- 01-Fundamentals Configuration Guide
- 01-CLI configuration
- 02-RBAC configuration
- 03-Login management configuration
- 04-FTP and TFTP configuration
- 05-File system management configuration
- 06-Configuration file management configuration
- 07-Software upgrade configuration
- 08-ISSU configuration
- 09-Emergency Shell configuration
- 10-Automatic configuration
- 11-Device management configuration
- 12-Tcl configuration
- 13-Management with BootWare
- 14-Python configuration
- 15-License management
15-License management | 74.48 KB |
License-based feature packages
General restrictions and guidelines
Licenses for different device types
Compressing the license storage
Registering and activating a license·
Displaying and maintaining licenses·
Managing licenses
Overview
License-based features, such as MDC and EVI, require a license to run on your device. To use a license-based feature, you must purchase a license or obtain a free trial license.
This chapter describes how to license a feature, transfer a license between devices, remove a license, and manage the license storage space.
The following are feature packages available to be licensed for the device:
· CAMPUS—Includes the MDC feature.
· DATACENTER—Includes the MDC and EVI features.
To use features in these packages, you must register and install the feature package licenses.
For more information about these features, see EVI Configuration Guide and Virtual Technologies Configuration Guide.
Switches of this series also support the unified wired and wireless access controller feature. You can purchase licenses to increase the number of manageable APs. For information about the unified wired and wireless access controller feature, see H3C Unified Wired and Wireless Access Controller User Manual.
NOTE: To use the unified wired and wireless access controller feature on the device, you must load the WLAN feature package. For information about how to load WLAN feature package, see performing an ISSU by using install commands in "Performing an ISSU." |
License types
The following types of licenses are available depending on validity period:
· Permanent—A permanent license is always valid and never expires.
· Days restricted—A license valid for a limited period in days, for example, 30 days.
Trial licenses are typically days restricted.
Locking methods
(S7503E-M.) The following locking methods are available:
· Device locked—A license can be installed only on the DID-specific device. The license takes effect on any MPU in the device even after an MPU replacement. The device supports this locking method.
· MPU locked—A license can be installed only on the DID-specific MPU. The license takes effect on the MPU even after the MPU is moved to a different device.
(Devices except S7503E-M.) The following locking methods are available:
· MPU locked—A license can be installed only on the DID-specific MPU. The license takes effect on the MPU even after the MPU is moved to a different device. The device supports this locking method.
When you manage licenses, follow the general restrictions and guidelines:
· (S7503E-M.) Make sure no one else is performing license management tasks on the MPU you are working with.
· (Devices except S7503E-M.) Make sure no one else is performing license management tasks on the MPU you are working with.
· Manage licenses on the default MDC, and the licensed features will be licensed to the non-default MDCs automatically. Non-default MDCs do not support the license management. For information about MDCs, see Virtual Technologies Configuration Guide.
· Trial licenses and expired formal licenses cannot be uninstalled. Expired licenses remain in the license storage area unless you compress the license storage area.
· Licenses cannot be installed if the license storage area is not sufficient. Before registering licenses, use the display license feature command to identify the number of available licenses. Do not register licenses more than the available number.
· After a license is activated, it takes 5 minutes for fiber ports that are bound to an IRF port to function correctly.
· If you cannot obtain or re-register the activation file due to problems such as operating system and browser errors of the HTTP client, contact H3C Support.
License file safety
When you manage licenses, follow these restrictions and guidelines for license file safety:
· Save and back up the obtained activation file in case of loss.
· If you use FTP to transfer the activation file, use the Binary mode.
· Do not open and edit the activation file to avoid file corruption.
· Do not modify the name of the activation file to avoid licensing error.
· Do not delete or move files in the flash:/license directory. The license management feature uses this directory for license management. An incorrect file operation can cause problems. For example, if you delete an activation file that is usable or in use, the related feature will not function correctly. If a file is missing or corrupted, use the copy command to copy its backup file to the directory to recover the license. If the state of the recovered license is In use but not all licensed features can function, reboot the device. To verify the license state, use the display license command.
S7503E-M:
To run a license-based feature on a device in standalone mode, install the registered license. The device will copy the activation file to other MPUs on the device during installation.
When you register and install licenses for campus and datacenter feature packages in an IRF fabric, follow these restrictions and guidelines:
· Install one license for the features on each member in the fabric. Make sure the SN and DID used for registering the feature license matches the current SN and DID of the specified member device.
· Make sure the licenses installed on the members are the same.
· A registered license takes effect on the member device where it is installed, and it is effective even after the member device joins another IRF fabric.
When you register and install licenses for the WLAN feature package, follow these restrictions and guidelines:
· To increase the number of manageable APs, install licenses on any member devices in the IRF fabric. Make sure the SN and DID used for registering the feature license matches the current SN and DID of the specified member device.
· While an activation file is being installed on one member device, the device will copy the activation file to other member devices in the IRF fabric. When the member device where the license is installed joins another IRF fabric, the following situations occur:
? The license is still effective on the member device, and it will be synchronized to other member devices in the IRF fabric.
? The synchronized licenses on other member devices in the original IRF fabric will expire in 30 days.
Devices except S7503E-M:
When you register and install licenses for campus and datacenter feature packages, follow these restrictions and guidelines:
· Install one license for the features on each MPU on a device. Make sure the SN and DID used for registering the feature license matches the current SN and DID of the specified MPU.
