05-Layer 3-IP Routing Configuration Guide
HomeSupportResource CenterSwitchesH3C S6860 Switch SeriesH3C S6860 Switch SeriesTechnical DocumentsConfigureConfiguration GuidesH3C S6860 Switch Series Configuration Guide-Release 26xx-6W10205-Layer 3-IP Routing Configuration Guide
08-IPv6 static routing configuration
08-IPv6 static routing configuration 131.93 KB
Configuring IPv6 static routing
Static routes are manually configured and cannot adapt to network topology changes. If a fault or a topological change occurs in the network, the network administrator must modify the static routes manually. IPv6 static routing works well in a simple IPv6 network.
Configuring an IPv6 static route
Before you configure an IPv6 static route, complete the following tasks:
·     Configure parameters for the related interfaces.
·     Configure link layer attributes for the related interfaces.
·     Make sure the neighboring nodes can reach each other.
To configure an IPv6 static route:
Step
Remarks
N/A
2.     Configure an IPv6 static route.
·     Method 1:
ipv6 route-static ipv6-address prefix-length { interface-type interface-number [ next-hop-address ] | next-hop-address | vpn-instance d-vpn-instance-name next-hop-address } [ permanent ] [ preference preference ] [ tag tag-value ] [ description text ]
·     Method 2:
ipv6 route-static
vpn-instance s-vpn-instance-name ipv6-address prefix-length { interface-type interface-number [ next-hop-address ] | next-hop-address [ public ] | vpn-instance d-vpn-instance-name next-hop-address } [ permanent ] [ preference preference ] [ tag tag-value ] [ description text ]
By default, no IPv6 static route is configured.
3.     (Optional.) Set the default preference for IPv6 static routes.
ipv6 route-static default-preference default-preference
The default setting is 60.
4.     (Optional.) Delete all IPv6 static routes, including the default route.
delete ipv6 [ vpn-instance vpn-instance-name ] static-routes all
The undo ipv6 route-static command deletes one IPv6 static route.
Configuring BFD for IPv6 static routes
BFD provides a general purpose, standard, and medium- and protocol-independent fast failure detection mechanism. It can uniformly and quickly detect the failures of the bidirectional forwarding paths between two routers for protocols, such as routing protocols. For more information about BFD, see High Availability Configuration Guide.
IMPORTANT
IMPORTANT:
Enabling BFD for a flapping route could worsen the situation.
Bidirectional control mode
To use BFD bidirectional control detection between two devices, enable BFD control mode for each device's static route destined to the peer.
To configure a static route and enable BFD control mode, use one of the following methods:
·     Specify an output interface and a direct next hop.
·     Specify an indirect next hop and a BFD packet source address for the static route.
To configure BFD control mode for an IPv6 static route (direct next hop):
Step
Remarks
N/A
2.     Configure BFD control mode for an IPv6 static route.
ipv6 route-static [ vpn-instance s-vpn-instance-name ] ipv6-address prefix-length interface-type interface-number next-hop-address bfd control-packet [ bfd-source ipv6-address ] [ preference preference ] [ tag tag-value ] [ description text ]
By default, BFD control mode for an IPv6 static route is not configured.
To configure BFD control mode for an IPv6 static route (indirect next hop):
Step
Remarks
N/A
ipv6 route-static [ vpn-instance s-vpn-instance-name ] ipv6-address prefix-length [ vpn-instance d-vpn-instance-name ] { next-hop-address bfd control-packet bfd-source ipv6-address } [ preference preference ] [ tag tag-value ] [ description text ]
Single-hop echo mode
With BFD echo mode enabled for a static route, the output interface sends BFD echo packets to the destination device, which loops the packets back to test the link reachability.
IMPORTANT
IMPORTANT:
Do not use BFD for a static route with the output interface in spoofing state.
To configure BFD echo mode for an IPv6 static route:
Step
Remarks
N/A
2.     Configure the source address of echo packets.
By default, the source address of echo packets is not configured.
The source address of echo packets must be a global unicast address.
For more information about this command, see High Availability Command Reference.
3.     Configure BFD echo mode for an IPv6 static route.
ipv6 route-static [ vpn-instance s-vpn-instance-name ] ipv6-address prefix-length interface-type interface-number next-hop-address bfd echo-packet [ bfd-source ipv6-address ] [ preference preference ] [ tag tag-value ] [ description text ]
By default, BFD echo mode for an IPv6 static route is not configured.
The next hop IPv6 address must be a global unicast address.
Displaying and maintaining IPv6 static routes
Display IPv6 static route information.
display ipv6 routing-table protocol static [ inactive | verbose ]
Display IPv6 static route next hop information.
display ipv6 route-static nib [ nib-id ] [ verbose ]
Display IPv6 static routing table information.
display ipv6 route-static routing-table [ vpn-instance vpn-instance-name ] [ ipv6-address prefix-length ]
IPv6 static routing configuration examples
Basic IPv6 static route configuration example
Network requirements
As shown in Figure 1, configure IPv6 static routes so that hosts can reach one another.
