03-Layer 3 Configuration Guide
HomeSupportWirelessWX3000E Series Wireless SwitchesConfigure & DeployConfiguration GuidesH3C WX3000E Series Wireless Switches Switching Engine Configuration Guides(R3507P26)-6W10203-Layer 3 Configuration Guide
12-RIPng Configuration
12-RIPng Configuration 192.42 KB
This chapter includes these sections:
·          Introduction to RIPng
·          RIPng configuration task list
·          Displaying and maintaining RIPng
·          RIPng configuration examples
·      The term "switch" or "device" in this chapter refers to the switching engine on a WX3000E wireless switch.
·      The WX3000E series comprises WX3024E and WX3010E wireless switches.
·      The port numbers in this chapter are for illustration only.
RIP next generation (RIPng) is an extension of RIP-2 for IPv4. Most RIP concepts are applicable in RIPng.
RIPng for IPv6 has the following basic differences from RIP:
·          UDP port number—RIPng uses UDP port 521 for sending and receiving routing information
·          Multicast address—RIPng uses FF02:9 as the link-local-router multicast address
·          Destination Prefix—128-bit destination address prefix
·          Next hop—128-bit IPv6 address
·          Source address—RIPng uses FE80::/10 as the link-local source address
RIPng working mechanism
RIPng is a routing protocol based on the distance vector (D-V) algorithm. RIPng uses UDP packets to exchange routing information through port 521.
RIPng uses a hop count to measure the distance to a destination. The hop count is the metric or cost. The hop count from a router to a directly connected network is 0. The hop count between two directly connected routers is 1. When the hop count is greater than or equal to 16, the destination network or host is unreachable.
By default, the routing update is sent every 30 seconds. If the router receives no routing updates from a neighbor within 180 seconds, the routes learned from the neighbor are considered unreachable. If no routing update is received within another 240 seconds, the router removes these routes from the routing table.
RIPng supports split horizon and poison reverse to prevent routing loops and route redistribution.
Each RIPng router maintains a routing database, which includes route entries of all reachable destinations. A route entry contains the following information:
·          Destination address—IPv6 address of a host or a network.
·          Next hop address—IPv6 address of a neighbor along the path to the destination
·          Egress interface—Outbound interface that forwards IPv6 packets
·          Metric—Cost from the local router to the destination
·          Route time—Time that elapsed since a route entry is last changed. Each time a route entry is modified, the routing time is set to 0.
RIPng packet format
Basic format
A RIPng packet consists of a header and multiple route table entries (RTEs). The maximum number of RTEs in a packet depends on the IPv6 MTU of the sending interface.
Figure 1 RIPng basic packet format
Packet header description:
·          Command: Type of message. 0x01 indicates Request, 0x02 indicates Response.
·          Version: Version of RIPng. It can only be 0x01 now.
·          RTE: Route table entry, 20 bytes for each entry.
RTE format
The following are types of RTEs in RIPng:
·          Next hop RTE—Defines the IPv6 address of a next hop
·          IPv6 prefix RTE—Describes the destination IPv6 address, route tag, prefix length and metric in the RIPng routing table.
Figure 2 Next hop RTE format
IPv6 next hop address is the IPv6 address of the next hop.
Figure 3 IPv6 prefix RTE format
·          IPv6 prefix—Destination IPv6 address prefix.
·          Route tag—Route tag.
·          Prefix len—Length of the IPv6 address prefix.
·          Metric—Cost of a route.
RIPng packet processing procedure
Request packet
When a RIPng router first starts or needs to update entries in its routing table, usually a multicast request packet is sent to ask for needed routes from neighbors.
The receiving RIPng router processes RTEs in the request. If only one RTE exists with the IPv6 prefix and prefix length both being 0, and with a metric value of 16, the RIPng router will respond with the entire routing table information in response messages. If multiple RTEs exist in the request message, the RIPng router will examine each RTE, update its metric, and send the requested routing information to the requesting router in the response packet.
Response packet
The response packet containing the local routing table information is generated as:
·          A response to a request
·          An update periodically
·          A trigged update caused by route change
After receiving a response, a router checks the validity of the response before adding the route to its routing table, such as whether the source IPv6 address is the link-local address and whether the port number is correct. The response packet that failed the check will be discarded.
