| 04-IPv6 Multicast VLAN Commands | 44.47 KB |
IPv6 multicast VLAN configuration commands································ 1
display multicast-vlan ipv6······························································································· 1
multicast-vlan ipv6·········································································································· 2
port (IPv6 multicast VLAN view)························································································ 3
port multicast-vlan ipv6···································································································· 3
Use display multicast-vlan ipv6 to display information about the specified IPv6 multicast VLANs.
display multicast-vlan ipv6 [ vlan-id ] [ | { begin | exclude | include } regular-expression ]
Default command level
1: Monitor level
vlan-id: Specifies an IPv6 multicast VLAN, in the range of 1 to 4094. If this argument is not provided, the information about all IPv6 multicast VLANs will be displayed.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Support for the IPv6 multicast VLAN configuration methods depends on your device model. The command output is different from model to model:
· If your device supports only sub-VLAN-based IPv6 multicast VLAN, this command displays only the sub-VLAN information.
· If your device supports only port-based IPv6 multicast VLAN, this command displays only the port information.
· If your device supports both methods, this command displays both the sub-VLAN information and port information.
# Display information about all IPv6 multicast VLANs.
<Sysname> display multicast-vlan ipv6
Total 3 IPv6 multicast-vlan(s)
IPv6 Multicast vlan 100
port list:
no port
IPv6 Multicast vlan 200
port list:
GE1/0/1 GE1/0/2
IPv6 Multicast vlan 300
port list:
no port
Total 3 IPv6 multicast-vlan(s) |
Total number of IPv6 multicast VLANs. |
port list |
Port list of the IPv6 multicast VLAN. |
multicast-vlan ipv6
Use multicast-vlan ipv6 to configure the specified VLAN as an IPv6 multicast VLAN and enter IPv6 multicast VLAN view.
Use undo multicast-vlan ipv6 to remove the specified VLAN as an IPv6 multicast VLAN.
multicast-vlan ipv6 vlan-id
undo multicast-vlan ipv6 { all | vlan-id }
No VLAN is configured as an IPv6 multicast VLAN.
2: System level
vlan-id: Specifies a VLAN by its ID, in the range of 1 to 4094.
all: Specifies all IPv6 multicast VLANs.
The specified VLAN to be configured as an IPv6 multicast VLAN must exist.
The IPv6 multicast VLAN feature cannot be enabled on a device with IPv6 multicast routing enabled.
For a port-based IPv6 multicast VLAN, you need to enable MLD snooping in both the IPv6 multicast VLAN and all user VLANs.
# Enable MLD snooping in VLAN 100. Configure it as an IPv6 multicast VLAN and enter IPv6 multicast VLAN view.
[Sysname] mld-snooping
[Sysname-mld-snooping] quit
[Sysname] vlan 100
[Sysname-vlan100] mld-snooping enable
[Sysname-vlan100] quit
[Sysname] multicast-vlan ipv6 100
[Sysname-ipv6-mvlan-100]
mld-snooping enable
Use port to assign ports to the current IPv6 multicast VLAN.
Use undo port to delete ports from the current IPv6 multicast VLAN.
port interface-list
undo port { all | interface-list }
An IPv6 multicast VLAN has no member ports.
2: System level
interface-list: Specifies a space-separated list of interface items. Each item specifies an interface or an interface list in the format of start-interface-type interface-number to end-interface-type interface-number. The interface-type interface-number argument specifies an interface by its type and number.
all: Specifies all ports in the current IPv6 multicast VLAN.
A port can belong to only one IPv6 multicast VLAN.
You can assign only Ethernet ports, WLAN-ESS interfaces, and WLAN-MESH interfaces to a multicast VLAN.
# Assign ports WLAN-ESS 2 through WLAN-ESS 3 to IPv6 multicast VLAN 100.
[Sysname-ipv6-mvlan-100] port WLAN-ESS 2 to WLAN-ESS 3
Use port multicast-vlan ipv6 to assign the current port to the specified IPv6 multicast VLAN.
Use undo port multicast-vlan ipv6 to restore the default.
port multicast-vlan ipv6 vlan-id
A port does not belong to any IPv6 multicast VLAN.
Ethernet interface view, WLAN-ESS interface view, Layer 2 aggregate interface view, port group view.
2: System level
Configuration views for this command vary by device models. For more information, see About the H3C Access Controllers Command References.
# Assign WLAN-ESS 1 to IPv6 multicast VLAN 100.
[Sysname] interface WLAN-ESS 1
[Sysname-WLAN-ESS1] port multicast-vlan ipv6 100
