| 00-Preface | 80.93 KB |
Preface
H3C WX2560H Access Controller Installation Guide describes the procedures for installing, troubleshooting, and maintaining the WX2560H access controller.
· Audience
Audience
· Network administrators working with the WX3000H access controllers.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Wireless terminator unit. |
Wireless terminator. |
Documentation feedback
We appreciate your comments.
