list-name: Specifies the SID list name, a case-sensitive string of 1 to 128 characters.
# Create a SID list named abc and enter its view.
Use sr-policy backup hot-standby enable to enable hot standby for all SR-TE policies.
Use undo sr-policy backup hot-standby enable to disable hot standby for all SR-TE policies.
Hot standby is disabled for all SR-TE policies.
SR TE view
# Enable hot standby for all SR-TE policies.
[Sysname-sr-te] sr-policy backup hot-standby enable
backup hot-standby
Use sr-policy sbfd enable to enable SBFD for all SR-TE policies.
Use undo sr-policy sbfd enable to disable SBFD for all SR-TE policies.
SBFD is disabled for all SR-TE policies.
SR TE view
This command enables SR-TE policies to use SBFD to detect availability of SID lists. If all SID lists for the current candidate path are faulty, another candidate path takes over to minimize service interruption.
# Enable SBFD for all SR-TE policies.
[Sysname-sr-te] sr-policy sbfd enable
sbfd
sr-policy sbfd timer
Use sr-policy sbfd timer to configure SBFD detection timer parameters.
Use undo sr-policy sbfd timer to delete SBFD detection timer parameters.
sr-policy sbfd timer { detect-multiplier multiplier-value | min-transmit-interval transmit-interval }
undo sr-policy sbfd timer { detect-multiplier | min-transmit-interval }
The SBFD detection time multiplier is 5, and the minimum SBFD packet transmission interval is 10 milliseconds.
SR TE view
detect-multiplier multiplier-value: Specifies the SBFD detection time multiplier, in the range of 3 to 50.
min-transmit-interval transmit-interval: Specifies the minimum SBFD packet transmission interval, in the range of 3 to 10000 milliseconds.
Set the minimum SBFD packet transmission interval to prevent the SBFD control packet sending rate from exceeding the device capability. The actual SBFD control packet transmitting interval is the set minimum interval.
The detection time multiplier determines the maximum number of SBFD control packets that an initiator can discard continuously. The detection time is the detection time multiplier of the initiator multiplied by the minimum SBFD packet transmission interval of the initiator.
# Set the minimum SBFD packet transmission interval to 100 milliseconds.
[Sysname-sr-te] sr-policy sbfd timer min-transmit-interval 100
sr-policy steering
Use sr-policy steering to configure the traffic steering mode for SR-TE policies.
Use undo sr-policy steering to restore the default.
sr-policy steering [ disable | policy-based ]
The device steers data packets to SR-TE policies based on colors of the packets.
BGP instance view
disable: Disables traffic steering to SR-TE policies.
policy-based: Steers traffic to an SR-TE policy based on the tunnel policy.
The following traffic steering modes are available for SR-TE policies:
· Based on color—The device searches for an SR-TE policy whose color and endpoint address match the color and nexthop address of a BGP route. If a matching SR-TE policy exists, the device recurses the BGP route to that SR-TE policy. Then, when the device receives packets that match the BGP route, it forwards the packets through the SR-TE policy.
· Based on tunnel policy—On the ingress PE of an MPLS L3VPN or EVPN L3VPN network, configure a preferred tunnel or load sharing tunnel policy that uses the SR-TE policy. In this way, the SR-TE policy will be used as the public tunnel to carry the packets of a VPN instance. For more information about the tunnel policy configuration, see MPLS Configuration Guide.
# Configure the SR-TE traffic steering mode as tunnel policy.
[Sysname] bgp 100
[Sysname-bgp-default] sr-policy steering policy-based
traffic-engineering
Use traffic-engineering to create and enter the SR TE view, or enter the existing SR TE view.
Use undo traffic-engineering to delete the SR TE view and all the configuration in the view.
traffic-engineering
The SR TE view does not exist.
Segment routing view
# Create and enter the SR TE view.
[Sysname-sr-te]