Protocols and standards
·          RFC 2080, RIPng for IPv6
·          RFC 2081, RIPng Protocol Applicability Statement
Complete the following tasks to configure RIPng:
Remarks
Configuring RIPng basic functions
Required
Configuring RIPng route control
Configuring an additional routing metric
Optional
Configuring RIPng route summarization
Optional
Advertising a default route
Optional
Configuring a RIPng route filtering policy
Optional
Configuring a priority for RIPng
Optional
Configuring RIPng route redistribution
Optional
Tuning and optimizing the RIPng network
Configuring RIPng timers
Optional
Configuring split horizon and poison reverse
Optional
Configuring zero field check on RIPng packets
Optional
Configuring the maximum number of equal cost routes for load balancing
Optional
This section presents the information to configure the basic RIPng features.
You need to enable RIPng first before configuring other tasks, but it is not necessary for RIPng related interface configurations, such as assigning an IPv6 address.
Configuration prerequisites
Before the configuration, complete the following tasks first:
·          Enable IPv6 packet forwarding.
·          Configure an IP address for each interface, and make sure all nodes are reachable to one another.
Configuration procedure
Follow these steps to configure the basic RIPng functions:
To do…
Use the command…
Remarks
Enter system view
Create a RIPng process and enter RIPng view
ripng [ process-id ]
Required
Not created by default
Return to system view
Enter interface view
Enable RIPng on the interface
ripng process-id enable
Required
Disabled by default
If RIPng is not enabled on an interface, the interface will not send or receive any RIPng route.
This section covers the following topics:
·          Configuring RIPng route summarization
·          Advertising a default route
·          Configuring a RIPng route filtering policy
·          Configuring a priority for RIPng
·          Configuring RIPng route redistribution
Before configuring RIPng, complete the following tasks:
·          Configure an IPv6 address on each interface, and make sure all nodes are reachable to one another.
·          Configure RIPng basic functions
·          Define an IPv6 ACL before using it for route filtering. See the ACL and QoS Configuration Guide for related information.
An additional routing metric can be added to the metric of an inbound or outbound RIP route.
The outbound additional metric is added to the metric of a sent route. The route’s metric in the routing table is not changed.
The inbound additional metric is added to the metric of a received route before the route is added into the routing table, so the route’s metric is changed.
Follow these steps to configure an inbound/outbound additional routing metric:
To do…
Use the command…
Remarks
Enter system view
Specify an inbound routing additional metric
ripng metricin value
Optional
0 by default
Specify an outbound routing additional metric
ripng metricout value
Optional
1 by default
Follow these steps to configure RIPng route summarization:
To do…
Use the command…
Remarks
Enter system view
Advertise a summary IPv6 prefix
ripng summary-address ipv6-address prefix-length
Required
Follow these steps to advertise a default route:
To do…
Use the command…
Remarks
Enter system view
Advertise a default route
ripng default-route { only | originate } [ cost cost ]
Required
Not advertised by default
With this feature enabled, a default route is advertised through the specified interface regardless of whether the default route is available in the local IPv6 routing table.
You can reference a configured IPv6 ACL or prefix list to filter received/advertised routing information. You can also specify a routing protocol to filter outbound routes redistributed from the protocol.
Follow these steps to configure a RIPng route filtering policy:
To do…
Use the command…
Remarks
Enter system view
Enter RIPng view
Configure a filter policy to filter incoming routes
filter-policy { acl6-number | ipv6-prefix ipv6-prefix-name } import
Required
By default, RIPng does not filter incoming routing information.
Configure a filter policy to filter outgoing routes
filter-policy { acl6-number | ipv6-prefix ipv6-prefix-name } export [ protocol [ process-id ] ]
Required
By default, RIPng does not filter outgoing routing information.
Any routing protocol has its own protocol priority used for optimal route selection. You can set a priority for RIPng manually. The smaller the value is, the higher the priority is.
Follow these steps to configure a RIPng priority:
To do…
Use the command…
Remarks
Enter system view
Enter RIPng view
Configure a RIPng priority
preference preference
Optional
By default, the RIPng priority is 100.
Follow these steps to configure RIPng route redistribution:
To do…
Use the command…
Remarks
Enter system view
Enter RIPng view
Configure a default routing metric for redistributed routes
default cost cost
Optional
The default metric of redistributed routes is 0.
Redistribute routes from another routing protocol
import-route protocol [ process-id ] [ cost cost ] *
Required
No route redistribution is configured by default.
This section describes how to tune and optimize the performance of the RIPng network as well as applications under special network environments. Before tuning and optimizing the RIPng network, complete the following tasks:
·          Configure a network layer address for each interface
·          Configure the basic RIPng functions
·          Configuring RIPng timers
·          Configuring split horizon and poison reverse
·          Configuring zero field check on RIPng packets
·          Configuring the maximum number of equal cost routes for load balancing
You can adjust RIPng timers to optimize the performance of the RIPng network.
