- 05-Layer 3-IP Routing Configuration Guide
- 01-Basic IP routing configuration
- 02-Static routing configuration
- 03-RIP configuration
- 04-OSPF configuration
- 05-IS-IS configuration
- 06-BGP configuration
- 07-Policy-based routing configuration
- 08-IPv6 static routing configuration
- 09-RIPng configuration
- 10-OSPFv3 configuration
- 11-IPv6 IS-IS configuration
- 12-IPv6 policy-based routing configuration
- 13-Routing policy configuration
01-Basic IP routing configuration | 145.66 KB |
Extension attribute redistribution
Setting the maximum lifetime for routes and labels in the RIB
Setting the maximum lifetime for routes in the FIB
Enabling the RIB to flush route attribute information to the FIB
Setting the maximum number of ECMP routes
Enabling the enhanced ECMP mode
Enabling the compressed ECMP mode·
Configuring inter-protocol FRR
Configuring IPv4 RIB inter-protocol FRR
Configuring IPv6 RIB inter-protocol FRR
Enabling support for IPv6 routes with prefixes longer than 64 bits
Configuring routing policy-based recursive lookup
Configuring routing policy-based recursive lookup for IPv4 routes
Configuring routing policy-based recursive lookup for IPv6 routes
Setting the maximum number of active routes
Setting the maximum number of active IPv4 routes
Setting the maximum number of active IPv6 routes
Enabling route fast switchover
Enabling IPv4 route fast switchover
Enabling IPv6 route fast switchover
Displaying and maintaining a routing table
Configuring basic IP routing
IP routing directs IP packet forwarding on routers based on a routing table. This chapter focuses on unicast routing protocols. For more information about multicast routing protocols, see IP Multicast Configuration Guide.
Routing table
A RIB contains the global routing information and related information, including route recursion, route redistribution, and route extension information. The router selects optimal routes from the routing table and puts them into the FIB table. It uses the FIB table to forward packets. For more information about the FIB table, see Layer 3—IP Services Configuration Guide.
Table 1 categorizes routes by different criteria.
Criterion |
Categories |
Destination |
· Network route—The destination is a network. The subnet mask is less than 32 bits. · Host route—The destination is a host. The subnet mask is 32 bits. |
Whether the destination is directly connected |
· Direct route—The destination is directly connected. · Indirect route—The destination is indirectly connected. |
Origin |
· Direct route—A direct route is discovered by the data link protocol on an interface, and is also called an interface route. · Static route—A static route is manually configured by an administrator. · Dynamic route—A dynamic route is dynamically discovered by a routing protocol. |
To view brief information about a routing table, use the display ip routing-table command.
<Sysname> display ip routing-table
Destinations : 9 Routes : 9
0.0.0.0/32 Direct 0 0 127.0.0.1 InLoop0
3.3.3.3/32 Direct 0 0 127.0.0.1 InLoop0
127.0.0.0/32 Direct 0 0 127.0.0.1 InLoop0
127.255.255.255/32 Direct 0 0 127.0.0.1 InLoop0
A route entry includes the following key items:
· Destination—IP address of the destination host or network.
· Mask—Mask length of the IP address.
· Proto—Protocol that installed the route.
· Pre—Preference of the route. Among routes to the same destination, the route with the highest preference is optimal.
· Cost—If multiple routes to a destination have the same preference, the one with the smallest cost is the optimal route.
· NextHop—Next hop.
· Interface—Output interface.
Dynamic routing protocols
Static routes work well in small, stable networks. They are easy to configure and require fewer system resources. However, in networks where topology changes occur frequently, a typical practice is to configure a dynamic routing protocol. Compared with static routing, a dynamic routing protocol is complicated to configure, requires more router resources, and consumes more network resources.
Dynamic routing protocols dynamically collect and report reachability information to adapt to topology changes. They are suitable for large networks.
Dynamic routing protocols can be classified by different criteria, as shown in Table 2.
