- 01-Fundamentals Configuration Guide
- 01-CLI configuration
- 02-RBAC configuration
- 03-Login management configuration
- 04-FTP and TFTP configuration
- 05-File system management configuration
- 06-Configuration file management configuration
- 07-Software upgrade configuration
- 08-ISSU configuration
- 09-Emergency Shell configuration
- 10-Automatic configuration
- 11-Device management configuration
- 12-Tcl configuration
- 13-Management with BootWare
- 14-Python configuration
- 15-License management
04-FTP and TFTP configuration | 138.83 KB |
Using the device as an FTP server
Configuring authentication and authorization
Manually releasing FTP connections
Displaying and maintaining the FTP server
FTP server configuration example in standalone mode
FTP server configuration example in IRF mode
Using the device as an FTP client
Establishing an FTP connection
Managing directories on the FTP server
Working with files on the FTP server
Changing to another user account
Maintaining and troubleshooting the FTP connection
Terminating the FTP connection
Displaying command help information
Displaying and maintaining the FTP client
FTP client configuration example in standalone mode
FTP client configuration example in IRF mode
Configuring the device as an IPv4 TFTP client
Configuring the device as an IPv6 TFTP client
Configuring FTP
File Transfer Protocol (FTP) is an application layer protocol for transferring files from one host to another over an IP network. It uses TCP port 20 to transfer data and TCP port 21 to transfer control commands. For more information about FTP, see RFC 959.
FTP is based on the client/server model. The device can act as the FTP server or FTP client. Make sure the FTP server and the FTP client can reach each other before establishing the FTP connection.
Figure 1 FTP application scenario
FTP supports the following transfer modes:
· Binary mode—Used to non-text files, such as .app, .bin, and .btm files.
· ASCII mode—Used to transfer text files, such as .txt, .bat, and .cfg files.
When the device acts as the FTP client, you can set the transfer mode (binary by default). When the device acts as the FTP server, the transfer mode is determined by the FTP client.
FTP can operate in either of the following modes:
· Active mode (PORT)—The FTP server initiates the TCP connection.
· Passive mode (PASV)—The FTP client initiates the TCP connection. This mode is not suitable when the server does not allow the client to use a random unprivileged port greater than 1024.
FTP operation mode varies depending on the FTP client program.
FIPS compliance
FTP is not supported in FIPS mode.
To use the device as an FTP server, you must enable the FTP server and configure authentication and authorization on the device. Other commands are optional.
Configuring basic parameters
Step |
Command |
Remarks |
1. Enter system view. |
system-view |
N/A |
2. Enable the FTP server. |
ftp server enable |
By default, the FTP server is disabled. |
3. (Optional.) Use an ACL to control access to the FTP server. |
ftp server acl { ipv4-acl-number | ipv6 ipv6-acl-number } |
By default, no ACL is used for access control. |
4. (Optional.) Enable logging for FTP login attempts that are denied by the FTP login control ACL. |
ftp server acl-deny-log enable |
By default, logging is disabled for FTP login attempts that are denied by the FTP login control ACL. |
5. (Optional.) Associate an SSL server policy with the FTP server to ensure data security. |
ftp server ssl-server-policy policy-name |
By default, no SSL server policy is associated with the FTP server. |
ftp timeout minutes |
By default, the FTP connection idle-timeout timer is 30 minutes. If no data transfer occurs on an FTP connection within the idle-timeout interval, the FTP server closes the FTP connection to release resources. |
7. (Optional.) Set the DSCP value for outgoing FTP packets. |
For an IPv4 FTP
server: ·
For an IPv6 FTP server: |
By default, the DSCP value is 0. |
8. (Optional.) Set the maximum number of concurrent FTP users. |
aaa session-limit ftp max-sessions |
The default is 32. Changing this setting does not affect users who are currently online. If the new list is less than the number of online FTP users, no additional FTP users can log in until the number drops below the new limit. For more information about this command, see Security Command Reference. |
Perform this task on the FTP server to authenticate FTP clients and set the authorized directories that authenticated clients can access.
The following authentication modes are available:
· Local authentication—The device looks up the client's username and password in the local user account database. If a match is found, authentication succeeds.
· Remote authentication—The device sends the client's username and password to a remote authentication server for authentication. The user account is configured on the remote authentication server rather than the device.
The following authorization modes are available:
· Local authorization—The device assigns authorized directories to FTP clients based on the locally configured authorization attributes.
· Remote authorization—A remote authorization server assigns authorized directories on the device to FTP clients.
For information about configuring authentication and authorization, see Security Configuration Guide.
Execute the following commands in user view.
