HomeSupportResource CenterSwitchesH3C S6860 Switch SeriesH3C S6860 Switch SeriesTechnical DocumentsConfigureConfiguration GuidesH3C S6860 Switch Series Configuration Guide-Release 26xx-6W10201-Fundamentals Configuration Guide
05-File system management configuration
05-File system management configuration 101.49 KB
Managing file systems
Overview
File systems
The device supports the following storage media:
·           Flash memory.
·           Hot-swappable storage medium USB disk.
The flash memory has one file system.
The USB disk can be partitioned. An unpartitioned USB disk has one file system. A partitioned USB disk has one file system on each partition.
File system naming conventions
The name of the file system on a flash memory has the following parts:
·           File system location. For more information, see "File system location".
·           Storage medium type flash.
·           Colon (:).
The name of a file system on a USB disk has the following parts:
·           Storage medium type usb.
·           Sequence number, a lower-case English letter such as a, b, or c.
·           Partition number, a digit that starts at 0 and increments by 1. If the USB disk is not partitioned, the system determines that the USB disk has one partition.
·           Colon (:).
For example, the file system on the first partition of the first USB disk is named usba0:.
IMPORTANT
IMPORTANT:
File system names are case sensitive and must be entered in lower case.
To identify a file system on the master device, you do not need to specify the file system location. To identify a file system on a subordinate member device, you must specify the file system location in the slotn# format. The n argument represents the IRF member ID of the member device. For example, the location is slot2# for a file system that resides on member device 2.
Default file system
You are working with the default file system by default after you log in. To specify a file or directory on the default file system, you do not need to specify the file system name. For example, you do not need to specify any location information if you want to save the running configuration to the root directory of the default file system.
To change the default file system, use the BootWare or Boot ROM menu. For more information, see the software release notes.
Directories
Directories in a file system are structured in a tree form.
Root directory
The root directory is represented by a forwarding slash (/). For example, flash:/ represents the root directory of the flash memory.
Working directory
The working directory is also called the current directory.
The default working directory is the root directory of the flash memory on the master device.
Directory naming conventions
When you specify a name for a directory, follow these conventions:
·           A directory name can contain letters, digits, and special characters except for asterisks (*), vertical bars (|), forward slashes (/), backward slashes (\), question marks (?), left angle brackets (<), right angle brackets (>), quotation marks ("), and colons (:).
·           A directory whose name starts with a dot character (.) is a hidden directory. To prevent the system from hiding a directory, make sure the directory name does not start with a dot character.
Commonly used directories
The device has some factory-default directories. The system automatically creates directories during operation. These directories include:
·           diagfile—Stores diagnostic information files.
·           license—Stores license files.
·           logfile—Stores log files.
·           seclog—Stores security log files.
·           versionInfo—Stores software version information files.
Files
File naming conventions
When you specify a name for a file, follow these conventions:
·           A file name can contain letters, digits, and special characters except for asterisks (*), vertical bars (|), forward slashes (/), backward slashes (\), question marks (?), left angle brackets (<), right angle brackets (>), quotation marks ("), and colons (:).
·           A file whose name starts with a dot character (.) is a hidden file. To prevent the system from hiding a file, make sure the file name does not start with a dot character.
Common file types
The device is shipped with some files. The system automatically creates files during operation. The types of these files include:
·           .ipe file—Compressed software image package file.
·           .bin file—Software image file.
·           .cfg file—Configuration file.
·           .mdb file—Binary configuration file.
·           .log file—Log file.
Specifying a directory name or file name
To specify a directory, you can use the absolute path or a relative path. For example, the working directory is flash:/. To specify the test2 directory in Figure 1, you can use the following methods:
·           flash:/test/test1/test2 (absolute path)
·           flash:/test/test1/test2/ (absolute path)
·           test/test1/test2 (relative path)
·           test/test1/test2/ (relative path)
Figure 1 Sample directory hierarchy
Specifying a file name
To specify a file, use the following methods:
·           Enter the absolute path of the file and the file name in the format of filesystem/directory1/directory2//directoryn/filename, where directoryn is the directory in which the file resides.
·           Enter the relative path of the file and the file name.
For example, the working directory is flash:/. The samplefile.cfg file is in the test2 directory shown in Figure 1. To specify the file, you can use the following methods:
·           flash:/test/test1/test2/samplefile.cfg
·           test/test1/test2/samplefile.cfg
FIPS compliance
File system management restrictions and guidelines
To avoid file system corruption, do not perform the following tasks during file system management:
·           Install or remove storage media.
·           Perform a master/subordinate switchover.
If you remove a storage medium while a directory or file on the medium is being accessed, the device might not recognize the medium when you reinstall it. To reinstall this kind of storage medium, perform one of the following tasks:
·           If you were accessing a directory on the storage medium, change the working directory.
·           If you were accessing a file on the storage medium, close the file.
·           If another administrator was accessing the storage medium, unmount all file systems on the storage medium.
Make sure a USB disk is not write protected before an operation that requires the write right on the disk.
You cannot access a storage medium that is being partitioned, or a file system that is being formatted or repaired.
Before managing file systems, directories, and files, make sure you know the possible impact.
Managing storage media and file systems
Partitioning a storage medium
A storage medium can be divided into logical devices called partitions. Operations on one partition do not affect the other partitions.
The flash memory does not support partitioning.
A partition must have a minimum of 32 MB of storage space.
The actual partition size and the specified partition size might have a difference of less than 5% of the storage medium's total size.
Before partitioning a storage medium, perform the following tasks:
·           Back up the files in the storage medium. The partition operation clears all data on the medium.