· Make sure the licenses installed on the MPUs are the same.
· A registered license takes effect on the MPU where it is installed, and it is effective even after the MPU is placed on another device.
· To increase the number of manageable APs, install licenses on any MPUs in the IRF fabric. Make sure the SN and DID used for registering the feature license matches the current SN and DID of the specified MPU.
· While an activation file is being installed on one MPU, the MPU will copy the activation file to other MPUs on the device. When the MPU where the license is installed is placed on another device, the following situations occur:
? The license is still effective on the MPU, and it will be synchronized to other MPUs in the device.
? The synchronized licenses on other MPUs in the original device will expire in 30 days.
CAUTION: · Compressing the license storage deletes expired licenses, uninstalled licenses, and Uninstall files. Back up the Uninstall files before you compress the license storage. · The DID changes each time the license storage is compressed. Before performing a compression, make sure all activation files generated based on the old DID have been installed. They cannot be installed after the compression. |
When the value for the Total field equals that of the Usage field from the output of the display license feature command, the license storage area is full. To ensure sufficient storage space for installing new licenses, compress the license storage area.
(S7503E-M.) To compress the license storage:
Step |
Command |
1. Enter system view. |
system-view |
2. Compress the license storage. |
In standalone mode: In IRF mode: |
(Devices except S7503E-M.) To compress the license storage:
Step |
Command |
system-view |
Make sure you have purchased a license for the first registration or an upgrade license for add-on nodes, add-on features, or time extensions.
(S7503E-M.) To register and activate a license:
Step |
Command |
1. Identify the number of available license storage entries. |
display license feature |
2. (Optional.) Compress the license storage if the free license storage is not sufficient for licenses to be activated. |
3. Obtain the SN and DID of the device. |
display license device-id |
4. Identity the license key on your license. |
N/A |
5. Access http://www.h3c.com.hk/Technical_Support___Documents/Product_Licensing/, and select Register the First Time or Register Upgrade Licenses from the navigation tree. |
N/A |
6. Select the product category and use the license key, SN, and DID to register the license. |
N/A |
7. Download the activation file to the device. |
N/A |
8. Enter system view. |
system-view |
9. Install the activation file. |
(Devices except S7503E-M.) To register and activate a license:
Step |
Command |
3. Obtain the SN and DID of the MPU. |
N/A |
N/A |
N/A |
7. Download the activation file to the flash memory of the MPU. |
N/A |
system-view |
Transferring a license
You can transfer a license from one MPU to another if its activation file has not expired. If the activation file has expired, the license is not transferrable. Trial licenses are not transferrable either.
(S7503E-M.) To transfer a license:
Step |
Command |
Remarks |
1. Enter system view on the source device. |
system-view |
N/A |
2. Uninstall the activation file. |
When an activation file is uninstalled, the system creates an Uninstall file that contains an Uninstall key. This Uninstall key is required when you register the license for the target device. The uninstallation action does not delete license data from the license storage area. To free storage space, you must compress the license storage (see "Compressing the license storage"). |
3. Obtain the Uninstall key of the source device. |
display license |
N/A |
4. Access the target device and display SN and DID information. |
N/A |
5. Access http://www.h3c.com.hk/Technical_Support___Documents/Product_Licensing/, and use the target device's SN and DID information and the source device's Uninstall key to generate a new activation file. |
N/A |
N/A |
6. Download the new activation file to the target device. |
N/A |
N/A |
7. Install the activation file on the target device. |
N/A |
(Devices except S7503E-M.) To transfer a license:
Step |
Command |
Remarks |
1. Enter system view on the source MPU. |
system-view |
N/A |
When an activation file is uninstalled, the system creates an Uninstall file that contains an Uninstall key. This Uninstall key is required when you register the license for the target MPU. The uninstallation action does not delete license data from the license storage area. To free storage space, you must compress the license storage (see "Compressing the license storage"). |
3. Obtain the Uninstall key of the source MPU. |
display license |
N/A |
4. Access the target MPU and display SN and DID information. |
N/A |
5. Access http://www.h3c.com.hk/Technical_Support___Documents/Product_Licensing/, and use the target MPU's SN and DID information and the source MPU's Uninstall key to generate a new activation file. |
N/A |
N/A |
6. Download the new activation file to the target MPU. |
N/A |
N/A |
7. Install the activation file on the target MPU. |
N/A |
(S7503E-M.) Execute display commands in any view.
Task |
Command |
(In standalone mode.) Display the SN and DID. |
(In IRF mode.) Display the SN and DID of a member device. |
display license device-id chassis chassis-number |
(In standalone mode.) Display detailed license information. |
display license [ activation-file ] |
(In IRF mode.) Display detailed license information. |
display license [ activation-file ] [ chassis chassis-number ] |
Display brief feature license information. |
(Devices except S7503E-M.) Execute display commands in any view.
Task |
Command |
(In standalone mode.) Display the SN and DID of an MPU. |
display license device-id slot slot-number |
(In IRF mode.) Display the SN and DID of an MPU. |
display license device-id chassis chassis-number slot slot-number |
display license [ activation-file ] [ slot slot-number ] |
display license [ activation-file ] [ chassis chassis-number slot slot-number ] |