Follow these steps to configure RIPng timers:
To do…
Use the command…
Remarks
Enter system view
Enter RIPng view
Configure RIPng timers
Optional.
The RIPng timers have the following defaults:
·      30 seconds for the update timer
·      180 seconds for the timeout timer
·      120 seconds for the suppress timer
·      120 seconds for the garbage-collect timer
When adjusting RIPng timers, consider the network performance and perform unified configurations on routers running RIPng to avoid unnecessary network traffic increase or route oscillation.
If both split horizon and poison reverse are configured, only the poison reverse function takes effect.
Enabling split horizon
Split horizon disables RIPng from sending routes through the interface where the routes were learned to prevent routing loops between adjacent routers. Do not disable it unless you make sure that it is necessary.
Follow these steps to enable split horizon:
To do…
Use the command…
Remarks
Enter system view
Enable split horizon
ripng split-horizon
Optional
Enabled by default
Enabling poison reverse
Poison reverse allows RIPng to send routes through the interface where the routes were learned, but the metric of these routes is always set to 16 (unreachable) to avoid routing loops between neighbors.
Follow these steps to configure poison reverse:
To do…
Use the command…
Remarks
Enter system view
Enable poison reverse
ripng poison-reverse
Required
Disabled by default
Some fields in the RIPng packet must be zero, which are called “zero fields”. With zero field check on RIPng packets enabled, if such a field contains a non-zero value, the entire RIPng packet will be discarded. If you are sure that all packets are reliable, disable the zero field check to reduce the CPU processing time.
Follow these steps to configure RIPng zero field check:
To do…
Use the command…
Remarks
Enter system view
Enter RIPng view
Enable the zero field check
checkzero
Optional
Enabled by default
Follow these steps to configure the maximum number of equal cost RIPng routes for load balancing:
To do…
Use the command…
Remarks
Enter system view
Enter RIPng view
Configure the maximum number of equal cost RIPng routes for load balancing
maximum load-balancing number
Optional
6 by default
To do…
Use the command…
Remarks
Display configuration information of a RIPng process
display ripng [ process-id ] [ | { begin | exclude | include } regular-expression ]
Available in any view
Display routes in the RIPng database
display ripng process-id database [ | { begin | exclude | include } regular-expression ]
Display the routing information of a specified RIPng process
display ripng process-id route [ | { begin | exclude | include } regular-expression ]
Display RIPng interface information
display ripng process-id interface [ interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
Reset a RIPng process
reset ripng process-id process
Available in user view
Clear statistics of a RIPng process
reset ripng process-id statistics
Network requirements
As shown in Figure 4, all switches run RIPng. Configure Switch B to filter the route (3::/64) learned from Switch C, which means the route will not be added to the routing table of Switch B, and Switch B will not forward it to Switch A.