·           To partition a storage medium, make sure the disk is not write protected. If the disk is write protected, the partition operation will fail, and you must remount or reinstall the disk to restore access to the storage medium.
·           Make sure no other users are accessing the medium.
Configuration procedure
Perform this task in user view.
Remarks
Partition a storage medium.
fdisk medium [ partition-number ]
To partition a storage medium evenly, specify the partition-number argument.
To customize the sizes of partitions, do not specify the partition-number argument. The command will require you to specify a size for each partition.
Mounting or unmounting a file system
Generally, file systems on a hot-swappable storage medium are automatically mounted when the storage medium is connected to the device. If the system cannot recognize a file system, you must mount the file system before you can access it.
To remove a hot-swappable storage medium from the device, you must first unmount all file systems on the storage medium to disconnect the medium from the device. Removing a connected hot-swappable storage medium might damage files on the storage medium or even the storage medium itself.
To use an unmounted file system, you must mount the file system again.
You can mount or unmount a file system only when no other users are accessing the file system.
To prevent a USB disk and the USB interface from being damaged, make sure the following requirements are met before unmounting file systems on the USB disk:
·           The system has recognized the USB disk.
·           The USB disk LED is not blinking.
Perform one of the following tasks in user view as appropriate:
Mount a file system.
mount filesystem
Unmount a file system.
umount filesystem
Formatting a file system
CAUTION
CAUTION:
Formatting a file system permanently deletes all files and directories in the file system. You cannot restore the deleted files or directories.
You can format a file system only when no other users are accessing the file system.
Format a file system.
format filesystem
Repairing a file system
If part of a file system is inaccessible, use this task to examine and repair the file system.
You can repair a file system only when no other users are accessing the file system.
Repair a file system.
fixdisk filesystem
Managing directories
Displaying directory information
Remarks
Display directory or file information.
dir [ /all ] [ file | directory | /all-filesystems ]
If multiple users perform file operations (for example, creating or deleting files or directories) at the same time, the output for this command might be incorrect.
Displaying the working directory
Display the working directory.
pwd
Changing the working directory
Change the working directory.
cd { directory | .. }
Creating a directory
Create a directory.
mkdir directory
Renaming a directory
Rename a directory.
rename source-directory dest-directory
Archiving or extracting directories
When you archive or extract directories or display archived directories, files in the directories are also archived, extracted, or displayed.
Perform the following tasks in user view:
Archive directories.
tar create [ gz ] archive-file dest-file [ verbose ] source source-directory &<1-5>
Extract directories.
tar extract archive-file file [ verbose ] [ screen | to directory ]
Display archived directories.
tar list archive-file file
Deleting a directory
To delete a directory, you must delete all files and subdirectories in the directory. To delete a file, use the delete command. To delete a subdirectory, use the rmdir command.
Deleting a directory permanently deletes all its files in the recycle bin, if any.
Delete a directory.
rmdir directory
Setting the operation mode for directories
The device supports the following directory operation modes:
·           alert—The system prompts for confirmation when your operation might cause problems such as data loss. This mode provides an opportunity to cancel a disruptive operation.
·           quiet—The system does not prompt for confirmation.
To set the operation mode for directories:
Step
Remarks
1.      Enter system view.
N/A
2.      Set the operation mode for directories.
file prompt { alert | quiet }
The default mode is alert.
This command also sets the operation mode for files.
Managing files
You can create a file by copying a file, downloading a file, or using the save command. For more information about downloading a file, see "Configuring FTP" and "Configuring TFTP." For more information about the save command, see Fundamentals Command Reference.
Displaying file information
Remarks
Displaying the contents of a text file
Display the contents of a text file.
more file
Renaming a file
Rename a file.
rename source-file dest-file
Copying a file
Copy a file.
copy source-file { dest-file | dest-directory }
Moving a file
Move a file.
Compressing or decompressing a file
Compress a file.
gzip file
Decompress a file.
gunzip file
Archiving or extracting files
Archive files.
tar create [ gz ] archive-file dest-file [ verbose ] source source-file &<1-5>
Extract files.
Display the names of archived files.
Deleting or restoring a file
You can delete a file permanently or move it to the recycle bin. A file moved to the recycle bin can be restored, but a permanently deleted file cannot.
Files in the recycle bin occupy storage space. To save storage space, periodically empty the recycle bin by using the reset recycle-bin command.
Delete a file by moving it to the recycle bin.
delete file
Restore a file from the recycle bin.
undelete file
Delete a file permanently.
delete /unreserved file
IMPORTANT
IMPORTANT:
Do not use the delete command to delete files from the recycle bin. To delete files from the recycle bin, use the reset recycle-bin command.
Deleting files from the recycle bin
Each file system has a recycle bin of its own. A recycle bin is a folder named .trash in the root directory of a file system.
To view which files or directories are in a recycle bin, use either of the following methods:
·           Access the file system and execute the dir/all .trash command.
·           Execute the cd .trash command to enter the recycle bin folder, and then execute the dir command.
To delete files from a recycle bin, perform the following task in user view:
Delete files from the recycle bin.
reset recycle-bin [ /force ]
Calculating the file digest
File digests are used to verify file integrity.
Use the following commands in user view:
Calculate the digest of a file by using the SHA-256 algorithm.
sha256sum file
Calculate the digest of a file by using the MD5 algorithm.
md5sum file
Setting the operation mode for files
The device supports the following file operation modes:
·           alert—The system prompts for confirmation when your operation might cause problems such as file corruption or data loss. This mode provides an opportunity to cancel a disruptive operation.
To set the operation mode for files:
Step
Remarks
N/A
2.      Set the operation mode for files.
This command also sets the operation mode for directories.
