05-IP Multicast Command Reference
HomeSupportReference GuidesCommand ReferencesH3C Access Controllers Command References(E3703P61 R2509P61 R3709P61 R2609P61 R3509P61)-6W10205-IP Multicast Command Reference
01-IGMP Snooping Commands
01-IGMP Snooping Commands 159.34 KB
IGMP snooping configuration commands· 1
display igmp-snooping group· 1
display igmp-snooping host 2
display igmp-snooping statistics· 3
dot1p-priority (IGMP-snooping view) 4
drop-unknown (IGMP-snooping view) 5
fast-leave (IGMP-snooping view) 5
group-policy (IGMP-snooping view) 6
host-aging-time (IGMP-snooping view) 7
host-tracking (IGMP-snooping view) 7
igmp-snooping· 8
igmp-snooping dot1p-priority· 8
igmp-snooping drop-unknown· 9
igmp-snooping enable· 10
igmp-snooping fast-leave· 10
igmp-snooping general-query source-ip· 11
igmp-snooping group-limit 12
igmp-snooping group-policy· 13
igmp-snooping host-aging-time· 14
igmp-snooping host-join· 15
igmp-snooping host-tracking· 16
igmp-snooping last-member-query-interval 16
igmp-snooping leave source-ip· 17
igmp-snooping max-response-time· 18
igmp-snooping overflow-replace· 19
igmp-snooping proxying enable· 19
igmp-snooping pim-hello-proxy enable· 20
igmp-snooping querier 21
igmp-snooping query-interval 21
igmp-snooping report source-ip· 22
igmp-snooping router-aging-time· 23
igmp-snooping router-port-deny· 24
igmp-snooping special-query source-ip· 24
igmp-snooping static-group· 25
igmp-snooping static-router-port 26
igmp-snooping version· 27
last-member-query-interval (IGMP-snooping view) 27
max-response-time (IGMP-snooping view) 28
overflow-replace (IGMP-snooping view) 29
report-aggregation (IGMP-snooping view) 29
reset igmp-snooping group· 30
reset igmp-snooping statistics· 30
router-aging-time (IGMP-snooping view) 31
Use display igmp-snooping group to display IGMP snooping group information, including both dynamic entries and static entries.
display igmp-snooping group [ vlan vlan-id ] [ verbose ] [ | { begin | exclude | include } regular-expression ]
Default command level
1: Monitor level
vlan vlan-id: Specifies a VLAN by its ID, in the range of 1 to 4094. If this option is not specified, this command displays information about IGMP snooping groups on all VLANs.
verbose: Displays detailed IGMP snooping group information.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
# Display detailed IGMP snooping group information in VLAN 2.
<Sysname> display igmp-snooping group vlan 2 verbose
  Total 1 IP Group(s).
  Total 1 IP Source(s).
  Total 1 MAC Group(s).
  Port flags: D-Dynamic port, S-Static port, C-Copy port, P-PIM port
  Subvlan flags: R-Real VLAN, C-Copy VLAN
  Vlan(id):2.
    Router port(s):total 1 port(s).
            GE1/0/1                (D) ( 00:01:30 )
    IP group(s):the following ip group(s) match to one mac group.
      IP group address:224.1.1.1
        (1.1.1.1, 224.1.1.1):
          Attribute:    Host Port
          Host port(s):total 1 port(s).
            GE1/0/2                (D) ( 00:03:23 )
    MAC group(s):
      MAC group address:0100-5e01-0101
            GE1/0/2
Total 1 IP Group(s)
Total number of IP multicast groups.
Total number of multicast sources.
Total number of MAC multicast groups.
Port flags:
·     D—Dynamic port.
·     S—Static port.
·     C—Port copied from a (*, G) entry to an (S, G) entry.
·     P—Port added by PIM snooping.
Sub-VLAN flags:
R—Real egress sub-VLAN under the current entry.
C—Sub-VLAN copied from a (*, G) entry to an (S, G) entry.
Router port(s)
Number of router ports.
( 00:01:30 )
Remaining time of the aging timer for the dynamic member port or router port.
IP group address
Address of IP multicast group.
MAC group address
Address of MAC multicast group.
Attribute
Attribute of IP multicast group.
Host port(s)
Number of member ports.