Figure 4 Network diagram for RIPng configuration
1.        Configure the IPv6 address for each interface (omitted)
2.        Configure basic RIPng functions
# Configure Switch A.
[SwitchA] ripng 1
[SwitchA-ripng-1] quit
[SwitchA-Vlan-interface100] ripng 1 enable
[SwitchA] interface vlan-interface 400
[SwitchA-Vlan-interface400] ripng 1 enable
[SwitchA-Vlan-interface400] quit
# Configure Switch B.
[SwitchB] ripng 1
[SwitchB-ripng-1] quit
[SwitchB-Vlan-interface200] ripng 1 enable
[SwitchB-Vlan-interface100] ripng 1 enable
# Configure Switch C.
[SwitchC] ripng 1
[SwitchC-ripng-1] quit
[SwitchC-Vlan-interface200] ripng 1 enable
[SwitchC] interface vlan-interface 500
[SwitchC-Vlan-interface500] ripng 1 enable
[SwitchC-Vlan-interface500] quit
[SwitchC] interface vlan-interface 600
[SwitchC-Vlan-interface600] ripng 1 enable
[SwitchC-Vlan-interface600] quit
# Display the routing table of Switch B.
[SwitchB] display ripng 1 route
   Route Flags: A - Aging, S - Suppressed, G - Garbage-collect
 Peer FE80::20F:E2FF:FE23:82F5  on Vlan-interface100
 Dest 1::/64,
     via FE80::20F:E2FF:FE23:82F5, cost  1, tag 0, A, 6 Sec
 Dest 2::/64,
 Peer FE80::20F:E2FF:FE00:100  on Vlan-interface200
 Dest 3::/64,
     via FE80::20F:E2FF:FE00:100, cost  1, tag 0, A, 11 Sec
 Dest 4::/64,
 Dest 5::/64,
# Display the routing table of Switch A.
[SwitchA] display ripng 1 route
 Peer FE80::200:2FF:FE64:8904  on Vlan-interface100
 Dest 1::/64,
     via FE80::200:2FF:FE64:8904, cost  1, tag 0, A, 31 Sec
 Dest 4::/64,
     via FE80::200:2FF:FE64:8904, cost  2, tag 0, A, 31 Sec
 Dest 5::/64,
 Dest 3::/64,
3.        Configure Switch B to filter incoming and outgoing routes.
[SwitchB] acl ipv6 number 2000
[SwitchB-acl6-basic-2000] rule deny source 3::/64
[SwitchB-acl6-basic-2000] rule permit
[SwitchB-acl6-basic-2000] quit
[SwitchB] ripng 1
[SwitchB-ripng-1] filter-policy 2000 import
[SwitchB-ripng-1] filter-policy 2000 export
# Display routing tables of Switch B and Switch A.
 Dest 1::/64,
     via FE80::20F:E2FF:FE23:82F5, cost  1, tag 0, A, 2 Sec
 Dest 2::/64,
 Dest 4::/64,
     via FE80::20F:E2FF:FE00:100, cost  1, tag 0, A, 5 Sec
 Dest 5::/64,
 Peer FE80::20F:E2FF:FE00:1235  on Vlan-interface100
 Dest 1::/64,
     via FE80::20F:E2FF:FE00:1235, cost  1, tag 0, A, 2 Sec
 Dest 4::/64,
     via FE80::20F:E2FF:FE00:1235, cost  2, tag 0, A, 2 Sec
 Dest 5::/64,
·          Two RIPng processes are running on Switch B, which communicates with Switch A through RIPng 100 and with Switch C through RIPng 200.
·          Configure route redistribution on Switch B, letting the two RIPng processes redistribute routes from each other. Set the default cost of redistributed routes from RIPng 200 to 3.
Figure 5 Network diagram for RIPng route redistribution configuration
1.        Configure IPv6 addresses for the interfaces (omitted)
2.        Configure RIPng basic functions
#  Enable RIPng 100 on Switch A.
[SwitchA] ripng 100
[SwitchA-ripng-100] quit
[SwitchA-Vlan-interface100] ripng 100 enable
[SwitchA-Vlan-interface200] ripng 100 enable
# Enable RIP 100 and RIP 200 on Switch B.
[SwitchB] ripng 100
[SwitchB-ripng-100] quit
[SwitchB-Vlan-interface100] ripng 100 enable
[SwitchB] ripng 200
[SwitchB-ripng-200] quit
[SwitchB] interface vlan-interface 300
[SwitchB-Vlan-interface300] ripng 200 enable
[SwitchB-Vlan-interface300] quit
# Enable RIPng 200 on Switch C.
[SwitchC] ripng 200
[SwitchC-Vlan-interface300] ripng 200 enable
[SwitchC-Vlan-interface300] quit
[SwitchC] interface vlan-interface 400
[SwitchC-Vlan-interface400] ripng 200 enable
[SwitchC-Vlan-interface400] quit
[SwitchA] display ipv6 routing-table
Routing Table :
         Destinations : 6        Routes : 6
Destination: ::1/128                                     Protocol  : Direct
NextHop    : ::1                                         Preference: 0
Interface  : InLoop0                                     Cost      : 0
Destination: 1::/64                                      Protocol  : Direct
NextHop    : 1::1                                        Preference: 0
Interface  : Vlan100                                     Cost      : 0
Destination: 1::1/128                                    Protocol  : Direct
Destination: 2::/64                                      Protocol  : Direct
NextHop    : 2::1                                        Preference: 0
Interface  : Vlan200                                     Cost      : 0
Destination: 2::1/128                                    Protocol  : Direct
Destination: FE80::/10                                   Protocol  : Direct
NextHop    : ::                                          Preference: 0
Interface  : NULL0                                       Cost      : 0
3.        Configure RIPng route redistribution
# Configure route redistribution between the two RIPng processes on Switch B.
[SwitchB] ripng 100
[SwitchB-ripng-100] default cost 3
[SwitchB-ripng-100] import-route ripng 200
[SwitchB] ripng 200
[SwitchB-ripng-200] import-route ripng 100
Routing Table :
         Destinations : 7        Routes : 7
Destination: 4::/64                                      Protocol  : RIPng
NextHop    : FE80::200:BFF:FE01:1C02                     Preference: 100
Interface  : Vlan100                                     Cost      : 4
Interface  : NULL0                                       Cost      : 0d