Task |
Command |
Manually release FTP connections. |
Release the FTP connection
established by using a specific user account: ·
Release the FTP
connection to a specific IP address: |
Task |
Command |
Display FTP server configuration and status information. |
display ftp-server |
Display detailed information about online FTP users. |
display ftp-user |
Network requirements
· Configure the device as an FTP server.
· Create a local user account named abc on the FTP server. Set the password to 123456.
· Use the user account to log in to the FTP server from the FTP client.
· Upload the temp.bin file from the FTP client to the FTP server.
· Download configuration file startup.cfg from the FTP server to the FTP client for backup.
Configuration procedure
1. Configure IP addresses as shown in Figure 2. Make sure the device and PC can reach other. (Details not shown.)
2. Configure the device (FTP server):
# Create a local user named abc. Set the password to 123456.
[Sysname] local-user abc class manage
[Sysname-luser-manage-abc] password simple 123456
# Assign the network-admin user role to the user. Set the working directory to the root directory of the flash memory on the active MPU. (To set the working directory to the root directory of the flash memory on the standby MPU, replace flash:/ with slot1#flash:/.)
[Sysname-luser-manage-abc] authorization-attribute user-role network-admin work-directory flash:/
# Assign the service type FTP to the user.
[Sysname-luser-manage-abc] service-type ftp
[Sysname-luser-manage-abc] quit
# Enable the FTP server.
[Sysname] ftp server enable
[Sysname] quit
# Examine the storage space for space insufficiency and delete unused files for more free space.
<Sysname> dir
Directory of flash:
1 drw- - Jun 29 2011 18:30:38 logfile
2 drw- - Jun 21 2011 14:51:38 diagfile
3 drw- - Jun 21 2011 14:51:38 seclog
4 -rw- 2943 Jul 02 2011 08:03:08 startup.cfg
5 -rw- 63901 Jul 02 2011 08:03:08 startup.mdb
6 -rw- 716 Jun 21 2011 14:58:02 hostkey
7 -rw- 572 Jun 21 2011 14:58:02 serverkey
8 -rw- 6541264 Aug 04 2011 20:40:49 backup.bin
473664 KB total (467080 KB free)
<Sysname> delete /unreserved flash:/backup.bin
3. Perform FTP operations from the PC (FTP client):
# Log in to the FTP server at 1.1.1.1 using username abc and password 123456.
c:\> ftp 1.1.1.1
Connected to 1.1.1.1.
220 FTP service ready.
User(1.1.1.1:(none)):abc
331 Password required for abc.
Password:
230 User logged in.
# Use the ASCII mode to download configuration file startup.cfg from the device to the PC for backup.
ftp> ascii
200 TYPE is now ASCII
ftp> get startup.cfg back-startup.cfg
# Use the binary mode to upload the file temp.bin from the PC to the root directory of the flash memory on the active MPU.
ftp> binary
200 TYPE is now 8-bit binary
ftp> put temp.bin
# Exit FTP.
ftp> bye
· Configure the IRF fabric as an FTP server.
· Download configuration file config.cfg from the FTP server to the FTP client for backup.
1. Configure IP addresses as shown in Figure 3. Make sure the IRF fabric and the PC can reach each other. (Details not shown.)
2. Configure the FTP server:
# Examine the storage space on the member devices. If the free space is insufficient, use the delete/unreserved file-url command to delete unused files. (Details not shown.)
# Assign the network-admin user role to the user. Set the working directory to the root directory of the flash memory on the global active MPU. (To set the working directory to the root directory of the flash memory on one of the global standby MPUs, replace flash:/ with, for example, chassis2#slot1#flash:/.)
[Sysname] quit
3. Perform FTP operations from the FTP client:
c:\> ftp 1.1.1.1
Password:
230 User logged in.
# Use the ASCII mode to download configuration file config.cfg from the server to the client for backup.
ftp> ascii
ftp> get config.cfg back-config.cfg
# Use the binary mode to upload the temp.bin file to the root directory of the flash memory on the global active MPU.
ftp> binary
ftp> put temp.bin
# Exit FTP.
ftp> bye
To access an FTP server, you must establish a connection from the FTP client to the FTP server.
To establish an IPv4 FTP connection:
Step |
Command |
Remarks |
system-view |
N/A |
2. (Optional.) Specify a source IP address for outgoing FTP packets. |
ftp client source { interface interface-type interface-number | ip source-ip-address } |
By default, no source IP address is specified. The device uses the primary IP address of the output interface as the source IP address. |
3. Return to user view. |
quit |
N/A |
4. Log in to the FTP server. |
(Method 1.) Log in to
the FTP server from user view: · (Method 2.) Log in to the FTP server from FTP client view: a.
Enter FTP client view: b.