Use display igmp-snooping host to display information about the hosts tracked by IGMP snooping.
display igmp-snooping host vlan vlan-id group group-address [ source source-address ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
group group-address: Specifies a multicast group . The value range for the group-address argument is 224.0.1.0 to 239.255.255.255.
source source-address: Specifies a multicast source. The value of the source-address argument is a valid unicast address or 0.0.0.0, where 0.0.0.0 specifies all multicast sources.
# Display information about the hosts tracked by IGMP snooping in VLAN 2 that are in multicast group 224.1.1.1.
<Sysname> display igmp-snooping host vlan 2 group 224.1.1.1
VLAN(ID) : 2
  (0.0.0.0, 224.1.1.1)
    Port : GE1/0/1
      Host                                    Uptime          Expires
      1.1.1.1                                 00:02:20        00:00:40
      2.2.2.2                                 00:02:21        00:00:39
    Port : GE1/0/2
      Host                                    Uptime          Expires
      3.3.3.3                                 00:02:20        00:00:40
VLAN(ID)
VLAN ID.
(S, G) entry, where "0.0.0.0" means all multicast sources.
Port
Member port.
Host
Host IP address.
Uptime
Host running duration.
Expires
Host expiration time, where "timeout" means that the host has expired.
Use display igmp-snooping statistics to display statistics for the IGMP messages learned through IGMP snooping.
display igmp-snooping statistics [ | { begin | exclude | include } regular-expression ]
1: Monitor level
# Display statistics for the IGMP messages learned through IGMP snooping.
<Sysname> display igmp-snooping statistics
  Received IGMP general queries:0.
  Received IGMPv1 reports:0.
  Received IGMPv2 reports:19.
  Received IGMP leaves:0.
  Received IGMPv2 specific queries:0.
  Sent     IGMPv2 specific queries:0.
  Received IGMPv3 reports:1.
  Received IGMPv3 reports with right and wrong records:0.
  Received IGMPv3 specific queries:0.
  Received IGMPv3 specific sg queries:0.
  Sent     IGMPv3 specific queries:0.
  Sent     IGMPv3 specific sg queries:0.
  Received error IGMP messages:19.
general queries
Number of IGMP general queries.
specific queries
Number of IGMP group-specific queries.
reports
Number of IGMP reports.
leaves
Number of IGMP leave messages.
Number of IGMP reports with correct and incorrect records.
specific sg query packet(s)
Number of IGMP group-and-source-specific queries.
error IGMP messages
Number of IGMP messages with errors.
Use dot1p-priority to set the 802.1p precedence for IGMP messages globally.
Use undo dot1p-priority to restore the default.
dot1p-priority priority-number
undo dot1p-priority
IGMP-snooping view
2: System level
priority-number: Specifies an 802.1p precedence for IGMP messages, in the range of 0 to 7. A higher number means a higher precedence.
The default 802.1p precedence for IGMP messages is 0.
# Set the 802.1p precedence for IGMP messages to 3 globally.
[Sysname] igmp-snooping
[Sysname-igmp-snooping] dot1p-priority 3
Use drop-unknown to enable dropping unknown multicast data globally.
Use undo drop-unknown to disable dropping unknown multicast data globally.
drop-unknown
undo drop-unknown
This function is disabled and unknown multicast data is flooded.
IGMP-snooping view
2: System level
# Enable the device to drop unknown multicast data globally.
[Sysname-igmp-snooping] drop-unknown
Use fast-leave to enable fast-leave processing globally. With this function enabled, when the AC receives an IGMP leave message on a port, it directly removes that port from the multicast forwarding entry of the specific group.
Use undo fast-leave to disable fast-leave processing globally.
fast-leave [ vlan vlan-list ]
undo fast-leave [ vlan vlan-list ]
Fast-leave processing is disabled.
IGMP-snooping view
2: System level
vlan vlan-list: Specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN by its ID or a range of VLANs in the form of start-vlan-id to end-vlan-id. The value range of a VLAN ID is 1 to 4094. If you do not specify any VLAN, the command takes effect on all VLANs. If you specify more VLANs, the command takes effect on only the specified VLANs.
# Enable fast-leave processing for VLAN 2.
[Sysname-igmp-snooping] fast-leave vlan 2
Use group-policy to configure a global multicast group filter to control the multicast groups that a host in the specified VLAN can join.
Use undo group-policy to remove the configured global multicast group filter.
group-policy acl-number [ vlan vlan-list ]
undo group-policy [ vlan vlan-list ]
No global multicast group filter is configured. Namely, a host in the specified VLAN can join any multicast group.
