| 04-Hardware management and maintenance | 60.97 KB |
4 Hardware management and maintenance
Displaying hardware information for the device
Displaying software and hardware version information for the device
Displaying operational statistics for the device
Displaying detailed information about the device
Displaying the electronic label data for the device
Displaying the CPU usage of the device
Displaying the memory usage of the device
Displaying the operational status of the built-in fans
Displaying the operating state of a power module
The command lines and outputs depend on the software version that runs on the device.
Use the display version command to display software and hardware version information about the device. The output includes the following information:
· The current software.
· The hardware version.
· The device operating time.
The output depends on the software and hardware version of the device.
<H3C> display version
H3C Comware Software, Version 7.1.064, Release 5323
Copyright (c) 2004-2020 New H3C Technologies Co., Ltd. All rights reserved.
H3C WX2560H uptime is 0 weeks, 0 days, 0 hours, 5 minutes
Last reboot reason : User soft reboot
Boot image: flash:/boot.bin
Boot image version: 7.1.064, Release 5323
Compiled Mar 21 2017 16:00:00
System image: flash:/system.bin
System image version: 7.1.064, Release 5323
with 1 1000MHz Multi-core Processor
1024M bytes DDR3
16M bytes NorFlash Memory
1024M bytes NandFlash Memory
Hardware Version is Ver.A
CPLD Version is 002
Basic Bootrom Version is 1.03
Extend Bootrom Version is 1.05
[Subslot 0]WX2560H Hardware Version is Ver.A
When you perform routine maintenance or the system fails, you might need to display the operational information of each feature module to locate failures. Typically, you need to run the display commands individually. However, you can use the display diagnostic-information command in any view to display or save the operational statistics of multiple feature modules of the device. This command displays the output of the display clock, display version, display device, and display current-configuration commands.
· Save the operational statistics for each feature module of the device:
<H3C>display diagnostic-information
Save or display diagnostic information (Y=save, N=display)? [Y/N]:y
Please input the file name(*.tar.gz)[cfa0:/diag_WX3010H-X_20170223-071047.tar.gz]:
Diagnostic information is outputting to cfa0:/diag_WX3010H-X_20170223-071047.tar.gz.
Please wait...
Save successfully.
To view the contents of the default.diag file, execute the more default.diag command in user view, and then press the Page Up and Page Down keys.
· Display the operational statistics for each feature module of the device. (Details not shown.)
<H3C> display diagnostic-information
Save or display diagnostic information (Y=save, N=display)? [Y/N]:N
18:11:42 UTC Wed 04/05/2017
H3C WX2560H uptime is 0 weeks, 0 days, 0 hours, 14 minutes
1024M bytes DDR3
CPLD Version is 002
===============display system internal version===============
H3C WX2560H V500R001B64D023
Comware V700R001B64D023
===============display device verbose===============
Slot No. Subslot No. Board Type Status Max Ports
1 0 WX2560H Normal 10
Use the display device verbose command to display detailed information about the device.
<H3C>display device verbose
Table4-1 Command output
Slot No. |
Member ID of the IRF member device. |
Board Type |
Device type. |
Status |
Device status: · Fault—The device is not operating correctly. · Normal—The device is operating correctly. |
Max Ports |
Maximum number of ports supported. |
An electronic label is a profile of a device. It contains the permanent configuration, including the serial number, manufacturing date, MAC address, and vendor name.
Use the display device manuinfo command to display the electronic label data for the device.
<H3C> display device manuinfo
DEVICE_NAME:WX2560H
DEVICE_SERIAL_NUMBER:219801A0WF6666666666
MAC_ADDRESS:000f-e212-6103
MANUFACTURING_DATE:2017-04-10
VENDOR_NAME:H3C
Table4-2 Command output
DEVICE_NAME |
Device model. |
DEVICE_SERIAL_NUMBER |
Serial number of the device. |
MAC_ADDRESS |
MAC address of the device. |
MANUFACTURING_DATE |
Manufacturing data of the device. |
VENDOR_NAME |
Vendor name. |
Use the display cpu-usage command to display the CPU usage statistics for the device.