Log in to the FTP server: |
The source IP address specified in the ftp command takes precedence over the one set by the ftp client source command. |
To establish an IPv6 FTP connection:
Step |
Command |
Remarks |
system-view |
N/A |
2. (Optional.) Specify the source IPv6 address for FTP packets sent by the FTP client. |
ftp client ipv6 source { interface interface-type interface-number | ipv6 source-ipv6-address } |
By default, no source IPv6 address is specified. The source address is automatically selected as defined in RFC 3484. |
quit |
N/A |
(Method 1.) Log in to the FTP
Log in to the FTP
server: |
The source IP address specified in the ftp ipv6 command takes precedence over the one set by the ftp client ipv6 source command. |
Perform the following tasks in FTP client view:
Task |
Command |
Display directory and file information on the FTP server. |
Display the detailed information
of a directory or file on the FTP server: ·
Display the name of a directory
or file on the FTP server: |
Change the working directory on the FTP server. |
cd { directory | .. | / } |
Return to the upper level directory on the FTP server. |
cdup |
Display the working directory that is being accessed. |
pwd |
Create a directory on the FTP server. |
mkdir directory |
Delete a directory from the remote FTP server. |
rmdir directory |
After you log in to the server, you can upload a file to or download a file from the authorized directory by following these steps:
1. Use the dir or ls command to display the directory and location of the file on the FTP server.
2. Delete unused files to get more free storage space.
3. Set the file transfer mode to ASCII for text files or to binary for non-text files.
4. Use the lcd command to change the local working directory of the FTP client. You can upload the file or save the downloaded file in this directory.
5. Upload or download the file.
To work with files on an FTP server, execute the following commands in FTP client view:
Task |
Command |
Remarks |
Display directory or file information on the FTP server. |
N/A |
Delete a file from the FTP server permanently. |
delete remotefile |
N/A |
Set the file transfer mode. |
mode to ASCII: ·
binary: |
The default file transfer mode is binary. |
Change the FTP operation mode. |
passive |
The default mode is passive. |
Display or change the local working directory of the FTP client. |
lcd [ directory | / ] |
N/A |
Upload a file to the FTP server. |
put localfile [ remotefile ] |
N/A |
Download a file from the FTP server. |
get remotefile [ localfile ] |
N/A |
Add the content of a file on the FTP client to a file on the FTP server. |
append localfile [ remotefile ] |
N/A |
Specify the retransmit marker. |
restart marker |
Use this command together with the put, get, or append command. |
Update the local file. |
newer remotefile |
N/A |
Get the missing part of a file. |
reget remotefile [ localfile ] |
N/A |
Rename the file. |
rename [ oldfilename [ newfilename ] ] |
N/A |
After you log in to the FTP server, you can initiate an FTP authentication to change to a new account. By changing to a new account, you can get a different privilege without re-establishing the FTP connection.
For successful account change, you must enter the new username and password correctly. A wrong username or password can cause the FTP connection to be disconnected.
To change to another user account, execute the following command in user view:
Task |
Command |
Initiate an FTP authentication on the current FTP connection. |
user username [ password ] |
Task |
Command |
Remarks |
Display FTP commands on the FTP server. |
rhelp |
N/A |
Display FTP commands help information on the FTP server. |
rhelp protocol-command |
N/A |
Display FTP server status. |
rstatus |
N/A |
Display detailed information about a directory or file on the FTP server. |
rstatus remotefile |
N/A |
Display FTP connection status. |
status |
N/A |
Display the system information of the FTP server. |
system |
N/A |
Enable or disable FTP operation information display. |
verbose |
By default, this function is enabled. |
Enable or disable FTP client debugging. |
debug |
By default, FTP client debugging is disabled. |
Clear the reply information in the buffer. |
reset |
N/A |
Execute one of the following commands in FTP client view:
Task |
Command |
Terminate the connection to the FTP server without exiting FTP client view. |
· disconnect · close |
Terminate the connection to the FTP server and return to user view. |
· bye · quit |
Task |
Command |
Display command help information. |
· help [ command-name ] · ? [ command-name ] |
Execute the display command in any view.
Task |
Command |
Display source IP address information on the FTP client. |
display ftp client source |
As shown in Figure 4, the PC is acting as an FTP server. A user account with the username abc and password 123456 has been created on the PC.
· Use the device as an FTP client to log in to the FTP server.
· Download the temp.bin file from the PC to the device.
· Upload configuration file startup.cfg from the device to the PC for backup.
# Configure IP addresses as shown in Figure 4. Make sure the device and PC can reach each other. (Details not shown.)
# Examine the storage space of the device. If the free space is insufficient, use the delete/unreserved file-url command to delete unused files. (Details not shown.)
