| 04-QinQ commands | 50.82 KB |
QinQ commands
This document uses the following terms:
· CVLAN—Customer network VLANs, also called inner VLANs, refer to VLANs that a customer uses on the private network.
· SVLAN—Service provider network VLANs, also called outer VLANs, refer to VLANs that a service provider uses to transmit VLAN tagged traffic for customers.
display qinq
Use display qinq to display QinQ-enabled interfaces.
display qinq [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays all QinQ-enabled interfaces.
If QinQ is not enabled on any interfaces, this command does not provide any output.
# Enable QinQ on GigabitEthernet 1/2/0/1. Then, verify that QinQ is enabled on the interface.
[Sysname] interface gigabitethernet 1/2/0/1
[Sysname-GigabitEthernet1/2/0/1] qinq enable
[Sysname-GigabitEthernet1/2/0/1] display qinq interface gigabitethernet 1/2/0/1
# Enable QinQ on GigabitEthernet 1/2/0/1 and GigabitEthernet 1/2/0/3. Then, verify that QinQ is enabled on the interfaces.
[Sysname-GigabitEthernet1/2/0/1] quit
[Sysname] interface gigabitethernet 1/2/0/3
[Sysname-GigabitEthernet1/2/0/3] qinq enable
[Sysname-GigabitEthernet1/2/0/3] display qinq
qinq enable
qinq enable
Use qinq enable to enable QinQ on an interface.
Use undo qinq enable to disable QinQ on an interface.
qinq enable
undo qinq enable
QinQ is disabled on interfaces.
display qinq
qinq ethernet-type (interface view)
Use qinq ethernet-type to set the TPID value in SVLAN tags on an interface.
Use undo qinq ethernet-type to restore the default TPID value in SVLAN tags on an interface.
qinq ethernet-type service-tag hex-value
undo qinq ethernet-type service-tag
If the device supports global TPID configuration, the interface-level TPID value in SVLAN tags equals the global TPID value.
If the device does not support global TPID configuration, the TPID value in both SVLAN tags is 8100 in hexadecimal notation.
service-tag: Sets the TPID value in the SVLAN tag.
hex-value: Sets a hexadecimal TPID value in the range of 1 to ffff, excluding the reserved EtherType values listed in Table 1.
Table 1 Reserved EtherType values
Protocol type |
Value |
ARP |
0x0806 |
PUP |
0x0200 |
RARP |
0x8035 |
IP |
0x0800 |
IPv6 |
0x86dd |
PPPoE |
0x8863/0x8864 |
MPLS |
0x8847/0x8848 |
IPX/SPX |
0x8137 |
IS-IS |
0x8000 |
LACP |
0x8809 |
LLDP |
0x88cc |
802.1X |
0x888e |
802.1ag |
0x8902 |
Cluster |
0x88a7 |
Reserved |
0xfffd/0xfffe/0xffff |
For a port, the TPID value set in interface view applies preferentially over the TPID value set in system view. You can set the TPID value only to 8100 or 9100 in hexadecimal notation.
# Set the TPID value in the SVLAN tags to 9100 (hexadecimal) on GigabitEthernet 1/2/0/1.
[Sysname-GigabitEthernet1/2/0/1] qinq ethernet-type service-tag 9100
qinq ethernet-type (system view)