IGMP-snooping view
2: System level
acl-number: Specifies a basic or advanced ACL number, in the range of 2000 to 3999. A host can join only the multicast groups that match the permit statement in the specified ACL.
If the specified ACL does not exist or the ACL rule is null, all multicast groups are filtered out.
You can configure different ACL rules for a port in different VLANs. For a given VLAN, a newly configured ACL rule overrides the existing one.
# Apply ACL 2000 as a multicast group filter in VLAN 2 so that hosts in this VLAN can join only the multicast group 225.1.1.1.
[Sysname] acl number 2000
[Sysname-acl-basic-2000] rule permit source 225.1.1.1 0
[Sysname-acl-basic-2000] quit
[Sysname-igmp-snooping] group-policy 2000 vlan 2
Use host-aging-time to set the aging timer for the dynamic member ports globally.
Use undo host-aging-time to restore the default.
host-aging-time interval
The aging timer of the dynamic member ports is 260 seconds.
IGMP-snooping view
2: System level
interval: Specifies an aging time in seconds for dynamic member ports, in the range of 200 to 1000.
# Set the aging timer for the dynamic member ports to 300 seconds globally.
[Sysname-igmp-snooping] host-aging-time 300
Use host-tracking to enable the IGMP snooping host tracking function globally.
Use undo host-tracking to disable the IGMP snooping host tracking function globally.
host-tracking
undo host-tracking
This function is disabled.
IGMP-snooping view
2: System level
# Enable the IGMP snooping host tracking function globally.
[Sysname-igmp-snooping] host-tracking
igmp-snooping
Use igmp-snooping to enable IGMP snooping globally and enter IGMP-snooping view.
Use undo igmp-snooping to disable IGMP snooping globally.
igmp-snooping
undo igmp-snooping
IGMP snooping is disabled.
2: System level
# Enable IGMP snooping globally and enter IGMP-snooping view.
Use igmp-snooping dot1p-priority to set the 802.1p precedence for IGMP messages in a VLAN.
Use undo igmp-snooping dot1p-priority to restore the default.
igmp-snooping dot1p-priority priority-number
VLAN view
2: System level
Before you configure this command in a VLAN, enable IGMP snooping in the VLAN.
# On VLAN 2, enable IGMP snooping and set the 802.1p precedence for IGMP messages to 3.
[Sysname-igmp-snooping] quit
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping enable
[Sysname-vlan2] igmp-snooping dot1p-priority 3
Use igmp-snooping drop-unknown to enable dropping unknown multicast data in the VLAN.
Use undo igmp-snooping drop-unknown to disable dropping unknown multicast data in the VLAN.
VLAN view
2: System level
This command takes effect only if IGMP snooping is enabled in the VLAN.
# On VLAN 2, enable IGMP snooping and the function of dropping unknown multicast data.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping drop-unknown
·     drop-unknown
·     igmp-snooping enable
Use igmp-snooping enable to enable IGMP snooping in the current VLAN.
Use undo igmp-snooping enable to disable IGMP snooping in the current VLAN.
IGMP snooping is disabled in a VLAN.
VLAN view
2: System level
IGMP snooping must be enabled globally before it can be enabled in a VLAN.
# Enable IGMP snooping in VLAN 2.
[Sysname] vlan 2
igmp-snooping
Use igmp-snooping fast-leave to enable fast-leave processing on a port. With this function enabled, when the AC receives an IGMP leave message on the port, it directly removes that port from the multicast forwarding entry of the specific group.
Use undo igmp-snooping fast-leave to disable fast-leave processing.
igmp-snooping fast-leave [ vlan vlan-list ]
undo igmp-snooping fast-leave [ vlan vlan-list ]
Layer 2 Ethernet interface view, Layer 2 aggregate interface view, port group view
2: System level
Configuration views for this command vary by device models. For more information, see About the H3C Access Controllers Command References.
If you do not specify any VLAN when using this command in Layer 2 Ethernet interface view or Layer 2 aggregate interface view, the command takes effect on all VLANs to which the interface belongs. If you specify one or more VLANs, the command takes effect on the specified VLANs to which the interface belongs.
If you do not specify any VLAN when using this command in port group view, the command takes effect on all the ports in this group. If you specify one or more VLANs, the command takes effect only on those ports in this group that belong to the specified VLANs.
