- 13-High Availability Configuration Guide
- 01-Ethernet OAM configuration
- 02-CFD configuration
- 03-DLDP configuration
- 04-Monitor Link configuration
- 05-VRRP configuration
- 06-Failover group configuration
- 07-Service instance group configuration
- 08-BFD configuration
- 09-Track configuration
- 10-Process placement configuration
07-Service instance group configuration | 36.43 KB |
Configuring service instance groups
Restrictions and guidelines: Service instance group configuration
Configuring a service instance group
Display and maintenance commands for service instance groups
About service instance groups
Associated with a failover group, a service instance group helps back up service data for specific service modules (such as NAT), and guarantee correct operation of specific services. For more information about failover groups, see "Configuring failover groups."
A service instance group can be associated with only one failover group. A failover group can be associated with only one service instance group.
If the NAT instance with a service instance group specified has NAT entries, you are not allowed to perform the following operations:
· Delete the service instance group.
· Cancel the association between the service instance group and failover group.
1. Enter system view.
2. Create a service instance group and enter its view.
service-instance-group service-instance-group-name
3. Associate a failover group with the service instance group.
failover-group failover-group-name
By default, a service instance group is not associated with any failover groups.
Task |
Command |
Display service instance group information. |
display service-instance-group [ service-instance-group-name ] |