Figure 1 Network diagram
Configuration procedure
1.     Configure the IPv6 addresses for all VLAN interfaces. (Details not shown.)
2.     Configure IPv6 static routes:
# Configure a default IPv6 static route on Switch A.
[SwitchA] ipv6 route-static :: 0 4::2
# Configure two IPv6 static routes on Switch B.
[SwitchB] ipv6 route-static 1:: 64 4::1
[SwitchB] ipv6 route-static 3:: 64 5::1
# Configure a default IPv6 static route on Switch C.
[SwitchC] ipv6 route-static :: 0 5::2
3.     Configure the IPv6 addresses for all the hosts and configure the default gateway of Host A, Host B, and Host C as 1::1, 2::1, and 3::1.
# Display the IPv6 static route information on Switch A.
[SwitchA] display ipv6 routing-table protocol static
Summary Count : 1
Static Routing table Status : <Active>
Summary Count : 1
Destination: ::                                          Protocol  : Static
NextHop    : 4::2                                        Preference: 60
Interface  : Vlan-interface200                           Cost      : 0
Static Routing table Status : <Inactive>
Summary Count : 0
# Display the IPv6 static route information on Switch B.
[SwitchB] display ipv6 routing-table protocol static
Summary Count : 2
Summary Count : 2
Destination: 1::/64                                      Protocol  : Static
NextHop    : 4::1                                        Preference: 60
Destination: 3::/64                                      Protocol  : Static
NextHop    : 5::1                                        Preference: 60
Interface  : Vlan-interface300                           Cost      : 0
Summary Count : 0
# Use the ping command to test the reachability.
[SwitchA] ping ipv6 3::1
Ping6(56 data bytes) 4::1 --> 3::1, press CTRL_C to break
56 bytes from 3::1, icmp_seq=0 hlim=62 time=0.700 ms
56 bytes from 3::1, icmp_seq=1 hlim=62 time=0.351 ms
56 bytes from 3::1, icmp_seq=2 hlim=62 time=0.338 ms
56 bytes from 3::1, icmp_seq=3 hlim=62 time=0.373 ms
56 bytes from 3::1, icmp_seq=4 hlim=62 time=0.316 ms
--- Ping6 statistics for 3::1 ---
round-trip min/avg/max/std-dev = 0.316/0.416/0.700/0.143 ms
BFD for IPv6 static routes configuration example (direct next hop)
As shown in Figure 2:
·     Configure an IPv6 static route to subnet 120::/64 on Switch A.
·     Configure an IPv6 static route to subnet 121::/64 on Switch B.
·     Enable BFD for both routes.
·     Configure an IPv6 static route to subnet 120::/64 and an IPv6 static route to subnet 121::/64 on Switch C.
When the link between Switch A and Switch B through the Layer 2 switch fails, BFD can detect the failure immediately, and Switch A and Switch B can communicate through Switch C.
Figure 2 Network diagram
Device
IPv6 address
Switch A
Vlan-int10
12::1/64
Switch A
Vlan-int11
10::102/64
Switch B
Vlan-int10
12::2/64
Switch B
Vlan-int13
13::1/64
Switch C
Vlan-int11
10::100/64
Switch C
Vlan-int13
13::2/64
1.     Configure IPv6 addresses for interfaces. (Details not shown.)
2.     Configure IPv6 static routes and BFD:
# Configure IPv6 static routes on Switch A and enable BFD control mode for the static route that traverses the Layer 2 switch.
[SwitchA-vlan-interface10] bfd min-transmit-interval 500
[SwitchA-vlan-interface10] bfd min-receive-interval 500
[SwitchA-vlan-interface10] bfd detect-multiplier 9
[SwitchA-vlan-interface10] quit
[SwitchA] ipv6 route-static 120:: 64 vlan-interface 10 12::2 bfd control-packet
[SwitchA] ipv6 route-static 120:: 64 10::100 preference 65
[SwitchA] quit
# Configure IPv6 static routes on Switch B and enable BFD control mode for the static route that traverses the Layer 2 switch.
[SwitchB-vlan-interface10] bfd min-transmit-interval 500
[SwitchB-vlan-interface10] bfd min-receive-interval 500
[SwitchB-vlan-interface10] bfd detect-multiplier 9
[SwitchB-vlan-interface10] quit
[SwitchB] ipv6 route-static 121:: 64 vlan-interface 10 12::1 bfd control-packet
[SwitchB] ipv6 route-static 121:: 64 vlan-interface 13 13::2 preference 65
[SwitchB] quit
# Configure IPv6 static routes on Switch C.
[SwitchC] ipv6 route-static 120:: 64 13::1
[SwitchC] ipv6 route-static 121:: 64 10::102
# Display the BFD sessions on Switch A.
<SwitchA> display bfd session
 IPv6 Session Working Under Ctrl Mode:
       Local Discr: 513                 Remote Discr: 33
         Source IP: 12::1
    Destination IP: 12::2
     Session State: Up                      Interface: Vlan10
         Hold Time: 2012ms
The output shows that the BFD session has been created.
