H3C WX1800H Series Access Controllers Installation Guide-6W102
HomeSupportWirelessWX1800H Series Access ControllersInstall & UpgradeInstallation GuidesH3C WX1800H Series Access Controllers Installation Guide-6W102
05-Appendix A Chassis views and technical specifications
5 Appendix A Chassis views and technical specifications
Chassis views
WX1804H-PWR
Figure5-1 Front panel
(1) Grounding screw
(2) Power receptacle
(3) 100/1000BASE-T autosensing Ethernet copper port (WAN)
(4) 100/1000BASE-T PoE+ autosensing Ethernet copper ports (LAN1 to LAN4)
(5) USB port
(6) Console port (CONSOLE)
(7) Reset button (RESET)
Figure5-2 Rear panel
WX1810H-PWR
Figure5-3 Front panel
(1) 100/1000BASE-T PoE+ autosensing Ethernet copper ports (LAN 1 to LAN 10)
(2) 100/1000BASE-T autosensing Ethernet copper ports (WAN 11 and WAN 12)
(3) USB port
(4) Console port (CONSOLE)
(5) Reset button (RESET)
Figure5-4 Rear panel
(1) Grounding screw
WX1820H
Figure5-5 Front panel
(1) Power receptacle
(2) 100/1000BASE-T autosensing Ethernet copper ports (LAN1 to LAN4 and WAN)
(3) Console port (CONSOLE)
(4) SD card slot
(5) USB port
(6) Reset button (RESET)
Figure5-6 Rear panel
(1) Security slot
(2) Grounding screw
WX1840H
Figure5-7 Front panel
(1) 100/1000BASE-T autosensing Ethernet copper ports (WAN 1, WAN2, and LAN1 to LAN6)
(2) 1000BASE-X SFP port 5 and 6
(3) USB port
(4) SD card slot
(5) Console port (CONSOLE)
Figure5-8 Rear panel
(1) AC power receptacle
(2) Grounding screw
Interface numbering
WX1804H-PWR
Fixed ports on a WX1804H-PWR access controller are numbered as follows:
·          100/1000BASE-T autosensing Ethernet copper port WAN is represented by interface number GigabitEthernet 1/0/1.
·          100/1000BASE-T-PoE+ autosensing Ethernet copper ports LAN1 through LAN4 are represented by interface numbers GigabitEthernet 1/0/2 through GigabitEthernet 1/0/5, respectively.
WX1810H-PWR
Fixed ports on a WX1810H-PWR access controller are numbered as follows:
·          100/1000BASE-T-PoE+ autosensing Ethernet copper ports LAN 1 through LAN 10 are represented by interface numbers GigabitEthernet 1/0/1 through GigabitEthernet 1/0/10, respectively.
·          100/1000BASE-T autosensing Ethernet copper ports WAN 11 and WAN 12 are represented by interface numbers GigabitEthernet 1/0/11 and GigabitEthernet 1/0/12, respectively.
WX1820H
Fixed ports on a WX1820H access controller are numbered as follows:
·          100/1000BASE-T autosensing Ethernet copper ports LAN1 through LAN4 are represented by interface numbers GigabitEthernet 1/0/1 through GigabitEthernet 1/0/4, respectively.
·          100/1000BASE-T autosensing Ethernet copper port WAN is represented by interface number GigabitEthernet 1/0/5.
WX1840H
Fixed ports on a WX1840H access controller are numbered as follows:
·          100/1000BASE-T autosensing Ethernet copper ports LAN 1 through LAN 4 are represented by interface numbers GigabitEthernet 1/0/1 through GigabitEthernet 1/0/4, respectively.
·          100/1000BASE-T autosensing Ethernet copper ports LAN 5 and LAN 6 form combo interfaces (GigabitEthernet 1/0/5 and GigabitEthernet 1/0/6) with 1000BASE-X SFP ports 5 and 6, respectively.
·          100/1000BASE-T autosensing Ethernet copper port WAN 1 and WAN 2 are represented by interface numbers GigabitEthernet 1/0/7 and GigabitEthernet 1/0/8, respectively.
Technical specifications
Table5-1 Technical specifications
Item
WX1804H-PWR
WX1810H-PWR
WX1820H
WX1840H
Console port
One, 9600 bps (default) to 115200 bps
5, including four LAN ports and one WAN port
12, including ten LAN ports and two WAN ports
8, including six LAN ports and two WAN ports
SFP port
N/A
N/A
N/A
1000BASE-X SFP ports 5 and 6 form combo interfaces with 100/1000BASE-T autosensing Ethernet copper ports LAN 5 and LAN 6, respectively.
Memory
1 GB
1 GB
1 GB
1 GB
Storage medium
1GB NAND flash memory
Dimensions (H × W × D)
27 × 220 × 145.5 mm (1.06 × 8.66 × 5.73 in)
43.6 × 440 × 260 mm (1.72 × 17.32 × 10.24 in)
28 × 220 × 147 mm (1.10 × 8.66 × 5.79 in)
43.6 × 330 × 230 mm (1.72 × 13.00 × 9.06 in)
Rated AC voltage
100 VAC to 240 VAC @ 50 to 60 Hz
Power consumption
4.8 to 10.7 W
15.2 to 33.5 W
5.7 to 8.7 W
20 to 32 W
PoE port
4
10
N/A
N/A
Max. output capacity per PoE port
30 W
30 W
N/A
N/A
Max. PoE output capacity
70 W
(The system allows two PoE ports to supply the max. output concurrently.)
196 W
(The system allows six PoE ports to supply the max. output concurrently.)
N/A
N/A
Weight
1.45 kg (3.20 lb)
3.60 kg (7.94 lb)
0.90 kg (1.98 lb)
2.0 kg (4.41 lb)
