H3C WX1800H Series Access Controllers Installation Guide-6W102
HomeSupportWirelessWX1800H Series Access ControllersInstall & UpgradeInstallation GuidesH3C WX1800H Series Access Controllers Installation Guide-6W102
07-Appendix C Optional transceiver modules
07-Appendix C Optional transceiver modules 98.86 KB
7 Appendix C Optional transceiver modules
Transceiver module, fiber connector, and optical fiber views
The WX1840H access controller provides SFP ports. To connect a SFP port on the device, use an SFP transceiver module and an optical fiber with LC connectors.
Figure7-1 SFP transceiver module
Figure7-2 Optical fiber with LC connectors
(1) LC connector
(2) Optical fiber
Transceiver module specifications
The transceiver modules that have MM and SM in their names support multi-mode optical fibers and single-mode optical fibers, respectively.
The SFP ports on the WX1840H access controller support the following transceiver modules:
·          SFP-GE-LX-SM1310-A (seeTable7-1)
·          SFP-GE-SX-MM850-A (see Table7-2)
Table7-1 SFP-GE-LX-SM1310-A specifications
Item
Specification
Central wavelength
1310 nm
Transmission distance
10 km (6.21 miles)
Transmission rate
1250 Mbps
Connector type
Duplex LC
Fiber mode
SMF
Fiber diameter
9 µm
Transmit power
–9.5 to –3 dBm
Receive sensitivity
≤ –20 dBm
Saturation
≤ –3 dBm
Table7-2 SFP-GE-SX-MM850-A specifications
Item
Specification
Central wavelength
850 nm
550 m (1804.46 ft)
Transmission rate
1250 Mbps
Connector type
Duplex LC
Fiber mode
MMF
Fiber diameter
50 µm
Transmit power
–9.5 to 0 dBm
Receive sensitivity
≤ –17 dBm
Saturation
≤ –3 dBm
