03-Layer 3 Configuration Guide
HomeSupportWirelessWX3000E Series Wireless SwitchesConfigure & DeployConfiguration GuidesH3C WX3000E Series Wireless Switches Switching Engine Configuration Guides(R3507P26)-6W10203-Layer 3 Configuration Guide
02-IP Addressing Configuration
02-IP Addressing Configuration 92.24 KB
This chapter includes these sections:
·          IP addressing overview
·          Configuring IP addresses
·          Displaying and maintaining IP addressing
·      The term "switch" or "device" in this chapter refers to the switching engine on a WX3000E wireless switch.
·      The WX3000E series comprises WX3024E and WX3010E wireless switches.
·      The port numbers in this chapter are for illustration only.
IP address classes
IP addressing uses a 32-bit address to identify each host on a network. To make addresses easier to read, they are written in dotted decimal notation, each address being four octets in length. For example, address 00001000000000010000000100000001 in binary is written as 10.1.1.1.
Each IP address breaks down into two parts:
·          Net ID: Identifies a network. The first several bits of a net ID, known as the class field or class bits, identify the class of the IP address.
·          Host ID: Identifies a host on a network.
IP addresses are divided into five classes, shown in Figure 1. The shaded areas represent the address class. The first three classes are widely used.
Figure 1 IP address classes
Table 1 describes the address ranges of these five classes.
Table 1 IP address classes and ranges
Class
Address range
Remarks
A
0.0.0.0 to 127.255.255.255
The IP address 0.0.0.0 is used by a host at startup for temporary communication. This address is never a valid destination address.
Addresses starting with 127 are reserved for loopback test. Packets destined to these addresses are processed locally as input packets rather than sent to the link.
B
128.0.0.0 to 191.255.255.255
C
192.0.0.0 to 223.255.255.255
D
224.0.0.0 to 239.255.255.255
Multicast addresses.
E
240.0.0.0 to 255.255.255.255
Reserved for future use except for the broadcast address 255.255.255.255.
Special IP addresses
The following IP addresses are for special use, and they cannot be used as host IP addresses.
·          IP address with an all-zero net ID: Identifies a host on the local network. For example, IP address 0.0.0.16 indicates the host with a host ID of 16 on the local network.
·          IP address with an all-zero host ID: Identifies a network.
·          IP address with an all-one host ID: Identifies a directed broadcast address. For example, a packet with the destination address of 192.168.1.255 will be broadcast to all the hosts on the network 192.168.1.0.
Subnetting and masking
Subnetting divides a network down into smaller networks called subnets by using some bits of the host ID to create a subnet ID.
Masking identifies the boundary between the host ID and the combination of net ID and subnet ID.
Each subnet mask comprises 32 bits that correspond to the bits in an IP address. In a subnet mask, consecutive ones represent the net ID and subnet ID, and consecutive zeros represent the host ID.
Before being subnetted, Class A, B, and C networks use these default masks (also called natural masks): 255.0.0.0, 255.255.0.0, and 255.255.255.0 respectively.
Figure 2 shows how a Class B network is subnetted.
Figure 2 Subnet a Class B network
Subnetting increases the number of addresses that cannot be assigned to hosts. Therefore, using subnets means accommodating somewhat fewer hosts
For example, a Class B network without subnetting can accommodate 1022 more hosts than the same network subnetted into 512 subnets.
·          Without subnetting: 65,534 hosts (216 – 2). (The two deducted addresses are the broadcast address, which has an all-one host ID, and the network address, which has an all-zero host ID.)
·          With subnetting: Using the first 9 bits of the host-id for subnetting provides 512 (29) subnets. However, only 7 bits remain available for the host ID. This allows 126 (27 – 2) hosts in each subnet, a total of 64,512 hosts (512 × 126).
An interface must have an IP address to communicate with other hosts. You can either manually assign an IP address to an interface, or configure the interface to obtain an IP address through BOOTP or DHCP. If you change the way an interface obtains an IP address, the new IP address will overwrite the previous one.
This chapter only covers how to assign an IP address manually. For information about how to obtain an IP address through BOOTP or DHCP, see the chapter “DHCP overview.”
Assigning an IP address to an interface
Follow these steps to assign an IP address to an interface:
To do…
Use the command…
Remarks
Enter system view
Enter interface view
Assign an IP address to the interface
ip address ip-address { mask-length | mask }
Required
No IP address is assigned by default.
To do…
Use the command…
Remarks
Display IP configuration information for a specified Layer 3 interface or all Layer 3 interfaces
display ip interface [ interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
Available in any view
Display brief IP configuration information for a specified Layer 3 interface or all Layer 3 interfaces
display ip interface [ interface-type [ interface-number ] ] brief [ | { begin | exclude | include } regular-expression ]