# Display IPv6 static routes on Switch A.
<SwitchA> display ipv6 routing-table protocol static
Summary Count : 1
Summary Count : 1
Destination: 120::/64                                    Protocol  : Static
NextHop    : 12::2                                       Preference: 60
Interface  : Vlan10                                      Cost      : 0
Direct Routing table Status : <Inactive>
Summary Count : 0
The output shows that Switch A communicates with Switch B through VLAN-interface 10. The link over VLAN-interface 10 fails.
# Display IPv6 static routes on Switch A again.
Summary Count : 1
Summary Count : 1
NextHop    : 10::100                                     Preference: 65
Interface  : Vlan11                                      Cost      : 0
Static Routing table Status : < Inactive>
Summary Count : 0
The output shows that Switch A communicates with Switch B through VLAN-interface 11.
BFD for IPv6 static routes configuration example (indirect next hop)
As shown in Figure 3:
·     Switch A has a route to interface Loopback 1 (2::9/128) on Switch B, and the output interface is VLAN-interface 10.
·     Switch B has a route to interface Loopback 1 (1::9/128) on Switch A, and the output interface is VLAN-interface 12.
·     Switch D has a route to 1::9/128, and the output interface is VLAN-interface 10. It also has a route to 2::9/128, and the output interface is VLAN-interface 12.
Configure the following:
·     Configure an IPv6 static route to subnet 120::/64 and an IPv6 static route to subnet 121::/64 on both Switch C and Switch D.
When the link between Switch A and Switch B through Switch D fails, BFD can detect the failure immediately and Switch A and Switch B can communicate through Switch C.
Figure 3 Network diagram
Device
IPv6 address
Switch A
Vlan-int10
12::1/64
Switch A
Vlan-int11
10::102/64
Switch A
Loop1
1::9/128
Switch B
Vlan-int12
11::2/64
Switch B
Vlan-int13
13::1/64
Switch B
Loop1
2::9/128
Switch C
Vlan-int11
10::100/64
Switch C
Vlan-int13
13::2/64
Switch D
Vlan-int10
12::2/64
Switch D
Vlan-int12
11::1/64
# Configure IPv6 static routes on Switch A and enable BFD control packet mode for the IPv6 static route that traverses Switch D.
[SwitchA] bfd multi-hop min-transmit-interval 500
[SwitchA] bfd multi-hop min-receive-interval 500
[SwitchA] bfd multi-hop detect-multiplier 9
[SwitchA] ipv6 route-static 120:: 64 2::9 bfd control-packet bfd-source 1::9
[SwitchA] ipv6 route-static 2::9 128 12::2
[SwitchA] quit
# Configure IPv6 static routes on Switch B and enable BFD control packet mode for the static route that traverses Switch D.
[SwitchB] bfd multi-hop min-transmit-interval 500
[SwitchB] bfd multi-hop min-receive-interval 500
[SwitchB] bfd multi-hop detect-multiplier 9
[SwitchB] ipv6 route-static 121:: 64 1::9 bfd control-packet bfd-source 2::9
[SwitchB] ipv6 route-static 121:: 64 13::2 preference 65
[SwitchB] ipv6 route-static 1::9 128 11::1
[SwitchB] quit
# Configure IPv6 static routes on Switch D.
<SwitchD> system-view
[SwitchD] ipv6 route-static 120:: 64 11::2
[SwitchD] ipv6 route-static 121:: 64 12::1
[SwitchD] ipv6 route-static 2::9 128 11::2
[SwitchD] ipv6 route-static 1::9 128 12::1
         Source IP: 1::9
    Destination IP: 2::9
     Session State: Up                      Interface: N/A
         Hold Time: 2012ms
# Display the IPv6 static routes on Switch A.
Summary Count : 1
Summary Count : 1
NextHop    : 2::9                                        Preference: 60
Summary Count : 0
The output shows that Switch A communicates Switch B through VLAN-interface 10. The link over VLAN-interface 10 fails.
Summary Count : 1
Summary Count : 1
Summary Count : 0
Configuring an IPv6 default route
A default IPv6 route is used to forward packets that match no entry in the routing table.
A default IPv6 route can be configured in either of the following ways:
·     The network administrator can configure a default route with a destination prefix of ::/0. For more information, see "Configuring IPv6 static routing."
·     Some dynamic routing protocols can generate a default IPv6 route. For example, an upstream router running OSPFv3 can generate a default IPv6 route and advertise it to other routers. These routers install the default IPv6 route with the next hop being the upstream router. For more information, see the respective chapters on those routing protocols in this configuration guide.