Table 2 Categories of dynamic routing protocols
Criterion |
Categories |
Operation scope |
· IGPs—Work within an AS. Examples include RIP, OSPF, and IS-IS. · EGPs—Work between ASs. The most popular EGP is BGP. |
Routing algorithm |
· Distance-vector protocols—Examples include RIP and BGP. BGP is also considered a path-vector protocol. · Link-state protocols—Examples include OSPF and IS-IS. |
Destination address type |
· Unicast routing protocols—Examples include RIP, OSPF, BGP, and IS-IS. · Multicast routing protocols—Examples include PIM-SM and PIM-DM. |
IP version |
· IPv4 routing protocols—Examples include RIP, OSPF, BGP, and IS-IS. · IPv6 routing protocols—Examples include RIPng, OSPFv3, IPv6 BGP, and IPv6 IS-IS. |
An AS refers to a group of routers that use the same routing policy and work under the same administration.
Route preference
Routing protocols, including static and direct routing, each by default have a preference. If they find multiple routes to the same destination, the router selects the route with the highest preference as the optimal route.
The preference of a direct route is always 0 and cannot be changed. You can configure a preference for each static route and each dynamic routing protocol. The following table lists the route types and default preferences. The smaller the value, the higher the preference.
Table 3 Route types and default route preferences
Route type |
Preference |
Direct route |
0 |
Multicast static route |
1 |
OSPF |
10 |
IS-IS |
15 |
Unicast static route |
60 |
RIP |
100 |
OSPF ASE |
150 |
OSPF NSSA |
150 |
IBGP |
255 |
EBGP |
255 |
Unknown (route from an untrusted source) |
256 |
Load sharing
A routing protocol might find multiple optimal equal-cost routes to the same destination. You can use these routes to implement equal-cost multi-path (ECMP) load sharing.
Static routing, IPv6 static routing, RIP, RIPng, OSPF, OSPFv3, BGP, IPv6 BGP, IS-IS, and IPv6 IS-IS support ECMP load sharing.
Route backup
Route backup can improve network availability. Among multiple routes to the same destination, the route with the highest priority is the primary route and others are secondary routes.
The router forwards matching packets through the primary route. When the primary route fails, the route with the highest preference among the secondary routes is selected to forward packets. When the primary route recovers, the router uses it to forward packets.
Route recursion
To use a BGP, static, or RIP route that has an indirectly connected next hop, a router must perform route recursion to find the output interface to reach the next hop.
Link-state routing protocols, such as OSPF and IS-IS, do not need route recursion, because they obtain directly connected next hops through route calculation.
The RIB records and saves route recursion information, including brief information about related routes, recursive paths, and recursion depth.
Route redistribution
Route redistribution enables routing protocols to learn routing information from each other. A dynamic routing protocol can redistribute routes from other routing protocols, including direct and static routing. For more information, see the respective chapters on those routing protocols in this configuration guide.
The RIB records redistribution relationships of routing protocols.
Extension attribute redistribution enables routing protocols to learn route extension attributes from each other, including BGP extended community attributes, OSPF area IDs, route types, and router IDs.
The RIB records extended attributes of each routing protocol and redistribution relationships of different routing protocol extended attributes.
Perform this task to prevent routes of a certain protocol from being aged out due to slow protocol convergence resulting from a large number of route entries or long GR period.
The configuration takes effect at the next protocol or RIB process switchover.
To set the maximum lifetime for routes and labels in the RIB (IPv4):
Step |
Command |
Remarks |
1. Enter system view. |
system-view |
N/A |
2. Enter RIB view. |
rib |
N/A |
3. Create the RIB IPv4 address family and enter its view. |
address-family ipv4 |
By default, no RIB IPv4 address family exists. |
4. Set the maximum lifetime for IPv4 routes and labels in the RIB. |
protocol protocol [ instance instance-name ] lifetime seconds |
By default, the maximum lifetime for routes and labels in the RIB is 480 seconds. |
To set the maximum route lifetime for routes and labels in the RIB (IPv6):
Step |
Command |
Remarks |
system-view |
N/A |
rib |
N/A |
3. Create the RIB IPv6 address family and enter its view. |
address-family ipv6 |
By default, no RIB IPv6 address family exists. |
4. Set the maximum lifetime for IPv6 routes and labels in the RIB. |
When GR or NSR is disabled, FIB entries must be retained for some time after a protocol process switchover or RIB process switchover. When GR or NSR is enabled, FIB entries must be removed immediately after a protocol or RIB process switchover to avoid routing issues. Perform this task to meet such requirements.
