Strategy Partner :
00-Preface
Preface
The H3C MSR3610-X1 Gigabit Ethernet Integrated Service Gateway Installation Guide includes seven chapters, which describe the preparing for installation, installing the router, replacement procedure, troubleshooting, chassis views and technical specifications, LEDs, and slot arrangement.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the routers.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
Coperation Event & Solution
- H3C MSR3610-X1 Gigabit Ethernet Integrated Service Gateway Installation Guide-6W100-Preface.pdf