# Enable fast-leave processing on GigabitEthernet 1/0/1 in VLAN 2.
[Sysname] interface Gigabitethernet 1/0/1
[Sysname-GigabitEthernet1/0/1] igmp-snooping fast-leave vlan 2
fast-leave
Use igmp-snooping general-query source-ip to configure the source address of IGMP general queries.
Use undo igmp-snooping general-query source-ip to restore the default.
igmp-snooping general-query source-ip { ip-address | current-interface }
The source IP address of IGMP general queries is 0.0.0.0.
VLAN view
2: System level
ip-address: Specifies the source address of IGMP general queries, which can be any legal IP address.
current-interface: Sets the source address of IGMP general queries to the address of the current VLAN interface. If the current VLAN interface does not have an IP address, the default IP address 0.0.0.0 is used as the source IP address of IGMP general queries.
# On VLAN 2, enable IGMP snooping and specify 10.1.1.1 as the source IP address of IGMP general queries.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping general-query source-ip 10.1.1.1
Use igmp-snooping group-limit to set the maximum number of multicast groups that a port can join.
Use undo igmp-snooping group-limit to restore the default.
igmp-snooping group-limit limit [ vlan vlan-list ]
undo igmp-snooping group-limit [ vlan vlan-list ]
The default value varies with devices. For more information, see About the H3C Access Controllers Command References.
2: System level
limit: Specifies the maximum number of multicast groups that a port can join. The value range varies with devices. For more information, see About the H3C Access Controllers Command References.
vlan vlan-list: Specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN by its ID or a range of VLANs in the form of start-vlan-id to end-vlan-id. The value range of a VLAN ID is 1 to 4094. If this option is not specified, the command separately takes effect on all VLANs to which the port belongs.
If you do not specify any VLAN when using this command in Layer 2 Ethernet interface view or Layer 2 aggregate interface view, the command takes effect on all VLANs that the interface belongs to. If you specify one or more VLANs, the command takes effect on the specified VLANs that the interface belongs to.
# Configure the device to allow GigabitEthernet 1/0/1 in VLAN 2 to join up to 10 multicast groups.
[Sysname-GigabitEthernet1/0/1] igmp-snooping group-limit 10 vlan 2
igmp group-limit
Use igmp-snooping group-policy to configure a multicast group filter on a port to control the multicast groups that the hosts on the port can join.
Use undo igmp-snooping group-policy to remove a multicast group filter.
igmp-snooping group-policy acl-number [ vlan vlan-list ]
undo igmp-snooping group-policy [ vlan vlan-list ]
No multicast group filter is configured on an interface. A host can join any valid multicast group.
2: System level
acl-number: Specifies a basic or advanced ACL number, in the range of 2000 to 3999. A host can only join the multicast groups that match the permit statement in the specified ACL.
# Apply ACL 2000 as a multicast group filter so that the hosts on GigabitEthernet 1/0/1 in VLAN 2 can join 225.1.1.1 only.
[Sysname-GigabitEthernet1/0/1] igmp-snooping group-policy 2000 vlan 2
group-policy
Use igmp-snooping host-aging-time to set the aging timer for the dynamic member ports in the current VLAN.
Use undo igmp-snooping host-aging-time to restore the default.
igmp-snooping host-aging-time interval
VLAN view
2: System level
interval: Sets an aging time for the dynamic member port in seconds, in the range of 200 to 1000.
# Enable IGMP snooping for VLAN 2 and set the aging timer for the dynamic member ports in the VLAN to 300 seconds.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping host-aging-time 300
·     host-aging-time
Use igmp-snooping host-join to configure a port on the AC as a simulated member host for the specified multicast group or the specified multicast source and group.
Use undo igmp-snooping host-join to remove a simulated member host from the specified multicast group or the specified multicast source and group.
igmp-snooping host-join group-address [ source-ip source-address ] vlan vlan-id
undo igmp-snooping host-join group-address [ source-ip source-address ] vlan vlan-id
2: System level
group-address: Specifies the address of the multicast group that the simulated host will join, in the range of 224.0.1.0 to 239.255.255.255.
source-address: Specifies the address of the multicast source that the simulated host will join. The value of this argument should be a valid unicast address or 0.0.0.0. A source IP address of 0.0.0.0 specifies all multicast sources.
The source-ip source-address option in the command is meaningful only for IGMPv3 snooping. If IGMPv2 snooping is running, the source-ip source-address option does not take effect, although you can include source-ip source-address in the command.