To set the maximum lifetime for routes in the FIB (IPv4):
Step |
Command |
Remarks |
system-view |
N/A |
rib |
N/A |
4. Set the maximum lifetime for IPv4 routes in the FIB. |
fib lifetime seconds |
By default, the maximum lifetime for routes in the FIB is 600 seconds. |
To set the maximum lifetime for routes in the FIB (IPv6):
Step |
Command |
Remarks |
system-view |
N/A |
rib |
N/A |
4. Set the maximum lifetime for IPv6 routes in the FIB. |
This feature is available only for BGP routes in the current software version. You can configure this feature when using sFlow to monitor BGP traffic. For more information about BGP path attributes and sFlow, see Layer 3—IP Routing Configuration Guide and Network Management and Monitoring Configuration Guide.
To enable RIB to flush route attribute information to the FIB:
Step |
Command |
Remarks |
system-view |
N/A |
rib |
N/A |
4. Enable the RIB to flush route attribute information to the FIB. |
flush route-attribute protocol |
By default, the RIB does not flush route attribute information to the FIB. |
This configuration takes effect at reboot. Make sure the reboot does not impact your network.
To set the maximum number of ECMP routes:
Step |
Command |
Remarks |
system-view |
N/A |
2. Set the maximum number of ECMP routes. |
max-ecmp-num number |
By default, the maximum number of ECMP routes is 8. |
Configuring the ECMP mode
About the enhanced ECMP mode
When one or multiple ECMP routes fail, the default ECMP mode enables the device to reallocate all traffic to the remaining routes.
The enhanced ECMP mode enables the device to reallocate only the traffic of the failed routes to the remaining routes, which ensures forwarding continuity.
Step |
Command |
Remarks |
system-view |
N/A |
2. Enable the enhanced ECMP mode. |
ecmp mode enhanced |
By default, the enhanced ECMP mode is disabled. |
About the compressed ECMP mode
An ECMP route group contains ECMP routes to the same destination. When the hardware resources used by all ECMP route groups on the device reach the upper limit, no more ECMP route groups can be created.
This feature enables the device to compress the hardware resources of all ECMP route groups to save storage space for more ECMP route groups.
Step |
Command |
Remarks |
system-view |
N/A |
2. Enable the compressed ECMP mode. |
ecmp mode compressed |
By default, the compressed ECMP mode is disabled. |
Configuring RIB NSR
IMPORTANT: Use this feature with protocol GR or NSR to avoid route timeouts and traffic interruption. |
When an active/standby switchover occurs, nonstop routing (NSR) backs up routing information from the active process to the standby process to avoid routing flapping and ensure forwarding continuity.
RIB NSR provides faster route convergence than protocol NSR during an active/standby switchover.
Configuring IPv4 RIB NSR
Step |
Command |
Remarks |
system-view |
N/A |
rib |
N/A |
4. Enable IPv4 RIB NSR. |
non-stop-routing |
By default, RIB NSR is disabled. |
Configuring IPv6 RIB NSR
Step |
Command |
Remarks |
system-view |
N/A |
rib |
N/A |
4. Enable IPv6 RIB NSR. |
non-stop-routing |
CAUTION: This feature uses the next hop of a route from a different protocol as the backup next hop for the faulty route, which might cause loops. |
Inter-protocol fast reroute (FRR) enables fast rerouting between routes of different protocols. A backup next hop is automatically selected to reduce the service interruption time caused by unreachable next hops. When the next hop of the primary link fails, the traffic is redirected to the backup next hop.
