H3C WX2560H Access Controller Installation Guide-6W102
HomeSupportWirelessWX2500H Series Access ControllersInstall & UpgradeInstallation GuidesH3C WX2560H Access Controller Installation Guide-6W102
06-Appendix B LEDs
06-Appendix B LEDs 60.37 KB
6 Appendix B LEDs
Figure6-1 Front panel LEDs
(1) 100/1000Base-T autosensing Ethernet copper port status LEDs
(2) 1000Base-X SFP port status LEDs
(3) System status LED (SYS)
Table6-2 LED description
LED
Mark
Status
System status LED
SYS
Flashing green (0.5 Hz)
The system is operating correctly.
Flashing green (4 Hz)
The system is starting up.
Steady red
The system has failed POST or a serious fault has occurred.
Off
The system is powered off or a power failure has occurred.
N/A
Steady green
A 1000 Mbps link is present on the port.
Flashing green
The port is receiving or transmitting data at 1000 Mbps.
Steady yellow
A 100 Mbps link is present on the port.
Flashing yellow
The port is receiving or transmitting data at 100 Mbps.
Off
No link is present on the port.
1000Base-X SFP autosensing port status LED
N/A
Steady green
Flashing green
Off