In Layer 2 Ethernet interface view or Layer 2 aggregate interface view, this command takes effect only if the interface belongs to the specified VLAN.
In port group view, this command takes effect only on those ports in this port group that belong to the specified VLAN.
# Configure GigabitEthernet 1/0/1 as a simulated member host in VLAN 2 for the multicast source and group (1.1.1.1, 224.1.1.1).
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping version 3
[Sysname-vlan2] quit
[Sysname-GigabitEthernet1/0/1] igmp-snooping host-join 224.1.1.1 source-ip 1.1.1.1 vlan 2
Use igmp-snooping host-tracking to enable the IGMP snooping host tracking function in a VLAN.
Use undo igmp-snooping host-tracking to disable the IGMP snooping host tracking function in a VLAN.
VLAN view
2: System level
Before you configure this command, enable IGMP snooping in the VLAN.
# Enable IGMP snooping and IGMP snooping host tracking in VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping host-tracking
·     host-tracking
Use igmp-snooping last-member-query-interval to set the IGMP last-member query interval for a VLAN.
Use undo igmp-snooping last-member-query-interval to restore the default.
igmp-snooping last-member-query-interval interval
The default setting is 1 second.
VLAN view
2: System level
interval: Sets the IGMP last-member query interval in seconds, in the range of 1 to 5.
The IGMP last-member query interval determines the interval for sending IGMP group-specific queries and the maximum response delay for IGMP group-specific queries in a VLAN.
# Enable IGMP snooping for VLAN 2 and set the IGMP last-member query interval to 3 seconds.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping last-member-query-interval 3
·     last-member-query-interval
Use igmp-snooping leave source-ip to configure the source IP address of the IGMP leave messages that the IGMP snooping proxy sends.
Use undo igmp-snooping leave source-ip to restore the default.
igmp-snooping leave source-ip { ip-address | current-interface }
The source IP address of the IGMP leave messages that the IGMP snooping proxy sends is 0.0.0.0.
VLAN view
2: System level
ip-address: Specifies a source address for the IGMP leave messages that the IGMP snooping proxy sends, which can be any legal IP address.
current-interface: Specifies the IP address of the current VLAN interface as the source address of IGMP leave messages that the IGMP snooping proxy sends. If no IP address has been assigned to the current VLAN interface, the default IP address 0.0.0.0 is used.
The source IP address configured in the igmp-snooping leave source-ip command also applies when the simulated host sends IGMP leave messages.
# On VLAN 2, enable IGMP snooping and configure the source IP address of IGMP leave messages that the IGMP snooping proxy sends to 10.1.1.1.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping leave source-ip 10.1.1.1
Use igmp-snooping max-response-time to set the maximum response delay for IGMP general queries in the VLAN.
Use undo igmp-snooping max-response-time to restore the default.
igmp-snooping max-response-time interval
The default setting is 10 seconds.
VLAN view
2: System level
interval: Specifies the maximum response delay for IGMP general queries in seconds, in the range of 1 to 25.
# Enable IGMP snooping and set the maximum response delay for IGMP general queries to 5 seconds in VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping max-response-time 5
·     igmp-snooping query-interval
·     max-response-time
Use igmp-snooping overflow-replace to enable the multicast group replacement function.
Use undo igmp-snooping overflow-replace to disable the multicast group replacement function.
igmp-snooping overflow-replace [ vlan vlan-list ]
undo igmp-snooping overflow-replace [ vlan vlan-list ]
The multicast group replacement function is disabled.
2: System level
# Enable the multicast group replacement function on GigabitEthernet 1/0/1 in VLAN 2.
[Sysname-GigabitEthernet1/0/1] igmp-snooping overflow-replace vlan 2
overflow-replace
Use igmp-snooping proxying enable to enable the IGMP snooping proxying function in a VLAN.
Use undo igmp-snooping proxying enable to disable the IGMP snooping proxying function in a VLAN.
IGMP snooping proxying is disabled in all VLANs.
VLAN view
2: System level
# Enable IGMP snooping and then IGMP snooping proxying in VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping proxying enable
Use igmp-snooping pim-hello-proxy enable to enable the PIM hello proxy.
Use undo igmp-snooping pim-hello-proxy enable to disable the PIM hello proxy.
The PIM hello proxy is disabled.