Among the routes to the same destination in the RIB, a router adds the route with the highest preference to the FIB table. For example, if a static route and an OSPF route in the RIB have the same destination, the router adds the OSPF route to the FIB table by default. The next hop of the static route is selected as the backup next hop for the OSPF route. When the next hop of the OSPF route is unreachable, the backup next hop is used.
Step |
Command |
Remarks |
system-view |
N/A |
rib |
N/A |
4. Enable IPv4 RIB inter-protocol FRR. |
inter-protocol fast-reroute [ vpn-instance vpn-instance-name ] |
By default, inter-protocol FRR is disabled. If you do not specify a VPN instance, inter-protocol FRR is enabled for the public network. |
Step |
Command |
Remarks |
system-view |
N/A |
rib |
N/A |
4. Enable IPv6 RIB inter-protocol FRR. |
This feature takes effect at next reboot. Make sure the reboot does not impact your network.
To enable support for IPv6 routes with prefixes longer than 64 bits:
Step |
Command |
Remarks |
system-view |
N/A |
2. Enable support for IPv6 routes with prefixes longer than 64 bits. |
hardware-resource routing-mode { ipv6-64 | ipv6-128 } |
By default, the device does not support IPv6 routes with prefixes longer than 64 bits. |
When a route changes, the routing protocol has to perform a route recursion if the next hop is indirectly connected. The routing protocol might select an incorrect path, which can cause traffic loss. To prevent this problem, you can use a routing policy to verify the recursive route. If the recursive route fails to match the routing policy, the routing protocol invalidates the route and marks it as unreachable.
For the device to use exact routes to forward the traffic, make sure all desired routes can match the routing policy.
Step |
Command |
Remarks |
system-view |
N/A |
rib |
N/A |
4. Configure routing policy-based recursive lookup. |
protocol protocol nexthop recursive-lookup route-policy route-policy-name |
By default, routing policy-based recursive lookup is not configured. |
Step |
Command |
Remarks |
system-view |
N/A |
rib |
N/A |
This feature helps limit the number of active routes on a device. When the number of active IPv4 or IPv6 routes exceeds the limit, the system still accepts new active routes but generates a log message. You can take relevant actions based on the message to save system resources.
Step |
Command |
Remarks |
system-view |
N/A |
rib |
N/A |
4. Set the maximum number of active IPv4 routes. |
routing-table limit number simply-alert |
By default, the maximum number of active IPv4 routes is not set. The configuration in RIB IPv4 address family view applies to active IPv4 routes in the public network and all VPN instances. |
Step |
Command |
Remarks |
system-view |
N/A |
rib |
N/A |
4. Set the maximum number of active IPv6 routes. |
By default, the maximum number of active IPv6 routes is not set. The configuration in RIB IPv6 address family view applies to active IPv6 routes in the public network and all VPN instances. |
This command applies to a device that provides the same physical output interface for large numbers of routes, including ECMP routes and primary/secondary routes. When a link failure occurs on the interface, the device must perform the following tasks before switching the traffic to another route:
1. Deletes all ARP or ND entries for the link.
2. Instructs the FIB to delete the associated FIB entries.
This procedure is time consuming and interrupts traffic for a long time. To resolve this problem, you can enable route fast switchover. This feature allows the device to instruct the FIB to delete the invalid FIB entries for route switchover without deleting the relevant ARP or ND entries.