<H3C> display cpu-usage
Unit CPU usage:
0% in last 5 seconds
1% in last 1 minute
5% in last 5 minutes
Table4-3 Command output
0% in last 5 seconds |
Average CPU usage in the last 5 seconds (after the device boots, the device calculates and records the average CPU usage at the interval of 5 seconds). |
1% in last 1 minute |
Average CPU usage in the last minute (after the device boots, the device calculates and records the average CPU usage at the interval of 1 minute). |
5% in last 5 minutes |
Average CPU usage in the last 5 minutes (after the device boots, the device calculates and records the average CPU usage at the interval of 5 minutes). |
Use the display memory command to display the memory usage statistics for the device.
<H3C> display memory
Memory statistics are measured in KB:
Slot 1:
Total Used Free Shared Buffers Cached FreeRatio
Mem: 1008932 480848 528084 0 1760 121976 52.3%
-/+ Buffers/Cache: 357112 651820
Swap: 0 0 0
Slot x |
Mem |
Memory usage information. |
Total |
Total size of the physical memory space that can be allocated. |
Used |
Used physical memory. |
Free |
Free physical memory. |
Shared |
Physical memory shared by processes. |
Buffers |
Physical memory used for buffers. |
Cached |
Used physical memory for cache. |
FreeRatio |
Free memory ratio. |
–/+ Buffers/Cache |
· -/+ Buffers/Cache:used = Mem:Used – Mem:Buffers – Mem:Cached, which indicates the physical memory used by applications. · -/+ Buffers/Cache:free = Mem:Free + Mem:Buffers + Mem:Cached, which indicates the physical memory available for applications. |
Swap |
Swap memory. |
Use the display fan command to display the operating states of fans.
<H3C> display fan
Fan 1 State: Normal
Table4-5 Command output
Fan n |
Number of the fan. |
State |
Fan state: · Normal—The fan is operating correctly. · Absent—The fan is not in position. · Fault—The fan has failed. |
Use the display power command to display the operating state of a power module.
<H3C> display power
Power 1 State: Normal
Table4-6 Command output
Power 1, 2 |
Number of the power module. |
State |
Power module state: · Normal—The power module is operating correctly. · Absent—The power module is not in position. · Fault—The power module has failed. |
Rebooting the device
To reboot the device, use one of the following methods:
· Reboot the device at the CLI. You can remotely reboot the device in either of the following ways:
¡ Reboot the device immediately by using the reboot command.
¡ Schedule a reboot to occur at a specific time or date or after a delay by using the schedule reboot command.
· Power off and power on the device. This method cuts off the power of the device forcibly, which might cause data loss. It is the least-preferred method.
· Before you reboot the device, perform the following tasks:
¡ Use the save command to save the running configuration. For more information about the save command, see file system management commands in H3C WX2560H Access Controller Fundamentals Command Reference.
¡ Use the display startup and display boot-loader commands to make sure you have specified the correct next-startup configuration files and startup software images. If the main startup software image is corrupt or does not exist, a reboot failure will occur. To avoid a reboot failure, use the boot-loader file command to specify a new startup software image. For more information about the display startup and display boot-loader commands, see file system management commands and software upgrade commands in H3C WX2560H Access Controller Fundamentals Command Reference, respectively.
· The device will not reboot if a file is being accessed.
Configuration procedure
Rebooting the device immediately
Task |
Command |
Remarks |
Reboot the device immediately. |
reboot [ force ] |
Available in user view. |
Scheduling a reboot for the device
Task |
Command |
Remarks |
Schedule a reboot. |
Schedule a reboot to occur at a specific time or date: ·
Schedule a reboot to occur after a delay: |
Use either command. By default, no reboot date or time or reboot delay time is specified. Available in user view. The most recent configuration takes effect if you execute the scheduler reboot at or scheduler reboot delay command multiple times. |
