00-Preface | 81.80 KB |
Preface
This deployment guide describes the fundamentals of VM deployment on the H3C MSR3610-I iMC EAD End-user Admission Defense Gateway, including the VM login method, network configuration, and service data interaction modes. It also covers the following information:
· How to deploy the EAD gateway.
· How to configure RAID on the EAD gateway.
· How to manage and configure the VM and display VM information on the EAD gateway.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
