03-Layer 3 Configuration Guide
HomeSupportWirelessWX3000E Series Wireless SwitchesConfigure & DeployConfiguration GuidesH3C WX3000E Series Wireless Switches Switching Engine Configuration Guides(R3507P26)-6W10203-Layer 3 Configuration Guide
06-UDP Helper Configuration
06-UDP Helper Configuration 74.35 KB
This chapter includes these sections:
·          Introduction to UDP helper
·          Configuring UDP
·          Displaying and maintaining UDP helper
·          UDP helper configuration example
·      The term "switch" or "device" in this chapter refers to the switching engine on a WX3000E wireless switch.
·      The WX3000E series comprises WX3024E and WX3010E wireless switches.
·      The port numbers in this chapter are for illustration only.
·      UDP helper can be configured on VLAN interfaces only.
UDP helper functions as a relay agent that converts UDP broadcast packets into unicast packets and forwards them to a specified destination server. This is helpful when a host cannot obtain network configuration information or request device names through broadcasting because the server or host to be requested is located on another broadcast domain.
With UDP helper enabled, a device decides whether to forward a received UDP broadcast packet according to the UDP destination port number of the packet.
·          If the destination port number of the packet matches the one pre-configured on the device, the device modifies the destination IP address in the IP header, and then sends the packet to the specified destination server.
·          If not, the device sends the packet to the upper layer protocol for processing.
Configuring UDP helper
Follow these steps to configure UDP helper:
To do…
Use the command…
Remarks
Enter system view
Enable UDP helper
udp-helper enable
Required
Disabled by default.
Enable the forwarding of packets with the specified UDP destination port number(s)
Required
No UDP port number is specified by default.
Enter interface view
Specify the destination server to which UDP packets are to be forwarded
udp-helper server ip-address
Required
No destination server is specified by default.
CAUTION
CAUTION:
·      On the devices supporting the directed broadcast suppression function, the receiving of directed broadcasts to a directly connected network is disabled by default. As a result, UDP helper is available only when the ip forward-broadcast command is configured in system view. For more information about reception and forwarding of directed broadcasts to a directly connected network, see the chapter “IP performance optimization configuration.”
·      The UDP helper enabled device must not forward DHCP broadcast packets that use destination port 67 or 68. Therefore, the UDP port numbers set with the udp-helper port command must not include 67 or 68.
·      You can specify a port number or the corresponding parameter for an UDP port to forward packets. For example, udp-helper port 53 and udp-helper port dns specify the same UDP port number.
·      The configuration of all UDP ports is removed if you disable UDP helper.
·      You can configure up to 256 UDP port numbers to enable the forwarding of packets with these UDP port numbers.
·      You can configure up to 20 destination servers on an interface.
To do…
Use the command…
Remarks
Displays the information of forwarded UDP packets
display udp-helper server [ interface interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
Available in any view
Clear statistics about packets forwarded
reset udp-helper packet
Available in user view
Network requirements
As shown in Figure 1, the IP address of VLAN-interface 1 of Switch A is 10.110.1.1/16, and the interface connects to the subnet 10.110.0.0/16.
Configure UDP helper to forward broadcast packets with UDP destination port number 55 and destination IP address 255.255.255.255 or 10.110.255.255 to the destination server 10.2.1.1/16.
Figure 1 Network diagram for UDP helper configuration
Configuration procedure
Make sure that a route from Switch A to the subnet 10.2.0.0/16 is available.
# Enable Switch A to receive directed broadcasts.
[SwitchA] ip forward-broadcast
# Enable UDP helper.
[SwitchA] udp-helper enable
# Enable the forwarding broadcast packets with the UDP destination port 55.
[SwitchA] udp-helper port 55
# Specify the destination server 10.2.1.1 on VLAN-interface 1.
[SwitchA-Vlan-interface1] ip address 10.110.1.1 16
[SwitchA-Vlan-interface1] udp-helper server 10.2.1.1