# Log in to the FTP server at 10.1.1.1 using username abc and password 123456.
<Sysname> ftp 10.1.1.1
Press CTRL+C to abort.
Connected to 10.1.1.1 (10.1.1.1).
User (10.1.1.1:(none)): abc
Password:
230 Logged in successfully
Remote system type is MSDOS.
ftp>
# Set the file transfer mode to binary.
ftp> binary
# Download the temp.bin file from the PC to the root directory of the flash memory on the active MPU.
ftp> get temp.bin
local: temp.bin remote: temp.bin
150 Connecting to port 47457
226 File successfully transferred
23951480 bytes received in 95.399 seconds (251.0 kbyte/s)
# Download the temp.bin file from the PC to the root directory of the flash memory on the standby MPU (in slot 1).
ftp> get temp.bin slot1#flash:/temp.bin
# Use the ASCII mode to upload configuration file startup.cfg from the device to the PC for backup.
ftp> ascii
ftp> put startup.cfg back-startup.cfg
local: startup.cfg remote: back-startup.cfg
150 Connecting to port 47461
3494 bytes sent in 5.646 seconds (618.00 kbyte/s)
ftp> bye
221-Goodbye. You uploaded 2 and downloaded 2 kbytes.
221 Logout.
<Sysname>
As shown in Figure 5, the PC is acting as an FTP server. A user account with the username abc and password 123456 has been created on the PC.
· Use the IRF fabric as an FTP client to log in to the FTP server.
· Download the temp.bin file from the FTP server to the FTP client.
· Upload configuration file config.cfg from the FTP client to the FTP server for backup.
# Configure IP addresses as shown in Figure 5. Make sure the IRF fabric and PC can reach each other. (Details not shown.)
# Log in to the FTP server using username abc and password 123456.
Password:
ftp>
ftp> binary
# Download the temp.bin file from the PC to the root directory of the flash memory on the global active MPU.
ftp> get temp.bin
# Download the temp.bin file from the PC to the root directory of the flash memory on the global standby MPUs.
ftp> get temp.bin chassis1#slot1#flash:/temp.bin
ftp> get temp.bin chassis2#slot0#flash:/temp.bin
ftp> get temp.bin chassis2#slot1#flash:/temp.bin
# Use the ASCII mode to upload configuration file config.cfg from the IRF fabric to the PC for backup.
ftp> ascii
ftp> put config.cfg back-config.cfg
local: config.cfg remote: back-config.cfg
ftp> bye
221 Logout.
<Sysname>
Configuring TFTP
Trivial File Transfer Protocol (TFTP) is a simplified version of FTP for file transfer over secure reliable networks. TFTP uses UDP port 69 for data transmission. In contrast to TCP-based FTP, TFTP does not require authentication or complex message exchanges, and is easier to deploy. TFTP is suited for reliable network environments.
The device can only act as a TFTP client. You can upload a file from the device to the TFTP server or download a file from the TFTP server to the device. If you download a file with a file name that exists in the target directory, the device deletes the existing file and saves the new one. If file download fails due to network disconnection or other reasons, the original file cannot be restored. Therefore, use a nonexistent file name instead.
Figure 6 TFTP application scenario
FIPS compliance
TFTP is not supported in FIPS mode.
Step |
Command |
Remarks |
system-view |
N/A |
2. (Optional.) Use an ACL to control the client's access to TFTP servers. |
tftp-server acl acl-number |
3. Specify the source IP address for TFTP packets sent by the TFTP client. |
tftp client source { interface interface-type interface-number | ip source-ip-address } |
4. Return to user view. |
quit |
N/A |
5. Download or upload a file in an IPv4 network. |
tftp tftp-server { get | put | sget } source-filename [ destination-filename ] [ vpn-instance vpn-instance-name ] [ dscp dscp-value | source { interface interface-type interface-number | ip source-ip-address } ] * |
The source IP address specified in this command takes precedence over the one set by the tftp client source command. Use this command in user view. |
Step |
Command |
Remarks |
system-view |
N/A |
tftp-server ipv6 acl ipv6-acl-number |
3. Specify the source IPv6 address for TFTP packets sent by the TFTP client. |
tftp client ipv6 source { interface interface-type interface-number | ipv6 source-ipv6-address } |
quit |
N/A |
5. Download or upload a file in an IPv6 network. |
tftp ipv6 tftp-server [ -i interface-type interface-number ] { get | put | sget } source-filename [ destination-filename ] [ vpn-instance vpn-instance-name ] [ dscp dscp-value | source { interface interface-type interface-number | ipv6 source-ipv6-address } ] * |
The source IP address specified in this command takes precedence over the one set by the tftp client ipv6 source command. Use this command in user view. |