Step |
Command |
Remarks |
system-view |
N/A |
2. Enable IPv4 route fast switchover. |
By default, IPv4 route fast switchover is disabled. |
Step |
Command |
Remarks |
system-view |
N/A |
2. Enable IPv6 route fast switchover. |
ipv6 route fast-switchover enable |
By default, IPv6 route fast switchover is disabled. |
Task |
Command |
Display the ECMP mode. |
display ecmp mode |
Display routing table information. |
display ip routing-table [ all-vpn-instance | vpn-instance vpn-instance-name ] [ verbose ] display ip routing-table [ all-routes ] |
Display information about routes permitted by an IPv4 basic ACL. |
display ip routing-table [ vpn-instance vpn-instance-name ] acl ipv4-acl-number [ verbose ] |
Display information about routes to a specific destination address. |
display ip routing-table [ vpn-instance vpn-instance-name ] ip-address [ mask-length | mask ] [ longer-match ] [ verbose ] |
Display information about routes to a range of destination addresses. |
display ip routing-table [ vpn-instance vpn-instance-name ] ip-address1 to ip-address2 [ verbose ] |
Display information about routes permitted by an IP prefix list. |
display ip routing-table [ vpn-instance vpn-instance-name ] prefix-list prefix-list-name [ verbose ] |
Display information about routes installed by a protocol. |
display ip routing-table [ vpn-instance vpn-instance-name ] protocol protocol [ inactive | verbose ] |
Display IPv4 route statistics. |
display ip routing-table [ all-routes | all-vpn-instance | vpn-instance vpn-instance-name ] statistics |
Display brief IPv4 routing table information. |
display ip routing-table [ vpn-instance vpn-instance-name ] summary |
Display the maximum number of ECMP routes. |
display max-ecmp-num |
Display route attribute information in the RIB. |
display rib attribute [ attribute-id ] |
Display RIB GR state information. |
display rib graceful-restart |
Display next hop information in the RIB. |
display rib nib [ self-originated ] [ nib-id ] [ verbose ] display rib nib protocol protocol [ verbose ] |
Display next hop information for direct routes. |
display route-direct nib [ nib-id ] [ verbose ] |
Clear IPv4 route statistics. |
reset ip routing-table statistics protocol [ vpn-instance vpn-instance-name ] { protocol | all } reset ip routing-table [ all-routes | all-vpn-instance ] statistics protocol { protocol | all } |
Display IPv6 routing table information. |
display ipv6 routing-table [ all-vpn-instance | vpn-instance vpn-instance-name ] [ verbose ] display ipv6 routing-table [ all-routes ] |
Display information about routes to an IPv6 destination address. |
display ipv6 routing-table [ vpn-instance vpn-instance-name ] ipv6-address [ prefix-length ] [ longer-match ] [ verbose ] |
Display information about routes permitted by an IPv6 basic ACL. |
display ipv6 routing-table [ vpn-instance vpn-instance-name ] acl ipv6-acl-number [ verbose ] |
Display information about routes to a range of IPv6 destination addresses. |
display ipv6 routing-table [ vpn-instance vpn-instance-name ] ipv6-address1 to ipv6-address2 [ verbose ] |
Display information about routes permitted by an IPv6 prefix list. |
display ipv6 routing-table [ vpn-instance vpn-instance-name ] prefix-list prefix-list-name [ verbose ] |
Display information about routes installed by an IPv6 protocol. |
display ipv6 routing-table [ vpn-instance vpn-instance-name ] protocol protocol [ inactive | verbose ] |
Display IPv6 route statistics. |
display ipv6 routing-table [ all-routes | all-vpn-instance | vpn-instance vpn-instance-name ] statistics |
Display brief IPv6 routing table information. |
display ipv6 routing-table [ vpn-instance vpn-instance-name ] summary |
Display route attribute information in the IPv6 RIB. |
display ipv6 rib attribute [ attribute-id ] |
Display IPv6 RIB GR state information. |
display ipv6 rib graceful-restart |
Display next hop information in the IPv6 RIB. |
display ipv6 rib nib [ self-originated ] [ nib-id ] [ verbose ] display ipv6 rib nib protocol protocol [ verbose ] |
Display next hop information for IPv6 direct routes. |
display ipv6 route-direct nib [ nib-id ] [ verbose ] |
Display support for IPv6 routes with prefixes longer than 64 bits. |
display hardware-resource routing-mode |
Clear IPv6 route statistics. |
reset ipv6 routing-table statistics protocol [ vpn-instance vpn-instance-name ] { protocol | all } reset ipv6 routing-table [ all-routes | all-vpn-instance ] statistics protocol { protocol | all } |
