H3C WX1800H Series Access Controllers Installation Guide-6W102
HomeSupportWirelessWX1800H Series Access ControllersInstall & UpgradeInstallation GuidesH3C WX1800H Series Access Controllers Installation Guide-6W102
06-Appendix B LEDs
06-Appendix B LEDs 215.43 KB
6 Appendix B LEDs
WX1804H-PWR
Figure6-1 WX1804H-PWR LEDs
(1) LEDs for the 100/1000BASE-T autosensing Ethernet copper port
(2) LEDs for the 100/1000BASE-T PoE+ autosensing Ethernet copper ports
(3) System status LED (SYS)
(4) PoE status LED (PoE)
WX1810H-PWR
Figure6-2 WX1810H-PWR LEDs
(1) LEDs for the 100/1000BASE-T PoE+ autosensing Ethernet copper ports
(2) LEDs for the 100/1000BASE-T autosensing Ethernet copper port
WX1820H
Figure6-3 WX1820H LEDs
(1) LEDs for the 100/1000BASE-T autosensing Ethernet copper ports
(2) System status LED (SYS)
WX1840H
Figure6-4 WX1840H LEDs
(2) LEDs for the 1000BASE-X SFP ports
LED description
LED
Status
100/1000BASE-T or 100/1000BASE-T PoE+ autosensing Ethernet copper port LED
Steady green
A 1000 Mbps link is present.
Flashing green
Data is being received or transmitted at 1000 Mbps.
Steady yellow
A 100 Mbps link is present.
Flashing yellow
Data is being received or transmitted at 100 Mbps.
Off
No link is present.
Fast flashing green
The system is loading software.
Slow flashing green
The system is operating correctly
Steady red
A problem, such as startup failure, power failure, or overtemperature has occurred.
Off
The device is in the reset process, or the system is not operating.
PoE power supply status LED (PoE)
Steady green
A PoE port is supplying power.
Flashing green
PoE power supply failure or overload has occurred.
Off
No PoE port is supplying power.
1000BASE-X SFP port LED
Steady green
A 1000 Mbps link is present on the port.
Flashing green
The port is sending or receiving data at 1000 Mbps.
Off
No link is present on the port.