VLAN view
2: System level
# Enable the PIM hello proxy for VLAN 100.
[Sysname] vlan 100
[Sysname-vlan100]igmp-snooping pim-hello-proxy enable
Use igmp-snooping querier to enable the IGMP snooping querier function.
Use undo igmp-snooping querier to disable the IGMP snooping querier function.
The IGMP snooping querier function is disabled.
VLAN view
2: System level
This command does not take effect on a sub-VLAN of a multicast VLAN.
# Enable IGMP snooping and the IGMP snooping querier function for VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping querier
Use igmp-snooping query-interval to configure the interval for sending IGMP general queries.
Use undo igmp-snooping query-interval to restore the default.
igmp-snooping query-interval interval
The IGMP general query interval is 60 seconds.
VLAN view
2: System level
interval: Specifies an interval in seconds for sending IGMP general queries, in the range of 2 to 300.
# Enable IGMP snooping and set the interval for sending IGMP general queries to 20 seconds in VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping query-interval 20
·     igmp-snooping max-response-time
·     igmp-snooping querier
·     max-response-time
Use igmp-snooping report source-ip to configure the source IP address for the IGMP reports that the IGMP snooping proxy sends.
Use undo igmp-snooping report source-ip to restore the default.
igmp-snooping report source-ip { ip-address | current-interface }
The source IP address of the IGMP reports that the IGMP snooping proxy sends is 0.0.0.0.
VLAN view
2: System level
ip-address: Specifies a source address for the IGMP reports that the IGMP snooping proxy sends, which can be any legal IP address.
current-interface: Specifies the IP address of the current VLAN interface as the source address of IGMP reports that the IGMP snooping proxy sends. If no IP address has been assigned to the current VLAN interface, the default IP address 0.0.0.0 is used.
The source IP address configured in the igmp-snooping report source-ip command also applies when the simulated host sends IGMP reports.
# On VLAN 2, enable IGMP snooping and configure the source IP address for IGMP reports that the IGMP snooping proxy sends to 10.1.1.1.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping report source-ip 10.1.1.1
Use igmp-snooping router-aging-time to set the aging timer for the dynamic router ports in the current VLAN.
Use undo igmp-snooping router-aging-time to restore the default.
igmp-snooping router-aging-time interval
The aging timer of the dynamic router ports is 105 seconds.
VLAN view
2: System level
interval: Specifies an aging timer for the dynamic router ports in seconds, in the range of 1 to 1000.
# Enable IGMP snooping and set the aging timer for the dynamic router ports to 100 seconds in VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping router-aging-time 100
·     router-aging-time
Use igmp-snooping router-port-deny to disable a port from becoming a dynamic router port.
Use undo igmp-snooping router-port-deny to restore the default.
igmp-snooping router-port-deny [ vlan vlan-list ]
undo igmp-snooping router-port-deny [ vlan vlan-list ]
A port can become a dynamic router port.
2: System level
# Disable GigabitEthernet 1/0/1 from becoming a dynamic router port in VLAN 2.
[Sysname-GigabitEthernet1/0/1] igmp-snooping router-port-deny vlan 2
Use igmp-snooping special-query source-ip to configure the source IP address for IGMP group-specific queries.
Use undo igmp-snooping special-query source-ip to restore the default.
igmp-snooping special-query source-ip { ip-address | current-interface }
The source IP address of IGMP group-specific queries is 0.0.0.0.
VLAN view
2: System level
ip-address: Specifies a source address for IGMP group-specific queries.
current-interface: Specifies the address of the current VLAN interface as the source address of IGMP group-specific queries. If the current VLAN interface does not have an IP address, the default IP address 0.0.0.0 is used as the source IP address of IGMP group-specific queries.
# On VLAN 2, enable IGMP snooping and specify 10.1.1.1 as the source IP address of IGMP group-specific queries.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping special-query source-ip 10.1.1.1
Use igmp-snooping static-group to configure a port as a static member port of the specified multicast group or the specified multicast source and group.
Use undo igmp-snooping static-group to restore the default.
igmp-snooping static-group group-address [ source-ip source-address ] vlan vlan-id
undo igmp-snooping static-group group-address [ source-ip source-address ] vlan vlan-id
No ports are static member ports.
2: System level
group-address: Specifies the address of the multicast group that the port joins as a static member port, in the range of 224.0.1.0 to 239.255.255.255.
source-address: Specifies the address of the multicast source that the port joins as a static member port. The value of this argument should be a valid unicast address or 0.0.0.0. A source IP address of 0.0.0.0 specifies all multicast sources.
The source-ip source-address option in the command is meaningful only for IGMPv3 snooping. If IGMPv2 snooping is running, the source-ip source-address option does not take effect although you can include source-ip source-address in the command.
# Configure GigabitEthernet 1/0/1 in VLAN 2 to be a static member port for the multicast source and group (1.1.1.1, 224.1.1.1).
[Sysname] vlan 2
[Sysname-GigabitEthernet1/0/1] igmp-snooping static-group 224.1.1.1 source-ip 1.1.1.1 vlan 2
Use igmp-snooping static-router-port to configure a port as a static router port.
Use undo igmp-snooping static-router-port to restore the default.
igmp-snooping static-router-port vlan vlan-id
undo igmp-snooping static-router-port vlan vlan-id
No ports are static router ports.
2: System level
Configuration views for this command varies with devices. For more information, see About the H3C Access Controllers Command References.
# Configure GigabitEthernet 1/0/1 in VLAN 2 as a static router port.
[Sysname-GigabitEthernet1/0/1] igmp-snooping static-router-port vlan 2
Use igmp-snooping version to specify the IGMP snooping version.
Use undo igmp-snooping version to restore the default.
igmp-snooping version version-number
The IGMP snooping version is IGMPv2 snooping.
VLAN view
2: System level
version-number: Specifies an IGMP snooping version, in the range of 2 to 3.
This command can take effect only if IGMP snooping is enabled in the VLAN.
# Enable IGMP snooping and specify the IGMP snooping version to IGMPv3 snooping in VLAN 2.
[Sysname] vlan 2
Use last-member-query-interval to configure the IGMP last-member query interval globally.
Use undo last-member-query-interval to restore the default.
IGMP-snooping view
2: System level
The IGMP last-member query interval determines the interval for sending IGMP group-specific queries and the maximum response delay for IGMP group-specific queries.
# Set the IGMP last-member query interval to 3 seconds globally.
[Sysname-igmp-snooping] last-member-query-interval 3
Use max-response-time to set the global maximum response delay for IGMP general queries.
Use undo max-response-time to restore the default.
IGMP-snooping view
2: System level
interval: Sets the maximum response delay in seconds for IGMP general queries, in the range of 1 to 25.
# Set the global maximum response delay for IGMP general queries to 5 seconds.
[Sysname-igmp-snooping] max-response-time 5
Use overflow-replace to enable the multicast group replacement function globally.
Use undo overflow-replace to disable the multicast group replacement function globally.
undo overflow-replace [ vlan vlan-list ]
IGMP-snooping view
2: System level
# Enable the multicast group replacement function globally in VLAN 2.
[Sysname-igmp-snooping] overflow-replace vlan 2
Use report-aggregation to enable IGMP report suppression.
Use undo report-aggregation to disable IGMP report suppression.
report-aggregation
IGMP report suppression is enabled.
IGMP-snooping view
2: System level
# Disable IGMP report suppression.
[Sysname-igmp-snooping] undo report-aggregation
Use reset igmp-snooping group to remove the dynamic group entries for the specified IGMP snooping groups.
reset igmp-snooping group { group-address | all } [ vlan vlan-id ]
2: System level
group-address: Specifies an IGMP snooping group. The value range for this argument is 224.0.1.0 to 239.255.255.255.
all: Specifies all IGMP snooping groups.
vlan vlan-id: Specifies a VLAN ID, in the range of 1 to 4094.
This command cannot remove the static group entries for IGMP snooping groups.
# Remove the dynamic group entries for all IGMP snooping groups.
<Sysname> reset igmp-snooping group all
Use reset igmp-snooping statistics to clear statistics for the IGMP messages learned through IGMP snooping.
2: System level
# Clear the statistics for all IGMP messages learned through IGMP snooping.
<Sysname> reset igmp-snooping statistics
Use router-aging-time to set the aging timer for the dynamic router ports globally.
Use undo router-aging-time to restore the default.
The aging timer of dynamic router ports is 105 seconds.
IGMP-snooping view
2: System level
interval: Specifies an aging timer in seconds for the dynamic router ports, in the range of 1 to 1000.
# Set the aging timer for the dynamic router ports to 100 seconds globally.
[Sysname-igmp-snooping] router-aging-time 100
